Part Number: DRA72XEVM
Tool/software: Linux
I completed my yocto build with some errors, The yocto build created dtb's and zImage but didnt create a a rootfs. I am having some erros in my console is it because of that the rootfs build got failed. I was following this thread actually to build yocto e2e.ti.com/support/arm/automotive_processors/f/1020/t/696850
ERROR: input-utils-1.0-r0 do_compile: oe_runmake failed ERROR: input-utils-1.0-r0 do_compile: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/input-utils/1.0-r0/temp/log.do_compile.16039) ERROR: Logfile of failure stored in: /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/input-utils/1.0-r0/temp/log.do_compile.16039 Log data follows: | DEBUG: Executing shell function do_compile | NOTE: make -j 4 DESTDIR=/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/input-utils/1.0-r0/image STRIP= | Make.config:1: *** empty variable name. Stop. | ERROR: oe_runmake failed | ERROR: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/input-utils/1.0-r0/temp/log.do_compile.16039) ERROR: Task 1829 (/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-devtools/input-utils/input-utils_1.0.bb, do_compile) failed with exit code '1' ERROR: edma3-lld-rtos-2.12.05.30-r0.0 do_compile: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/edma3-lld-rtos/2.12.05.30-r0.0/temp/log.do_compile.16024) ERROR: Logfile of failure stored in: /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/edma3-lld-rtos/2.12.05.30-r0.0/temp/log.do_compile.16024 Log data follows: ERROR: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/edma3-lld-rtos/2.12.05.30-r0.0/temp/log.do_compile.16024) ERROR: Task 6733 (/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/meta-ti/recipes-bsp/edma3-lld/edma3-lld-rtos_git.bb, do_compile) failed with exit code '1' ERROR: openmp-rtos-2_06_00_00-r0 do_install: Function failed: do_install (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/openmp-rtos/2_06_00_00-r0/temp/log.do_install.16029) ERROR: Logfile of failure stored in: /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/openmp-rtos/2_06_00_00-r0/temp/log.do_install.16029 Log data follows: | DEBUG: Executing shell function do_install | cp: cannot overwrite directory '/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/openmp-rtos/2_06_00_00-r0/image/usr/share/ti/ti-omp-tree/.' with non-directory | WARNING: exit code 1 from a shell command. | ERROR: Function failed: do_install (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/openmp-rtos/2_06_00_00-r0/temp/log.do_install.16029) ERROR: Task 5163 (/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/meta-ti/recipes-ti/openmp-rtos/openmp-rtos_git.bb, do_install) failed with exit code '1' ERROR: ti-llvm3.6-3.6-r5 do_compile: oe_runmake failed ERROR: ti-llvm3.6-3.6-r5 do_compile: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/temp/log.do_compile.16025) ERROR: Logfile of failure stored in: /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/temp/log.do_compile.16025 | collect2: error: ld returned 1 exit status | /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/git/Makefile.rules:1199: recipe for target '/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/llvm-3.6.build/Release/lib/libLLVM-3.6.so' failed | make[1]: *** [/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/llvm-3.6.build/Release/lib/libLLVM-3.6.so] Error 1 | make[1]: Leaving directory '/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/llvm-3.6.build/tools/llvm-shlib' | /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/git/Makefile.rules:873: recipe for target 'all' failed | make: *** [all] Error 1 | WARNING: exit code 1 from a shell command. | ERROR: oe_runmake failed | ERROR: Function failed: do_compile (log file is located at /home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-llvm3.6/3.6-r5/temp/log.do_compile.16025) ERROR: Task 4943 (/home/ganesh/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-core/llvm/ti-llvm3.6_3.6.bb, do_compile) failed with exit code '1' NOTE: Tasks Summary: Attempted 7245 tasks of which 7241 didn't need to be rerun and 4 failed. NOTE: Writing buildhistory
The Whole build log 2337.build.txt
