Need help in MP3 Decoding with FFMPEG and cross compilation for AM335x for Audio
We are AM335x and 3.14 kernel version with gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313  cross toolchain.
for ffmpeg cross compilation we are taken this reference :
compiling ffmpeg : in this below link
https://trac.ffmpeg.org/wiki/CompilationGuide/RaspberryPi
in some of the steps we are getting errors either in configuration or in building/compilation .
Ex: in this : ./configure --enable-cross-compile --cross-prefix=${CCPREFIX} --arch=armel --target-os=linux --prefix=/my/path/were/i/keep/built/arm/stuff
1.  --arch= ____ ??   2. --prefix= __ ?? --cross-prefix=arm-linux-gnueabihf(we are assuming toolchain).
please any one help in this.
regards,.
Viswanath K
  • forwarding this to the SW team.
  • Hi Viswanath,
    I advise to execute those steps from ti-sdk folder.
    Set "arch=arm", "prefix" should be the folder where you keep the Arago fs binaries and "cross-prefix" should be arm-linux-gnueabihf- .
    Also don't forget to export the PATH variable to point to your ti-sdk/linux-devkit/sysroot/i686-arago-linux/usr/bin.
    It will also be useful to source the environment-setup file.
    Yordan
  • Thank you Yordan.
    Thank you it is compiled and we are able to configure and make is also done with out error.
    Command:
    ./configure --enable-cross-compile --cross-prefix=arm-linux-gnueabihf- --arch=arm --target-os=arm-linux --prefix=/home/vk29835/ti-sdk-am335x-evm-08.00.00.00/filesystem/tisdk-rootfs-image-am335x-evm/usr --enable-gpl --enable-nonfree --extra-cflags="-I/home/vk29835/ti-sdk-am335x-evm-08.00.00.00/filesystem/tisdk-rootfs-image-am335x-evm/usr/include" --extra-ldflags="-L/home/vk29835/ti-sdk-am335x-evm-08.00.00.00/filesystem/tisdk-rootfs-image-am335x-evm/usr/lib" --extra-libs=-ldl
    here my doubt is: make : is it take as per configuration ..?? and
    make install : where it will install -- or do we need to give any another path with cross toolchain for the target. ???  or else.
    regards,
    Viswanath K
    Make install should put the output files (from the compilation) inside the specified --prefix path, in your case /ti-sdk-am335x-evm-08.00.00.00/filesystem/tisdk-rootfs-image-am335x-evm/usr
    You can either use make install, or manually copy each of the compiled files to your filesystem.
    Yordan
  • Thank you Yordan. I cross compiled ffmpeg successfully. But no Luck. ffplay is not generated and with ffmpeg we not able to play the mp3 file.
    and then we tried with gstreamer: gst-launch commands --- but still no luck
    Log for ffmpeg :
    root@am335x-evm:/usr# ffplay
    -sh: ffplay: command not found
    root@am335x-evm:/usr# ffmpeg
    ffmpeg version N-73902-g6b2bb3d Copyright (c) 2000-2015 the FFmpeg developers
    built with gcc 4.7.3 (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) 20130226 (prerelease)
    configuration: --enable-cross-compile --cross-prefix=arm-linux-gnueabihf- --arch=arm --target-os=linux --prefix=/home/vk29835/ti-sdk-l
    libavutil 54. 28.100 / 54. 28.100
    libavcodec 56. 50.101 / 56. 50.101
    libavformat 56. 40.101 / 56. 40.101
    libavdevice 56. 4.100 / 56. 4.100
    libavfilter 5. 25.100 / 5. 25.100
    libswscale 3. 1.101 / 3. 1.101
    libswresample 1. 2.101 / 1. 2.101
    libpostproc 53. 3.100 / 53. 3.100
    Hyper fast Audio and Video encoder
    usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
    Use -h to get full help or, even better, run 'man ffmpeg'
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3
    [mp3 @ 0x1169d30] Skipping 417 bytes of junk at 4096.
    [mp3 @ 0x1169d30] Estimating duration from bitrate, this may be inaccurate
    Input #0, mp3, from '03Varaveena.mp3':
    Metadata:
    album : Andhrawave.com
    track : 3
    genre : Other
    date : 2008
    Duration: 00:03:52.13, start: 0.000000, bitrate: 128 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
    At least one output file must be specified
    root@am335x-evm:/usr# aplay -L
    null
    Discard all samples (playback) or generate zero samples (capture)
    default:CARD=AM335xEVMSK
    AM335x-EVMSK,
    Default Audio Device
    sysdefault:CARD=AM335xEVMSK
    AM335x-EVMSK,
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -f alsa hw:0
    [mp3 @ 0x1171560] Skipping 417 bytes of junk at 4096.
    [mp3 @ 0x1171560] Estimating duration from bitrate, this may be inaccurate
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [NULL @ 0x1173210] Requested output format 'alsa' is not a suitable output format
    hw:0: Invalid argument
    root@am335x-evm:/usr# alsa
    -sh: alsa: command not found
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 hw:0
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [NULL @ 0x1173600] Unable to find a suitable output format for 'hw:0'
    root@am335x-evm:/usr# ffmpeg -codecs
    Codecs:
    D..... = Decoding supported
    .E.... = Encoding supported
    ..V... = Video codec
    ..A... = Audio codec
    ..S... = Subtitle codec
    ...I.. = Intra frame-only codec
    ....L. = Lossy compression
    .....S = Lossless compression
    -------below all supported codec list was came
    Metadata:
    track : 3
    genre : Other
    date : 2008
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -c:a pcm hw:0
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [NULL @ 0x1173210] Unable to find a suitable output format for 'hw:0'
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -acodec alsa hw:0
    Metadata:
    track : 3
    genre : Other
    date : 2008
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -acodec alsa ""
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [NULL @ 0x1173210] Unable to find a suitable output format for ''
    : Invalid argument
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -f alsa "hw:0"
    Metadata:
    track : 3
    genre : Other
    date : 2008
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.wav -f alsa "hw:0"
    Guessed Channel Layout for Input Stream #0.0 : stereo
    Input #0, wav, from '03Varaveena.wav':
    Duration: 00:03:52.12, bitrate: 1411 kb/s
    Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 44100 Hz, 2 channels, s16, 1411 kb/s
    [NULL @ 0x11b1150] Requested output format 'alsa' is not a suitable output format
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.wav "hw:0"
    [NULL @ 0x11b1150] Unable to find a suitable output format for 'hw:0'
    root@am335x-evm:/usr# ffmpeg -i file -f alsa plughw:0,3
    file: No such file or directory
    root@am335x-evm:/usr# ffmpeg -i 03Varaveena.mp3 -f alsa plughw:0,3
    Metadata:
    track : 3
    genre : Other
    date : 2008
    plughw:0,3: Invalid argument
    Metadata:
    track : 3
    genre : Other
    date : 2008
    plughw:0: Invalid argument oot@am335x-evm:/usr# ffmpeg -loglevel debug
    root@am335x-evm:/usr# ffmpeg -loglevel debug -i 03Varaveena.mp3 -f alsa plughw:0
    Splitting the commandline.
    Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
    Reading option '-i' ... matched as input file with argument '03Varaveena.mp3'.
    Reading option '-f' ... matched as option 'f' (force format) with argument 'alsa'.
    Reading option 'plughw:0' ... matched as output file.
    Finished splitting the commandline.
    Parsing a group of options: global .
    Applying option loglevel (set logging level) with argument debug.
    Successfully parsed a group of options.
    Parsing a group of options: input file 03Varaveena.mp3.
    Opening an input file: 03Varaveena.mp3.
    [mp3 @ 0x11714f0] Format mp3 probed with size=8192 and score=51
    [mp3 @ 0x11714f0] id3v2 ver:3 flags:00 len:4086
    [mp3 @ 0x11714f0] Skipping 417 bytes of junk at 4096.
    [mp3 @ 0x11714f0] Before avformat_find_stream_info() pos: 4513 bytes read:32768 seeks:0
    [mp3 @ 0x11714f0] All info found
    [mp3 @ 0x11714f0] Estimating duration from bitrate, this may be inaccurate
    [mp3 @ 0x11714f0] After avformat_find_stream_info() pos: 26017 bytes read:32768 seeks:0 frames:50
    Metadata:
    track : 3
    genre : Other
    date : 2008
    Stream #0:0, 50, 1/14112000: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
    Successfully opened the file.
    Parsing a group of options: output file plughw:0.
    Applying option f (force format) with argument alsa.
    Opening an output file: plughw:0.
    [NULL @ 0x1173490] Requested output format 'alsa' is not a suitable output format
    root@am335x-evm:/usr# ffmpeg -loglevel debug -i 03Varaveena.mp3 plughw:
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [NULL @ 0x11734f0] Unable to find a suitable output format for 'plughw:0'
    [AVIOContext @ 0x1170ca0] Statistics: 32768 bytes read, 0 seeks
    root@am335x-evm:/usr# ffmpeg -loglevel debug -i 03Varaveena.mp3 "plughw:0"
    Metadata:
    track : 3
    genre : Other
    date : 2008
    root@am335x-evm:/usr# ffmpeg -loglevel debug -i 03Varaveena.mp3 -f wav
    Reading option '-f' ... matched as option 'f' (force format) with argument 'wav'.
    Trailing options were found on the commandline.
    [mp3 @ 0x1169d50] Format mp3 probed with size=8192 and score=51
    [mp3 @ 0x1169d50] id3v2 ver:3 flags:00 len:4086
    [mp3 @ 0x1169d50] Skipping 417 bytes of junk at 4096.
    [mp3 @ 0x1169d50] Before avformat_find_stream_info() pos: 4513 bytes read:32768 seeks:0
    [mp3 @ 0x1169d50] All info found
    [mp3 @ 0x1169d50] Estimating duration from bitrate, this may be inaccurate
    [mp3 @ 0x1169d50] After avformat_find_stream_info() pos: 26017 bytes read:32768 seeks:0 frames:50
    Metadata:
    track : 3
    genre : Other
    date : 2008
    [AVIOContext @ 0x11722f0] Statistics: 32768 bytes read, 0 seeks
    root@am335x-evm:/usr# ffmpeg -loglevel debug -i 03Varaveena.mp3 -f wav ""
    Reading option '' ... matched as output file.
    Metadata:
    track : 3
    genre : Other
    date : 2008
    Parsing a group of options: output file .
    Applying option f (force format) with argument wav.
    Opening an output file: .
    root@am335x-evm:/usr# apt-get
    -sh: apt-get: command not found
    root@am335x-evm:/usr# ls
    03Varaveena.mp3 mpg123
    03Varaveena.wav sbin
    5706.chkusb.sh share
    arm-oe-linux-gnueabi src
    bin tailyn
    games tailyn_bk
    include test_beep
    lib test_stereo_48000Hz_8bit_PCM.wav
    libexec usbreg.sh
    root@am335x-evm:/usr# cd lib
    root@am335x-evm:/usr/lib# ls
    ES3.0
    ES5.0
    ES6.0
    ES8.0
    ES9.0
    alsa-lib
    crda
    dbus
    e2initrd_helper
    elfutils
    engines
    fonts
    gio
    gstreamer
    gstreamer-0.10
    libEGL.so
    libEGL.so.1
    libEGL.so.1.10
    libEGL.so.1.10.2359475
    libEGL_eglimage.so
    libEGL_eglimage.so.1
    libEGL_eglimage.so.1.10
    libEGL_eglimage.so.1.10.2359475
    libFLAC.so.8
    libFLAC.so.8.3.0
    libGLES_CM.so
    libGLES_CM.so.1
    libGLES_CM.so.1.10
    libGLES_CM.so.1.10.2359475
    libGLES_CM_eglimage.so
    libGLES_CM_eglimage.so.1
    libGLES_CM_eglimage.so.1.10
    libGLES_CM_eglimage.so.1.10.2359475
    libGLESv2.so
    libGLESv2.so.1
    libGLESv2.so.1.10
    libGLESv2.so.1.10.2359475
    and so on complete list of files in /usr/lib.
    log for gstreamer:
    root@am335x-evm:/usr# gst-launch -p 03Varaveena.wav
    /usr/bin/gst-launch-0.10 03Varaveena.wav
    (gst-plugin-scanner:1587): GLib-GObject-WARNING **: cannot register existing type 'GstVorbisDec'
    (gst-plugin-scanner:1587): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
    (gst-plugin-scanner:1587): GStreamer-CRITICAL **: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
    ERROR: pipeline could not be constructed: Unrecoverable syntax error while parsing pipeline 03Varaveena.wav .
    root@am335x-evm:/usr# gst-launch-1.0 playbin uri=03Varaveena.wav
    -sh: gst-launch-1.0: command not found
    root@am335x-evm:/usr# gst-launch playbin uri=03Varaveena.wav
    Setting pipeline to PAUSED ...
    ERROR: Pipeline doesn't want to pause.
    ERROR: from element /GstPlayBin:playbin0: Invalid URI "03Varaveena.wav".
    Additional debug info:
    /home/jenkins/amsdk-nightly-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8t2hf-vfp-neon-oe-linux-gnueabi/gst-pl0
    Setting pipeline to NULL ...
    Freeing pipeline ...
    root@am335x-evm:/usr# pwd
    /usr
    root@am335x-evm:/usr# gst-launch playbin uri=file:///usr/03Varaveena.wav
    Pipeline is PREROLLING ...
    [ 276.471106] davinci_mcasp_startup:dir:1 substream->stream:0
    [ 276.655239] ## aic31xx_set_dai_sysclk: clk_id = 0, freq = 24000000, dir = 1
    [ 276.662646] davinci_mcasp_set_sysclk:mcasp->sysclk_freq:24000000 ; dir:1
    [ 276.676648] ## aic31xx_setup_pll: mclk_p:12000000 bclk_n:8 bclk_score:0 match:15
    [ 276.684623] davinci-mcasp 4803c000.mcasp: Inaccurate BCLK: 24000000 Hz / 17 != 1411200 Hz
    [ 276.693181] davinci_mcasp_hw_params:mcasp->sysclk_freq:24000000 bclk_freq:1411200
    [ 276.701131] davinci_mcasp_hw_params:word_length:16
    [ 276.723906] ## aic31xx_dapm_power_event:event:2 w->reg:63 w->shift:7
    [ 276.730717] ##PMU: reg:0x25:mask:128
    [ 276.737502] ## aic31xx_dapm_power_event:event:2 w->reg:160 w->shift:7
    [ 276.744426] ##PMU: reg:0x25:mask:16
    [ 276.750625] ## Speaker connected
    Pipeline is PREROLLED ...
    Setting pipeline to PLAYING ...
    [ 276.873943] davinci_mcasp_start:
    [ 276.877361] mcasp_start_tx:
    New clock: GstAudioSinkClock
    ^CCaught interrupt -- handling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 6264915335 ns.
    Setting [ 283.155199] mcasp_stop_tx:
    [ 283.161703] ## Speaker connected
    Setting pipeline to READY ...
    [ 283.286295] ## Speaker connected
    root@am335x-evm:/usr# gst-launch playbin uri=file:///usr/03Varaveena.mp3
    [ 288.565272] ## aic31xx_dapm_power_event:event:8 w->reg:160 w->shift:7
    [ 288.572242] ##PMD: reg:0x25:mask:16
    [ 288.595857] ## aic31xx_dapm_power_event:event:8 w->reg:63 w->shift:7
    [ 288.602663] ##PMD: reg:0x25:mask:128
    ** Message: don't know how to handle audio/mpeg, mpegversion=(int)1, mpegaudioversion=(int)1, layer=(int)3, rate=(int)44100, channels=(e
    Missing element: MPEG-1 Layer 3 (MP3) decoder
    ERROR: from element /GstPlayBin:playbin0: You do not have a decoder installed to handle this file. You might need to install the necess.
    ERROR: pipeline doesn't want to preroll.
    root@am335x-evm:/usr# [ 289.677309] tlv320aic31xx-codec 0-0018: aic31xx_wait_bits: Failed! 0x25 was 0x88 expected 0x0 (0, 0x80, 500000)
    [ 289.688291] tlv320aic31xx-codec 0-0018: ASoC: POST_PMD: DAC Left event failed: -1
    //--------------this is the log for the ffmpeg and gstreamer.
    Please anyone help in this.
    regards,
    Viswanath K
