Part Number: TDA4VH
How to enable save-env feature in SDCARD , eMMC and OSPI FLASH ?
Below are the steps to enable saveenv on different boot medias.
SAVE ENABLE ON SD CARD FAT PARTITION:
In order to save the env to SD card , the below changes must be added to the corresponding A72/A53 defconfig file of the corresponding board specific file of U-BOOT.
SAVE ENABLE ON EMMC UDA FAT PARTITION:
In order to save the env to EMMC UDA FAT partition, the below changes must be added to the corresponding A72/A53 defconfig file of the corresponding board specific file of U-BOOT.
SAVE ENV ENABLE ON EMMC BOOT 0 PARTITION:
1) In order to save the env to EMMC , the below changes must be added to the corresponding A72/A53 defconfig file of the corresponding board specific file of U-BOOT.
2)Once the above changes are made,rebuild Uboot.
3)Now to save the environment variables,enter into Uboot:
=>setenv ...
=>setenv ...
=>saveenv
4)Reboot
Note : The value assigned to CONFIG_ENV_OFFSET variable may vary from board to board.Hence,it is advised to look into the SDK documentation of the respective board for cross-verifying the offset values.
WORKAROUND FOR SAVEENV IN OSPI FLASH:
