Linux/TDA2PXEVM: TDA2PXEVM
Part Number: TDA2PXEVM
Tool/software: Linux
My usecase is below.
IssCapture -> IssM2mIsp -> IssM2mResizer_Capture -> Select_Capture -> IssM2mSimcop -> Merge_Simcop -> Dup_Simcop
Select_Capture -> Merge_Simcop
Dup_Simcop -> Sync_Org -> Alg_DmaSwMs -> Display_Org
Dup_Simcop -> Sync_CensusIn -> Dup_CensusIn -> Alg_Census (EVE1) -> Alg_DisparityHamDist (EVE1) -> Merge_StereoOut -> Alg_StereoPostProcess (DSP1) -> Display_Disparity
Dup_CensusIn->Merge_StereoOut
IssM2mIsp -> Alg_IssAewb
GrpxSrc -> Display_Grp
The Performance Statistics is below.
[HOST] [EVE1 ] 156.139815 s: [ IPC_IN_0 ] Link Statistics,
[HOST] [EVE1 ] 156.140029 s: ******************************
[HOST] [EVE1 ] 156.140242 s:
[HOST] [EVE1 ] 156.140425 s: Elapsed time = 3187 msec
[HOST] [EVE1 ] 156.140669 s:
[HOST] [EVE1 ] 156.140852 s: Get Full Buf Cb = 24.16 fps
[HOST] [EVE1 ] 156.141127 s: Put Empty Buf Cb = 26.4 fps
[HOST] [EVE1 ] 156.141401 s: Driver/Notify Cb = 26.4 fps
[HOST] [EVE1 ] 156.141645 s:
[HOST] [EVE1 ] 156.141828 s: Input Statistics,
[HOST] [EVE1 ] 156.142011 s:
[HOST] [EVE1 ] 156.142194 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [EVE1 ] 156.142469 s: | FPS | FPS | FPS | FPS
[HOST] [EVE1 ] 156.142713 s: --------------------------------------------------
[HOST] [EVE1 ] 156.142987 s: 0 | 26. 4 0. 0 0. 0 26. 4
[HOST] [EVE1 ] 156.143353 s:
[HOST] [EVE1 ] 156.143506 s: Output Statistics,
[HOST] [EVE1 ] 156.143719 s:
[HOST] [EVE1 ] 156.143872 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [EVE1 ] 156.144116 s: | ID | FPS | FPS | FPS
[HOST] [EVE1 ] 156.144390 s: ---------------------------------------------
[HOST] [EVE1 ] 156.144634 s: 0 | 0 26. 4 0. 0 0. 0
[HOST] [EVE1 ] 156.145000 s:
[HOST] [EVE1 ] 156.145183 s: [ IPC_IN_0 ] LATENCY,
[HOST] [EVE1 ] 156.145366 s: ********************
[HOST] [EVE1 ] 156.145580 s: Local Link Latency : Avg = 47 us, Min = 30 us, Max = 61 us,
[HOST] [EVE1 ] 156.145976 s: Source to Link Latency : Avg = 47408 us, Min = 20100 us, Max = 73843 us,
[HOST] [EVE1 ] 156.146434 s:
[HOST] [EVE1 ] 156.146647 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> EVE1 ] ,
[HOST] [EVE1 ] 156.146983 s: ***************************************************************
[HOST] [EVE1 ] 156.147288 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 556, Min = 396, Max = 1098
[HOST] [EVE1 ] 156.147745 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 362, Min = 183, Max = 915
[HOST] [EVE1 ] 156.152870 s:
[HOST] [EVE1 ] 156.153053 s: [ ALG_CENSUS ] Link Statistics,
[HOST] [EVE1 ] 156.153266 s: ******************************
[HOST] [EVE1 ] 156.153510 s:
[HOST] [EVE1 ] 156.153663 s: Elapsed time = 3199 msec
[HOST] [EVE1 ] 156.153937 s:
[HOST] [EVE1 ] 156.154120 s: New data Recv = 24.7 fps
[HOST] [EVE1 ] 156.154364 s:
[HOST] [EVE1 ] 156.154547 s: Input Statistics,
[HOST] [EVE1 ] 156.154730 s:
[HOST] [EVE1 ] 156.154913 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [EVE1 ] 156.155188 s: | FPS | FPS | FPS | FPS
[HOST] [EVE1 ] 156.155432 s: --------------------------------------------------
[HOST] [EVE1 ] 156.155706 s: 0 | 26.25 0. 0 0. 0 26.25
[HOST] [EVE1 ] 156.156072 s: 1 | 26.25 0. 0 0. 0 26.25
[HOST] [EVE1 ] 156.156469 s:
[HOST] [EVE1 ] 156.156652 s: Output Statistics,
[HOST] [EVE1 ] 156.156926 s:
[HOST] [EVE1 ] 156.157079 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [EVE1 ] 156.157353 s: | ID | FPS | FPS | FPS
[HOST] [EVE1 ] 156.157597 s: ---------------------------------------------
[HOST] [EVE1 ] 156.157841 s: 0 | 0 26.25 0. 0 0. 0
[HOST] [EVE1 ] 156.158146 s: 1 | 0 26.25 0. 0 0. 0
[HOST] [EVE1 ] 156.158543 s:
[HOST] [EVE1 ] 156.158695 s: [ ALG_CENSUS ] LATENCY,
[HOST] [EVE1 ] 156.158909 s: ********************
[HOST] [EVE1 ] 156.159122 s: Local Link Latency : Avg = 3532 us, Min = 3447 us, Max = 3691 us,
[HOST] [EVE1 ] 156.159549 s: Source to Link Latency : Avg = 51768 us, Min = 23852 us, Max = 77869 us,
[HOST] [EVE1 ] 156.159976 s:
[HOST] [EVE1 ] 156.193192 s:
[HOST] [EVE1 ] 156.193375 s: [ ALG_DISPARITY_HAMDIST ] Link Statistics,
[HOST] [EVE1 ] 156.193588 s: ******************************
[HOST] [EVE1 ] 156.193832 s:
[HOST] [EVE1 ] 156.193985 s: Elapsed time = 3237 msec
[HOST] [EVE1 ] 156.194259 s:
[HOST] [EVE1 ] 156.194412 s: New data Recv = 23.78 fps
[HOST] [EVE1 ] 156.194686 s:
[HOST] [EVE1 ] 156.194869 s: Input Statistics,
[HOST] [EVE1 ] 156.195052 s:
[HOST] [EVE1 ] 156.195205 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [EVE1 ] 156.195479 s: | FPS | FPS | FPS | FPS
[HOST] [EVE1 ] 156.195723 s: --------------------------------------------------
[HOST] [EVE1 ] 156.195998 s: 0 | 25.94 0. 0 0. 0 25.94
[HOST] [EVE1 ] 156.196364 s:
[HOST] [EVE1 ] 156.196547 s: Output Statistics,
[HOST] [EVE1 ] 156.196821 s:
[HOST] [EVE1 ] 156.196974 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [EVE1 ] 156.197218 s: | ID | FPS | FPS | FPS
[HOST] [EVE1 ] 156.197492 s: ---------------------------------------------
[HOST] [EVE1 ] 156.197736 s: 0 | 0 25.94 0. 0 0. 0
[HOST] [EVE1 ] 156.198102 s:
[HOST] [EVE1 ] 156.198255 s: [ ALG_DISPARITY_HAMDIST ] LATENCY,
[HOST] [EVE1 ] 156.198499 s: ********************
[HOST] [EVE1 ] 156.198712 s: Local Link Latency : Avg = 32516 us, Min = 32209 us, Max = 32789 us,
[HOST] [EVE1 ] 156.199170 s: Source to Link Latency : Avg = 87173 us, Min = 56579 us, Max = 110505 us,
[HOST] [EVE1 ] 156.199627 s:
[HOST] [EVE1 ] 156.200817 s:
[HOST] [EVE1 ] 156.201000 s: [ IPC_OUT_0 ] Link Statistics,
[HOST] [EVE1 ] 156.201213 s: ******************************
[HOST] [EVE1 ] 156.201457 s:
[HOST] [EVE1 ] 156.201610 s: Elapsed time = 3211 msec
[HOST] [EVE1 ] 156.201884 s:
[HOST] [EVE1 ] 156.202037 s: New data Recv = 26.16 fps
[HOST] [EVE1 ] 156.202311 s: Release data Recv = 26.16 fps
[HOST] [EVE1 ] 156.202586 s: Driver/Notify Cb = 35.81 fps
[HOST] [EVE1 ] 156.202860 s:
[HOST] [EVE1 ] 156.203043 s: Input Statistics,
[HOST] [EVE1 ] 156.203226 s:
[HOST] [EVE1 ] 156.203409 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [EVE1 ] 156.203653 s: | FPS | FPS | FPS | FPS
[HOST] [EVE1 ] 156.203928 s: --------------------------------------------------
[HOST] [EVE1 ] 156.204203 s: 0 | 26.16 0. 0 0. 0 26.16
[HOST] [EVE1 ] 156.204569 s:
[HOST] [EVE1 ] 156.204752 s: Output Statistics,
[HOST] [EVE1 ] 156.204965 s:
[HOST] [EVE1 ] 156.205118 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [EVE1 ] 156.205362 s: | ID | FPS | FPS | FPS
[HOST] [EVE1 ] 156.205636 s: ---------------------------------------------
[HOST] [EVE1 ] 156.205880 s: 0 | 0 26.16 0. 0 0. 0
[HOST] [EVE1 ] 156.206246 s:
[HOST] [EVE1 ] 156.206399 s: [ IPC_OUT_0 ] LATENCY,
[HOST] [EVE1 ] 156.206612 s: ********************
[HOST] [EVE1 ] 156.206917 s: Local Link Latency : Avg = 26 us, Min = 0 us, Max = 31 us,
[HOST] [EVE1 ] 156.207283 s: Source to Link Latency : Avg = 90156 us, Min = 57067 us, Max = 140685 us,
[HOST] [EVE1 ] 156.207741 s:
[HOST] [IPU2 ] 156.208900 s:
[HOST] [IPU2 ] 156.208961 s: [ IPC_IN_0 ] Link Statistics,
[HOST] [IPU2 ] 156.209022 s: ******************************
[HOST] [IPU2 ] 156.209083 s:
[HOST] [IPU2 ] 156.209113 s: Elapsed time = 3218 msec
[HOST] [IPU2 ] 156.209205 s:
[HOST] [IPU2 ] 156.209266 s: Get Full Buf Cb = 50.34 fps
[HOST] [IPU2 ] 156.209357 s: Put Empty Buf Cb = 25.79 fps
[HOST] [IPU2 ] 156.209449 s: Driver/Notify Cb = 23.92 fps
[HOST] [IPU2 ] 156.209510 s:
[HOST] [IPU2 ] 156.209571 s: Input Statistics,
[HOST] [IPU2 ] 156.209601 s:
[HOST] [IPU2 ] 156.209662 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 156.209723 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 156.209815 s: --------------------------------------------------
[HOST] [IPU2 ] 156.209967 s: 0 | 26.10 0. 0 0. 0 26.10
[HOST] [IPU2 ] 156.210120 s:
[HOST] [IPU2 ] 156.210150 s: Output Statistics,
[HOST] [IPU2 ] 156.210242 s:
[HOST] [IPU2 ] 156.210272 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 156.210364 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 156.210425 s: ---------------------------------------------
[HOST] [IPU2 ] 156.210516 s: 0 | 0 26.10 0. 0 0. 0
[HOST] [IPU2 ] 156.210638 s:
[HOST] [IPU2 ] 156.210669 s: [ IPC_IN_0 ] LATENCY,
[HOST] [IPU2 ] 156.210730 s: ********************
[HOST] [IPU2 ] 156.210791 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max = 61 us,
[HOST] [IPU2 ] 156.210913 s: Source to Link Latency : Avg = 90438 us, Min = 57311 us, Max = 141082 us,
[HOST] [IPU2 ] 156.211035 s:
[HOST] [IPU2 ] 156.211096 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ EVE1 -> IPU2 ] ,
[HOST] [IPU2 ] 156.211187 s: ***************************************************************
[HOST] [IPU2 ] 156.211309 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 366, Min = 305, Max = 610
[HOST] [IPU2 ] 156.211431 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 196, Min = 122, Max = 457
[HOST] [IPU2 ] 156.212346 s:
[HOST] [IPU2 ] 156.212407 s: [ IPC_OUT_1 ] Link Statistics,
[HOST] [IPU2 ] 156.212468 s: ******************************
[HOST] [IPU2 ] 156.212529 s:
[HOST] [IPU2 ] 156.212560 s: Elapsed time = 3260 msec
[HOST] [IPU2 ] 156.212651 s:
[HOST] [IPU2 ] 156.212682 s: New data Recv = 49.7 fps
[HOST] [IPU2 ] 156.212743 s: Release data Recv = 25.76 fps
[HOST] [IPU2 ] 156.212834 s: Driver/Notify Cb = 124.53 fps
[HOST] [IPU2 ] 156.212926 s:
[HOST] [IPU2 ] 156.212956 s: Input Statistics,
[HOST] [IPU2 ] 156.213017 s:
[HOST] [IPU2 ] 156.213200 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 156.213322 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 156.213414 s: --------------------------------------------------
[HOST] [IPU2 ] 156.213475 s: 0 | 25.76 0. 0 0. 0 25.76
[HOST] [IPU2 ] 156.213627 s: 1 | 26.38 0. 0 0. 0 26.38
[HOST] [IPU2 ] 156.213749 s:
[HOST] [IPU2 ] 156.213780 s: Output Statistics,
[HOST] [IPU2 ] 156.213841 s:
[HOST] [IPU2 ] 156.213871 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 156.213963 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 156.214054 s: ---------------------------------------------
[HOST] [IPU2 ] 156.214115 s: 0 | 0 25.76 0. 0 0. 0
[HOST] [IPU2 ] 156.214268 s: 1 | 0 26.38 0. 0 0. 0
[HOST] [IPU2 ] 156.214390 s:
[HOST] [IPU2 ] 156.214451 s: [ IPC_OUT_1 ] LATENCY,
[HOST] [IPU2 ] 156.214512 s: ********************
[HOST] [IPU2 ] 156.214573 s: Local Link Latency : Avg = 7 us, Min = 0 us, Max = 61 us,
[HOST] [IPU2 ] 156.214695 s: Source to Link Latency : Avg = 59938 us, Min = 19917 us, Max = 141295 us,
[HOST] [IPU2 ] 156.214786 s:
[HOST] [DSP1 ] 156.224852 s:
[HOST] [DSP1 ] 156.224882 s: [ IPC_IN_0 ] Link Statistics,
[HOST] [DSP1 ] 156.224882 s: ******************************
[HOST] [DSP1 ] 156.224913 s:
[HOST] [DSP1 ] 156.224913 s: Elapsed time = 3272 msec
[HOST] [DSP1 ] 156.224943 s: Get Full Buf Cb = 48.89 fps
[HOST] [DSP1 ] 156.224943 s: Put Empty Buf Cb = 51.34 fps
[HOST] [DSP1 ] 156.224974 s: Driver/Notify Cb = 48.59 fps
[HOST] [DSP1 ] 156.225004 s: Input Statistics,
[HOST] [DSP1 ] 156.225004 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [DSP1 ] 156.225035 s: | FPS | FPS | FPS | FPS
[HOST] [DSP1 ] 156.225035 s: --------------------------------------------------
[HOST] [DSP1 ] 156.225065 s: 0 | 25.67 0. 0 0. 0 25.67
[HOST] [DSP1 ] 156.225096 s: 1 | 26.28 0. 0 0. 0 26.28
[HOST] [DSP1 ] 156.225126 s:
[HOST] [DSP1 ] 156.225126 s: Output Statistics,
[HOST] [DSP1 ] 156.225157 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [DSP1 ] 156.225157 s: | ID | FPS | FPS | FPS
[HOST] [DSP1 ] 156.225187 s: ---------------------------------------------
[HOST] [DSP1 ] 156.225187 s: 0 | 0 25.67 0. 0 0. 0
[HOST] [DSP1 ] 156.225218 s: 1 | 0 26.28 0. 0 0. 0
[HOST] [DSP1 ] 156.225248 s:
[HOST] [DSP1 ] 156.225248 s: [ IPC_IN_0 ] LATENCY,
[HOST] [DSP1 ] 156.225279 s: ********************
[HOST] [DSP1 ] 156.225279 s: Local Link Latency : Avg = 12 us, Min = 0 us, Max = 31 us,
[HOST] [DSP1 ] 156.225309 s: Source to Link Latency : Avg = 62864 us, Min = 20039 us, Max = 141448 us,
[HOST] [DSP1 ] 156.225340 s:
[HOST] [DSP1 ] 156.225340 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> DSP1 ] ,
[HOST] [DSP1 ] 156.225401 s: ***************************************************************
[HOST] [DSP1 ] 156.225401 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 168, Min = 122, Max = 305
[HOST] [DSP1 ] 156.225431 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 94, Min = 61, Max = 183
[HOST] [DSP1 ] 156.226346 s:
[HOST] [DSP1 ] 156.226377 s: [ ALG_STEREO_POST_PROCESS ] Link Statistics,
[HOST] [DSP1 ] 156.226407 s: ******************************
[HOST] [DSP1 ] 156.226407 s: Elapsed time = 3274 msec
[HOST] [DSP1 ] 156.226438 s:
[HOST] [DSP1 ] 156.226438 s: New data Recv = 48.56 fps
[HOST] [DSP1 ] 156.226468 s:
[HOST] [DSP1 ] 156.226468 s: Input Statistics,
[HOST] [DSP1 ] 156.226499 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [DSP1 ] 156.226499 s: | FPS | FPS | FPS | FPS
[HOST] [DSP1 ] 156.226529 s: --------------------------------------------------
[HOST] [DSP1 ] 156.226529 s: 0 | 25.65 0. 0 0. 0 25.65
[HOST] [DSP1 ] 156.226560 s:
[HOST] [DSP1 ] 156.226590 s: Output Statistics,
[HOST] [DSP1 ] 156.226590 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [DSP1 ] 156.226621 s: | ID | FPS | FPS | FPS
[HOST] [DSP1 ] 156.226621 s: ---------------------------------------------
[HOST] [DSP1 ] 156.226651 s: 0 | 0 25.65 0. 0 0. 0
As above, the IPC IN(EVE1) has one channel but the 2 channels input is coming into Alg_census link.
Is it normal?
Heechang
    yes, this is normal.
    Census link takes input as System_VideoFrameCompositeBuffer which contain multiple System_VideoFrameBuffer.
    for(channelId=0; channelId < pCensusObj->numInputChannels; channelId++)
    /* Repeating the count for RightInput and LeftInput */
    linkStatsInfo->linkStats.chStats[channelId].inBufRecvCount++;
    Above code is responsible for multiple channels.
    Anuj
