We have one J6E cpu module always boot up fail.
And there are some strange message about encryption error message.
Could you help on this ?
Full log please see the attachment.
[ 4.432498] alg: skcipher: Chunk test 1 failed on encryption at page 0 for ecb-aes-omap
[ 4.440607] 00000000: 71 73 f7 db 24 93 21 6d 61 1e bb 63 42 79 db 64
[ 4.447102] 00000010: 6f 82 c0 ca a3 9b fa 0b d9 08 c7 4a 90 ae 8f 5f
[ 4.453634] 00000020: 5e 06 f0 5f 31 51 18 37 45 d7 ca 3a fd 6c 3f e1
[ 4.460179] 00000030: dd 8d 22 65 2b 00 50 ce ba 28 67 d7 ce 0e 0d ea
[ 4.466651] 00000040: 78 69 7f ae 8f 8b 69 37 75 e0 dc 96 e0 b7 f4 09
[ 4.703108] alg: skcipher: Test 5 failed on encryption for ctr-aes-omap
[ 4.710123] 00000000: da 4e 3f bc e8 b6 3a a2 d5 4d 84 4a a9 0c e1 a5
[ 4.716642] 00000010: b8 73 bc f9 bb 59 2f 44 8b ab 82 6c b4 32 9a de
[ 4.724252] 00000020: 5a 0b db 7a 6b f2 38 9f 06 f7 f7 ff ff c0 8a 2e
[ 4.732775] 00000030: 76 ea 06 32 23 f3 59 2e 75 de 71 86 3c 98 23 44
[ 4.739326] 00000040: 5b f2 fa 6a 00 bb c1 ad 58 bd 3e 6f 2e b4 19 04
[ 4.745841] 00000050: 70 8b 92 55 23 e9 6a 3a 78 7a 1b 10 85 52 9c 12
Andy
boot-sd Unknown command 'boot-sd' - try 'help' U-Boot# boot_sd J6E ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 reading uenv.txt 219 bytes read in 3 ms (71.3 KiB/s) Loaded environment from uenv.txt Importing environment from mmc0 ... 5240088 bytes read in 269 ms (18.6 MiB/s) 99206 bytes read in 31 ms (3.1 MiB/s) Booting from mmc0 ... Kernel image @ 0x82000000 [ 0x000000 - 0x4ff518 ] ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffe4000, end 8ffff385 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.14.63 (andy@andy-Veriton-M490) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #2 SMP PREEMPT Fri Sep 2 10:05:32 CST 2016 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] Machine model: TI DRA722 20160831 [ 0.000000] Reserved memory: created CMA memory pool at 0x95800000, size 56 MiB [ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 64 MiB [ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x9d000000, size 32 MiB [ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool [ 0.000000] cma: CMA: reserved 64 MiB at ab800000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] DRA722 ES1.0 [ 0.000000] PERCPU: Embedded 8 pages/cpu @eaf53000 s8640 r8192 d15936 u32768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259088 [ 0.000000] Kernel command line: console=ttyO2,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait earlyprintk fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=64M rootfstype=ext4 snd.slots_reserved=1,1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 800580K/1042432K available (6839K kernel code, 693K rwdata, 2704K rodata, 376K init, 267K bss, 241852K reserved, 268288K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc095a0d4 (9545 kB) [ 0.000000] .init : 0xc095b000 - 0xc09b91c0 ( 377 kB) [ 0.000000] .data : 0xc09ba000 - 0xc0a674e0 ( 694 kB) [ 0.000000] .bss : 0xc0a674ec - 0xc0aaa1fc ( 268 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] GIC CPU mask not found - kernel will fail to boot. [ 0.000000] GIC CPU mask not found - kernel will fail to boot. [ 0.000000] OMAP clockevent source: timer1 at 31475 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65536000000000ns [ 0.000030] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000427] Architected cp15 timer(s) running at 5.90MHz (virt). [ 0.000462] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 2911033065472ns [ 0.000470] Switching to timer-based delay loop [ 0.001442] Console: colour dummy device 80x30 [ 0.001461] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2' [ 0.001467] This ensures that you still see kernel messages. Please [ 0.001473] update your kernel commandline. [ 0.001486] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016) [ 0.001500] pid_max: default: 32768 minimum: 301 [ 0.001592] Security Framework initialized [ 0.001632] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001642] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.024019] CPU: Testing write buffer coherency: ok [ 0.024292] /cpus/cpu@0 missing clock-frequency property [ 0.024305] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.024327] Setting up static identity map for 0x806b4028 - 0x806b4098 [ 0.060528] Brought up 1 CPUs [ 0.060539] SMP: Total of 1 processors activated (11.80 BogoMIPS). [ 0.060547] CPU: All CPU(s) started in SVC mode. [ 0.060948] devtmpfs: initialized [ 0.061705] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.063393] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.076195] omap_hwmod: tptc0 using broken dt data from edma-controller [ 0.076696] omap_hwmod: tptc1 using broken dt data from edma-controller [ 0.241237] pinctrl core: initialized pinctrl subsystem [ 0.242075] regulator-dummy: no parameters [ 0.246185] NET: Registered protocol family 16 [ 0.248070] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.250440] cpuidle: using governor ladder [ 0.250450] cpuidle: using governor menu [ 0.295320] syscon 4a002000.tisysconcore: regmap [mem 0x4a002000-0x4a0026cf] registered [ 0.295674] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e7b] registered [ 0.298674] OMAP GPIO hardware version 0.1 [ 0.313889] platform 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000 [ 0.314221] platform 55020000.ipu: assigned reserved memory node ipu2_cma@95800000 [ 0.314542] platform 40800000.dsp: assigned reserved memory node dsp1_cma@99000000 [ 0.339304] No ATAGs? [ 0.339323] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.339333] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.342874] OMAP DMA hardware revision 0.0 [ 0.376149] bio: create slab <bio-0> at 0 [ 0.394113] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.401751] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver [ 0.402691] evm_3v3_sd: 3300 mV [ 0.403027] evm_3v3_sw: 3300 mV [ 0.403369] aic_dvdd: 1800 mV [ 0.403462] aic_dvdd: supplied by evm_3v3_sw [ 0.403819] vmmcwl_fixed: 1800 mV [ 0.407830] vgaarb: loaded [ 0.408300] i2c-core: driver [palmas] using legacy suspend method [ 0.408309] i2c-core: driver [palmas] using legacy resume method [ 0.408925] SCSI subsystem initialized [ 0.410324] usbcore: registered new interface driver usbfs [ 0.410499] usbcore: registered new interface driver hub [ 0.410706] usbcore: registered new device driver usb [ 0.412757] palmas 0-0058: could not find pctldev for node /ocp/padconf@4844a000/tps65917_pins_default, deferring probe [ 0.412775] i2c 0-0058: Driver palmas requests probe deferral [ 0.412800] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 1.411398] omap_i2c 48072000.i2c: controller timed out [ 1.431432] pcf857x: probe of 1-0026 failed with error -110 [ 1.431854] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz [ 1.432327] omap_i2c 48060000.i2c: bus 2 rev0.12 at 1 kHz [ 2.432020] omap_i2c 4807a000.i2c: controller timed out [ 2.452053] pcf857x: probe of 3-0021 failed with error -110 [ 2.452083] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 1 kHz [ 2.452511] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 1 kHz [ 2.452859] media: Linux media interface: v0.10 [ 2.453025] Linux video capture interface: v2.00 [ 2.453285] pps_core: LinuxPPS API ver. 1 registered [ 2.453293] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.453422] PTP clock support registered [ 2.455090] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 2.455165] omap-mailbox: probe of 48842000.mailbox failed with error -22 [ 2.456181] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 2.456296] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 2.456402] omap-iommu 58882000.mmu: 58882000.mmu registered [ 2.456504] omap-iommu 55082000.mmu: 55082000.mmu registered [ 2.457457] Advanced Linux Sound Architecture Driver Initialized. [ 2.458935] Switched to clocksource arch_sys_counter [ 2.478691] NET: Registered protocol family 2 [ 2.479370] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 2.479438] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 2.479569] TCP: Hash tables configured (established 8192 bind 8192) [ 2.479617] TCP: reno registered [ 2.479630] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 2.479662] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 2.479839] NET: Registered protocol family 1 [ 2.480137] RPC: Registered named UNIX socket transport module. [ 2.480147] RPC: Registered udp transport module. [ 2.480154] RPC: Registered tcp transport module. [ 2.480160] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.481426] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available [ 2.484321] futex hash table entries: 256 (order: 2, 16384 bytes) [ 2.598648] bounce pool size: 64 pages [ 2.598897] VFS: Disk quotas dquot_6.5.2 [ 2.599034] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 2.599501] NFS: Registering the id_resolver key type [ 2.599544] Key type id_resolver registered [ 2.599553] Key type id_legacy registered [ 2.599584] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 2.599719] msgmni has been set to 1471 [ 2.604108] alg: No test for stdrng (krng) [ 2.604311] NET: Registered protocol family 38 [ 2.604341] io scheduler noop registered (default) [ 2.604350] io scheduler deadline registered [ 2.604371] io scheduler cfq registered [ 2.607385] platform 4a084000.phy: Driver omap-usb2 requests probe deferral [ 2.607532] platform 4a085000.phy: Driver omap-usb2 requests probe deferral [ 2.610050] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124 [ 2.610465] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4 [ 2.645333] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00 [ 2.645348] pci_bus 0000:00: root bus resource [io 0x1000-0x10000] [ 2.645360] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 2.645371] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff] [ 2.645901] PCI: bus0: Fast back to back transfers disabled [ 2.646155] PCI: bus1: Fast back to back transfers enabled [ 2.646275] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [ 2.646292] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [ 2.646305] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.646325] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.648751] OMAP DSS rev 6.1 [ 2.653968] platform encoder@1: Driver dra7evm-tpd12s015 requests probe deferral [ 2.654695] connector-hdmi connector@1: failed to find video source [ 2.654714] platform connector@1: Driver connector-hdmi requests probe deferral [ 2.655699] pbias_mmc_omap5: 1800 <--> 3000 mV at 3000 mV [ 2.656555] abb_mpu: 1100 <--> 1210 mV [ 2.656926] abb_ivahd: 1060 <--> 1250 mV [ 2.657306] abb_dspeve: 1060 <--> 1250 mV [ 2.657688] abb_gpu: 1060 <--> 1280 mV [ 2.658905] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 2.663756] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250 [ 2.664538] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250 [ 2.665347] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250 [ 3.697209] console [ttyS2] enabled [ 3.701526] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250 [ 3.711171] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250 [ 3.720833] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250 [ 3.730472] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250 [ 3.741308] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20 [ 3.748520] [drm] Initialized drm 1.1.0 20060810 [ 3.764209] brd: module loaded [ 3.773007] loop: module loaded [ 3.776564] (hci_tty): inside hci_tty_init [ 3.781405] (hci_tty): allocated 249, 0 [ 3.787975] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled [ 3.794817] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 3.803638] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst [ 3.814225] scsi0 : ahci_platform [ 3.818048] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 343 [ 3.827482] mtdoops: mtd device (mtddev=name/number) must be supplied [ 3.844091] usbcore: registered new interface driver asix [ 3.849919] usbcore: registered new interface driver ax88179_178a [ 3.856214] usbcore: registered new interface driver cdc_ether [ 3.862258] usbcore: registered new interface driver smsc95xx [ 3.868209] usbcore: registered new interface driver net1080 [ 3.874276] usbcore: registered new interface driver cdc_subset [ 3.880411] usbcore: registered new interface driver zaurus [ 3.886211] usbcore: registered new interface driver cdc_ncm [ 3.893773] platform 48890000.usb: Driver dwc3 requests probe deferral [ 3.901145] platform 488d0000.usb: Driver dwc3 requests probe deferral [ 3.909113] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.915670] ehci-pci: EHCI PCI platform driver [ 3.920400] ehci-omap: OMAP-EHCI Host Controller driver [ 3.926130] usbcore: registered new interface driver cdc_wdm [ 3.932034] usbcore: registered new interface driver usb-storage [ 3.938397] usbcore: registered new interface driver usbserial [ 3.944451] usbcore: registered new interface driver pl2303 [ 3.950291] usbserial: USB Serial support registered for pl2303 [ 3.957442] mousedev: PS/2 mouse device common for all mice [ 3.965638] i2c-core: driver [rtc-ds1307] using legacy suspend method [ 3.972185] i2c-core: driver [rtc-ds1307] using legacy resume method [ 3.979412] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as rtc0 [ 3.987813] i2c /dev entries driver [ 3.992792] tvp5158 1-0058: Camera sensor driver registered [ 3.999525] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ 4.005730] pinctrl-single 4a003400.pinmux: pin 4a00363c.0 already requested by 4806a000.serial; cannot claim for 48970000.vip [ 4.017320] pinctrl-single 4a003400.pinmux: pin-143 (48970000.vip) status -22 [ 4.024741] pinctrl-single 4a003400.pinmux: could not request pin 143 (4a00363c.0) from group pinmux_vin2a_pins on device pinctrl-single [ 4.037245] vpe 489d0000.vpe: Device registered as /dev/video0 [ 4.043197] vip 48970000.vip: Error applying setting, reverse things back [ 4.050249] pinctrl-single 4a003400.pinmux: pin 4a00363c.0 already requested by 4806a000.serial; cannot claim for 48970000.vip [ 4.061733] pinctrl-single 4a003400.pinmux: pin-143 (48970000.vip) status -22 [ 4.068902] pinctrl-single 4a003400.pinmux: could not request pin 143 (4a00363c.0) from group pinmux_vin2a_pins on device pinctrl-single [ 4.081339] vip 48970000.vip: Error applying setting, reverse things back [ 4.088161] vip 48970000.vip: No explicit pinctrl resources data. [ 4.095244] vip 48970000.vip: loading firmware vpdma-1b8.bin [ 4.101806] DRA7xx Radio probe done [ 4.105829] Driver for 1-wire Dallas network protocol. [ 4.112243] coproc iva_coproc: probe [ 4.115949] Adding alias for supply vdd,iva_coproc -> vdd,4a0025cc.voltdm [ 4.122810] vip 48970000.vip: VPDMA firmware loaded [ 4.127729] vip1-s0: Port A enabled but no endpoints found [ 4.133173] vip1-s1: Using subdev tvp5158 1-0058 for capture [ 4.139136] Adding alias for supply vbb,iva_coproc -> vbb,4a0025cc.voltdm [ 4.145974] omap_voltdm 4a0025cc.voltdm: Unable to get vdd regulator:-517 [ 4.153112] vip1-s1: vip Device registered as /dev/video1 [ 4.158543] vip1-s0: Port B enabled but no endpoints found [ 4.163955] coproc iva_coproc: of_pm_voltdm_notifier_register: Failed to get coproc regulator/voltdm: -517 [ 4.173876] ata1: SATA link down (SStatus 0 SControl 300) [ 4.179330] vip1-s1: Port B enabled but no endpoints found [ 4.184716] coproc iva_coproc: coproc clock notifier not ready, retry [ 4.191462] coproc iva_coproc: coproc_probe result=-517 [ 4.196723] platform iva_coproc: Driver coproc requests probe deferral [ 4.203357] coproc dsp_coproc: probe [ 4.207037] Adding alias for supply vdd,dsp_coproc -> vdd,4a0025e0.voltdm [ 4.213893] Adding alias for supply vbb,dsp_coproc -> vbb,4a0025e0.voltdm [ 4.220759] omap_voltdm 4a0025e0.voltdm: Unable to get vdd regulator:-517 [ 4.227579] coproc dsp_coproc: of_pm_voltdm_notifier_register: Failed to get coproc regulator/voltdm: -517 [ 4.237291] coproc dsp_coproc: coproc clock notifier not ready, retry [ 4.243820] coproc dsp_coproc: coproc_probe result=-517 [ 4.249094] platform dsp_coproc: Driver coproc requests probe deferral [ 4.260325] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 4.309445] 480b4000.mmc supply vmmc not found, using dummy regulator [ 4.316225] omap_hsmmc 480b4000.mmc: could not set regulator OCR (-22) [ 4.356128] mmc0: host does not support reading read-only switch. assuming write-enable. [ 4.364655] 480d1000.mmc supply vmmc not found, using dummy regulator [ 4.371482] omap_hsmmc 480d1000.mmc: could not set regulator OCR (-22) [ 4.378132] mmc0: new high speed SDHC card at address 1234 [ 4.384192] mmcblk0: mmc0:1234 SA04G 3.70 GiB [ 4.389947] mmcblk0: p1 p2 [ 4.400994] omap_hsmmc 480b4000.mmc: exceeding card's volts [ 4.419705] ledtrig-cpu: registered to indicate activity on CPUs [ 4.426047] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 4.432498] alg: skcipher: Chunk test 1 failed on encryption at page 0 for ecb-aes-omap [ 4.440607] 00000000: 71 73 f7 db 24 93 21 6d 61 1e bb 63 42 79 db 64 [ 4.447102] 00000010: 6f 82 c0 ca a3 9b fa 0b d9 08 c7 4a 90 ae 8f 5f [ 4.453634] 00000020: 5e 06 f0 5f 31 51 18 37 45 d7 ca 3a fd 6c 3f e1 [ 4.460179] 00000030: dd 8d 22 65 2b 00 50 ce ba 28 67 d7 ce 0e 0d ea [ 4.466651] 00000040: 78 69 7f ae 8f 8b 69 37 75 e0 dc 96 e0 b7 f4 09 [ 4.473178] mmc1: BKOPS_EN bit is not set [ 4.477214] 00000050: cb 6d a2 fb da af 09 f8 81 82 27 fa 45 9c 29 a4 [ 4.483720] 00000060: 22 8b 78 69 5b 46 f9 39 1b cc f9 1d 09 eb bc 5c [ 4.490247] 00000070: 41 72 51 97 1d 07 49 a0 1b 8e 65 4b b2 6a 12 03 [ 4.496736] 00000080: 6a 60 95 ac bd ac 1a 64 de 5a a5 f0 83 2f cb ca [ 4.503291] 00000090: 22 74 a6 6c 9b 73 ce 3f e1 8b 22 17 59 0c 47 89 [ 4.509792] 000000a0: 33 a1 d6 47 03 19 4f a8 67 69 f0 5b f0 20 ad 06 [ 4.516297] mmc1: Voltage range not supported for power class. [ 4.522195] 000000b0: 27 81 92 d8 c5 ba 98 12 be 24 b5 2f 75 02 c2 ad [ 4.528662] 000000c0: 12 2f 07 32 ee 39 af 64 05 8f b3 d4 eb 1b 46 6e [ 4.535146] mmc1: power class selection to bus width 8 failed [ 4.540941] 000000d0: d9 21 f9 c4 b7 c9 45 68 b4 a1 74 9f 82 47 eb cc [ 4.547475] 000000e0: bd 0a 14 95 0f 8b a8 2f 4b 1b a7 bf 82 a6 43 0c [ 4.553977] mmc1: Voltage range not supported for power class. [ 4.559850] 000000f0: b9 39 4a a8 10 6f 50 7b 25 fb 26 81 e0 2f f0 96 [ 4.566316] 00000100: 8d 8b ac 92 0f f6 ed 64 63 29 4c 8e 18 13 c5 bf [ 4.572799] mmc1: power class selection to bus width 8 ddr 2 failed [ 4.579117] 00000110: fc a0 d9 bf 7c 3a 0e 29 6f d1 6c 6f a5 da bf b1 [ 4.585685] 00000120: d8 94 8a 0e c0 a8 df a0 a1 59 76 80 1b 8a f3 de [ 4.592207] mmc1: new high speed DDR MMC card at address 0001 [ 4.598192] 00000130: f0 f6 f0 59 bd 8f 38 50 31 cb 69 3f 96 15 d6 f5 [ 4.604965] mmcblk1: mmc1:0001 R1J55A 7.28 GiB [ 4.609549] 00000140: ae ff f6 aa 41 85 4c 10 58 e3 f9 44 e6 28 da 9a [ 4.616017] 00000150: dc 6a 80 34 73 97 1b c5 ca 26 16 77 0e 60 ab 89 [ 4.622685] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB [ 4.628721] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB [ 4.634614] 00000160: 0f 04 27 bd ce 3e 71 b4 a0 d7 22 7e db eb 24 70 [ 4.641650] 00000170: 42 71 51 78 70 b3 e0 3d 84 8e 8d 7b d0 6d ea 92 [ 4.648183] mmcblk1: p1 p2 [ 4.651246] 00000180: 11 08 42 4f e5 ad 26 92 d2 00 ae a8 e3 4b 37 47 [ 4.657714] 00000190: 22 c1 95 c1 63 7f cb 03 f3 e3 d7 9d 60 c7 bc ea [ 4.665279] 000001a0: 35 a2 fd 45 52 39 13 6f c1 53 f3 53 df 33 84 d7 [ 4.671847] 000001b0: d2 c8 37 b0 75 e3 41 46 b3 c7 83 2e 8a bb a4 e5 [ 4.678316] 000001c0: 7f 3c fd 8b eb ea 63 bd b7 46 e7 bf 09 9c 0d 0f [ 4.684883] mmcblk1boot1: unknown partition table [ 4.689768] 000001d0: 40 86 7f 51 e1 11 9c cb 88 e6 68 47 e3 2b c5 ff [ 4.698016] mmcblk1boot0: unknown partition table [ 4.703108] alg: skcipher: Test 5 failed on encryption for ctr-aes-omap [ 4.710123] 00000000: da 4e 3f bc e8 b6 3a a2 d5 4d 84 4a a9 0c e1 a5 [ 4.716642] 00000010: b8 73 bc f9 bb 59 2f 44 8b ab 82 6c b4 32 9a de [ 4.724252] 00000020: 5a 0b db 7a 6b f2 38 9f 06 f7 f7 ff ff c0 8a 2e [ 4.732775] 00000030: 76 ea 06 32 23 f3 59 2e 75 de 71 86 3c 98 23 44 [ 4.739326] 00000040: 5b f2 fa 6a 00 bb c1 ad 58 bd 3e 6f 2e b4 19 04 [ 4.745841] 00000050: 70 8b 92 55 23 e9 6a 3a 78 7a 1b 10 85 52 9c 12 [ 4.752439] 00000060: e4 55 81 21 ce 53 d0 3b 63 77 2c 74 d1 f5 60 f3 [ 4.758971] 00000070: a1 de 44 3c 8f 4d 2f dd 8a fe 3c 42 8e d3 f2 8e [ 4.765486] 00000080: a8 28 69 65 31 e1 45 83 e4 49 c4 9c a7 28 aa 21 [ 4.772011] 00000090: cd 5d 0f 15 b7 93 07 26 b0 65 6d 91 90 23 7a c6 [ 4.778524] 000000a0: db 68 b0 a1 8e a4 76 4e c6 91 83 20 92 4d 63 7a [ 4.785051] 000000b0: 45 18 18 74 19 ad 71 01 6b 23 ad 9d 4e e4 6e 46 [ 4.791582] 000000c0: c9 73 7a f9 02 95 f4 07 0e 7a a6 c5 ae fa 15 2c [ 4.799100] 000000d0: 51 71 f1 dc 22 b6 ac d8 19 24 44 bc 0c fb 3c 2d [ 4.805567] 000000e0: b1 50 47 15 0e db b6 d7 e8 61 e5 95 52 1e 3e 49 [ 4.812071] 000000f0: 70 e9 66 04 4c e1 af bd dd 15 3b 20 59 24 ff b0 [ 4.818539] 00000100: 39 2a e7 bf 23 a3 6e d5 15 f0 61 4f ae 89 10 58 [ 4.825018] 00000110: 5a 33 95 52 2a b5 77 9c a5 43 80 40 27 2d ae d9 [ 4.831496] 00000120: 3f e0 80 94 78 79 cb 7e ad 12 44 4c ec 27 b0 ee [ 4.837962] 00000130: 0b 05 2a 82 99 58 bb 7a 8d 6d 9d 8e e2 8e e7 93 [ 4.844439] 00000140: 2f b3 09 8d 06 d5 ee 70 16 ae 35 c5 52 0f 46 1f [ 4.850916] 00000150: 71 f9 5e f2 67 dc 98 2f a3 23 aa d5 d0 49 f4 a6 [ 4.857382] 00000160: f6 b8 32 cd d6 85 73 60 59 20 e7 55 0e 91 e2 0c [ 4.863859] 00000170: 3f 1c eb 3d df 52 64 f2 7d 8b 5d 63 16 b9 b2 5d [ 4.870336] 00000180: 5e ab b2 97 ab 78 44 e7 c6 72 20 c5 90 9b dc 5d [ 4.876802] 00000190: b0 ef 44 ef 87 31 8d f4 fb 81 5d f7 96 96 d4 50 [ 4.883278] 000001a0: 89 a7 f6 b9 67 76 40 9e 9d 40 d5 2c 30 b8 01 8f [ 4.889756] 000001b0: e4 7b 71 48 a9 a0 a0 1d 87 52 a4 91 a9 d7 a9 51 [ 4.896222] 000001c0: d9 59 f7 cc 63 22 c1 8d 84 7b d8 22 32 5c 6f 1d [ 4.902724] 000001d0: 6e 9f fa dd 49 40 dc 37 14 8c e1 80 1b dd 36 2a [ 4.909205] 000001e0: d0 e9 54 99 5d ba 3b 11 d8 fe c9 5b 5c 25 e5 76 [ 4.915670] 000001f0: fb f2 3f [ 4.918783] Unable to handle kernel NULL pointer dereference at virtual address 0000001e [ 4.926954] pgd = c0004000 [ 4.929689] [0000001e] *pgd=00000000 [ 4.933289] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 4.938623] Modules linked in: [ 4.941699] CPU: 0 PID: 1047 Comm: cryptomgr_test Not tainted 3.14.63 #2 [ 4.948429] task: ea413240 ti: ea4fc000 task.ti: ea4fc000 [ 4.953857] PC is at omap_aes_gcm_crypt+0x6c/0x238 [ 4.958673] LR is at crypto_mod_put+0x54/0x58 [ 4.963047] pc : [<c054efa0>] lr : [<c02751e8>] psr: 20000113 [ 4.963047] sp : ea4fdcd0 ip : ea4fdc08 fp : ea4fdd3c [ 4.974572] r10: ea4b94e8 r9 : ea4f2000 r8 : ea4b9480 [ 4.979817] r7 : 00000001 r6 : fffffffe r5 : ea4b9400 r4 : ea4fdce8 [ 4.986370] r3 : 00000006 r2 : 0000000c r1 : 000000d0 r0 : fffffffe [ 4.992924] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 5.000263] Control: 10c5387d Table: 8000406a DAC: 00000015 [ 5.006032] Process cryptomgr_test (pid: 1047, stack limit = 0xea4fc240) [ 5.012760] Stack: (0xea4fdcd0 to 0xea4fe000) [ 5.017135] dcc0: c0a00ff8 00000000 c0a68158 00000010 [ 5.025348] dce0: 00000011 ea4b9480 01000000 ea4fdcf8 c0029304 ea4b9480 00000010 ea4b9480 [ 5.033561] dd00: c0a91d80 ea4b94c8 00000010 c054f538 0000000f 00000000 00000000 ea4c8000 [ 5.041773] dd20: 00000001 ea4b9480 ea4f2000 c0a218e8 ea4fdd4c ea4fdd40 c054f4e8 c054ef40 [ 5.049985] dd40: ea4fde7c ea4fdd50 c027ee3c c054f4e0 ea25dc00 00000000 ea25dc40 c002b5d4 [ 5.058197] dd60: ea4fdd84 ea4fdd70 00000010 c002a0c4 ea25cc10 c0a509e8 ea4fdd9c c08a18f0 [ 5.066409] dd80: c08a6a54 ea46c240 60000193 00000000 ea46c1c0 ea4fdda0 c06aefd0 ea46c140 [ 5.074621] dda0: ea4b9480 00000001 00000009 ea4b9400 00000000 c0a218e8 ea4fdddc 00000000 [ 5.082833] ddc0: 00000000 ea4fddc4 ea4fddc4 ea25cc70 ea4c8000 ea4c7000 ea4c6000 ea4c5000 [ 5.091045] dde0: ea4c4000 ea4c3000 ea4c0000 ea4f3000 ea4fde84 ea4fde00 c0277f20 ea25cc10 [ 5.099257] de00: ea25cc70 00000004 ea4fde24 ea4fde18 ea4f2000 ea4f1000 ea4f0000 ea4ef000 [ 5.107470] de20: ea4ee000 ea4ed000 ea4ec000 ea4eb000 00000000 00000000 00000000 01000000 [ 5.115681] de40: 00000000 00000000 00000000 00000000 00000000 ea4b9480 00000009 c0a218e8 [ 5.123893] de60: 00000001 ea46d600 00000000 ea46d640 ea4fdeac ea4fde80 c0280744 c027ea90 [ 5.132104] de80: 00000000 00000000 c06d31cc c06d31cc ea4b9480 00000000 ea46d600 ea46d600 [ 5.140317] dea0: ea4fdecc ea4fdeb0 c028081c c0280720 ffffffff 0000005c 00000000 00001083 [ 5.148529] dec0: ea4fdf44 ea4fded0 c027fbbc c02807e0 c09b8ac0 00000400 c006df34 c006dc74 [ 5.156741] dee0: ea4fdf24 ea4fdef0 c007aa24 ea4fc000 ea0ffc40 a0000113 c027d544 00000000 [ 5.164953] df00: 00000000 00000000 ea4fdf2c ea4fdf18 c06ac18c c06abb38 00000002 ea46d600 [ 5.173164] df20: ea4d0880 ea46d600 c027d544 00000000 00000000 00000000 ea4fdf5c ea4fdf48 [ 5.181377] df40: c027d58c c027faf8 ea413240 00000000 ea4fdfac ea4fdf60 c0062654 c027d550 [ 5.189588] df60: ea4fdf94 00000000 c006a1e4 ea46d600 00000000 00000000 ea4fdf78 ea4fdf78 [ 5.197801] df80: 00000000 00000000 ea4fdf88 ea4fdf88 ea4d0880 c0062588 00000000 00000000 [ 5.206013] dfa0: 00000000 ea4fdfb0 c000ec20 c0062594 00000000 00000000 00000000 00000000 [ 5.214225] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.222438] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 c7f7977d ddf70798 [ 5.230645] Backtrace: [ 5.233114] [<c054ef34>] (omap_aes_gcm_crypt) from [<c054f4e8>] (omap_aes_gcm_encrypt+0x14/0x18) [ 5.241934] r10:c0a218e8 r9:ea4f2000 r8:ea4b9480 r7:00000001 r6:ea4c8000 r5:00000000 [ 5.249837] r4:00000000 [ 5.252393] [<c054f4d4>] (omap_aes_gcm_encrypt) from [<c027ee3c>] (__test_aead+0x3b8/0xdcc) [ 5.260782] [<c027ea84>] (__test_aead) from [<c0280744>] (test_aead+0x30/0xc0) [ 5.268032] r10:ea46d640 r9:00000000 r8:ea46d600 r7:00000001 r6:c0a218e8 r5:00000009 [ 5.275934] r4:ea4b9480 [ 5.278485] [<c0280714>] (test_aead) from [<c028081c>] (alg_test_aead+0x48/0xa8) [ 5.285909] r8:ea46d600 r7:ea46d600 r6:00000000 r5:ea4b9480 r4:c06d31cc [ 5.292680] [<c02807d4>] (alg_test_aead) from [<c027fbbc>] (alg_test+0xd0/0x27c) [ 5.300104] r7:00001083 r6:00000000 r5:0000005c r4:ffffffff [ 5.305824] [<c027faec>] (alg_test) from [<c027d58c>] (cryptomgr_test+0x48/0x50) [ 5.313248] r10:00000000 r9:00000000 r8:00000000 r7:c027d544 r6:ea46d600 r5:ea4d0880 [ 5.321147] r4:ea46d600 [ 5.323704] [<c027d544>] (cryptomgr_test) from [<c0062654>] (kthread+0xcc/0xe8) [ 5.331040] r4:00000000 r3:ea413240 [ 5.334649] [<c0062588>] (kthread) from [<c000ec20>] (ret_from_fork+0x14/0x34) [ 5.341899] r7:00000000 r6:00000000 r5:c0062588 r4:ea4d0880 [ 5.347614] Code: e50b3058 ebf4a73d e3a010d0 e1a06000 (e5900020) [ 5.353855] ---[ end trace 67f6162b39c3b0bb ]---
