Other Parts Discussed in Thread: TPS2051
Hi all
When my custom board booting,the follow error message are always showed,
ti81xx_interrupt 1146: VBUS error workaround (delay coming)
I do not know the reason,
Please help me.
Best Regards
Qin Long
Hi all
Please help me.
Best Regards
Qin Long
The message means the USB VBUS is dropped below valid threshold.
Please provide more info, what device? what sdk/kernel version? do you see the message from the first time after ported kernel to the board or after software change? Please provide the usb portion of your schematics.
Hi Liu
Thanks a lot for you quick reply.
According to your advice,I check my hardware,I did not power usb1 before.
It's OK after i connect 5V power to USB1 power IC.
by the way, I linux-3.2.0-psp04.06.00.11,u-boot-2013.01.01-psp06.00.00.00
Best Regards
Qin Long
Hi Amon Wu,
The problem happened just because of my misoperation,
In my board,i used a Header1x3 between power with USB PMIC (TPS2051BD),
I forgot to conect power to USB PMIC with jump,so the output of VBUS is 0V.
After i connected power to USB PMIC with jump,the problem was fixed.
Amon Wu said:another problem is what is the different between TPS2051BD and TPS2051 (DGN) ? Is there another IC ?
I did not find out TPS2051 (DGN) in www.ti.com.
so i don't know the different between TPS2051BD and TPS2051 (DGN),you can ask for help from TI 's AFE.
by the way,TPS2051BD is in NRND(Not Recommended for New Designs).
Best Regards
Qin Long
