Other Parts Discussed in Thread: TUSB2046B
Hi All.
I have board beaglebone black, and use TUSB2046B chip on the USB1 port AM335x
Linux version: Linux version 3.13.6-00043-gb3f771c-dirty
Loading listing:
localhost (arm) ~ # dmesg | grep -e usb [ 0.195003] usbcore: registered new interface driver usbfs [ 0.195107] usbcore: registered new interface driver hub [ 0.195382] usbcore: registered new device driver usb [ 2.559044] usbcore: registered new interface driver asix [ 2.575845] usbcore: registered new interface driver ax88179_178a [ 2.594750] usbcore: registered new interface driver cdc_ether [ 2.612851] usbcore: registered new interface driver r815x [ 2.629940] usbcore: registered new interface driver smsc95xx [ 2.647770] usbcore: registered new interface driver net1080 [ 2.665343] usbcore: registered new interface driver cdc_subset [ 2.683713] usbcore: registered new interface driver zaurus [ 2.701070] usbcore: registered new interface driver cdc_ncm [ 2.772101] usbcore: registered new interface driver cdc_acm [ 2.814442] usbcore: registered new interface driver usb-storage [ 2.922220] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 2.922279] 47401b00.usb-phy supply vcc not found, using dummy regulator [ 2.944137] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) [ 2.944161] musb-hdrc: MHDRC RTL version 2.0 [ 2.944176] musb-hdrc: setup fifo_mode 4 [ 2.944201] musb-hdrc: 28/31 max ep, 16384/16384 memory [ 2.944349] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 2.962564] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1 [ 2.986781] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup [ 2.987000] usb usb1: default language 0x0409 [ 2.987126] usb usb1: udev 1, busnum 1, minor = 0 [ 2.987150] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.008141] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.030456] usb usb1: Product: MUSB HDRC host driver [ 3.045820] usb usb1: Manufacturer: Linux 3.13.6-00043-gb3f771c-dirty musb-hcd [ 3.068134] usb usb1: SerialNumber: musb-hdrc.1.auto [ 3.084293] usb usb1: usb_probe_device [ 3.084320] usb usb1: configuration #1 chosen from 1 choice [ 3.084440] usb usb1: adding 1-0:1.0 (config #1, interface 0) [ 3.084644] hub 1-0:1.0: usb_probe_interface [ 3.084667] hub 1-0:1.0: usb_probe_interface - got id [ 3.205760] usb usb1: bus auto-suspend, wakeup 1 [ 3.611098] usbcore: registered new interface driver usbhid [ 3.628403] usbhid: USB HID core driver [ 3.640271] usbip_core: USB/IP Core v1.0.0 [ 3.655140] usbcore: registered new interface driver usbip-host [ 3.673540] usbip_host: USB/IP Host Driver v1.0.0 [ 3.935551] musb-hdrc musb-hdrc.0.auto: Falied to request rx1. [ 3.953670] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 [ 3.977635] platform musb-hdrc.0.auto: Driver musb-hdrc requests probe deferral [ 4.113594] musb-hdrc musb-hdrc.0.auto: Falied to request rx1. [ 4.173174] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 [ 4.197116] platform musb-hdrc.0.auto: Driver musb-hdrc requests probe deferral
I see usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
but I not see TUSB2046B with 4 interface.
I think this my mistake in am33xx.dtsi file (see usb partition bellow).
usb: usb@47400000 {
compatible = "ti,am33xx-usb";
reg = <0x47400000 0x1000>;
ranges;
#address-cells = <1>;
#size-cells = <1>;
ti,hwmods = "usb_otg_hs";
status = "disabled";
usb_ctrl_mod: control@44e10000 {
compatible = "ti,am335x-usb-ctrl-module";
reg = <0x44e10620 0x10
0x44e10648 0x4>;
reg-names = "phy_ctrl", "wakeup";
usb0_phy: usb-phy@47401300 {
compatible = "ti,am335x-usb-phy";
reg = <0x47401300 0x100>;
reg-names = "phy";
ti,ctrl_mod = <&usb_ctrl_mod>;
usb0: usb@47401000 {
compatible = "ti,musb-am33xx";
reg = <0x47401400 0x400
0x47401000 0x200>;
reg-names = "mc", "control";
interrupts = <18>;
interrupt-names = "mc";
dr_mode = "otg";
mentor,multipoint = <1>;
mentor,num-eps = <16>;
mentor,ram-bits = <12>;
mentor,power = <500>;
phys = <&usb0_phy>;
dmas = <&cppi41dma 0 0 &cppi41dma 1 0
&cppi41dma 2 0 &cppi41dma 3 0
&cppi41dma 4 0 &cppi41dma 5 0
&cppi41dma 6 0 &cppi41dma 7 0
&cppi41dma 8 0 &cppi41dma 9 0
&cppi41dma 10 0 &cppi41dma 11 0
&cppi41dma 12 0 &cppi41dma 13 0
&cppi41dma 14 0 &cppi41dma 0 1
&cppi41dma 1 1 &cppi41dma 2 1
&cppi41dma 3 1 &cppi41dma 4 1
&cppi41dma 5 1 &cppi41dma 6 1
&cppi41dma 7 1 &cppi41dma 8 1
&cppi41dma 9 1 &cppi41dma 10 1
&cppi41dma 11 1 &cppi41dma 12 1
&cppi41dma 13 1 &cppi41dma 14 1>;
dma-names =
"rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7",
"rx8", "rx9", "rx10", "rx11", "rx12", "rx13",
"rx14", "rx15",
"tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7",
"tx8", "tx9", "tx10", "tx11", "tx12", "tx13",
"tx14", "tx15";
usb1_phy: usb-phy@47401b00 {
reg = <0x47401b00 0x100>;
reg-names = "phy";
usb1: usb@47401800 {
reg = <0x47401c00 0x400
0x47401800 0x200>;
interrupts = <19>;
dr_mode = "host";
phys = <&usb1_phy>;
dmas = <&cppi41dma 15 0 &cppi41dma 16 0
&cppi41dma 17 0 &cppi41dma 18 0
&cppi41dma 19 0 &cppi41dma 20 0
&cppi41dma 21 0 &cppi41dma 22 0
&cppi41dma 23 0 &cppi41dma 24 0
&cppi41dma 25 0 &cppi41dma 26 0
&cppi41dma 27 0 &cppi41dma 28 0
&cppi41dma 29 0 &cppi41dma 15 1
&cppi41dma 16 1 &cppi41dma 17 1
&cppi41dma 18 1 &cppi41dma 19 1
&cppi41dma 20 1 &cppi41dma 21 1
&cppi41dma 22 1 &cppi41dma 23 1
&cppi41dma 24 1 &cppi41dma 25 1
&cppi41dma 26 1 &cppi41dma 27 1
&cppi41dma 28 1 &cppi41dma 29 1>;
dma-names =
"rx16", "rx17", "rx18", "rx19", "rx20", "rx21", "rx22",
"rx23", "rx24", "rx25", "rx26", "rx27", "rx28",
"rx29", "rx30",
"tx16", "tx17", "tx18", "tx19", "tx20", "tx21", "tx22",
"tx23", "tx24", "tx25", "tx26", "tx27", "tx28",
"tx29", "tx30";
cppi41dma: dma-controller@07402000 {
compatible = "ti,am3359-cppi41";
0x47402000 0x1000
0x47403000 0x1000
0x47404000 0x4000>;
reg-names = "glue", "controller", "scheduler", "queuemgr";
interrupts = <17>;
interrupt-names = "glue";
#dma-cells = <2>;
#dma-channels = <30>;
#dma-requests = <256>;
