Other Parts Discussed in Thread: TPS65910
Hi TI
we have ported sdk6 finished, now we have to port sdk8 on our board, then filesystem we referenced beaglebone ubuntu 14.04
This is our first step on dts structure, and suffer the problem of filesystem can't be mounted. There are our boot log bellow, please indicate what the root cause, thank you very much.
U-Boot 2014.07-g4b537ee-dirty (May 06 2015 - 16:30:14)
I2C: ready
DRAM: 256 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
4283040 bytes read in 594 ms (6.9 MiB/s)
36285 bytes read in 36 ms (983.4 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x415aa0 ]
Loading Device Tree to 8e713000, end 8e71edbc ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.26-gc07a870 (bernie@ubuntu) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 Wed May 6 14:25:18 CST 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x EVM-SK
[ 0.000000] cma: CMA: reserved 24 MiB at 8c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64512
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 224344K/260096K available (5791K kernel code, 313K rwdata, 2088K rodata, 269K init, 231K bss, 35752K reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07ba054 (7881 kB)
[ 0.000000] .init : 0xc07bb000 - 0xc07fe454 ( 270 kB)
[ 0.000000] .data : 0xc0800000 - 0xc084e760 ( 314 kB)
[ 0.000000] .bss : 0xc084e760 - 0xc0888738 ( 232 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000026] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000072] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000676] Console: colour dummy device 80x30
[ 0.000742] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992)
[ 0.068463] pid_max: default: 32768 minimum: 301
[ 0.068687] Security Framework initialized
[ 0.068803] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.068830] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.086994] CPU: Testing write buffer coherency: ok
[ 0.087728] Setting up static identity map for 0x805ad920 - 0x805ad978
[ 0.089929] devtmpfs: initialized
[ 0.094273] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.112971] omap_hwmod: tptc0 using broken dt data from edma
[ 0.113183] omap_hwmod: tptc1 using broken dt data from edma
[ 0.113373] omap_hwmod: tptc2 using broken dt data from edma
[ 0.119879] omap_hwmod: debugss: _wait_target_disable failed
[ 0.190349] pinctrl core: initialized pinctrl subsystem
[ 0.192629] regulator-dummy: no parameters
[ 0.197442] NET: Registered protocol family 16
[ 0.202367] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.208470] cpuidle: using governor ladder
[ 0.208584] cpuidle: using governor menu
[ 0.225654] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered
[ 0.229392] platform 49000000.edma: alias fck already exists
[ 0.229451] platform 49000000.edma: alias fck already exists
[ 0.229489] platform 49000000.edma: alias fck already exists
[ 0.232225] OMAP GPIO hardware version 0.1
[ 0.267376] No ATAGs?
[ 0.267423] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.333609] bio: create slab <bio-0> at 0
[ 0.373332] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.375610] vbat: 5000 mV
[ 0.376552] lis3_reg: no parameters
[ 0.376786] reg-fixed-voltage fixedregulator.6: could not find pctldev for node /pinmux@44e10800/pinmux_wl12xx_gpio, deferring probe
[ 0.376836] platform fixedregulator.6: Driver reg-fixed-voltage requests probe deferral
[ 0.377816] vtt: 1500 mV
[ 0.385591] vgaarb: loaded
[ 0.386862] i2c-core: driver [palmas] using legacy suspend method
[ 0.386889] i2c-core: driver [palmas] using legacy resume method
[ 0.388708] SCSI subsystem initialized
[ 0.392389] usbcore: registered new interface driver usbfs
[ 0.392855] usbcore: registered new interface driver hub
[ 0.393341] usbcore: registered new device driver usb
[ 0.395615] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
[ 0.395680] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[ 0.396639] pps_core: LinuxPPS API ver. 1 registered
[ 0.396667] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.396990] PTP clock support registered
[ 0.401841] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.403904] Advanced Linux Sound Architecture Driver Initialized.
[ 0.407622] Switched to clocksource timer1
[ 0.456509] NET: Registered protocol family 2
[ 0.458641] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.458729] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.458804] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.458952] TCP: reno registered
[ 0.458985] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.459036] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.459474] NET: Registered protocol family 1
[ 0.460278] RPC: Registered named UNIX socket transport module.
[ 0.460307] RPC: Registered udp transport module.
[ 0.460323] RPC: Registered tcp transport module.
[ 0.460341] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462594] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.469282] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.905736] VFS: Disk quotas dquot_6.5.2
[ 0.905881] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.907007] NFS: Registering the id_resolver key type
[ 0.907198] Key type id_resolver registered
[ 0.907219] Key type id_legacy registered
[ 0.907310] jffs2: version 2.2. (NAND) (SUMMARY) c 2001-2006 Red Hat, Inc.
[ 0.907876] msgmni has been set to 486
[ 0.911442] NET: Registered protocol family 38
[ 0.911534] io scheduler noop registered
[ 0.911555] io scheduler deadline registered
[ 0.911603] io scheduler cfq registered (default)
[ 0.915554] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.923432] backlight.10 supply power not found, using dummy regulator
[ 0.932002] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.939497] omap_uart 44e09000.serial: no wakeirq for uart0
[ 0.939837] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0
[ 1.612624] console [ttyO0] enabled
[ 1.619627] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.627490] [drm] Initialized drm 1.1.0 20060810
[ 1.659634] brd: module loaded
[ 1.676605] loop: module loaded
[ 1.680857] (hci_tty): inside hci_tty_init
[ 1.686203] (hci_tty): allocated 249, 0
[ 1.699296] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.715565] usbcore: registered new interface driver asix
[ 1.721827] usbcore: registered new interface driver ax88179_178a
[ 1.728740] usbcore: registered new interface driver cdc_ether
[ 1.735396] usbcore: registered new interface driver smsc95xx
[ 1.741845] usbcore: registered new interface driver net1080
[ 1.748266] usbcore: registered new interface driver cdc_subset
[ 1.754959] usbcore: registered new interface driver zaurus
[ 1.761402] usbcore: registered new interface driver cdc_ncm
[ 1.768572] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.775455] ehci-pci: EHCI PCI platform driver
[ 1.780690] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.787268] usbcore: registered new interface driver cdc_wdm
[ 1.793828] usbcore: registered new interface driver usb-storage
[ 1.802745] mousedev: PS/2 mouse device common for all mice
[ 1.811644] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[ 1.819728] input: ti-tsc as /devices/ocp.3/44e0d000.tscadc/TI-am335x-tsc/input/input0
[ 1.831540] i2c-core: driver [rtc-ds1307] using legacy suspend method
[ 1.838405] i2c-core: driver [rtc-ds1307] using legacy resume method
[ 1.846760] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.856212] i2c /dev entries driver
[ 1.860354] Driver for 1-wire Dallas network protocol.
[ 1.870574] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.882273] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 1.889665] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 1.897861] omap_hsmmc 481d8000.mmc: unable to get vmmc regulator -517
[ 1.904869] platform 481d8000.mmc: Driver omap_hsmmc requests probe deferral
[ 1.917239] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.924375] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.933175] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.942927] usbcore: registered new interface driver usbhid
[ 1.948884] usbhid: USB HID core driver
[ 1.953511] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 1.968334] oprofile: using arm/armv7
[ 1.972837] TCP: cubic registered
[ 1.976337] Initializing XFRM netlink socket
[ 1.981100] NET: Registered protocol family 17
[ 1.985871] NET: Registered protocol family 15
[ 1.990848] Key type dns_resolver registered
[ 1.996828] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.006090] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.012076] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.021256] PM: bootloader does not support rtc-only!
[ 2.026599] ThumbEE CPU extension supported.
[ 2.031369] Registering SWP/SWPB emulation handler
[ 2.039830] lis3_reg: disabling
[ 2.043160] vbat: disabling
[ 2.046098] regulator-dummy: disabling
[ 2.058008] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.064987] [drm] No driver support for vblank timestamp query.
[ 2.133567] Console: switching to colour frame buffer device 60x34
[ 2.145768] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 2.151661] tilcdc 4830e000.lcdc: registered panic notifier
[ 2.157537] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.166123] vwl1271: 1800 mV
[ 2.173614] tps65910 0-002d: No interrupt support, no core IRQ
[ 2.182084] tps65910 0-002d: Error in configuring external control EN1
[ 2.189037] tps65910 0-002d: Failed to initialise ext control config
[ 2.196531] vrtc: failed to enable
[ 2.200753] tps65910 0-002d: failed to register tps65910-pmic regulator
[ 2.207899] tps65910-pmic: probe of tps65910-pmic failed with error -121
[ 2.218771] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.226478] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.233743] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.358865] remoteproc0: wkup_m3 is available
[ 2.363567] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.373056] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.384345] remoteproc0: Direct firmware load failed with error -2
[ 2.391053] remoteproc0: Falling back to user helper
[ 2.397026] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.406248] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.416309] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.424194] omap_hsmmc 481d8000.mmc: card claims to support voltages below defined range
[ 2.434347] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.441617] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.480202] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.487341] mmc0: new high speed SDIO card at address 0001
[ 2.517715] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.524140] davinci_mdio 4a101000.mdio: detected phy mask f00fff00
[ 2.540410] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.549661] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.558322] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.570567] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.579233] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.589818] libphy: 4a101000.mdio: probed
[ 2.594070] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
[ 2.602544] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
[ 2.610995] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver unknown
[ 2.619435] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver unknown
[ 2.627876] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver unknown
[ 2.636292] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[ 2.644742] davinci_mdio 4a101000.mdio: phy[6]: device 4a101000.mdio:06, driver unknown
[ 2.653182] davinci_mdio 4a101000.mdio: phy[7]: device 4a101000.mdio:07, driver Atheros 8035 ethernet
[ 2.662899] davinci_mdio 4a101000.mdio: phy[20]: device 4a101000.mdio:14, driver unknown
[ 2.671433] davinci_mdio 4a101000.mdio: phy[21]: device 4a101000.mdio:15, driver unknown
[ 2.679988] davinci_mdio 4a101000.mdio: phy[22]: device 4a101000.mdio:16, driver unknown
[ 2.688521] davinci_mdio 4a101000.mdio: phy[23]: device 4a101000.mdio:17, driver unknown
[ 2.697033] davinci_mdio 4a101000.mdio: phy[24]: device 4a101000.mdio:18, driver unknown
[ 2.705563] davinci_mdio 4a101000.mdio: phy[25]: device 4a101000.mdio:19, driver unknown
[ 2.714096] davinci_mdio 4a101000.mdio: phy[26]: device 4a101000.mdio:1a, driver unknown
[ 2.722620] davinci_mdio 4a101000.mdio: phy[27]: device 4a101000.mdio:1b, driver unknown
[ 2.731707] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.740931] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.748595] cpsw 4a100000.ethernet: Detected MACID = d0:39:72:50:77:43
[ 2.758335] cpsw 4a100000.ethernet: cpsw: Detected MACID = d0:39:72:50:77:45
[ 2.766921] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.776944] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.787849] input: gpio_buttons.9 as /devices/gpio_buttons.9/input/input1
[ 2.795849] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.804633] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.814397] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.823638] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.836054] ALSA device list:
[ 2.839304] No soundcards found.
[ 2.843657] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.852157] Waiting for root device /dev/mmcblk0p2...
[ 2.859523] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.866654] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 62.568507] remoteproc0: failed to load am335x-pm-firmware.elf
[ 62.574818] remoteproc0: powering up wkup_m3
[ 62.579833] remoteproc0: Direct firmware load failed with error -2
[ 62.586426] remoteproc0: Falling back to user helper
[ 111.655830] random: nonblocking pool is initialized
[ 122.728274] remoteproc0: request_firmware failed: -2
[ 122.733608] wkup_m3 44d00000.wkup_m3: rproc_boot failed
