udev reaching timeout
Dear Ti E2E community
Am using ti sdk 8 & arago-base-tisdk-image-am335x-evm rootfs & am working on boot time reduction
when I boot, udev is reaching its timeout. how can I edit the rules files to avoid this? the remaining queue entries , which relate to mmc, sound/controlc0,  /sys/devices/virtual/block/ram0, USB
udevadm settle - timeout of 3 seconds reached, the event queue contains:
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p1 (692)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p2 (693)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p3 (694)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p4 (695)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p5 (696)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p6 (697)
/sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0p7 (698)
/sys/devices/sound.17/sound/card0/controlC0 (801)
/sys/devices/virtual/net/lo (863)
/sys/devices/ocp.3/47400000.usb/44e10620.control (870)
/sys/devices/ocp.3/47400000.usb/47401300.usb-phy (871)
/sys/devices/ocp.3/47400000.usb/47401400.usb (873)
/sys/devices/ocp.3/47400000.usb/47401b00.usb-phy (874)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller (875)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan0 (876)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan1 (877)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan2 (878)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan3 (879)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan4 (880)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan5 (881)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan6 (882)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan7 (883)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan8 (884)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan9 (885)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan10 (886)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan11 (887)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan12 (888)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan13 (889)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan14 (890)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan15 (891)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan16 (892)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan17 (893)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan18 (894)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan19 (895)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan20 (896)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan21 (897)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan22 (898)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan23 (899)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan24 (900)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan25 (901)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1cha[ 8.122336] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
n26 (902)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan27 (903)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan28 (904)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan29 (905)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan30 (906)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan31 (907)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan32 (908)
/sys/devices/ocp.3/[ 8.173470] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
47400000.usb/47400000.dma-controller/dma/dma1chan33 (909)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan34 (910)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan35 (911)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan36 (912)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan37 (913)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan38 (914)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan39 (915)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan40 (916)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan41 (917)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan42 (918)
/sys/devices/ocp.3/47400000.usb/47400000.dma-controller/dma/dma1chan43 (919)
Kindly do the needful as early as possible
Many Thanks in advance
    I will forward this to the SW team.
  • Hello Srini,
    You can change the udev timeout through these steps:
    update-rc.d -f udev remove
    vi /etc/init.d/udev #search for udevadm settle --timeout=3 and replace the value with your prefered one
    update-rc.d -v udev start 04 S .
    Kemal
  • Dear Kemal,
    Thanks a lot for your quick responses
    Is there any harm in disabling those messages any kernel configuration needs to be done inorder to disable those messages or any rootfs services needs to be edited, because this is still time consuming
    /sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001 (688)
    /sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0 (689)
    /sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0boot0 (690)
    /sys/devices/ocp.3/481d8000.mmc/mmc_host/mmc1/mmc1:0001/block/mmcblk0/mmcblk0boot1 (691)
    /sys/devices/ocp.3/48302000.epwmss/48302200.ehrpwm (701)
    /sys/devices/ocp.3/48302000.epwmss/48302200.ehrpwm/pwm/pwmchip0 (702)
    /sys/devices/ocp.3/4a100000.ethernet (706)
    /sys/devices/ocp.3/4a100000.ethernet/44e10650.cpsw-phy-sel (707)
    /sys/devices/ocp.3/4a100000.ethernet/4a101000.mdio (708)
    /sys/devices/ocp.3/4a100000.ethernet/4a101000.mdio/4a101000.mdio:01 (709)
    /sys/devices/ocp.3/4a100000.ethernet/4a101000.mdio/mdio_bus/4a101000.mdio (710)
    /sys/devices/ocp.3/4a100000.ethernet/net/eth0 (711)
    /sys/devices/ocp.3/4a300000.pruss (712)
    /sys/devices/ocp.3/53100000.sham (713)
    /sys/devices/ocp.3/53500000.aes (714)
    /sys/devices/ocp.3/56000000.sgx (715)
    /sys/devices/output_relay.10 (716)
    /sys/devices/platform/alarmtimer (717)
    Let me know whether there is any chance to avoid throwing the above messages
    Many Thanks in advance,
  • Dear Kemal
    Could you please provide any updates how this messages can be disabled any chances in kernel configuration???
    Many thanks in advance
  • Do you have plans to attach hot-plug devices on it?
  • Dear Kemal,
    Did you mean hot-plug devices mean only USB??? yes we are using USB in our application but we are not using SD & we are using EMMC
  • Set the udevadm settle --timeout=0 and it will skip the udev event queueing on boot time.
  • Thats true Kemal!!! greatly appreciate your prompt support many many thanks once again
  • You are welcome!
