Part Number: TDA2
Tool/software: Linux
I cannot run the openclframecopy usecase successfully. I have done Following steps:
1. clone kernel, uboot, cmem,sgx driver and target file system;
2. run hlos/scripts/linux/setup-linux-build-env.sh and ./hlos/scripts/linux/setup_linux.sh;
3. set git config;
4. git Opencl supported package;
5. MAKECONFIG = tda2xx_evm_linux_opencx;
6. my system path is :PATH="/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/cg_tools/linux/ti-cgt-c6000_8.1.0/bin:/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/open_compute/opencl_rtos_am57xx_01_01_10_00/packages/ti/clocl:/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/os_tools/linux/targetfs/usr/share/ti/opencl/bin/x86:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
7. KERNEL_INSTALL_DIR="/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/os_tools/linux/kernel"
8. cd /vision_sdk/build run "rm -rf ../binaries/";
9. make clean ; make liunx_clean; make -s -j dpend ; make -s -j opencx;
10. use uenv_sd.txt as uenv.txt;
There is no error in the above steps .
But it cannot run success on the target.
Below is my running log:
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
=> pri
arch=arm
args_fit=setenv bootargs console=${console}
args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
baudrate=115200
board=dra7xx
board_name=dra7xx
board_rev=H.0
boot_fdt=try
boot_fit=0
boot_os=0
bootargs=androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard
bootcmd=if test ${dofastboot} -eq 1; then echo Boot fastboot requested, resetting dofastboot ...;setenv dofastboot 0; saveenv;echo Booting into fastboot ...; fastboot 0; fi;if test ${boot_fit} -eq 1; then run update_to_fit;fi;run findfdt; run envboot; run mmcboot;run emmc_android_boot;
bootdelay=2
bootdir=/boot
bootenvfile=uEnv.txt
bootfile=zImage
bootm_size=0x10000000
bootpart=0:2
bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
console=ttyO0,115200n8
cpu=armv7
dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 1 1;spl-os-image fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1
dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 0 1;spl-os-image fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1
dfu_alt_info_qspi=MLO raw 0x0 0x040000;u-boot.img raw 0x040000 0x0100000;u-boot-spl-os raw 0x140000 0x080000;u-boot-env raw 0x1C0000 0x010000;u-boot-env.backup raw 0x1D0000 0x010000;kernel raw 0x1E0000 0x800000
dfu_alt_info_ram=kernel ram 0x80200000 0x4000000;fdt ram 0x80f80000 0x80000;ramdisk ram 0x81000000 0x4000000
dfu_bufsiz=0x10000
dofastboot=0
emmc_android_boot=setenv eval_bootargs setenv bootargs $bootargs; run eval_bootargs; setenv mmcdev 1; setenv fdt_part 3; setenv boot_part 9; if test $reboot_image = recovery; then setenv boot_part 8; setenv reboot_image boot; saveenv; fi;setenv machid fe6; mmc dev $mmcdev; mmc rescan; part start mmc ${mmcdev} ${fdt_part} fdt_start; part size mmc ${mmcdev} ${fdt_part} fdt_size; part start mmc ${mmcdev} ${boot_part} boot_start; part size mmc ${mmcdev} ${boot_part} boot_size; mmc read ${fdtaddr} ${fdt_start} ${fdt_size}; mmc read ${loadaddr} ${boot_start} ${boot_size}; echo Booting from eMMC ...; bootm $loadaddr $loadaddr $fdtaddr;
envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootscript; then run bootscript;else if run loadbootenv; then echo Loaded env from ${bootenvfile};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;fi;fi;
ethaddr=7c:38:66:a1:e2:a6
fastboot.board_rev=H.0
fastboot.cpu=J6
fastboot.secure=GP
fastboot.userdata_size=unknown
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtcontroladdr=fdf0a598
fdtfile=undefined
findfdt=if test $board_name = omap5_uevm; then setenv fdtfile omap5-uevm.dtb; fi; if test $board_name = dra7xx; then setenv fdtfile dra7-evm.dtb; fi;if test $board_name = dra72x-revc; then setenv fdtfile dra72-evm-revc.dtb; fi;if test $board_name = dra72x; then setenv fdtfile dra72-evm.dtb; fi;if test $board_name = dra71x; then setenv fdtfile dra71-evm.dtb; fi;if test $board_name = dra76x; then setenv fdtfile dra76-evm.dtb; fi;if test $board_name = beagle_x15; then setenv fdtfile am57xx-beagle-x15.dtb; fi;if test $board_name = beagle_x15_revb1; then setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;if test $board_name = am57xx_evm; then setenv fdtfile am57xx-evm.dtb; fi;if test $board_name = am57xx_evm_reva3; then setenv fdtfile am57xx-evm-reva3.dtb; fi;if test $board_name = am572x_idk && test $idk_lcd = no; then setenv fdtfile am572x-idk.dtb; fi;if test $board_name = am572x_idk && test $idk_lcd = osd101t2045; then setenv fdtfile am572x-idk-lcd-osd.dtb; fi;if test $board_name = am572x_idk && test $idk_lcd = osd101t2587; then setenv fdtfile am572x-idk-lcd-osd101t2587.dtb; fi;if test $board_name = am571x_idk && test $idk_lcd = no; then setenv fdtfile am571x-idk.dtb; fi;if test $board_name = am571x_idk && test $idk_lcd = osd101t2045; then setenv fdtfile am571x-idk-lcd-osd.dtb; fi;if test $board_name = am571x_idk && test $idk_lcd = osd101t2587; then setenv fdtfile am571x-idk-lcd-osd101t2587.dtb; fi;if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi;
finduuid=part uuid mmc ${bootpart} uuid
fit_bootfile=fitImage.itb
fit_loadaddr=0x88000000
importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
kernel_addr_r=0x82000000
loadaddr=0x82000000
loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr
loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
loadfit=run args_fit; bootm ${loadaddr}#${fdtfile};
loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
mmcboot=if mmc dev ${mmcdev}; then setenv devtype mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then run loadfdt; echo Booting from mmc${mmcdev} ...; run args_mmc; bootz ${loadaddr} - ${fdtaddr}; fi; fi; fi;
mmcdev=0
mmcloados=run args_mmc; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcrootfstype=ext4 rootwait
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
netboot=echo Booting from network ...; setenv autoload no; dhcp; run netloadimage; run netloadfdt; run netargs; bootz ${loadaddr} - ${fdtaddr}
netloadfdt=tftp ${fdtaddr} ${fdtfile}
netloadimage=tftp ${loadaddr} ${bootfile}
nfsopts=nolock
partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}
partitions_android=uuid_disk=${uuid_gpt_disk};name=xloader,start=128K,size=256K,uuid=${uuid_gpt_xloader};name=bootloader,size=2304K,uuid=${uuid_gpt_bootloader};name=environment,size=256K,uuid=${uuid_gpt_environment};name=misc,size=128K,uuid=${uuid_gpt_misc};name=reserved,size=384K,uuid=${uuid_gpt_reserved};name=efs,size=16M,uuid=${uuid_gpt_efs};name=crypto,size=16K,uuid=${uuid_gpt_crypto};name=recovery,size=10M,uuid=${uuid_gpt_recovery};name=boot,size=10M,uuid=${uuid_gpt_boot};name=system,size=768M,uuid=${uuid_gpt_system};name=vendor,size=256M,uuid=${uuid_gpt_vendor};name=cache,size=256M,uuid=${uuid_gpt_cache};name=ipu1,size=8M,uuid=${uuid_gpt_ipu1};name=ipu2,size=8M,uuid=${uuid_gpt_ipu2};name=dsp1,size=8M,uuid=${uuid_gpt_dsp1};name=dsp2,size=8M,uuid=${uuid_gpt_dsp2};name=userdata,size=-,uuid=${uuid_gpt_userdata}
pxefile_addr_r=0x80100000
ramdisk_addr_r=0x88080000
rdaddr=0x88080000
reboot_image=boot
rootpath=/export/rootfs
scriptaddr=0x80000000
scsidevs=0
serial#=0b0140144bb600a2
soc=omap5
static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
stderr=serial@4806a000
stdin=serial@4806a000
stdout=serial@4806a000
update_to_fit=setenv loadaddr ${fit_loadaddr}; setenv bootfile ${fit_bootfile}
usbtty=cdc_acm
vendor=ti
ver=U-Boot 2016.05-00008-g1fbee98 (Jun 07 2018 - 20:31:19 +0800)
vram=16M
Environment size: 7470/131067 bytes
=> env default -fa
## Resetting to default environment
=> saveenv
Saving Environment to MMC...
Writing to redundant MMC(1)... done
=> reboot
Unknown command 'reboot' - try 'help'
=> boot
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
165 bytes read in 2 ms (80.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3552160 bytes read in 110 ms (30.8 MiB/s)
106665 bytes read in 15 ms (6.8 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3633a0 ]
Loading Device Tree to 8ffe2000, end 8ffff0a8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84-00018-gd326d64 (hancan@hancan-virtual-machine) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Thu Jun 7 20:42:56 CST 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA742
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef62b000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243264
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=2ca9f500-02 rw rootwait ip=none mem=1024M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 410844K/979968K available (6619K kernel code, 319K rwdata, 2388K rodata, 340K init, 290K bss, 364324K reserved, 204800K cma-reserved, 234496K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d402c (9009 kB)
[ 0.000000] .init : 0xc08d5000 - 0xc092a000 ( 340 kB)
[ 0.000000] .data : 0xc092a000 - 0xc0979d60 ( 320 kB)
[ 0.000000] .bss : 0xc097b000 - 0xc09c3800 ( 290 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000329] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000337] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000772] Console: colour dummy device 80x30
[ 0.000787] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000794] This ensures that you still see kernel messages. Please
[ 0.000799] update your kernel commandline.
[ 0.000813] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000825] pid_max: default: 32768 minimum: 301
[ 0.000921] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000931] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001474] Initializing cgroup subsys io
[ 0.001490] Initializing cgroup subsys memory
[ 0.001514] Initializing cgroup subsys devices
[ 0.001526] Initializing cgroup subsys freezer
[ 0.001537] Initializing cgroup subsys perf_event
[ 0.001548] Initializing cgroup subsys pids
[ 0.001575] CPU: Testing write buffer coherency: ok
[ 0.001777] /cpus/cpu@0 missing clock-frequency property
[ 0.001792] /cpus/cpu@1 missing clock-frequency property
[ 0.001802] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001834] Setting up static identity map for 0x80008380 - 0x800083e0
[ 0.080058] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080128] Brought up 2 CPUs
[ 0.080141] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080147] CPU: All CPU(s) started in HYP mode.
[ 0.080152] CPU: Virtualization extensions available.
[ 0.080531] devtmpfs: initialized
[ 0.109242] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.110221] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.313080] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.313100] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.317325] pinctrl core: initialized pinctrl subsystem
[ 0.318175] NET: Registered protocol family 16
[ 0.319103] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.340217] cpuidle: using governor ladder
[ 0.370245] cpuidle: using governor menu
[ 0.378708] OMAP GPIO hardware version 0.1
[ 0.385082] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.401068] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.401081] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.410323] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.410334] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.410795] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.410805] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.411376] OMAP DMA hardware revision 0.0
[ 0.451372] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452531] edma 43300000.edma: memcpy is disabled
[ 0.457176] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.461567] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461744] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.461910] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.462064] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.462353] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.462539] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.465540] palmas 0-0058: IRQ missing: skipping irq request
[ 0.480976] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[ 0.553288] pcf857x 0-0020: probed
[ 0.553850] pcf857x 0-0021: probed
[ 0.554000] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.554391] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.554596] media: Linux media interface: v0.10
[ 0.554647] Linux video capture interface: v2.00
[ 0.554690] pps_core: LinuxPPS API ver. 1 registered
[ 0.554697] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.554721] PTP clock support registered
[ 0.554766] EDAC MC: Ver: 3.0.0
[ 0.555511] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.555809] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.556139] Advanced Linux Sound Architecture Driver Initialized.
[ 0.556976] clocksource: Switched to clocksource arch_sys_counter
[ 0.567594] NET: Registered protocol family 2
[ 0.568088] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.568151] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.568276] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.568322] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.568353] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.568562] NET: Registered protocol family 1
[ 0.568831] RPC: Registered named UNIX socket transport module.
[ 0.568840] RPC: Registered udp transport module.
[ 0.568847] RPC: Registered tcp transport module.
[ 0.568853] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.569851] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.579807] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.580457] NFS: Registering the id_resolver key type
[ 0.580484] Key type id_resolver registered
[ 0.580492] Key type id_legacy registered
[ 0.580545] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.581805] bounce: pool size: 64 pages
[ 0.581952] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.581965] io scheduler noop registered
[ 0.581977] io scheduler deadline registered
[ 0.582010] io scheduler cfq registered (default)
[ 0.586905] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.590173] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.590186] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.590219] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.590241] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.620429] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.620605] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.620618] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.620628] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.620638] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.621042] PCI: bus0: Fast back to back transfers disabled
[ 0.621160] PCI: bus1: Fast back to back transfers enabled
[ 0.621242] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.621257] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.621270] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.621489] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.681968] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.685355] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 1.695337] console [ttyS0] enabled
[ 1.699736] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 1.709441] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[ 1.719491] [drm] Initialized drm 1.1.0 20060810
[ 1.725499] OMAP DSS rev 6.1
[ 1.729295] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.745084] loop: module loaded
[ 1.748626] vmemexp device MAJOR num = 246
[ 1.752755] vmemexp class registered
[ 1.756467] /dev/vmemexp device registered
[ 1.760602] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 1.766274] nand: No NAND device found
[ 1.770064] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[ 1.780008] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
[ 1.785405] 7 ofpart partitions found on MTD device spi32766.0
[ 1.791288] Creating 7 MTD partitions on "spi32766.0":
[ 1.796451] 0x000000000000-0x000000040000 : "QSPI.SPL"
[ 1.802569] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 1.808925] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 1.815850] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 1.822557] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 1.829958] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 1.836301] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 1.844100] libphy: Fixed MDIO Bus: probed
[ 1.897007] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.903132] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[ 1.913632] libphy: 48485000.mdio: probed
[ 1.917704] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 1.925746] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 1.934473] cpsw 48484000.ethernet: Detected MACID = 7c:38:66:a1:e2:a6
[ 1.941169] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 1.948182] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:38:66:a1:e2:a7
[ 1.956804] mousedev: PS/2 mouse device common for all mice
[ 1.963036] i2c /dev entries driver
[ 1.971772] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.977389] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.983773] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 1.990332] evm_3v3_sw: supplied by sysen1
[ 2.070762] mmc0: MAN_BKOPS_EN bit is not set
[ 2.107563] mmc0: new HS200 MMC card at address 0001
[ 2.123001] mmcblk0: mmc0:0001 MMC08G 7.25 GiB
[ 2.138059] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB
[ 2.144243] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB
[ 2.151978] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.160720] aic_dvdd: supplied by evm_3v3_sw
[ 2.166623] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[ 2.174329] NET: Registered protocol family 10
[ 2.179735] sit: IPv6 over IPv4 tunneling driver
[ 2.184944] NET: Registered protocol family 17
[ 2.189669] Key type dns_resolver registered
[ 2.194071] omap_voltage_late_init: Voltage driver support not added
[ 2.200999] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.207230] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.213938] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.220191] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.228443] Power Management for TI OMAP4+ devices.
[ 2.233519] Registering SWP/SWPB emulation handler
[ 2.240461] dmm 4e000000.dmm: initialized all PAT entries
[ 2.247819] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.254460] [drm] No driver support for vblank timestamp query.
[ 2.260815] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.267669] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.308218] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 2.327906] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 2.334795] hctosys: unable to open rtc device (rtc0)
[ 2.348137] evm_1v8: disabling
[ 2.351220] aic_dvdd: disabling
[ 2.354379] vmmcwl_fixed: disabling
[ 2.358073] ldousb: disabling
[ 2.361473] ALSA device list:
[ 2.364452] #0: DRA7xx-EVM
[ 2.367999] Waiting for root device PARTUUID=2ca9f500-02...
[ 2.566831] mmc2: host does not support reading read-only switch, assuming write-enable
[ 2.581884] mmc2: new ultra high speed DDR50 SDHC card at address aaaa
[ 2.598785] mmcblk1: mmc2:aaaa SS08G 7.40 GiB
[ 2.608384] mmcblk1: p1 p2
[ 2.700446] EXT4-fs (mmcblk1p2): couldn't mount as ext3 due to feature incompatibilities
[ 2.711919] EXT4-fs (mmcblk1p2): couldn't mount as ext2 due to feature incompatibilities
[ 3.649335] EXT4-fs (mmcblk1p2): recovery complete
[ 3.655107] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.663289] VFS: Mounted root (ext4 filesystem) on device 179:50.
[ 3.674130] devtmpfs: mounted
[ 3.677382] Freeing unused kernel memory: 340K
[ 3.681843] This architecture does not have kernel memory protection.
[ 3.807209] systemd[1]: System time before build time, advancing clock.
[ 3.842182] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 3.857727] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 3.873367] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.891880] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 3.921000] systemd[1]: Set hostname to <dra7xx-evm>.
[ 3.978497] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 3.990435] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 3.997224] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 4.025881] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 4.042360] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 4.120504] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 4.129985] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 4.139825] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 4.468095] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
[ 4.475884] systemd[1]: sockets.target: Found dependency on dbus.socket/start
[ 4.483108] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[ 4.490560] systemd[1]: sockets.target: Found dependency on alignment.service/start
[ 4.498293] systemd[1]: sockets.target: Found dependency on basic.target/start
[ 4.505548] systemd[1]: sockets.target: Found dependency on sockets.target/start
[ 4.512998] systemd[1]: sockets.target: Breaking ordering cycle by deleting job dbus.socket/start
[ 4.521929] systemd[1]: dbus.socket: Job dbus.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping D-Bus System Message Bus Socket
[ 4.557398] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
[ 4.565184] systemd[1]: sockets.target: Found dependency on rpcbind.socket/start
[ 4.572661] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[ 4.580130] systemd[1]: sockets.target: Found dependency on alignment.service/start
[ 4.587867] systemd[1]: sockets.target: Found dependency on basic.target/start
[ 4.595125] systemd[1]: sockets.target: Found dependency on sockets.target/start
[ 4.602592] systemd[1]: sockets.target: Breaking ordering cycle by deleting job rpcbind.socket/start
[ 4.611803] systemd[1]: rpcbind.socket: Job rpcbind.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping RPCbind Server Activation Socket
[ 4.637317] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
[ 4.645101] systemd[1]: sockets.target: Found dependency on avahi-daemon.socket/start
[ 4.653015] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[ 4.660481] systemd[1]: sockets.target: Found dependency on alignment.service/start
[ 4.668218] systemd[1]: sockets.target: Found dependency on basic.target/start
[ 4.675475] systemd[1]: sockets.target: Found dependency on sockets.target/start
[ 4.682942] systemd[1]: sockets.target: Breaking ordering cycle by deleting job avahi-daemon.socket/start
[ 4.692590] systemd[1]: avahi-daemon.socket: Job avahi-daemon.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping Avah...S/DNS-SD Stack Activation Socket
[ 4.727345] systemd[1]: dropbear.socket: Found ordering cycle on dropbear.socket/stop
[ 4.735216] systemd[1]: dropbear.socket: Found dependency on sysinit.target/start
[ 4.742781] systemd[1]: dropbear.socket: Found dependency on alignment.service/start
[ 4.750598] systemd[1]: dropbear.socket: Found dependency on basic.target/start
[ 4.758002] systemd[1]: dropbear.socket: Found dependency on sockets.target/start
[ 4.765520] systemd[1]: dropbear.socket: Found dependency on dropbear.socket/stop
[ 4.773075] systemd[1]: dropbear.socket: Breaking ordering cycle by deleting job alignment.service/start
[ 4.782636] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with dropbear.socket/stop
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 4.820458] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.847295] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.867357] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.887254] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.907263] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.927225] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.947223] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.967324] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.997313] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.028394] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 5.077428] systemd[1]: Starting Journal Service...
[ 5.107907] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.187335] systemd[1]: Mounting Temporary Directory...
[ 5.209453] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.244658] systemd[1]: Starting Load Kernel Modules...
[ 5.269357] systemd[1]: Mounting Debug File System...
[ 5.299520] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 5.327844] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 5.387308] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.404701] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 5.410440] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 5.438622] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.457179] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.477182] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.497227] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.547349] systemd[1]: Starting Setup Virtual Console...
[ 5.573372] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 5.597238] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 5.617319] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 5.647409] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Setup Virtual Console.
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 6.269836] systemd-journald[117]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ 6.645296] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 6.671979] remoteproc0: 55020000.ipu is available
[ 6.684290] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 6.705705] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.740884] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 6.759524] remoteproc1: 40800000.dsp is available
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ 6.781929] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 6.795057] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
Starting Create Volatile Files and Directories...
[ 6.826685] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 6.850174] remoteproc2: 41000000.dsp is available
[ 6.865408] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 6.888574] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Found device /dev/ttyS0.
[ 6.942505] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 6.957989] remoteproc0: registered virtio0 (type 7)
[ 6.982793] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ 7.068743] remoteproc1: registered virtio1 (type 7)
[ 7.084233] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[ 7.158582] remoteproc2: registered virtio2 (type 7)
Starting Update UTMP about System Boot/Shutdown...
[ 7.262284] SCSI subsystem initialized
Starting Network Time Synchronization...
[ 7.339781] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ OK ] Started Network Time Synchronization.
[ 7.406262] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ OK ] Started Update UTMP about System Boot/Shutdown.[ 7.417726] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 7.440443] CAN device driver interface
[ 7.517218] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=358)
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Synchronize System and HW clocks.
[ 7.590342] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 7.607359] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 7.628143] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 7.661923] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 7.776003] scsi host0: ahci
[ 7.779739] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 7.969023] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting Print notice about GPLv3 packages...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting Save/Restore Sound Card State...
Starting uim-sysfs.service...
Starting TI MultiCore Tools Daemon...
[ OK ] Started System Logging Service.
Starting Permit User Sessions...
Starting Network Service...
[ OK ] Started Kernel Logging Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Permit User Sessions.
[ 8.157037] ata1: SATA link down (SStatus 0 SControl 300)
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[ 8.195868] net eth1: initializing cpsw version 1.15 (0)
[ OK ] Started Network Service.
[ 8.234583] net eth0: initialized cpsw ale version 1.4
[ 8.263256] net eth0: ALE Table size 1024
[ 8.293195] NET: Registered protocol family 15
[ 8.318197] net eth1: phy found : id is : 0x20005c7a
[ 8.371771] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.411130] net eth0: initializing cpsw version 1.15 (0)
[ 8.454059] net eth0: phy found : id is : 0x20005c7a
[ 8.499265] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.594856] Initializing XFRM netlink socket
[ 8.949514] remoteproc0: powering up 55020000.ipu
[ 8.969231] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 3506540
[ 8.986247] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 9.040504] remoteproc0: remote processor 55020000.ipu is now up
[ 9.058215] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.072003] remoteproc1: powering up 40800000.dsp
[ 9.082869] random: nonblocking pool is initialized
[ 9.089121] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[ 9.098842] remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 2851415
[ 9.118291] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 9.124176] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 9.130114] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 9.177883] remoteproc1: remote processor 40800000.dsp is now up
[ 9.192761] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 9.198343] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
[ 9.214629] remoteproc2: powering up 41000000.dsp
[ 9.231706] remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 2851415
[ 9.253303] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 9.259191] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 9.265153] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Sound Card.
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Network Name Resolution...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ 9.333515] remoteproc2: remote processor 41000000.dsp is now up
[ 9.352288] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 9.357869] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 9.396790] NET: Registered protocol family 41
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Network Name Resolution.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ 9.802990] usbcore: registered new interface driver usbfs
[ 9.815713] usbcore: registered new interface driver hub
[ 9.821311] usbcore: registered new device driver usb
[ 9.875783] dwc3 48890000.usb: otg: primary host xhci-hcd.0.auto registered
[ 9.882994] dwc3 48890000.usb: otg: shared host xhci-hcd.0.auto registered
[ 9.891959] dwc3 48890000.usb: otg: can't start till gadget registers
[ 9.898961] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ 9.899590] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 9.899610] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 9.919300] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 9.928175] xhci-hcd xhci-hcd.1.auto: irq 500, io mem 0x488d0000
[ 9.934831] hub 1-0:1.0: USB hub found
[ 9.941470] hub 1-0:1.0: 1 port detected
[ 9.945820] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 9.953060] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 9.962386] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 9.972707] hub 2-0:1.0: USB hub found
[ 9.976564] hub 2-0:1.0: 1 port detected
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
Starting tiipclad-daemon.service...
[ OK ] Started telnetd.service.
[ OK ] Started tiipclad-daemon.service.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting gdbserverproxy.service...
[ OK ] Started gdbserverproxy.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ 10.454575] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 10.462890] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils-dev
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gstreamer1.0-libav
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
parted
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: root
root@dra7xx-evm:~# [ 19.194447] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
[ 19.208354] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 20.084449] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
[ 20.098354] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~# root
-sh: root: command not found
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~#
root@dra7xx-evm:~# cd /opt/vision_sdk/
root@dra7xx-evm:/opt/vision_sdk# ls
FragShader.fsh VipClockInversion.sh cmemk.ko enableIpu2CCSConectivity.sh load_ocl_kos.sh opencl_env.sh ub964Init.sh
FragShader3Dsfm.fsh apps.out debugss_kmodule.ko gdbserverproxy.ko memcache_load.sh ov106x3Config.sh vision_sdk_load.sh
VertShader.vsh bin disableDssInterruptsOnA15.sh hdmiReceiverConfig.sh memcache_unload.sh pvrscope vision_sdk_ov490_pinmux.sh
VertShader3Dsfm.vsh car.pod enableImx290.sh jeep2.bmp models tda2exEnableAVB.sh vision_sdk_unload.sh
root@dra7xx-evm:/opt/vision_sdk# ./load_ocl_kos.sh
Opened log file: lad.txt
numProcessors = 5 id = 0 baseId = 0
Spawned daemon: /usr/bin/lad_dra7xx
[ 49.788875] CMEMK module: reference Linux version 4.4.84
[ 49.794888] allocated heap buffer 0x40400000 of size 0x100000
[ 49.801212] cmemk initialized
root@dra7xx-evm:/opt/vision_sdk# source ./vision_sdk_load.sh
[ 71.469463] DMA: Module install successful, device major num = 242
[ 71.475909] DRV: Module install successful
insmod: ERROR: could not insert module ./bin/cmemk.ko: File exists
./disableDssInterruptsOnA15.sh: line 11: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 12: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 13: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 14: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 15: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 16: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 17: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 18: @0x4A002AC4:: command not found
./disableDssInterruptsOnA15.sh: line 19: @0x4A002AC4:: command not found
updated 0x4A002AC4 value is 00930000
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
[HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb65af000 of size 0x00100000
[HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa6baf000 of size 0x0fa00000
[HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa6aef000 of size 0x00040000
[HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa6b2f000 of size 0x00080000
[HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
[HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
[HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
80.228166] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[ 80.265311] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[ HOST] [HOST ] 143.146098 s: SYSTEM: System A15 Init in proress !!!
[HOST] [HOST ] 143.146190 s: SYSTEM: IPC: Init in progress !!!
[HOST] [HOST ] 143.146190 s: SYSTEM: IPC: Notify init in progress !!!
[HOST] [HOST ] 143.147501 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
[HOST] [HOST ] 143.147532 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 143.147593 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
[HOST] [HOST ] 143.147593 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 143.147715 s: SYSTEM: IPC: Notify init DONE !!!
[HOST] [HOST ] 143.147745 s: SYSTEM: MSGQ: MsgQ init in progress !!!
[HOST] [HOST ] 143.147837 s: SYSTEM: MSGQ: MsgQ init DONE !!!
[HOST] [HOST ] 143.147837 s: SYSTEM: IPC: Init DONE !!!
[HOST] [HOST ] 143.147837 s: SYSTEM: Initializing A15 Links !!!
[HOST] [HOST ] 143.147959 s: IPC_OUT_0 : Init done - linkid-0x2000000
[HOST] [HOST ] 143.148081 s: IPC_OUT_1 : Init done - linkid-0x2000001
[HOST] [HOST ] 143.148173 s: IPC_OUT_2 : Init done - linkid-0x2000002
[HOST] [HOST ] 143.148264 s: IPC_OUT_3 : Init done - linkid-0x2000003
[HOST] [HOST ] 143.148478 s: IPC_OUT_4 : Init done - linkid-0x2000004
[HOST] [HOST ] 143.148600 s: IPC_IN_0 : Init done - linkid-0x200000a
[HOST] [HOST ] 143.148722 s: IPC_IN_1 : Init done - linkid-0x200000b
[HOST] [HOST ] 143.148844 s: IPC_IN_2 : Init done - linkid-0x200000c
[HOST] [HOST ] 143.148935 s: IPC_IN_3 : Init done - linkid-0x200000d
[HOST] [HOST ] 143.149057 s: IPC_IN_4 : Init done - linkid-0x200000e
[HOST] [HOST ] 143.149149 s: IPC_IN_5 : Init done - linkid-0x200000f
[HOST] [HOST ] 143.149271 s: IPC_IN_6 : Init done - linkid-0x2000010
[HOST] [HOST ] 143.149362 s: NULL_0 : Init done - linkid-0x2000014
[HOST] [HOST ] 143.149454 s: NULL_1 : Init done - linkid-0x2000015
[HOST] [HOST ] 143.149576 s: NULL_SRC_0 : Init done - linkid-0x2000039
[HOST] [HOST ] 143.149667 s: ALGORITHM_0 : Init done - linkid-0x2000031
[HOST] [HOST ] 143.149789 s: ALGORITHM_1 : Init done - linkid-0x2000032
[HOST] [HOST ] 143.149881 s: ALGORITHM_2 : Init done - linkid-0x2000033
[HOST] [HOST ] 143.150003 s: ALGORITHM_3 : Init done - linkid-0x2000034
[HOST] [HOST ] 143.150094 s: ALGORITHM_4 : Init done - linkid-0x2000035
[HOST] [HOST ] 143.150186 s: ALGORITHM_5 : Init done - linkid-0x2000036
[HOST] [HOST ] 143.150277 s: ALGORITHM_6 : Init done - linkid-0x2000037
[HOST] [HOST ] 143.150369 s: ALGORITHM_7 : Init done - linkid-0x2000038
[HOST] [HOST ] 143.150552 s: DUP0 : Init done - linkid-0x0
[HOST] [HOST ] 143.150704 s: DUP1 : Init done - linkid-0x0
[HOST] [HOST ] 143.150857 s: DUP2 : Init done - linkid-0x0
[HOST] [HOST ] 143.151040 s: DUP3 : Init done - linkid-0x0
[HOST] [HOST ] 143.151192 s: DUP4 : Init done - linkid-0x0
[HOST] [HOST ] 143.151284 s: SYNC_0 : Init done - linkid-0x0
[HOST] [HOST ] 143.151436 s: SYNC_1 : Init done - linkid-0x0
[HOST] [HOST ] 143.151589 s: SYNC_2 : Init done - linkid-0x0
[HOST] [HOST ] 143.151741 s: SYNC_3 : Init done - linkid-0x0
[HOST] [HOST ] 143.151924 s: MERGE_0 : Init done - linkid-0x0
[HOST] [HOST ] 143.155005 s: MERGE_1 : Init done - linkid-0x0
[HOST] [HOST ] 143.155127 s: MERGE_2 : Init done - linkid-0x0
[HOST] [HOST ] 143.155249 s: MERGE_3 : Init done - linkid-0x0
[HOST] [HOST ] 143.155523 s: MERGE_4 : Init done - linkid-0x0
[HOST] [HOST ] 143.155645 s: SELECT_0 : Init done - linkid-0x0
[HOST] [HOST ] 143.155767 s: SELECT_1 : Init done - linkid-0x0
[HOST] [HOST ] 143.155859 s: GATE_0 : Init done - linkid-0x0
[HOST] [HOST ] 143.155950 s: GATE_1 : Init done - linkid-0x0
[HOST] [HOST ] 143.156011 s: GATE_2 : Init done - linkid-0x0
[HOST] [HOST ] 143.156103 s: GATE_3 : Init done - linkid-0x0
[HOST] [HOST ] 143.157201 s: SGXFRMCPY_0 : Init done - linkid-0x2000040
[HOST] [HOST ] 143.157231 s: SYSTEM: Initializing A15 Links ... DONE !!!
[HOST] [HOST ] 143.157689 s: OSA: Adjusting global time, timeH by 0 units!!!
[HOST] [HOST ] 143.157689 s: SYSTEM: System A15 Init Done !!!
[HOST] [HOST ] 143.157841 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[HOST] [HOST ] 143.157902 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[HOST] [IPU2 ] 72.002958 s: ***** IPU2 Firmware build time 20:58:27 Jun 7 2018
[HOST] [IPU2 ] 72.003141 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[HOST] [IPU2 ] 72.006008 s: SYSTEM: System Common Init in progress !!!
[HOST] [IPU2 ] 72.014975 s: SYSTEM: IPC init in progress !!!
[HOST] [IPU2 ] 72.015097 s: SYSTEM: Notify init done !!!
[HOST] [IPU2 ] 72.016836 s: SYSTEM: MsgQ init done !!!
[HOST] [IPU2 ] 72.017781 s: RpmsgInit in progress...
[HOST] [IPU2 ] 72.017842 s: Connection established with HLOS, calling rpmsgInit
[HOST] [IPU2 ] 72.018513 s: SYSTEM: IPC init DONE !!!
[HOST] [IPU2 ] 72.023607 s: SYSTEM: System Common Init Done !!!
[HOST] [IPU2 ] 72.023699 s: SYSTEM: System Init in progress !!!
[HOST] [IPU2 ] 72.023790 s: SYSTEM: BSP Common Init in progress !!!
[HOST] [IPU2 ] 72.023851 s: SYSTEM: BSP Common Init Done !!!
[HOST] [IPU2 ] 72.023912 s: SYSTEM: BSP Platform Init in progress !!!
[HOST] [IPU2 ] 72.024004 s: SYSTEM: BSP Platform Init Done !!!
[HOST] [IPU2 ] 72.024065 s: SYSTEM: FVID2 Init in progress !!!
[HOST] [IPU2 ] 72.024217 s: SYSTEM: FVID2 Init Done !!!
[HOST] [IPU2 ] 72.024278 s: SYSTEM: VPS Init in progress !!!
[HOST] [IPU2 ] 72.024370 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[HOST] [IPU2 ] 72.027176 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 72.027298 s: VPDMA Firmware Address = 0xa0349a80
[HOST] [IPU2 ] 72.027450 s: VPDMA Load Address = 0x4897d004
[HOST] [IPU2 ] 72.027542 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 72.027633 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 72.027694 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 72.028030 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 72.028121 s: VPDMA Firmware Address = 0xa0349a80
[HOST] [IPU2 ] 72.028213 s: VPDMA Load Address = 0x4899d004
[HOST] [IPU2 ] 72.028304 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 72.028396 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 72.028487 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 72.028792 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 72.028884 s: VPDMA Firmware Address = 0xa0349a80
[HOST] [IPU2 ] 72.028975 s: VPDMA Load Address = 0x489bd004
[HOST] [IPU2 ] 72.029067 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 72.029158 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 72.029219 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 72.082779 s: SYSTEM: VPS Init Done !!!
[HOST] [IPU2 ] 72.083633 s: UTILS: DMA: HWI Create for INT25 !!!
[HOST] [IPU2 ] 72.083877 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [IPU2 ] 72.083968 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260728 B (254 KB)
[HOST] [IPU2 ] 72.084121 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 72.084273 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 262144000 B (250 MB)
[HOST] [IPU2 ] 72.084517 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[HOST] [IPU2 ] 72.084670 s: SYSTEM: Initializing Links !!!
[HOST] [IPU2 ] 72.233697 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [IPU2 ] 72.234368 s: CHAINS: Application Started !!!
[HOST] [IPU2 ] 72.243183 s: BOARD: Board Init in progress !!!
[HOST] [IPU2 ] 72.243640 s: BOARD: Board Init Done !!!
[HOST] [IPU2 ] 72.250594 s:
[HOST] [HOST ] 143.704508 s:
[HOST] [HOST ]
[HOST] [HOST ] ====================
[HOST] [HOST ] Vision SDK Usecases
[HOST] [HOST ] 1: Single Camera Usecases
[HOST] [HOST ] 2: Multi-Camera LVDS Usecases
[HOST] [HOST ] 3: Open-Compute Usecases
[HOST] [HOST ]
[HOST] [HOST ] p: CPU Status
[HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
[HOST] [HOST ]
[HOST] [HOST ] s: System Settings
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
3
[HOST] [HOST ] 147.803117 s:
[HOST] [HOST ]
[HOST] [HOST ] OpenCompute Usecases
[HOST] [HOST ] ----------------------------
[HOST] [HOST ] 2: OpenCV Usecases
[HOST] [HOST ] 3: OpenCL Usecases
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ] 147.803178 s:
[HOST] [HOST ] 147.803178 s: Unsupported option '
[HOST] [HOST ] '. Please try again
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
3
[HOST] [HOST ] 153.651375 s:
[HOST] [HOST ]
[HOST] [HOST ] OpenCL Usecases
[HOST] [HOST ] 1: 1CH VIP capture + OpenCL Copy (A15->DSP) + SGX Copy + DISPLAY
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
1
[HOST] [HOST ] 159.932105 s:
[HOST] [IPU2 ] 159.932257 s: CHAINS: Sensor create in progress
[HOST] [IPU2 ] 159.932776 s: VIDEO_SENSOR: INST0 : I2C1 : I2C Addr = 0x30
[HOST] [IPU2 ] 160.026932 s: VIDEO_SENSOR: VIP 0: DRV ID 1203 (I2C ADDR 0x30): a635:0000:7fa2
[HOST] [IPU2 ] 160.027237 s: CHAINS: Sensor create ... DONE !!!
[HOST] [IPU2 ] 160.042213 s: CAPTURE: Create in progress !!!
[HOST] [IPU2 ] 160.042579 s: CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!!
ASSERT (chains_vipSingleCamOpenCLFrameCopySgxDisplay_priv.c|chains_vipSingleCamOpenCLFrameCopySgxDisplay_Create|165)
[HOST] [HOST ] 160.158726 s: IPC_IN_0 : Create in progress !!!
[HOST] [HOST ] 160.159092 s: IPC_IN_0 : Create Done !!!
[HOST] [HOST ] 160.159153 s: ALG: ERROR: No alg create function specified (algId = 6) !!!
[HOST] [IPU2 ] 160.157658 s: CAPTURE: Create Done !!!
[HOST] [IPU2 ] 160.158146 s: IPC_OUT_0 : Create in progress !!!
[HOST] [IPU2 ] 160.158482 s: IPC_OUT_0 : Create Done !!!
Is there a problem with my build environment or other reasons?
I have been plagued by this problem for a long time.
