[J6E] RGB888(vout3) can not output video to VGA port
Hi ,
There is a error about  that "omap_crtc_flush() timeout " will always come out when I type modetest.
And it begin at omapdrm module initial stage......
[ 5.198501] omapdrm omapdrm.0: lcd3: timeout waiting for enable
[ 5.398506] omapdrm omapdrm.0: omap_crtc_flush() timeo
Currently we use J6E custom board + 7.04.00.03 ,  we create 2 video out interface ,  one is hdmi and the other is RGB888.
We can  ignore hdmi interface here and focus RGB888 interface ( using vout3 interface ) ,  lcd3 error message  should mean the RGB888 .....
Maybe  this error lead to the RGB888 can not ouput video...
I attach my boot log and partial dts here.
Andy
modetest
[   35.148516] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   35.348511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   35.548512] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   35.748511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   35.948560] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   36.148513] omapdrm omapdrm.0: omap_crtc_flush() timeout
trying to load module i915...failed.
[   36.348512] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   36.548510] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   36.748511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   36.948557] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   37.148510] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   37.348513] omapdrm omapdrm.0: omap_crtc_flush() timeout
trying to load module radeon...failed.
[   37.548512] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   37.748512] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   37.948558] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   38.148511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   38.348511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   38.548511] omapdrm omapdrm.0: omap_crtc_flush() timeout
trying to load module nouveau...failed.
[   38.748511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   38.948558] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   39.148511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   39.348511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   39.548510] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   39.748511] omapdrm omapdrm.0: omap_crtc_flush() timeout
trying to load module vmwgfx...failed.
[   39.948559] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   40.148511] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   40.348510] omapdrm omapdrm.0: omap_crtc_flush() timeout
[   40.548510] omapdrm omapdrm.0: omap_crtc_flush() timeout
trying to load module omapdrm...success.[   40.556736] omapdss error: HDMI I2C Master Error
Encoders:
id	crtc	type	possible crtcs	possible clones
3	10	TMDS	0x00000001	0x00000000
15	18	TMDS	0x00000002	0x00000000
Connectors:
id	encoder	status		type	size (mm)	modes	encoders
4	3	connected	unknown	0x0		1	3
  modes:
	name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
  1920x1200 58 1920 2130 2160 2176 1200 1222 1235 1245 flags: nhsync, nvsync; type: preferred, driver
  props:
	1 EDID:
		flags: immutable blob
		blobs:
		value:	2 DPMS:
		flags: enum
		enums: On=0 Standby=1 Suspend=2 Off=3
		value: 0
16	15	connected	HDMI-A	0x0		5	15
  modes:
  1024x768 60 1024 1048 1184 1344 768 771 777 806 flags: nhsync, nvsync; type: driver
  800x600 60 800 840 968 1056 600 601 605 628 flags: phsync, pvsync; type: driver
  800x600 56 800 824 896 1024 600 601 603 625 flags: phsync, pvsync; type: driver
  848x480 60 848 864 976 1088 480 486 494 517 flags: phsync, pvsync; type: driver
  640x480 60 640 656 752 800 480 489 492 525 flags: nhsync, nvsync; type: driver
  props:
	1 EDID:
		blobs:
		value:	2 DPMS:
		flags: enum
		value: 0
CRTCs:
id	fb	pos	size
10	29	(0,0)	(1920x1200)
  props:
	11 trans-key-mode:
		flags: enum
		enums: disable=0 gfx-dst=1 vid-src=2
		value: 0
	12 trans-key:
		flags: range
		values: 0 16777215
		value: 0
	13 background:
		flags: range
		values: 0 16777215
		value: 0
	14 alpha_blender:
		flags: enum
		enums: disable=0 enable=1
		value: 0
	6 rotation:
		flags: bitmask
		values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
		value: 0
	7 zorder:
		flags: range
		values: 0 3
		value: 0
	8 global_alpha:
		flags: range
		values: 0 255
		value: 0
	9 pre_mult_alpha:
		flags: enum
		value: 0
18	29	(0,0)	(1024x768)
  props:
	11 trans-key-mode:
		flags: enum
		value: 0
	12 trans-key:
		flags: range
		values: 0 16777215
		value: 0
	13 background:
		flags: rang[   40.758511] omapdrm omapdrm.0: omap_crtc_flush() timeout
e
		values: 0 16777215
		value: 0
	14 alpha_blender:
		flags: enum
		value: 0
	6 rotation:
		flags: bitmask
		value: 0
	7 zorder:
		flags: range
		values: 0 3
		value: 0
	8 global_alpha:
		flags: range
		values: 0 255
		value: 0
	9 pre_mult_alpha:
		flags: enum
		value: 0
Planes:
id	crtc	fb	CRTC x,y	x,y	gamma size
19	0	0	0,0		0,0	0
  formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
  props:
	6 rotation:
		flags: bitmask
		value: 0
	7 zorder:
		flags: range
		values: 0 3
		value: 0
	8 global_alpha:
		flags: range
		values: 0 255
		value: 0
	9 pre_mult_alpha:
		flags: enum
		value: 0
20	0	0	0,0		0,0	0
  props:
	6 rotation:
		flags: bitmask
		value: 0
	7 zorder:
		flags: range
		values: 0 3
		value: 0
	8 global_alpha:
		flags: range
		values: 0 255
		value: 0
	9 pre_mult_alpha:
		flags: enum
		value: 0
Frame buffers:
id	size	pitch
[   40.968513] omapdrm omapdrm.0: omap_crtc_flush() timeout
root@dra7xx-evm:~#
dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.14.63 (andy@andy-Veriton-M490) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #20 SMP PREEMPT Sat Aug 20 17:08:05 CST 2016
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA722
[    0.000000] Reserved memory: created CMA memory pool at 0x95800000, size 56 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 64 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x9d000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: CMA: reserved 64 MiB at ab800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 260608
[    0.000000] free_area_init_node: node 0, pgdat c0a32f00, node_mem_map eaf8e000
[    0.000000]   Normal zone: 1520 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 193536 pages, LIFO batch:31
[    0.000000]   HighMem zone: 528 pages used for memmap
[    0.000000]   HighMem zone: 67072 pages, LIFO batch:15
[    0.000000] dra7xx_init_early:697---
[    0.000000] DRA722 ES1.0
[    0.000000] PERCPU: Embedded 8 pages/cpu @eaf53000 s8640 r8192 d15936 u32768
[    0.000000] pcpu-alloc: s8640 r8192 d15936 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259088
[    0.000000] Kernel command line: console=ttyO2,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait earlyprintk fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=64M rootfstype=ext4 snd.slots_reserved=1,1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 800784K/1042432K available (6691K kernel code, 690K rwdata, 2652K rodata, 376K init, 267K bss, 241648K reserved, 268288K highmem)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc09280d4   (9345 kB)
      .init : 0xc0929000 - 0xc09871c0   ( 377 kB)
      .data : 0xc0988000 - 0xc0a34ba0   ( 691 kB)
       .bss : 0xc0a34bac - 0xc0a7783c   ( 268 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] GIC CPU mask not found - kernel will fail to boot.
[    0.000000] dra7xx_dt_clk_init:322---
[    0.000000] OMAP clockevent source: timer1 at 31475 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65536000000000ns
[    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000396] Architected cp15 timer(s) running at 5.90MHz (virt).
[    0.000432] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 2911033065472ns
[    0.000440] Switching to timer-based delay loop
[    0.001426] Console: colour dummy device 80x30
[    0.001444] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.001451] This ensures that you still see kernel messages. Please
[    0.001457] update your kernel commandline.
[    0.001471] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
[    0.001484] pid_max: default: 32768 minimum: 301
[    0.001577] Security Framework initialized
[    0.001617] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001627] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.024095] CPU: Testing write buffer coherency: ok
[    0.024365] /cpus/cpu@0 missing clock-frequency property
[    0.024379] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.024403] Setting up static identity map for 0x8068e5a8 - 0x8068e618
[    0.060495] Brought up 1 CPUs
[    0.060506] SMP: Total of 1 processors activated (11.80 BogoMIPS).
[    0.060514] CPU: All CPU(s) started in SVC mode.
[    0.060909] devtmpfs: initialized
[    0.061653] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.063340] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.076090] omap_hwmod: tptc0 using broken dt data from edma-controller
[    0.076592] omap_hwmod: tptc1 using broken dt data from edma-controller
[    0.240707] pinctrl core: initialized pinctrl subsystem
[    0.241542] regulator-dummy: no parameters
[    0.245669] NET: Registered protocol family 16
[    0.247558] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.249926] cpuidle: using governor ladder
[    0.249936] cpuidle: using governor menu
[    0.294808] syscon 4a002000.tisysconcore: regmap [mem 0x4a002000-0x4a0026cf] registered
[    0.295164] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e7b] registered
[    0.297909] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[    0.298161] OMAP GPIO hardware version 0.1
[    0.298877] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[    0.299753] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[    0.300711] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[    0.301617] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[    0.302536] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[    0.303444] gpiochip_add: registered GPIOs 192 to 223 on device: gpio
[    0.304391] gpiochip_add: registered GPIOs 224 to 255 on device: gpio
[    0.313419] platform 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[    0.313759] platform 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    0.314081] platform 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    0.338872] No ATAGs?
[    0.338891] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.338901] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.342434] OMAP DMA hardware revision 0.0
[    0.375080] bio: create slab <bio-0> at 0
[    0.393030] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.399745] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.400458] of_get_named_gpiod_flags: can't parse gpios property of node '/fixedregulator-evm_3v3_sd[0]'
[    0.400714] evm_3v3_sd: 3300 mV
[    0.400988] of_get_named_gpiod_flags: can't parse gpios property of node '/fixedregulator-evm_3v3_sw[0]'
[    0.401908] evm_3v3_sw: 3300 mV
[    0.402027] of_get_named_gpiod_flags: can't parse gpios property of node '/fixedregulator-aic_dvdd[0]'
[    0.402257] aic_dvdd: 1800 mV
[    0.402351] aic_dvdd: supplied by evm_3v3_sw
[    0.402484] of_get_named_gpiod_flags: can't parse gpios property of node '/fixedregulator-mmcwl[0]'
[    0.402720] vmmcwl_fixed: 1800 mV
[    0.406775] vgaarb: loaded
[    0.407244] i2c-core: driver [palmas] using legacy suspend method
[    0.407252] i2c-core: driver [palmas] using legacy resume method
[    0.407869] SCSI subsystem initialized
[    0.408347] libata version 3.00 loaded.
[    0.409264] usbcore: registered new interface driver usbfs
[    0.409442] usbcore: registered new interface driver hub
[    0.409648] usbcore: registered new device driver usb
[    0.411705] palmas 0-0058: could not find pctldev for node /ocp/padconf@4844a000/tps65917_pins_default, deferring probe
[    0.411723] i2c 0-0058: Driver palmas requests probe deferral
[    0.411750] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    1.411373] omap_i2c 48072000.i2c: controller timed out
[    1.431387] pcf857x 1-0026: probe error -110 for 'pcf8575'
[    1.431406] pcf857x: probe of 1-0026 failed with error -110
[    1.431820] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[    1.432296] omap_i2c 48060000.i2c: bus 2 rev0.12 at 1 kHz
[    2.431996] omap_i2c 4807a000.i2c: controller timed out
[    2.452011] pcf857x 3-0021: probe error -110 for 'pcf8575'
[    2.452027] pcf857x: probe of 3-0021 failed with error -110
[    2.452056] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 1 kHz
[    2.452487] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 1 kHz
[    2.452838] media: Linux media interface: v0.10
[    2.453001] Linux video capture interface: v2.00
[    2.453257] pps_core: LinuxPPS API ver. 1 registered
[    2.453266] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.453400] PTP clock support registered
[    2.455041] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    2.455121] omap-mailbox: probe of 48842000.mailbox failed with error -22
[    2.456137] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    2.456245] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    2.456355] omap-iommu 58882000.mmu: 58882000.mmu registered
[    2.456456] omap-iommu 55082000.mmu: 55082000.mmu registered
[    2.457113] Advanced Linux Sound Architecture Driver Initialized.
[    2.458573] Switched to clocksource arch_sys_counter
[    2.478080] NET: Registered protocol family 2
[    2.478738] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    2.478806] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    2.478939] TCP: Hash tables configured (established 8192 bind 8192)
[    2.478986] TCP: reno registered
[    2.478999] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    2.479030] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    2.479214] NET: Registered protocol family 1
[    2.479525] RPC: Registered named UNIX socket transport module.
[    2.479535] RPC: Registered udp transport module.
[    2.479542] RPC: Registered tcp transport module.
[    2.479549] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.479559] PCI: CLS 0 bytes, default 64
[    2.480841] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[    2.483749] futex hash table entries: 256 (order: 2, 16384 bytes)
[    2.595383] bounce pool size: 64 pages
[    2.595633] VFS: Disk quotas dquot_6.5.2
[    2.595739] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.596196] NFS: Registering the id_resolver key type
[    2.596259] Key type id_resolver registered
[    2.596268] Key type id_legacy registered
[    2.596306] jffs2: version 2.2. (NAND) (SUMMARY)  \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
[    2.596436] msgmni has been set to 1472
[    2.600834] alg: No test for stdrng (krng)
[    2.601036] NET: Registered protocol family 38
[    2.601066] io scheduler noop registered (default)
[    2.601075] io scheduler deadline registered
[    2.601096] io scheduler cfq registered
[    2.604134] platform 4a084000.phy: Driver omap-usb2 requests probe deferral
[    2.604283] platform 4a085000.phy: Driver omap-usb2 requests probe deferral
[    2.606759] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[    2.607194] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[    2.610224] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/axi@0/pcie@51000000[0]'
[    2.642335] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    2.642349] pci_bus 0000:00: root bus resource [io  0x1000-0x10000]
[    2.642361] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    2.642372] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    2.642409] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[    2.642442] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[    2.642463] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[    2.642520] pci 0000:00:00.0: supports D1
[    2.642530] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.642909] PCI: bus0: Fast back to back transfers disabled
[    2.643166] PCI: bus1: Fast back to back transfers enabled
[    2.643180] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.643194] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[    2.643282] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    2.643297] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    2.643310] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.643331] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.643347] pci_bus 0000:00: resource 4 [io  0x1000-0x10000]
[    2.643357] pci_bus 0000:00: resource 5 [mem 0x20013000-0x2fffffff]
[    2.645791] OMAP DSS rev 6.1
[    2.650038] panel-dpi display@2: GPIO lookup for consumer enable
[    2.650050] panel-dpi display@2: using device tree for GPIO lookup
[    2.650060] of_get_named_gpiod_flags: can't parse gpios property of node '/display@2[0]'
[    2.650069] panel-dpi display@2: using lookup tables for GPIO lookup
[    2.650078] panel-dpi display@2: lookup for GPIO enable failed
[    2.650811] of_get_named_gpiod_flags exited with status 0
[    2.651038] platform encoder@1: Driver dra7evm-tpd12s015 requests probe deferral
[    2.651730] of_get_named_gpiod_flags: can't parse gpios property of node '/connector@1[0]'
[    2.651774] connector-hdmi connector@1: failed to find video source
[    2.651792] platform connector@1: Driver connector-hdmi requests probe deferral
[    2.652774] pbias_mmc_omap5: 1800 <--> 3000 mV at 3000 mV
[    2.653626] abb_mpu: 1100 <--> 1210 mV
[    2.654010] abb_ivahd: 1060 <--> 1250 mV
[    2.654388] abb_dspeve: 1060 <--> 1250 mV
[    2.654763] abb_gpu: 1060 <--> 1280 mV
[    2.655971] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    2.660371] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@4806a000[0]'
[    2.660795] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[    2.661199] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@4806c000[0]'
[    2.661572] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
[    2.662000] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@48020000[0]'
[    2.662362] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
[    3.700861] console [ttyS2] enabled
[    3.704789] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@48066000[0]'
[    3.705171] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250
[    3.714447] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@48068000[0]'
[    3.714812] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250
[    3.724097] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@48424000[0]'
[    3.724470] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250
[    3.733741] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@4ae2b000[0]'
[    3.734111] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250
[    3.744952] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    3.752214] [drm] Initialized drm 1.1.0 20060810
[    3.767753] brd: module loaded
[    3.776516] loop: module loaded
[    3.780393] (hci_tty): inside hci_tty_init
[    3.784894] (hci_tty): allocated 249, 0
[    3.791468] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    3.798220] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    3.807065] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    3.817655] scsi0 : ahci_platform
[    3.821640] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 343
[    3.831047] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.847599] usbcore: registered new interface driver asix
[    3.853255] usbcore: registered new interface driver ax88179_178a
[    3.859924] usbcore: registered new interface driver cdc_ether
[    3.865975] usbcore: registered new interface driver smsc95xx
[    3.871916] usbcore: registered new interface driver net1080
[    3.877774] usbcore: registered new interface driver cdc_subset
[    3.883898] usbcore: registered new interface driver zaurus
[    3.889807] usbcore: registered new interface driver cdc_ncm
[    3.896363] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.902982] ehci-pci: EHCI PCI platform driver
[    3.907583] ehci-omap: OMAP-EHCI Host Controller driver
[    3.913370] usbcore: registered new interface driver cdc_wdm
[    3.919331] usbcore: registered new interface driver usb-storage
[    3.926518] mousedev: PS/2 mouse device common for all mice
[    3.934709] i2c-core: driver [rtc-ds1307] using legacy suspend method
[    3.941310] i2c-core: driver [rtc-ds1307] using legacy resume method
[    3.948379] rtc rtc0: 48838000.rtcss: dev (254:0)
[    3.948405] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as rtc0
[    3.956860] i2c /dev entries driver
[    3.961918] tvp5158 1-0058: Camera sensor driver registered
[    3.968649] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    3.974845] vip 48970000.vip: No explicit pinctrl resources data.
[    3.982056] vip 48970000.vip: loading firmware vpdma-1b8.bin
[    3.988564] of_get_named_gpiod_flags exited with status 0
[    3.988861] DRA7xx Radio probe done
[    3.992581] vpe 489d0000.vpe: Device registered as /dev/video0
[    3.998919] Driver for 1-wire Dallas network protocol.
[    4.005278] coproc iva_coproc: probe
[    4.008919] vip 48970000.vip: VPDMA firmware loaded
[    4.013843] vip1-s0: Port A enabled but no endpoints found
[    4.019384] Adding alias for supply vdd,iva_coproc -> vdd,4a0025cc.voltdm
[    4.026382] Adding alias for supply vbb,iva_coproc -> vbb,4a0025cc.voltdm
[    4.033281] vip1-s1: Using subdev tvp5158 1-0058 for capture
[    4.039328] vip1-s1: vip Device registered as /dev/video1
[    4.044760] vip1-s0: Port B enabled but no endpoints found
[    4.050189] omap_voltdm 4a0025cc.voltdm: Unable to get vdd regulator:-517
[    4.057191] coproc iva_coproc: of_pm_voltdm_notifier_register: Failed to get coproc regulator/voltdm: -517
[    4.066941] vip1-s1: Port B enabled but no endpoints found
[    4.072399] coproc iva_coproc: coproc clock notifier not ready, retry
[    4.079149] coproc iva_coproc: coproc_probe result=-517
[    4.084410] platform iva_coproc: Driver coproc requests probe deferral
[    4.091022] coproc dsp_coproc: probe
[    4.094701] Adding alias for supply vdd,dsp_coproc -> vdd,4a0025e0.voltdm
[    4.101568] Adding alias for supply vbb,dsp_coproc -> vbb,4a0025e0.voltdm
[    4.108402] omap_voltdm 4a0025e0.voltdm: Unable to get vdd regulator:-517
[    4.115256] coproc dsp_coproc: of_pm_voltdm_notifier_register: Failed to get coproc regulator/voltdm: -517
[    4.124983] coproc dsp_coproc: coproc clock notifier not ready, retry
[    4.131514] coproc dsp_coproc: coproc_probe result=-517
[    4.136771] platform dsp_coproc: Driver coproc requests probe deferral
[    4.147956] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    4.156800] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@4809c000[0]'
[    4.156811] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@4809c000[0]'
[    4.178623] ata1: SATA link down (SStatus 0 SControl 300)
[    4.188796] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@480b4000[0]'
[    4.188807] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@480b4000[0]'
[    4.189067] 480b4000.mmc supply vmmc not found, using dummy regulator
[    4.195915] omap_hsmmc 480b4000.mmc: could not set regulator OCR (-22)
[    4.235773] mmc0: host does not support reading read-only switch. assuming write-enable.
[    4.244047] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@480d1000[0]'
[    4.244058] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@480d1000[0]'
[    4.244304] 480d1000.mmc supply vmmc not found, using dummy regulator
[    4.251132] omap_hsmmc 480d1000.mmc: could not set regulator OCR (-22)
[    4.257781] mmc0: new high speed SDHC card at address 1234
[    4.263840] mmcblk0: mmc0:1234 SA04G 3.70 GiB
[    4.269532]  mmcblk0: p1 p2
[    4.280590] omap_hsmmc 480b4000.mmc: exceeding card's volts
[    4.299350] ledtrig-cpu: registered to indicate activity on CPUs
[    4.305723] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    4.324686] mmc1: BKOPS_EN bit is not set
[    4.329435] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    4.335849] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    4.342312] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[    4.349995] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[    4.358036] mmc1: Voltage range not supported for power class.
[    4.364067] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[    4.371810] mmc1: power class selection to bus width 8 failed
[    4.379271] mmc1: Voltage range not supported for power class.
[    4.385129] mmc1: power class selection to bus width 4 failed
[    4.393796] mmc1: new high speed MMC card at address 0001
[    4.399958] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    4.405738] omap-sham 4b101000.sham: initialization failed.
[    4.411910] mmcblk1: mmc1:0001 R1J55A 7.28 GiB
[    4.416639] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB
[    4.422585] omap-sham: probe of 4b101000.sham failed with error -22
[    4.429090] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB
[    4.436208] usbcore: registered new interface driver usbhid
[    4.441940]  mmcblk1: p1 p2
[    4.445314] usbhid: USB HID core driver
[    4.454989] platform bt_sco_card: Driver asoc-simple-card requests probe deferral
[    4.462693]  mmcblk1boot1: unknown partition table
[    4.469206] asoc-simple-card asoc-simple-card.0:  hdmi-hifi <-> 58040000.encoder mapping ok
[    4.477660]  mmcblk1boot0: unknown partition table
[    4.484819] davinci-mcasp 48464000.mcasp: DAI is shared
[    4.493813] davinci-mcasp 48468000.mcasp: numevt will be ignored due to errata i868
[    4.503045] davinci-mcasp 48474000.mcasp: DAI is shared
[    4.508390] davinci-mcasp 48474000.mcasp: numevt will be ignored due to errata i868
[    4.516734] davinci-mcasp 48478000.mcasp: numevt will be ignored due to errata i868
[    4.525971] davinci-mcasp 4847c000.mcasp: numevt will be ignored due to errata i868
[    4.534420] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    4.542913] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    4.549713] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    4.556629] platform primary_sound: Driver davinci_evm requests probe deferral
[    4.564378] dra7xx-jamr3-snd jamr3_sound: codec dai node is invalid
[    4.570757] dra7xx-jamr3-snd jamr3_sound: failed to add dai link -22
[    4.577148] dra7xx-jamr3-snd: probe of jamr3_sound failed with error -22
[    4.584977] oprofile: using timer interrupt.
[    4.589395] nf_conntrack version 0.5.0 (15968 buckets, 63872 max)
[    4.595967] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.601427] TCP: cubic registered
[    4.604756] Initializing XFRM netlink socket
[    4.609142] NET: Registered protocol family 17
[    4.613621] NET: Registered protocol family 15
[    4.618143] Bridge firewalling registered
[    4.622235] can: controller area network core (rev 20120528 abi 9)
[    4.628497] NET: Registered protocol family 29
[    4.632996] can: raw protocol (rev 20120528)
[    4.637323] 8021q: 802.1Q VLAN Support v1.8
[    4.641642] Key type dns_resolver registered
[    4.646080] dra7xx_init_late:719---
[    4.650030] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[    4.656326] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[    4.662702] omap_voltdm 4a003b20.voltdm: Unable to get vdd regulator:-517
[    4.669563] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[    4.678299] cpu cpu0: cpu0 clock notifier not ready, retry
[    4.683851] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[    4.691533] Power Management for TI OMAP4+ devices.
[    4.696606] ThumbEE CPU extension supported.
[    4.700956] Registering SWP/SWPB emulation handler
[    4.705768] SmartReflex Class3 initialized
[    4.711002] vmmcwl_fixed: disabling
[    4.714507] aic_dvdd: disabling
[    4.717661] regulator-dummy: disabling
[    4.721782] dmm 4e000000.dmm: workaround for errata i878 in use
[    4.730035] dmm 4e000000.dmm: initialized all PAT entries
[    4.735950] platform omapdrm.0: Driver omapdrm requests probe deferral
[    4.744323] ======palmas_i2c_probe:517========
[    4.748900] palmas 0-0058: Irq flag is 0x00000000
[    4.753630] ======palmas_i2c_probe:549, features=0x0========
[    4.759968] palmas 0-0058: Force skipping irq request
[    4.765043] ======palmas_i2c_probe:630 no_irq========
[    4.770575] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[    4.775956] prom_parse: Bad cell count for /ocp/i2c@48070000/tps65917@58
[    4.784446] smps1: 850 <--> 1500 mV at 980 mV
[    4.790292] smps2: 850 <--> 1500 mV at 970 mV
[    4.796085] smps3: 850 <--> 1500 mV at 960 mV
[    4.801961] smps4: 1800 mV
[    4.806098] smps5: 1350 mV
[    4.810293] ldo1: 1800 <--> 3300 mV at 3000 mV
[    4.815693] ldo2: 1800 <--> 3300 mV
[    4.820976] ldo3: 1800 mV
[    4.825314] ldo4: 3300 mV
[    4.829677] ldo5: 1800 mV
[    4.833070] REGEN1: no parameters
[    4.836672] REGEN2: no parameters
[    4.840329] REGEN3: no parameters
[    4.843970] omap-usb2 4a084000.phy: Unbalanced pm_runtime_enable!
[    4.850650] omap-usb2 4a085000.phy: Unbalanced pm_runtime_enable!
[    4.857387] of_get_named_gpiod_flags exited with status 0
[    4.857813] of_get_named_gpiod_flags: can't parse gpios property of node '/connector@1[0]'
[    4.858069] coproc iva_coproc: probe
[    4.861856] Adding alias for supply vdd,iva_coproc -> vdd,4a0025cc.voltdm
[    4.868713] Adding alias for supply vbb,iva_coproc -> vbb,4a0025cc.voltdm
[    4.876947] coproc iva_coproc: coproc_probe result=0
[    4.882208] coproc dsp_coproc: probe
[    4.885884] Adding alias for supply vdd,dsp_coproc -> vdd,4a0025e0.voltdm
[    4.892800] Adding alias for supply vbb,dsp_coproc -> vbb,4a0025e0.voltdm
[    4.900786] coproc dsp_coproc: coproc_probe result=0
[    4.906900] asoc-simple-card bt_sco_card:  bt-sco-pcm <-> 48478000.mcasp mapping ok
[    4.916153] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    4.924636] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    4.931437] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    4.938355] platform primary_sound: Driver davinci_evm requests probe deferral
[    4.945814] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[    4.952194] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[    4.980636] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.987278] [drm] No driver support for vblank timestamp query.
[    4.995228] omapdss error: HDMI I2C Master Error
[    5.009908] [drm] Enabling DMM ywrap scrolling
[    5.118587] omapdrm omapdrm.0: lcd3: timeout waiting for enable
[    5.318592] omapdrm omapdrm.0: omap_crtc_flush() timeout
[    5.344329] Console: switching to colour frame buffer device 128x48
[    5.367621] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    5.373578] omapdrm omapdrm.0: registered panic notifier
[    5.378934] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    5.385326] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    5.393833] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    5.400610] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    5.407527] platform primary_sound: Driver davinci_evm requests probe deferral
[    5.416081] omap_rtc 48838000.rtcss: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[    5.424979] sr_init: No PMIC hook to init smartreflex
[    5.430433] sr_init: platform driver register failed for SR
[    5.449618] ALSA device list:
[    5.452606]   #1: HDMI 58040000.encoder
[    5.456456]   #2: DRA7xx-WiLink
[    5.902209] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.910379] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    5.926607] devtmpfs: mounted
[    5.929835] Freeing unused kernel memory: 376K (c0929000 - c0987000)
[    6.441547] udevd[1156]: starting version 182
[    7.052825] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    7.162430] tvp5158 1-0058: Currently only D1 resolution is supported
[    7.183824] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    7.244412] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    7.273457] random: nonblocking pool is initialized
[    7.361256] platform primary_sound: Driver davinci_evm requests probe deferral
[    7.465513] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    7.530124] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    7.578509] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    7.645577] platform primary_sound: Driver davinci_evm requests probe deferral
[    7.724613] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    7.781962] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    7.816357] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    7.830640] platform primary_sound: Driver davinci_evm requests probe deferral
[    8.284561] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    8.308597] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    8.315347] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    8.328599] platform primary_sound: Driver davinci_evm requests probe deferral
[    8.722120] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    8.739928] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    8.746687] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    8.753644] platform primary_sound: Driver davinci_evm requests probe deferral
[    8.824996] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    8.830907] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    8.838948] xhci-hcd xhci-hcd.0.auto: irq 434, io mem 0x48890000
[    8.845101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    8.851940] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.859198] usb usb1: Product: xHCI Host Controller
[    8.864094] usb usb1: Manufacturer: Linux 3.14.63 xhci-hcd
[    8.869607] usb usb1: SerialNumber: xhci-hcd.0.auto
[    8.875065] hub 1-0:1.0: USB hub found
[    8.878864] hub 1-0:1.0: 1 port detected
[    8.883241] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    8.891861] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    8.897616] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    8.904384] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    8.912114] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    8.919197] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    8.926013] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.933934] platform primary_sound: Driver davinci_evm requests probe deferral
[    8.941510] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    8.949930] usb usb2: Product: xHCI Host Controller
[    8.954825] usb usb2: Manufacturer: Linux 3.14.63 xhci-hcd
[    8.960371] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    8.967115] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    8.974032] usb usb2: SerialNumber: xhci-hcd.0.auto
[    8.979606] hub 2-0:1.0: USB hub found
[    8.983390] hub 2-0:1.0: 1 port detected
[    8.987348] platform primary_sound: Driver davinci_evm requests probe deferral
[    8.994905] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.000694] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    9.009343] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    9.017295] xhci-hcd xhci-hcd.1.auto: irq 435, io mem 0x488d0000
[    9.023368] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    9.030225] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    9.037039] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.044320] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    9.051265] platform primary_sound: Driver davinci_evm requests probe deferral
[    9.058542] usb usb3: Product: xHCI Host Controller
[    9.063463] usb usb3: Manufacturer: Linux 3.14.63 xhci-hcd
[    9.068989] usb usb3: SerialNumber: xhci-hcd.1.auto
[    9.074409] hub 3-0:1.0: USB hub found
[    9.078191] hub 3-0:1.0: 1 port detected
[    9.082484] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    9.091131] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.096728] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    9.103614] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    9.111334] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    9.118242] platform primary_sound: Driver davinci_evm requests probe deferral
[    9.125642] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    9.132482] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.140038] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    9.148448] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    9.155195] usb usb4: Product: xHCI Host Controller
[    9.160101] usb usb4: Manufacturer: Linux 3.14.63 xhci-hcd
[    9.165606] usb usb4: SerialNumber: xhci-hcd.1.auto
[    9.170527] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    9.177433] platform primary_sound: Driver davinci_evm requests probe deferral
[    9.185310] hub 4-0:1.0: USB hub found
[    9.189136] hub 4-0:1.0: 1 port detected
[    9.224919] davinci_evm primary_sound: Could not get requested rate 11289600 using 9600000.
[    9.234431] davinci_evm primary_sound: ASoC: CODEC (null) not registered
[    9.242721] davinci_evm primary_sound: snd_soc_register_card failed (-517)
[    9.250465] platform primary_sound: Driver davinci_evm requests probe deferral
[   10.156071] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[  212.388596] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  212.588609] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  212.788589] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  212.988588] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  213.188607] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  213.388591] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  213.588592] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  213.788603] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  213.988587] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  214.188592] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  214.388607] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  214.588591] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  214.788589] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  214.988602] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  215.188607] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  215.388591] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  215.588607] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  215.788588] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  215.988588] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  216.188607] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  216.388591] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  216.588592] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  216.788604] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  216.988588] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  217.188615] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  217.388606] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  217.588590] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  217.788588] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  217.988604] omapdrm omapdrm.0: omap_crtc_flush() timeout
[  218.188595] omapdrm omapdrm.0: omap_crtc_flush() timeout
root@dra7xx-evm:/usr/local/bin#
#include <dt-bindings/pinmux/mux_dra7xx.h>
	aliases {
		display0 = &hdmi0;
		display1 = &lcd2;
	lcd2: display {
		compatible = "omapdss,panel-dpi", "panel-dpi";
		status = "ok";
		label = "lcd";
		//enable-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>;
		// 1920x1200@60
		// 1920x1200@30
		// 1920x1080@60
		// 1920x1080@30
		// 1280x720@30
		// 800x480@30
		// 1920x1200@60
		// (1920+226)*(1200+32)*30=158632320
		panel-timing {
				clock-frequency = <158000000>;
				hactive = <1920>;
				vactive = <1200>;
				hfront-porch = <210>;
				hback-porch = <16>;
				hsync-len = <30>;
				vback-porch = <10>;
				vfront-porch = <22>;
				vsync-len = <13>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <1>;
				pixelclk-active = <1>;
		port {
			lcd2_in: endpoint {
				remote-endpoint = <&dpi2_out>;
&dra7_pmx_core {
	vout3_pins: pinmux_vout3_pins {
		pinctrl-single,pins = <
			GPMC_A0	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d16 GPIO7_3 R6	 */
			GPMC_A1   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A1.vout3_d17	 */
			GPMC_A2	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A2.vout3_d18  */
			GPMC_A3   (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A3.vout3_d18 */
			GPMC_A4	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A4.vout3_d20  */
			GPMC_A5	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A5.vout3_d21	 */
			GPMC_A6	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A6.vout3_d22	 */
			GPMC_A7	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A7.vout3_d23 */
			GPMC_AD8	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD8.vout3_d8	 */
			GPMC_AD9  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD9.vout3_d9	 */
			GPMC_AD10 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD10.vout3_d10  */
			GPMC_AD11 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD11.vout3_d11	 */
			GPMC_AD12 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD12.vout3_d12  */
			GPMC_AD13 (PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD13.vout3_d13	 */
			GPMC_AD14	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD14.vout3_d14	 */
			GPMC_AD15	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_AD15.vout3_d15 */
			GPMC_AD0	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d0	 */
			GPMC_AD1  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d1	 */
			GPMC_AD2	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d2  */
			GPMC_AD3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d3	 */
			GPMC_AD4	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d4  */
			GPMC_AD5	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d5	 */
			GPMC_AD6	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d6	 */
			GPMC_AD7	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A0.vout3_d7	 */
			GPMC_A11	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A11.vout3_fld	 */
			GPMC_A10	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_A10.vout3_de	 */
			GPMC_A8	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A8.vout3_hsync	 */
			GPMC_A9	  (PIN_OUTPUT | MUX_MODE3)	/* GPMC_A9.vout3_vsync	 */
			GPMC_CS3	(PIN_OUTPUT | MUX_MODE3)	/* GPMC_CS3.vout3_clk	 */
			VIN2A_D9	(PIN_OUTPUT | MUX_MODE14)	/* VIN2A_D9.gpio4_10  DISP_RESETQ	 */
&dss {
	pinctrl-names = "default";
	pinctrl-0 = <&vout3_pins>;
	status = "ok";
	ports {
		#address-cells = <1>;
		#size-cells = <0>;
		status = "okay";
		port@lcd2 {
			reg = <2>;
			dpi2_out: endpoint {
				remote-endpoint = <&lcd2_in>;
				data-lines = <24>;
&i2c3 {
	clock-frequency = <1000>;
&i2c4 {
&i2c5 {
&sata {
	status="disabled";
Andy
  • Hi Andy,
    It appears as if the LCD clock has not locked. Could you please run the linked script on the target and share the output?
    git.ti.com/.../dss_clockdumps.sh
    regards,
    Venkat
  • Hi Venkat,
       Thanks for your reply.   Please see the attachment (J6 , J6E ) for the result.
       It looks like J6E video2 PLL ( DSI1_C_CLK - vout3 ) does not generate the clock.
    According J6E TRM , J6E doesn't have video2 clock source.
    So I try to configure LCD3_CLK to reference DSS_CLK ( from PRCM )   in DSS_CTRL register .
     Modetest will not hangup after this modification , but the DSS_CLK 192000000 is not the right clock for our VOUT3 1920x1200@60 setting  ( around 158000000)
    How could I modify the DSS_CLK to be clock we want ?  Should I use the dts or modify the register directly ??
    the clock after modification......
    Clock O/P of MUXes
    DSI1_A_CLK :  0
    DSI1_B_CLK :  0
    DSI1_C_CLK :  0
     2: LCD1 clk :  192000000
     3: LCD2 clk :  192000000
    10: LCD3 clk :  192000000
     1: func clk :  192000000
    LCD1 logic clk(/ 4 ) :  48000000  pix clk(/ 1 ) :  48000000
    LCD2 logic clk(/ 4 ) :  48000000  pix clk(/ 1 ) :  48000000
    LCD3 logic clk(/ 1 ) :  192000000  pix clk(/ 1 ) :  192000000
    Andy
    ./debug_dss_clockdumps_j6.sh
    =====================DSS clock script===================
    Dumps internal clocks and muxes of DSS
    CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x00000229
    video1 PLL :  Disabled
    video2 PLL :  Enabled
    HDMI   PLL :  Enabled
    DSI1_A_CLK mux : DPLL HDMI
    DSI1_B_CLK mux : DPLL video2
    DSI1_C_CLK mux : DPLL Video2
    DSS_CTRL (0x58000040) = 0x00080000
     2: LCD1 clk switch :  DSS clk
     3: LCD2 clk switch :  DSS clk
    10: LCD3 clk switch :  DSI1_C_CLK
     1: func clk switch :  DSS clk
    13: DPI1 output     :  HDMI
    Register dump for DPLL video2
    | Address (hex) | Data (hex) |
    | 0x58009300    | 0x00000018 |
    | 0x58009304    | 0x00002283 |
    | 0x58009308    | 0x00000000 |
    | 0x5800930C    | 0x0163160E |
    | 0x58009310    | 0x00616008 |
    | 0x58009314    | 0x00000000 |
    | 0x58009318    | 0x00000000 |
    | 0x5800931C    | 0x00000000 |
    | 0x58009320    | 0x00000000 |
    Details for DPLL video2
    PLL status  :  Locked
    M4 hsdiv(1) :  Active
    M5 hsdiv(2) :  inactive
    M6 hsdiv(3) :  inactive
    M7 hsdiv(4) :  inactive
    PLL_REGM   =  395
    PLL_REGN   =  7
    M4 DIV     =  11
    M6 DIV     =  0
    M7 DIV     =  0
    Clock calculations (DPLL video2)
    sysclk = 20000000
    DCO clk = sysclk * 2 * REGM / (REGN + 1) = 1975000000
    M4clk (clkcout1) = DCO clk / (M4 DIV + 1) = 164583333
    M6clk (clkcout1) = DCO clk / (M6 DIV + 1) = 0
    M7clk (clkcout1) = DCO clk / (M7 DIV + 1) = 0
    Register dump for DPLL hdmi
    | 0x58040200    | 0x00000018 |
    | 0x58040204    | 0x00000003 |
    | 0x58040208    | 0x00000000 |
    | 0x5804020C    | 0x000CB21E |
    | 0x58040210    | 0x00606008 |
    | 0x58040214    | 0x00002000 |
    | 0x58040218    | 0x00000000 |
    | 0x5804021C    | 0x00000000 |
    | 0x58040220    | 0x000C0000 |
    Details for DPLL hdmi
    PLL status  :  Locked
    M4 hsdiv(1) :  inactive
    PLL_REGM   =  1625
    PLL_REGN   =  15
    M4 DIV     =  0
    M6 DIV     =  0
    M7 DIV     =  0
    PLL_REGM2  =  3
    PLL_REGM_F =  3
    Clock calculations (DPLL hdmi)
    sysclk = 20000000
    CLKOUT = sysclk * REGM / (REGM2 * (REGN + 1)) = 677083333
    Clock O/P of MUXes
    DSI1_A_CLK :  677083333
    DSI1_B_CLK :  0
    DSI1_C_CLK :  164583333
    10: LCD3 clk :  164583333
    LCD3 logic clk(/ 1 ) :  164583333  pix clk(/ 1 ) :  164583333
    root@dra7xx-evm:~#
    ./debug_dss_clockdumps.sh
    CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x000002AA
    video1 PLL :  Enabled
    video2 PLL :  Disabled
    HDMI   PLL :  Enabled
    Register dump for DPLL video1
    | 0x58004300    | 0x00000018 |
    | 0x58004304    | 0x00002283 |
    | 0x58004308    | 0x00000000 |
    | 0x5800430C    | 0x0163160E |
    | 0x58004310    | 0x00616008 |
    | 0x58004314    | 0x00000000 |
    | 0x58004318    | 0x00000000 |
    | 0x5800431C    | 0x00000000 |
    | 0x58004320    | 0x00000000 |
    Details for DPLL video1
    PLL status  :  Locked
    PLL_REGM   =  395
    PLL_REGN   =  7
    M4 DIV     =  11
    M6 DIV     =  0
    M7 DIV     =  0
    Clock calculations (DPLL video1)
    sysclk = 20000000
    PLL status  :  Locked
    PLL_REGM   =  1625
    PLL_REGN   =  15
    M4 DIV     =  0
    M6 DIV     =  0
    M7 DIV     =  0
    PLL_REGM2  =  3
    PLL_REGM_F =  3
    sysclk = 20000000
    Clock O/P of MUXes
    DSI1_B_CLK :  0
    DSI1_C_CLK :  0
    10: LCD3 clk :  0
    LCD3 logic clk(/ 1 ) :  0  pix clk(/ 1 ) :  0
    root@dra7xx-evm:~#
  • Andy,
    I prefer setting up the clock through the device tree. Let me check on the procedure and get back to you.
    regards,
    Venkat
  • Hi Venkat,
    I configure LCD3_CLK to reference DSS_CLK ( from PRCM ) in DSS_CTRL register ( omapconf write 0x58000040 0x0 )
    And then change the RGB888 resolution to 1280x720@30 , the LCD3 pix clk will be changed automatically.
    Clock O/P of MUXes
    DSI1_B_CLK : 0
    DSI1_C_CLK : 0
    LCD3 logic clk(/ 1 ) : 192000000 pix clk(/ 8 ) : 24000000
    And then I can throw the bmp file to the VGA port successfully, but could you give a way which using dts to modify the DSS_CTRL register with the value we wanted.
    Andy
    There seems to be some hardcoding in the kernel driver on which PLL is used for which VOUT. This is in dpi.c and dispc.c. We need more time to investigate an answer and expect to have a further response by the end of this week.
    regards,
    Venkat
  • Hi Venkat,
    Do you any update on this ?
    Andy
  • Andy,
    I have looked into this issue from the clock muxing perspective. On
    the 3.14 kernel, the M6 divider of Video1 PLL is not configured. As a
    result, LCD3 cannot use Video1 PLL directly. You can manually set the
    dividers in the file dpi.c:dpi_set_pll_clk() to enable the M6 divider
    and get the LCD3 clock.
    ctx.pll_params.hsdiv_enabled[2] = true;
    ctx.pll_params.regm_hsdiv[2] = 9; /* Customize for each platform */
    Please try this out. If you face any issues, please send me the dump
    from the script below.
    This script has been updated today for VOUT3.
    A better alternative is to move to the 4.4 based SDK release where VOUT3
    works out of the box on J6 Eco.
    processors.wiki.ti.com/.../Category:Processor_SDK_Linux_Automotive
    regards,
    Venkat
  • Hi Venkat,
    This patch can work on J6E , but it will fail on J6 .
    Our purpose is that we want use the same kernel working on J6 and J6E , but can use different dts.
    Do you have another way to achieve the same result through dts modification ?
    Andy
  • Andy,
    No. I do not have device tree modification to do this in a clean manner.
    I would recommended moving to the 4.4 kernel where this feature is supported instead trying to modify the 3.14 kernel.
    regards,
    Venkat
  • Hi Venkat,
    I got it , thanks for your help.
    Andy
