VISION_SDK_02_10_00_00 installation problem xdc_configuro Error 139 segmentation fault after doing make -s -j
I am trying to install VISION_SDK_02_10_00_00 in Ubuntu machine 14.04 and followed the steps as mentioned in VisionSDK_LinuxUserGuide . I reached till make -s -j depend and the next step by the document is to do make -s -j but I encountered the following problem :
 Archiving tda2xx-evm:ipu2:release:vision_sdk_examples
# Invoking configuro...
Segmentation fault (core dumped)
make[5]: *** [xdc_configuro] Error 139
make[4]: *** [apps_dsp1] Error 2
make[4]: *** Waiting for unfinished jobs....
make[4]: *** [apps_eve3] Error 2
make[4]: *** [apps_dsp2] Error 2
make[4]: *** [apps_eve1] Error 2
make[4]: *** [apps_eve2] Error 2
make[4]: *** [apps_eve4] Error 2
make[3]: *** [apps] Error 2
make[2]: *** [apps] Error 2
make[1]: *** [vision_sdk_apps] Error 2
make: *** [vision_sdk] Error 2
Any help would be appreciated.
  • Hi Deepak,
    I have pinged a VisionSDK expert to comment.
    Yordan
  • can you just make and see if it still comes?
    Also please check if you have enough space. it should not segment fault.
    Brijesh
  • You can follow up this post, there is a workaround.
    e2e.ti.com/.../2226461
    add export JAVA_TOOL_OPTIONS=-Xss2560k or more to linux env for visionsdk.
  • did you made any changes on top of VISION_SDK_02_10_00_00?
    Or the issue is observed with VISION_SDK_02_10_00_00 original version?
  • original version.
    It is said that bug is caused by ubuntu 14.04 & 16.04 kernel upgrade(security fix) from 23th June. xdctools and ccsv7 also got affected.
  • It is original version ,no changes have been made.
    The day before I installed vision sdk and successfully built it (did make -s -j depend and make -s -j) on my colleague's PC which has same ubuntu version as mine 14.04 .But this issues comes in my PC only ,is it because of any ubuntu update?
  • I tried doing make ,the error still persists.
    I have enough space available in drive it's around 112 GB.
    I tried the below suggested workaround export JAVA_TOOL_OPTIONS=-Xss2560k.
    I did make clean and then did make linux ,make linux_install, make -s -j depend till here everything is ok,
    but when I did make -s -j got following set of errors :
    Picked up JAVA_TOOL_OPTIONS: -Xss1280k
    making package.mak (because of package.bld) ...
    # !!!  Current build platform is [tda2xx-evm] !!!
    # !!! Core is [arp32_2] !!!
    # !!! Core is [c66xdsp_1] !!!
    # !!! Core is [arp32_4] !!!
    # !!! Core is [c66xdsp_2] !!!
    # !!! Core is [arp32_3] !!!
    # !!! Core is [arp32_1] !!!
    gmake: *** Deleting file `package.mak'
    gmake: *** No rule to make target `linker.cmd'.  Stop.
    Warning: directory "/packages" on package path does not exist
    js: "/usr/local/VISION_SDK_02_10_00_00/ti_components/os_tools/linux/xdctools_3_32_00_06_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
  • Hi Yordan,
    I have posted the updated issue regarding building Vision SDK in the forum on Jun 27 .Please suggest, as I am stuck at the same place and tried out all the suggestions previously suggested.
  • Hi Yordan,
    I have found that mainly my xdc_tools is not working properly as it throws segmentation fault. This happens for xdc_tools which I have in my CCS also .So basically it has something to do with xdc_tools only. I have followed the same workaround of e2e.ti.com/.../2226461.But still no luck.
    Can u please suggest or redirect me to some expert.
    Deepak
    Pl. check with JAVA_TOOL_OPTIONS= -Xss2560k
    regards,
    Anand
    Solved the issue with downgrading the Ubuntu kernel version.
