Other Parts Discussed in Thread: TPS65910
Hi all,
I am having trouble getting the driver in meta-ti to accept the GPIO configuration from my DTS file. I get a parse error:
of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/serial@48024000[0]'
I checked my configuration against another DTS file and we use the same format for the GPIOs.
So two questions,
1) Has the driver been fixed from: question #408682 "8250_omap serial driver RS-485 support", e2e.ti.com/.../408682
2) What am I doing wrong with my configuration of the RTS line? See attached .dts file.
Chuck
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
build with:
cpp -nostdinc -Iinclude -undef -D__DTS__ -x assembler-with-cpp -o am335x-FinesseV2.dtb.dts.tmp am335x-FinesseV2.dts; dtc -O dtb -o am335x-FinesseV2.dtb -b 0 am335x-FinesseV2.dtb.dts.tmp
/dts-v1/;
#include "am33xx.dtsi"
#include <dt-bindings/pwm/pwm.h>
model = "TI AM335x Finesse Revision 2";
compatible = "ti,am335x-bone", "ti,am33xx";
cpus {
cpu@0 {
cpu0-supply = <&vdd1_reg>;
memory {
device_type = "memory";
reg = <0x80000000 0x20000000>; /* 512 MB */
vbat: fixedregulator@0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vtt_fixed: fixedregulator@3 {
regulator-name = "vtt";
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
gpio = <&gpio1 28 GPIO_ACTIVE_HIGH>;
regulator-always-on;
regulator-boot-on;
enable-active-high;
leds {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&user_leds_default>;
pinctrl-1 = <&user_leds_sleep>;
compatible = "gpio-leds";
led@2 {
label = "beaglebone:green:heartbeat";
gpios = <&gpio3 18 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
default-state = "off";
backlight {
compatible = "pwm-backlight";
pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>;
brightness-levels = <0 58 61 66 75 90 125 170 255>;
default-brightness-level = <8>;
// don't accidently turn off the dram on gpio 1,28!!!!
&gpio1 {
ti,no-reset-on-init;
&am33xx_pinmux {
pinctrl-names = "default";
pinctrl-0 = <&ddr3_vtt_toggle>;
ddr3_vtt_toggle: ddr3_vtt_toggle {
pinctrl-single,pins = <
0x78 (PIN_OUTPUT | MUX_MODE7) /* gpmc_be1.gpio1_28 OK */
user_leds_default: user_leds_default {
0x1A0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mcasp0_aclkr.gpio3_18 OK */
user_leds_sleep: user_leds_sleep {
i2c0_pins: pinmux_i2c0_pins {
0x188 (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda OK */
0x18c (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl OK */
uart0_pins: pinmux_uart0_pins {
0x170 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd OK */
0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd OK */
0x16C (PIN_INPUT_PULLUP | MUX_MODE7) /* uart0_rtsn.uart0_rtsn OK read UART0_RTSn it is nINVALID signal from 232 driver */
uart1_pins: pinmux_uart1_pins {
0x180 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd OK */
0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd OK */
0x17C (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_rtsn.uart1_rtsn OK GPIO */
uart2_pins: pinmux_uart2_pins {
0x12C (PIN_INPUT_PULLUP | MUX_MODE1) /* gmii1_txclk.uart2_rxd OK */
0x130 (PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* gmii1_rxclk.uart2_txd OK */
0x118 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gmii1_rxdv.GPIO3_4... uart2_rtsn OK GPIO */
ecap0_pins_default: backlight_pins {
0x164 (PIN_OUTPUT | MUX_MODE0) /* ecap0_in_pwm0_out */
ecap0_pins_sleep: ecap0_pins_sleep {
0x164 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* ecap0_in_pwm0_out */
cpsw_default: cpsw_default {
/* Slave 1 RMII mode */
0x10c (PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_crs.rmmi1_crs_dv OK */
0x110 (PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxer.rmii1_rxer OK */
0x114 (PIN_OUTPUT | MUX_MODE1) /* mii1_txen.rmii1_txen OK */
0x124 (PIN_OUTPUT | MUX_MODE1) /* mii1_txd1.rmii1_txd1 OK */
0x128 (PIN_OUTPUT | MUX_MODE1) /* mii1_txd0.rmii1_txd0 OK */
0x13C (PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd1.rmii1_rxd1 OK */
0x140 (PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd0.rmii1_rxd0 OK */
0x144 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* mii1_refclk.rmii1_refclk OK */
/* Slave 2 */
0x070 (PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_wait0.rmmi2_crs_dv OK */
0x074 (PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_wpn.rmii2_rxer OK */
0x040 (PIN_OUTPUT | MUX_MODE3) /* gpmc_a0.rmii2_txen OK */
0x050 (PIN_OUTPUT | MUX_MODE3) /* gpmc_a4.rmii2_txd1 OK */
0x054 (PIN_OUTPUT | MUX_MODE3) /* gpmc_a5.rmii2_txd0 OK */
0x068 (PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_a10.rmii2_rxd1 OK */
0x06c (PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_a11.rmii2_rxd0 OK */
0x108 (PIN_INPUT_PULLDOWN | MUX_MODE1) /* gmmi1_col.rmii2_refclk OK */
cpsw_sleep: cpsw_sleep {
/* Slave 1 reset value */
0x10C (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x13C (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x140 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x144 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
/* Slave 2 reset value*/
0x070 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x074 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x040 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x050 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x054 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x068 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x06c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data OK */
0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk OK */
davinci_mdio_sleep: davinci_mdio_sleep {
/* MDIO reset value */
0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x14c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
mmc1_pins_default: pinmux_mmc1_pins {
0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 OK */
0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 OK */
0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 OK */
0x0FC (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 OK */
0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk OK */
0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd OK */
0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 uSD_CARD_DETECT OK*/
mmc1_pins_sleep: pinmux_mmc1_pins_sleep {
0x0F0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x0F4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x0F8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x0FC (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x104 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
0x160 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* OK */
mmc2_pins: pinmux_mmc2_pins {
0x080 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk OK */
0x084 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd OK */
0x000 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 OK */
0x004 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 OK */
0x008 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 OK */
0x00C (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 OK */
0x010 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 OK */
0x014 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 OK */
0x018 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 OK */
0x01C (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 OK */
0x09C (PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_be0n_cle.gpio2_5 eMMC_RSTn OK */
nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins {
0x1b0 0x03 /* xdma_event_intr0, OMAP_MUX_MODE3 | AM33XX_PIN_OUTPUT */ /* setup as clockout 1 OK */
0x0a0 0x08 /* lcd_data0.lcd_data0, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0a4 0x08 /* lcd_data1.lcd_data1, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0a8 0x08 /* lcd_data2.lcd_data2, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0ac 0x08 /* lcd_data3.lcd_data3, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0b0 0x08 /* lcd_data4.lcd_data4, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0b4 0x08 /* lcd_data5.lcd_data5, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0b8 0x08 /* lcd_data6.lcd_data6, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA *OK */
0x0bc 0x08 /* lcd_data7.lcd_data7, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA *OK */
0x0c0 0x08 /* lcd_data8.lcd_data8, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA *OK */
0x0c4 0x08 /* lcd_data9.lcd_data9, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA *OK */
0x0c8 0x08 /* lcd_data10.lcd_data10, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0cc 0x08 /* lcd_data11.lcd_data11, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0d0 0x08 /* lcd_data12.lcd_data12, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0d4 0x08 /* lcd_data13.lcd_data13, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0d8 0x08 /* lcd_data14.lcd_data14, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0dc 0x08 /* lcd_data15.lcd_data15, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA OK */
0x0e0 0x00 /* lcd_vsync.lcd_vsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT OK */
0x0e4 0x00 /* lcd_hsync.lcd_hsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT OK */
0x0e8 0x00 /* lcd_pclk.lcd_pclk, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT OK */
0x0ec 0x00 /* lcd_ac_bias_en.lcd_ac_bias_en, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT OK */
nxp_hdmi_bonelt_off_pins: nxp_hdmi_bonelt_off_pins {
0x1b0 0x03 /* xdma_event_intr0, OMAP_MUX_MODE3 | AM33XX_PIN_OUTPUT */ /* turn off clock out */
mcasp0_pins: mcasp0_pins {
// need clock input here!
0x120 (PIN_INPUT_PULLUP | MUX_MODE6) /* MUX_MODE6 gmii1_txd2.mcasp0_ahclkx U15 */
0x19c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mcasp0_ahclkr.mcasp0_axr2 PIN C12*/
0x194 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx PIN B13*/
0x190 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx PIN A13*/
// need clock control output here
// 0x1A4 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO3_19 C13 */
mcasp0_pins_sleep: mcasp0_pins_sleep {
0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* MUX_MODE6 gmii1_txd2.mcasp0_ahclkx */
0x19c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mcasp0_ahclkr.mcasp0_axr2 */
0x194 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mcasp0_fsx.mcasp0_fsx */
0x190 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mcasp0_aclkx.mcasp0_aclkx */
// 0x1A4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 C13 */
&uart0 {
pinctrl-0 = <&uart0_pins>;
status = "okay";
&uart1 {
pinctrl-0 = <&uart1_pins>;
linux,rs485-enabled-at-boot-time;
rs485-rts-delay = <0 0>; // <a b> a for start of packet, b end of packet in milliseconds
rs485-rts-active-high; // sets rts active high
rts-gpio = <0x17C>;
status = "okay";
&uart2 {
pinctrl-0 = <&uart2_pins>;
rts-gpio = <0x118>;
status = "okay";
&usb {
status = "okay";
control@44e10620 {
status = "okay";
usb-phy@47401300 {
status = "okay";
usb-phy@47401b00 {
status = "okay";
usb@47401000 {
status = "okay";
dr_mode = "otg";
usb@47401800 {
status = "okay";
dr_mode = "otg";
dma-controller@47402000 {
status = "okay";
&i2c0 {
pinctrl-0 = <&i2c0_pins>;
status = "okay";
clock-frequency = <400000>;
tps: tps@2d {
reg = <0x2d>;
eeprom@50 {
compatible = "at,24c64";
reg = <0x50>;
eeprom@57 {
reg = <0x57>;
&epwmss0 {
status = "okay";
ecap0: ecap@48300100 {
status = "okay";
pinctrl-0 = <&ecap0_pins_default>;
pinctrl-1 = <&ecap0_pins_sleep>;
//Support for VTT Toggle
//In order to enable the support for VTT toggle during Suspend/Resume
//sequence needed by some boards (like AM335x EVM-SK & AM437x GP EVM),
//the below DT properties are required. It is possible to toggle VTT
//using one of two methods depending on the SoC being used, either
//GPIO0 toggle (AM335x and AM437x), or any GPIO with DS_PAD_CONFIG
//bits in the control module (AM437x only).
//Important Note:
//- Here it is assumed that VTT Toggle will be done using a pin on GPIO-0 Instance.
//It will not work on any other GPIO using the above properties, regardless of
//which part is being used.
//Example:
// wkup_m3: wkup_m3@44d00000 {
// compatible = "ti,am3353-wkup-m3";
// ti,needs-vtt-toggle;
// ti,vtt-gpio-pin = <7>;
// goes not work with gpio 1!!!
//&wkup_m3 {
// ti,vtt-gpio-pin = <&gpio1 28 GPIO_ACTIVE_HIGH>;
// ti,scale-data-fw = "am335x-evm-scale-data.bin";
#include "tps65910.dtsi"
&tps {
vcc1-supply = <&vbat>;
vcc2-supply = <&vbat>;
vcc3-supply = <&vbat>;
vcc4-supply = <&vbat>;
vcc5-supply = <&vbat>;
vcc6-supply = <&vbat>;
vcc7-supply = <&vbat>;
vccio-supply = <&vbat>;
regulators {
vrtc_reg: regulator@0 {
vio_reg: regulator@1 {
vdd1_reg: regulator@2 {
/* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */
regulator-name = "vdd_mpu";
regulator-min-microvolt = <912500>;
regulator-max-microvolt = <1378000>;
regulator-boot-on;
vdd2_reg: regulator@3 {
/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
regulator-name = "vdd_core";
regulator-max-microvolt = <1150000>;
regulator-boot-on;
vdd3_reg: regulator@4 {
vdig1_reg: regulator@5 {
vdig2_reg: regulator@6 {
vpll_reg: regulator@7 {
vdac_reg: regulator@8 {
vaux1_reg: regulator@9 {
vaux2_reg: regulator@10 {
vaux33_reg: regulator@11 {
vmmc_reg: regulator@12 {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <3300000>;
&cpsw_emac0 {
phy_id = <&davinci_mdio>, <0>;
phy-mode = "rmii";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
phy_id = <&davinci_mdio>, <1>;
phy-mode = "rmii";
dual_emac_res_vlan = <2>;
&phy_sel {
rmii-clock-ext;
&mac {
pinctrl-0 = <&cpsw_default>;
pinctrl-1 = <&cpsw_sleep>;
dual_emac = <1>;
&davinci_mdio {
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
&mmc1 {
status = "okay";
vmmc-supply = <&vmmc_reg>;
bus-width = <4>;
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_sleep>;
cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
//cd-inverted; //???
&mmc2 {
status = "okay";
ti,non-removable;
bus-width = <8>;
cap-power-off-card;
pinctrl-0 = <&mmc2_pins>;
&rtc {
ti,system-power-controller;
&lcdc {
status = "okay";
&mcasp0 {
pinctrl-0 = <&mcasp0_pins>;
pinctrl-1 = <&mcasp0_pins_sleep>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>; /* two channels per serializer */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 1 0 /* serilizer 2 active TX */
tx-num-evt = <1>;
rx-num-evt = <1>;
hdmi {
compatible = "ti,tilcdc,slave";
i2c = <&i2c0>;
pinctrl-names = "default", "off";
pinctrl-0 = <&nxp_hdmi_bonelt_pins>;
pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>;
status = "okay";
clk_mcasp0_fixed: clk_mcasp0_fixed {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24576000>;
clk_mcasp0: clk_mcasp0 {
#clock-cells = <0>;
compatible = "ti,gpio-gate-clock";
clocks = <&clk_mcasp0_fixed>;
// warning pin missed!
// enable-gpios = <&gpio3 19 0>; /* BeagleBone Black Clk enable on GPIO1_27 */
hdmi_audio: hdmi_audio@0 {
compatible = "linux,hdmi-audio";
status = "okay";
sound {
compatible = "ti,beaglebone-black-audio";
ti,model = "TI BeagleBone Black";
ti,audio-codec = <&hdmi_audio>;
ti,mcasp-controller = <&mcasp0>;
ti,audio-routing =
"HDMI Out", "TX";
clocks = <&clk_mcasp0>;
// ti,codec-clock-rate = <12000000>;
clock-names = "mclk";
