Other Parts Discussed in Thread: AM3352, TPS65910
I couln't bring up wifi on WL18xx on a custom board.
BT is working proper, have crosschecked WL_ENA and WL_IRQ hardware with oscilloscope -- seems to work under u-boot and linux.
Kernel is based on SDK 7...
here is my .dts file, which is working proper for all except WLAN:
Can you have a look at it and give some advice?
Many thanks in advance.
Reinhard
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* AM335x Starter Kit
* http://www.ti.com/tool/tmdssk3358
/dts-v1/;
#include "am33xx.dtsi"
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/pwm/pwm.h>
model = "Knobloch TXT AM3352";
compatible = "ti,am335x-evm", "ti,am33xx";
cpus {
cpu@0 {
cpu0-supply = <&vdd1_reg>;
memory {
device_type = "memory";
reg = <0x80000000 0x10000000>; /* 256 MB */
wlcore {
compatible = "wlcore";
gpio = <28>; /* Bank0, pin28 */
* TODO: use edge irqs for suspend/resume.
* in newer kerenls, we seem to miss interrupts when
* working with edge irqs, so revert back to level irqs.
platform-quirks = <1>;
/* if a 12xx card is there, configure the clock to
WL12XX_REFCLOCK_38_XTAL */
board-ref-clock = <4>;
kim {
compatible = "kim";
nshutdown_gpio = <97>; /* Bank3, pin1 */
dev_name = "/dev/ttyO3";
flow_cntrl = <1>;
baud_rate = <3000000>;
btwilink {
compatible = "btwilink";
am33xx_pinmux: pinmux@44e10800 {
pinctrl-names = "default";
pinctrl-0 = <&clkout2_pin &clkout1_pin &ddr3_vtt_toggle &wlan_pins>;
ddr3_vtt_toggle: ddr3_vtt_toggle {
pinctrl-single,pins = <
0x1ac 0x7 /* mcasp0_ahclkx.gpio3_21, OUTPUT | MODE7 */
i2c0_pins: pinmux_i2c0_pins {
0x188 (PIN_INPUT | MUX_MODE0) /* i2c0_sda.i2c0_sda */
0x18c (PIN_INPUT | MUX_MODE0) /* i2c0_scl.i2c0_scl */
uart0_pins: pinmux_uart0_pins {
0x170 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */
0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */
uart2_pins_default: pinmux_uart2_pins_default {
0x150 (PIN_INPUT_PULLUP | MUX_MODE1) /* spi0_sclk.uart2_rxd */
0x154 (PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* spi0_d0.uart2_txd */
uart2_pins_sleep: pinmux_uart2_pins_sleep {
0x150 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x154 (PIN_INPUT_PULLDOWN | MUX_MODE7)
uart3_pins_default: pinmux_uart3_pins_default {
0x148 (PIN_INPUT | MUX_MODE3) /* mdi0.uart3_ctsn */
0x14C (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* mdc.uart3_rtsn */
0x134 (PIN_INPUT | MUX_MODE1) /* mii1_rxd3.uart3_rxd */
0x138 (PIN_OUTPUT | MUX_MODE1) /* mii1_rxd2.uart3_txd */
uart3_pins_sleep: pinmux_uart3_pins_sleep {
0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x14C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x134 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x138 (PIN_INPUT_PULLDOWN | MUX_MODE7)
mmc1_pins_default: pinmux_mmc1_pins {
0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
0x0FC (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
0x1A0 (PIN_OUTPUT | MUX_MODE7) /* mcasp0_aclkr.gpio3_18 */
0x1A8 (PIN_INPUT | MUX_MODE7) /* mcasp0_axr1.gpio3_20 */
mmc1_pins_sleep: pinmux_mmc1_pins_sleep {
0x0F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x104 (PIN_INPUT_PULLDOWN | MUX_MODE7)
mmc3_pins_default: pinmux_mmc3_pins {
0x118 (PIN_INPUT_PULLDOWN | MUX_MODE5) /* mii1_rx_dv.mmc2_dat0, INPUT_PULLUP | MODE5 */
0x11C (PIN_INPUT_PULLDOWN | MUX_MODE5) /* mii1_txd3.mmc2_dat1, INPUT_PULLUP | MODE5 */
0x120 (PIN_INPUT_PULLDOWN | MUX_MODE5) /* mii1_txd2.mmc2_dat2, INPUT_PULLUP | MODE5 */
0x108 (PIN_INPUT_PULLDOWN | MUX_MODE5) /* mii1_col.mmc2_dat3, INPUT_PULLUP | MODE5 */
0x114 (PIN_INPUT_PULLDOWN | MUX_MODE6) /* mii1_tx_en.mmc2_cmd, INPUT_PULLUP | MODE6 */
0x13C (PIN_INPUT_PULLDOWN | MUX_MODE6) /* mii1_rxd1.mmc2_clk, INPUT_PULLUP | MODE6 */
mmc3_pins_sleep: pinmux_mmc3_pins_sleep {
0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x11C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x13C (PIN_INPUT_PULLDOWN | MUX_MODE7)
clkout1_pin: pinmux_clkout1_pin {
0x1b0 (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* xdma_event_intr0.clkout1 */
clkout2_pin: pinmux_clkout2_pin {
0x1b4 (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* xdma_event_intr1.clkout2 */
/* wl12xx/wl18xx card on mmc3 */
wlan_pins: pinmux_wlan_pins {
0x110 (PIN_OUTPUT_PULLUP | MUX_MODE7) /* mii1_rx_er.gpio3_2 (WL_EN) */
0x128 (PIN_INPUT_PULLUP | MUX_MODE7) /* mii1_txd0.gpio0_28 (WLAN_IRQ) */
0x10C (PIN_OUTPUT_PULLUP | MUX_MODE7) /* mii1_crs.gpio3_1 (BT_EN) */
ocp {
uart0: serial@44e09000 {
pinctrl-0 = <&uart0_pins>;
status = "okay";
uart2: serial@48024000 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&uart2_pins_default>;
pinctrl-1 = <&uart2_pins_sleep>;
status = "okay";
uart3: serial@481a6000 {
pinctrl-0 = <&uart3_pins_default>;
pinctrl-1 = <&uart3_pins_sleep>;
status = "okay";
i2c0: i2c@44e0b000 {
pinctrl-0 = <&i2c0_pins>;
status = "okay";
clock-frequency = <400000>;
tps: tps@2d {
reg = <0x2d>;
baseboard_eeprom: baseboard_eeprom@50 {
compatible = "at,24c01";
reg = <0x50>;
musb: usb@47400000 {
status = "okay";
control@44e10000 {
status = "okay";
usb-phy@47401300 {
status = "okay";
usb-phy@47401b00 {
status = "okay";
usb@47401000 {
status = "okay";
usb@47401800 {
status = "okay";
dr_mode = "host";
dma-controller@07402000 {
status = "okay";
vbat: fixedregulator@0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
lis3_reg: fixedregulator@1 {
regulator-name = "lis3_reg";
regulator-boot-on;
wlan_en_reg: fixedregulator@9 {
regulator-name = "wlan-en-regulator";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
gpio = <&gpio3 2 0>;
startup-delay-us = <70000>;
/*enable-active-high; */
regulator-boot-on;
#include "tps65910.dtsi"
&tps {
vcc1-supply = <&vbat>;
vcc2-supply = <&vbat>;
vcc3-supply = <&vbat>;
vcc4-supply = <&vbat>;
vcc5-supply = <&vbat>;
vcc6-supply = <&vbat>;
vcc7-supply = <&vbat>;
vccio-supply = <&vbat>;
regulators {
vrtc_reg: regulator@0 {
regulator-always-on;
vio_reg: regulator@1 {
vdd1_reg: regulator@2 {
/* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */
regulator-name = "vdd_mpu";
regulator-min-microvolt = <912500>;
regulator-max-microvolt = <1378000>;
regulator-boot-on;
vdd2_reg: regulator@3 {
/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
regulator-name = "vdd_core";
regulator-max-microvolt = <1150000>;
regulator-boot-on;
vdd3_reg: regulator@4 {
vdig1_reg: regulator@5 {
vdig2_reg: regulator@6 {
vpll_reg: regulator@7 {
vdac_reg: regulator@8 {
vaux1_reg: regulator@9 {
vaux2_reg: regulator@10 {
vaux33_reg: regulator@11 {
vmmc_reg: regulator@12 {
regulator-name = "vmmc_reg";
regulator-max-microvolt = <3300000>;
&gpio0 {
ti,no-reset;
&gpio3 {
ti,no-reset;
&mmc1 {
status = "okay";
vmmc-supply = <&vmmc_reg>;
bus-width = <4>;
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_sleep>;
cd-gpios = <&gpio3 20 GPIO_ACTIVE_LOW>;
&edma {
/* Map eDMA MMC2 Events from Crossbar */
ti,edma-xbar-event-map = <1 12
2 13>;
&mmc3 {
/* these are on the crossbar and are outlined in the
xbar-event-map element */
dmas = <&edma 12
&edma 13>;
dma-names = "tx", "rx";
status = "okay";
vmmc-supply = <&wlan_en_reg>;
bus-width = <4>;
pinctrl-0 = <&mmc3_pins_default>;
pinctrl-1 = <&mmc3_pins_sleep>;
ti,non-removable;
ti,needs-special-hs-handling;
cap-power-off-card;
keep-power-in-suspend;
