[FAQ] J721S2XSOMXEVM: EMMC Boot Partition Switching in keywriter application
Part Number: J721S2XSOMXEVM
eMMC has two boot partition 0 and 1 . Boot ROM selects the active partion based on PARTCONFIG register (EXCSD[179]) . How to switch between these in keywriter application?
  • Step 1: Apply the Patch
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/mmcsd_5F00_kw.patch
    Apply the `mmcsd_kw.patch` to your keywriter source code:
    cd /path/to/pdk/packages/ti/boot/keywriter
    git apply mmcsd_kw.patch
    Or manually apply the changes from the patch file.
    Step 2: Select Target Partition
    Open `main.c` and locate (after applying the patch):
    int32_t status = CSL_EFAIL, retVal, partition = 1;
    Modify the `partition` variable:
    - **For boot0**: Set `partition = 1`
    - **For boot1**: Set `partition = 2``
    Step 3: Rebuild Keywriter Application
    cd <RTOS_SDK>/<PDK>/packages/ti/build
    make keywriter_img_clean  BOARD=<BOARD_NAME>
    make keywriter_img  BOARD=<BOARD_NAME>
    Step 4: Deploy and Run
    1. Flash the rebuilt keywriter binary to your target device
    2. Run keywriter application
    3. Monitor UART output for partition switching confirmation.
