Part Number: TDA4VM
By default, the SBL does not support HSM boot when using eMMC UDA (User Data Area) partition on High Security (HS) devices.
The HSM boot support was only available for MMCSD, OSPI NOR, OSPI NAND, and UART boot modes.
Part Number: TDA4VM
This document describes two patches that enable High Security (HS) boot functionality when using the eMMC UDA partition on J721S2, J784S4, and J742S2 devices.
### 1. 0001-Add-sbl_emmc_uda_img_hs-build-support.patch
This patch adds build support for the HS variant of the eMMC UDA SBL.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_Add_2D00_sbl_5F00_emmc_5F00_uda_5F00_img_5F00_hs_2D00_build_2D00_support.patch
### 2. 0002-Add-HSM-binary-loading-support-for-eMMC-UDA.patch
This patch implements HSM binary loading support for eMMC UDA boot mode.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0002_2D00_Add_2D00_HSM_2D00_binary_2D00_loading_2D00_support_2D00_for_2D00_eMMC_2D00_UDA.patch
## Prerequisites
- TI Processor SDK RTOS for J721S2/J784S4/J742S2
- HS device or HS-FS device with appropriate signing keys
- eMMC with UDA partition formatted as FAT file system
- Valid HS signing certificate key configured as `SBL_CERT_KEY_HS`
## How to Apply the Patches
## Building the HS eMMC UDA SBL
Copy generated sbl_emmc_uda_img_mcu1_0_release.tiimage as tiboot3.bin in your boot partition of emmc UDA. Copy tifs.bin(HS binary), hsm.bin. Change the boot mode to emmc UDA and boot.
Dummy HSM binary can be found at:
<RTOS_SDK>/<pdk>packages/ti/boot/sbl/tools/hsm.bin
