[FAQ] J721S2XSOMXEVM: How to generate keyring data blob?
Part Number: J721S2XSOMXEVM
As per TISCI documentation, it supports keyring functionality which help import additional keys which can be further used to authenticate images. Generating keyring blob involves a lot of complex steps, do we have any reference tool to generate keyring blob?
  • KEY RING TOOL
    OVERVIEW
    The Key Ring Tool helps generate secure key ring blobs. It creates a structured keyring with both asymmetric and symmetric keys that can be used for firmware authentication.
    PREREQUISITES
    - Python 3
    - OpenSSL command-line tools
    - xxd utility (for binary to header conversion)
    INSTALLATION
    1. Extract the key_ring.zip file to your preferred directory
    2. Ensure you have Python 3 installed on your system
    USAGE
    Run the main script:
    python3 main.py
    Follow the interactive prompts:
    - Specify the number of key blocks (1-6)
    - For each key block:
    - Choose key type (1 for symmetric, 0 for asymmetric)
    - Assign a unique key ID (1-6)
    - Configure if the key is used for firmware authentication (0/1)
    - Configure if the key is used for debug authentication (0/1)
    - Set additional parameters as prompted
    The script will:
    - Generate a JSON configuration file
    - Create necessary key pairs using OpenSSL
    - Convert the JSON configuration to a binary format
    - Generate an X.509 certificate using the x509CertificateGen.sh script
    - Create the final keyring_blob.bin and keyring_blob.h files
    All output files will be placed in the build/ directory
    OUTPUT FILES
    The tool generates the following files in the build/ directory:
    - keyring_data.bin: Binary representation of the key ring data
    - keyring_blob.bin: Final key ring blob with X.509 certificate
    - keyring_blob.h: C header file containing the key ring data
    - private_key_*.pem: Private keys (keep these secure!)
    - public_key_*.pem: Public keys
    INTEGRATION WITH SBL
    To test the generated key ring with SBL (Secondary Boot Loader):
    1. Apply the provided patch:
    patch -p1 < 0001-ADD-test-case-for-keyring.patch
    2. Include the generated keyring_blob.h in your SBL project
    HOW IT WORKS
    The tool uses a multi-step process:
    1. gen_json.py creates a JSON configuration based on user input
    2. Key pairs are generated using OpenSSL
    3. json_to_c.py converts the JSON to C-compatible structures
    4. x509CertificateGen.sh creates an X.509 certificate for the key ring
    5. The final blob is formatted and output as both binary and C header files
    IMPORTANT NOTES
    - This is a reference tool and not intended for production use
    - Generated keys should be properly secured
    - For production systems, proper key management procedures should be implemented
    TOOL:key_ring.zip
    SBL Reference Patch:https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_ADD_2D00_test_2D00_case_2D00_for_2D00_keyring.patch
    Output Logs:
    SBL Revision: 01.00.10.01 (Aug 28 2025 - 14:39:26)
    TIFS  ver: 10.1.6--v10.01.06 (Fiery Fox)
    Sciclient_importkey... PASSED
    SIGN FIRMWARE WITH KEYRING IMPORTED KEYS
    1. Apply the changes to x509CertificateGen.sh to add support for keyring extension. Refer below patch for the same.
    File: https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0002_2D00_Add_2D00_keyring_2D00_node_2D00_information_2D00_to_2D00_X.509_2D00_certificate.patch
    2. Build unsigned application.
    3. Sign the app image with keyid you want to authenticate the image with. Also, make sure you are using the corresponding private key to sign the application.
    Example:
    ```bash
    ./x509CertificateGen.sh -b input.bin -o output.bin -c R5 -l 0x41C00100 -k private_key -A 1 [other options]
    Where:
    • -A 1: Specifies to use key ID 1 from the keyring for authentication
    • -E <id>: Can be used to specify an encryption key ID (not yet supported)
  • The GUI TOOL build on top of python script attached in the above response can be used.
    Tool:
     KeyringGenerator-v4.0-linux-x86_64.tar.gz
    Steps:
    1. untar the file
    2. Run ./KeyringGenerator
    Read INSTALL.txt for more details included in the tar. For more details on the tool, click on "Help" tab after launching the tool.
    Note - This is a reference tool and not intended for production use
