Hi all,
I follow the (TDA2x USER GUIDE V02.10.00) to 3.5. Load using SD card. some errors occur like below when i run the sbl_mlo_create_tda2xx.bat.And then gennerate a wrong MLO and AppImage.
Microsoft Windows [版本 6.1.7601]
版权所有 (c) 2009 Microsoft Corporation。保留所有权利。
C:\Windows\system32>cd \VISION_SDK_02_10_00_00\vision_sdk\build\scripts
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>sbl_mlo_create_tda2xx.bat
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>REM Use profile passed from
command line, else us
e default as release
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set profile=
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>IF . == . (set profile=release )
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set TICOMPONENTSBASE=C:
sion_sdk\build\scripts\..\..\..\
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set STARTERWAREDIRNAME=C:
vision_sdk\build\scripts\..\..\..\\ti_components\drivers\starterware_01_06_00_16
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set Gcc_Tools_Path=C:
on_sdk\build\scripts\..\..\..\\ti_components\cg_tools\windows\gcc-arm-none-eabi-4_9-
2015q3\bin
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>REM <blank> or _opp_od or
_opp_high
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set OPPMODE=
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set Sbl_Tools_Path=C:
\starterware_01_06_00_16\bootloader\Tools\tiimag
e
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set Sbl_Elf_Path=C:
_sdk\build\scripts\..\..\..\\ti_components\drivers\starterware_01_06_00_16\binary
\sbl_sd\bin\tda2xx
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set Sbl_Out_Path=C:
_sdk\build\scripts\mlo_tda2xx
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>set Sbl_Out_Path_hs=C:
ion_sdk\build\scripts\mlo_tda2xx_hs
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>IF NOT EXIST C:
\build\scripts\mlo_tda2xx\ mkdir C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts
\mlo_tda2xx
\build\scripts\mlo_tda2xx_hs\ mkdir C:\VISION_SDK_02_10_00_00\vision_sdk\build
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>del C:
ripts\mlo_tda2xx\MLO
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>"C:
ts\..\..\..\\ti_components\cg_tools\windows\gcc-arm-none-eabi-4_9-2015q3\bin\arm-
none-eabi-objcopy.e
xe" --gap-fill=0xff -O binary C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts\..
\..\..\\ti_compon
ents\drivers\starterware_01_06_00_16\binary\sbl_sd\bin\tda2xx
\sbl_sd_a15host_release.xa15fg C:\VISIO
N_SDK_02_10_00_00\vision_sdk\build\scripts\mlo_tda2xx\SBL.bin
ts\..\..\..\\ti_components\drivers\starterware_01_06_00_16\bootloader\Tools\tiimage
\tiimage.exe" 0x4
0300000 LE C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts\mlo_tda2xx\SBL.bin C:
\VISION_SDK_02_10
_00_00\vision_sdk\build\scripts\mlo_tda2xx\SBL.tiimage
\tiimage.exe" 0xF
FFFFFFF LE C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts\mlo_tda2xx\SBL.bin C:
\VISION_SDK_02_10
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>ren C:
ripts\mlo_tda2xx\SBL.tiimage MLO
ripts\mlo_tda2xx_hs\SBL.tiimage unsigned_MLO
系统找不到指定的文件。(system can't find the document)
C:\VISION_SDK_02_10_00_00\vision_sdk\build\scripts>pause
请按任意键继续. . .
