Part Number: J784S4XEVM
Other Parts Discussed in Thread: TDA4VM
The j721e/TDA4VM has SOC watchdog enabled. How to enable the same on J784s4?
Watchdog enabling needs 3 main modules:
#2 & #3 are enabled in U-Boot.
#1 is enabled in Linux.
This is the wiring to route the Main domain ESM events(including watchdog) to PMIC.
So j784s4 has 3 instances of ESM. Main, MCU & WKUP domain ESM
respevtively. For the main domain ESM event to propagate to
PMIC the event needs to be routed via MCU ESM & then MCU ESM
needs to route the event to WKUP ESM & finally to PMIC.
MAIN ESM --> MCU ESM --> WKUP ESM --> PMIC.
Below is the patch set on top of 8.6 SDK U-Boot directory:
Steps to compile U-Boot with ESM support & install to SD card:
cd $PSDK_Linux/board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344 tar xvf j784s4-u-boot-esm.tar git am j784s4-u-boot-esm/* cd ../.. make u-boot cp board-support/k3-image-gen-2022.01/tiboot3.bin board-support/u-boot_build/a72/tispl.bin board-support/u-boot_build/a72/u-boot.img /media/$USER/boot
The Linux RTI watchdog DTS nodes addition patch here:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_arm64_2D00_dts_2D00_ti_2D00_k3_2D00_j784s4_2D00_main_2D00_Enable_2D00_the_2D00_Main_2D00_domain_2D00_R.patch
Download the above patch to Linux folder of the SDK.
cd $PSDK_Linux/board-support/linux-5.10.162+gitAUTOINC+76b3e88d56-g76b3e88d56 git am 0001-arm64-dts-ti-k3-j784s4-main-Enable-the-Main-domain-R.patch cd ../.. make linux-dtbs sudo make linux-dtbs_install
With that the watchdog reset is functional.
Keerthy
