Other Parts Discussed in Thread: AM4372
Hi:
We are using AM4376 to do some developments.
Now we confronted a problem that is the L3 error while interrupt handling occurs.
Due to there is no related information for L3F_CFG in TRM, we could not debug for this issue.
The following is the log :
Please give me some advise or hint, thanks.
[Tue Dec 08 09:39:52.978 2015] [Tue Dec 08 09:39:52.978 2015] U-Boot SPL 2014.07-gaa8e1f0 (Dec 08 2015 - 09:30:25) [Tue Dec 08 09:39:53.001 2015] Could not probe the EEPROM at 0x50 [Tue Dec 08 09:39:53.001 2015] Could not get board ID. [Tue Dec 08 09:39:53.208 2015] SPL: Please implement spl_start_uboot() for your board [Tue Dec 08 09:39:53.208 2015] SPL: Direct Linux boot not active! [Tue Dec 08 09:39:53.208 2015] reading u-boot.img [Tue Dec 08 09:39:53.208 2015] reading u-boot.img [Tue Dec 08 09:39:53.223 2015] [Tue Dec 08 09:39:53.223 2015] [Tue Dec 08 09:39:53.223 2015] U-Boot 2014.07-gaa8e1f0 (Dec 08 2015 - 09:30:25) [Tue Dec 08 09:39:53.238 2015] [Tue Dec 08 09:39:53.238 2015] I2C: ready [Tue Dec 08 09:39:53.288 2015] DRAM: 512 MiB [Tue Dec 08 09:39:53.336 2015] MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 [Tue Dec 08 09:39:53.360 2015] Card did not respond to voltage select! [Tue Dec 08 09:39:53.361 2015] MMC init failed [Tue Dec 08 09:39:53.361 2015] Using default environment [Tue Dec 08 09:39:53.361 2015] [Tue Dec 08 09:39:53.426 2015] Could not probe the EEPROM at 0x50 [Tue Dec 08 09:39:53.426 2015] Could not get board ID. [Tue Dec 08 09:39:53.426 2015] Net: Net Initialization Skipped [Tue Dec 08 09:39:53.426 2015] No ethernet found. [Tue Dec 08 09:39:53.426 2015] Hit any key to stop autoboot: 1 0 [Tue Dec 08 09:39:54.514 2015] switch to partitions #0, OK [Tue Dec 08 09:39:54.514 2015] mmc0 is current device [Tue Dec 08 09:39:54.591 2015] SD/MMC found on device 0 [Tue Dec 08 09:39:54.614 2015] reading uEnv.txt [Tue Dec 08 09:39:54.614 2015] ** Unable to read file uEnv.txt ** [Tue Dec 08 09:39:54.870 2015] 4500584 bytes read in 263 ms (16.3 MiB/s) [Tue Dec 08 09:39:54.918 2015] 45158 bytes read in 9 ms (4.8 MiB/s) [Tue Dec 08 09:39:54.918 2015] Booting from mmc0 ... [Tue Dec 08 09:39:54.918 2015] Kernel image @ 0x82000000 [ 0x000000 - 0x44ac68 ] [Tue Dec 08 09:39:54.918 2015] ## Flattened Device Tree blob at 88000000 [Tue Dec 08 09:39:54.918 2015] Booting using the fdt blob at 0x88000000 [Tue Dec 08 09:39:54.918 2015] Loading Device Tree to 8fff1000, end 8ffff065 ... OK [Tue Dec 08 09:39:54.918 2015] [Tue Dec 08 09:39:54.918 2015] Starting kernel ... [Tue Dec 08 09:39:54.918 2015] [Tue Dec 08 09:39:55.747 2015] [ 0.000000] Booting Linux on physical CPU 0x0 [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Linux version 3.14.43-rt42-g2d2fe37-dirty (cindylin@linuxserver-OptiPlex-9020 linuxserver) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #3 PREEMPT RT Tue Dec 8 09:17:28 CST 2015 [Tue Dec 08 09:39:56.097 2015] [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [Tue Dec 08 09:39:56.097 2015] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Machine model: LITEON AM437x LP32cm EVT [Tue Dec 08 09:39:56.097 2015] [ 0.000000] cma: CMA: reserved 24 MiB at 9e400000 [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Memory policy: Data cache writeback [Tue Dec 08 09:39:56.097 2015] [ 0.000000] CPU: All CPU(s) started in SVC mode. [Tue Dec 08 09:39:56.097 2015] [ 0.000000] AM437x ES1.2 (neon ) [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129536 [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Kernel command line: console=ttyO0,115200n8 psplash=false root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait [Tue Dec 08 09:39:56.097 2015] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [Tue Dec 08 09:39:56.097 2015] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] Memory: 483760K/522240K available (6079K kernel code, 327K rwdata, 2200K rodata, 271K init, 259K bss, 38480K reserved, 0K highmem) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] Virtual kernel memory layout: [Tue Dec 08 09:39:56.103 2015] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] .text : 0xc0008000 - 0xc081e0c4 (8281 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] .init : 0xc081f000 - 0xc0862ff4 ( 272 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] .data : 0xc0864000 - 0xc08b5eb8 ( 328 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] .bss : 0xc08b5ec4 - 0xc08f6e78 ( 260 kB) [Tue Dec 08 09:39:56.103 2015] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [Tue Dec 08 09:39:56.109 2015] [ 0.000000] Preemptible hierarchical RCU implementation. [Tue Dec 08 09:39:56.109 2015] [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [Tue Dec 08 09:39:56.109 2015] [ 0.000000] GIC CPU mask not found - kernel will fail to boot. [Tue Dec 08 09:39:56.109 2015] [ 0.000000] GIC CPU mask not found - kernel will fail to boot. [Tue Dec 08 09:39:56.109 2015] [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [Tue Dec 08 09:39:56.109 2015] [ 0.000024] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns [Tue Dec 08 09:39:56.109 2015] [ 0.000042] OMAP clocksource: timer1 at 24000000 Hz [Tue Dec 08 09:39:56.109 2015] [ 0.000243] Console: colour dummy device 80x30 [Tue Dec 08 09:39:56.109 2015] [ 0.000369] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [Tue Dec 08 09:39:56.109 2015] [ 0.000371] This ensures that you still see kernel messages. Please [Tue Dec 08 09:39:56.109 2015] [ 0.000373] update your kernel commandline. [Tue Dec 08 09:39:56.109 2015] [ 0.059088] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664) [Tue Dec 08 09:39:56.109 2015] [ 0.059095] pid_max: default: 32768 minimum: 301 [Tue Dec 08 09:39:56.109 2015] [ 0.059270] Security Framework initialized [Tue Dec 08 09:39:56.109 2015] [ 0.059349] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [Tue Dec 08 09:39:56.109 2015] [ 0.059363] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [Tue Dec 08 09:39:56.113 2015] [ 0.068063] CPU: Testing write buffer coherency: ok [Tue Dec 08 09:39:56.113 2015] [ 0.068475] Setting up static identity map for 0x805f57f0 - 0x805f5848 [Tue Dec 08 09:39:56.113 2015] [ 0.068629] L310 cache controller enabled [Tue Dec 08 09:39:56.113 2015] [ 0.068653] l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x7e030000, Cache size: 256 kB [Tue Dec 08 09:39:56.113 2015] [ 0.070146] devtmpfs: initialized [Tue Dec 08 09:39:56.113 2015] [ 0.073221] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [Tue Dec 08 09:39:56.113 2015] [ 0.093713] omap_hwmod: tptc0 using broken dt data from edma [Tue Dec 08 09:39:56.113 2015] [ 0.093875] omap_hwmod: tptc1 using broken dt data from edma [Tue Dec 08 09:39:56.113 2015] [ 0.094019] omap_hwmod: tptc2 using broken dt data from edma [Tue Dec 08 09:39:56.113 2015] [ 0.158144] omap_hwmod: dss_dispc: cannot be enabled for reset (3) [Tue Dec 08 09:39:56.113 2015] [ 0.161464] omap_hwmod: dss_rfbi: cannot be enabled for reset (3) [Tue Dec 08 09:39:56.113 2015] [ 0.170816] omap_hwmod: rtc: _wait_target_disable failed [Tue Dec 08 09:39:56.113 2015] [ 0.171557] pinctrl core: initialized pinctrl subsystem [Tue Dec 08 09:39:56.113 2015] [ 0.172727] regulator-dummy: no parameters [Tue Dec 08 09:39:56.446 2015] [ 0.174708] NET: Registered protocol family 16 [Tue Dec 08 09:39:56.446 2015] [ 0.176543] DMA: preallocated 256 KiB pool for atomic coherent allocations [Tue Dec 08 09:39:56.446 2015] [ 0.179623] cpuidle: using governor ladder [Tue Dec 08 09:39:56.446 2015] [ 0.179637] cpuidle: using governor menu [Tue Dec 08 09:39:56.446 2015] [ 0.202507] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107f3] registered [Tue Dec 08 09:39:56.446 2015] [ 0.203598] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable) [Tue Dec 08 09:39:56.446 2015] [ 0.203627] omap_l3_noc 44000000.ocp: L3 debug error: target 13 mod:1 (unclearable) [Tue Dec 08 09:39:56.446 2015] [ 0.203780] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable) [Tue Dec 08 09:39:56.446 2015] [ 0.203801] ------------[ cut here ]------------ [Tue Dec 08 09:39:56.446 2015] [ 0.203834] WARNING: CPU: 0 PID: 51 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x234/0x35c() [Tue Dec 08 09:39:56.446 2015] [ 0.203846] 44000000.ocp:L3 Custom Error: MASTER M2 (64-bit) TARGET L4_WKUP (Read): Data Access in User mode during Functional access [Tue Dec 08 09:39:56.446 2015] [ 0.203853] Modules linked in: [Tue Dec 08 09:39:56.446 2015] [ 0.203870] CPU: 0 PID: 51 Comm: irq/42-l3-app-i Not tainted 3.14.43-rt42-g2d2fe37-dirty #3 [Tue Dec 08 09:39:56.455 2015] [ 0.203880] Backtrace: [Tue Dec 08 09:39:56.455 2015] [ 0.203911] [<c0011370>] (dump_backtrace) from [<c001150c>] (show_stack+0x18/0x1c) [Tue Dec 08 09:39:56.455 2015] [ 0.203919] r6:00000093 r5:00000009 r4:ddd61e38 r3:00000000 [Tue Dec 08 09:39:56.455 2015] [ 0.203948] [<c00114f4>] (show_stack) from [<c05ed5b0>] (dump_stack+0x20/0x28) [Tue Dec 08 09:39:56.455 2015] [ 0.203967] [<c05ed590>] (dump_stack) from [<c00386ec>] (warn_slowpath_common+0x6c/0x8c) [Tue Dec 08 09:39:56.455 2015] [ 0.203979] [<c0038680>] (warn_slowpath_common) from [<c00387b0>] (warn_slowpath_fmt+0x38/0x40) [Tue Dec 08 09:39:56.455 2015] [ 0.203986] r8:c061b294 r7:c0785c1c r6:c0785828 r5:80080003 r4:ddcfa850 [Tue Dec 08 09:39:56.455 2015] [ 0.204014] [<c003877c>] (warn_slowpath_fmt) from [<c02a31b8>] (l3_interrupt_handler+0x234/0x35c) [Tue Dec 08 09:39:56.455 2015] [ 0.204020] r3:ddcf4d40 r2:c07858e8 [Tue Dec 08 09:39:56.455 2015] [ 0.204048] [<c02a2f84>] (l3_interrupt_handler) from [<c006bb4c>] (irq_forced_thread_fn+0x28/0x5c) [Tue Dec 08 09:39:56.455 2015] [ 0.204055] r10:ddc06000 r9:c006bb24 r8:00000001 r7:ddd60000 r6:ddce8100 r5:ddc06000 [Tue Dec 08 09:39:56.455 2015] [ 0.204077] r4:ddce8100 [Tue Dec 08 09:39:56.455 2015] [ 0.204091] [<c006bb24>] (irq_forced_thread_fn) from [<c006b884>] (irq_thread+0xe0/0x138) [Tue Dec 08 09:39:56.464 2015] [ 0.204097] r6:ddce8100 r5:00000000 r4:ddce8100 r3:ddd58a00 [Tue Dec 08 09:39:56.464 2015] [ 0.204132] [<c006b7a4>] (irq_thread) from [<c00534b8>] (kthread+0xbc/0xd4) [Tue Dec 08 09:39:56.464 2015] [ 0.204139] r10:00000000 r9:00000000 r8:00000000 r7:c006b7a4 r6:ddce8100 r5:ddce8000 [Tue Dec 08 09:39:56.464 2015] [ 0.204160] r4:00000000 [Tue Dec 08 09:39:56.464 2015] [ 0.204175] [<c00533fc>] (kthread) from [<c000e918>] (ret_from_fork+0x14/0x3c) [Tue Dec 08 09:39:56.464 2015] [ 0.204182] r7:00000000 r6:00000000 r5:c00533fc r4:ddce8000 [Tue Dec 08 09:39:56.464 2015] [ 0.204200] ---[ end trace 0000000000000001 ]--- [Tue Dec 08 09:39:56.464 2015] [ 0.204223] omap_l3_noc 44000000.ocp: L3 application error: target 13 mod:1 (unclearable) [Tue Dec 08 09:39:56.464 2015] [ 0.205256] platform 49000000.edma: alias fck already exists [Tue Dec 08 09:39:56.464 2015] [ 0.205279] platform 49000000.edma: alias fck already exists [Tue Dec 08 09:39:56.464 2015] [ 0.205292] platform 49000000.edma: alias fck already exists [Tue Dec 08 09:39:56.464 2015] [ 0.210147] OMAP GPIO hardware version 0.1 [Tue Dec 08 09:39:56.464 2015] [ 0.230964] No ATAGs? [Tue Dec 08 09:39:56.464 2015] [ 0.230996] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [Tue Dec 08 09:39:56.464 2015] [ 0.231008] hw-breakpoint: maximum watchpoint size is 4 bytes. [Tue Dec 08 09:39:56.464 2015] [ 0.269085] bio: create slab <bio-0> at 0 [Tue Dec 08 09:39:56.471 2015] [ 0.290830] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [Tue Dec 08 09:39:56.471 2015] [ 0.292123] evm_v3_3d: 3300 mV [Tue Dec 08 09:39:56.471 2015] [ 0.292739] vtt_fixed: 1500 mV [Tue Dec 08 09:39:56.471 2015] [ 0.293355] vmmcwl_fixed: 1800 mV [Tue Dec 08 09:39:56.471 2015] [ 0.297276] vgaarb: loaded [Tue Dec 08 09:39:56.471 2015] [ 0.297950] i2c-core: driver [palmas] using legacy suspend method [Tue Dec 08 09:39:56.471 2015] [ 0.297962] i2c-core: driver [palmas] using legacy resume method [Tue Dec 08 09:39:56.471 2015] [ 0.298813] SCSI subsystem initialized [Tue Dec 08 09:39:56.471 2015] [ 0.301508] usbcore: registered new interface driver usbfs [Tue Dec 08 09:39:56.471 2015] [ 0.301753] usbcore: registered new interface driver hub [Tue Dec 08 09:39:56.471 2015] [ 0.302016] usbcore: registered new device driver usb [Tue Dec 08 09:39:56.471 2015] [ 0.303307] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/i2c0_pins, deferring probe [Tue Dec 08 09:39:56.471 2015] [ 0.303338] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral [Tue Dec 08 09:39:56.471 2015] [ 0.303369] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/i2c1_pins_default, deferring probe [Tue Dec 08 09:39:56.471 2015] [ 0.303385] platform 4802a000.i2c: Driver omap_i2c requests probe deferral [Tue Dec 08 09:39:56.785 2015] [ 0.303413] omap_i2c 4819c000.i2c: could not find pctldev for node /pinmux@44e10800/i2c2_pins, deferring probe [Tue Dec 08 09:39:56.785 2015] [ 0.303428] platform 4819c000.i2c: Driver omap_i2c requests probe deferral [Tue Dec 08 09:39:56.785 2015] [ 0.303934] pps_core: LinuxPPS API ver. 1 registered [Tue Dec 08 09:39:56.785 2015] [ 0.303947] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [Tue Dec 08 09:39:56.785 2015] [ 0.304119] PTP clock support registered [Tue Dec 08 09:39:56.785 2015] [ 0.306886] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [Tue Dec 08 09:39:56.785 2015] [ 0.308387] Advanced Linux Sound Architecture Driver Initialized. [Tue Dec 08 09:39:56.785 2015] [ 0.311037] Switched to clocksource timer1 [Tue Dec 08 09:39:56.785 2015] [ 0.335261] NET: Registered protocol family 2 [Tue Dec 08 09:39:56.785 2015] [ 0.336011] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [Tue Dec 08 09:39:56.785 2015] [ 0.336083] TCP bind hash table entries: 4096 (order: 4, 98304 bytes) [Tue Dec 08 09:39:56.785 2015] [ 0.336375] TCP: Hash tables configured (established 4096 bind 4096) [Tue Dec 08 09:39:56.785 2015] [ 0.336485] TCP: reno registered [Tue Dec 08 09:39:56.785 2015] [ 0.336505] UDP hash table entries: 256 (order: 2, 16384 bytes) [Tue Dec 08 09:39:56.799 2015] [ 0.336564] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes) [Tue Dec 08 09:39:56.799 2015] [ 0.336926] NET: Registered protocol family 1 [Tue Dec 08 09:39:56.799 2015] [ 0.337499] RPC: Registered named UNIX socket transport module. [Tue Dec 08 09:39:56.799 2015] [ 0.337514] RPC: Registered udp transport module. [Tue Dec 08 09:39:56.799 2015] [ 0.337522] RPC: Registered tcp transport module. [Tue Dec 08 09:39:56.799 2015] [ 0.337529] RPC: Registered tcp NFSv4.1 backchannel transport module. [Tue Dec 08 09:39:56.799 2015] [ 0.339346] omap_timer 48044000.timer: could not find pctldev for node /pinmux@44e10800/timer1_pins, deferring probe [Tue Dec 08 09:39:56.799 2015] [ 0.339376] platform 48044000.timer: Driver omap_timer requests probe deferral [Tue Dec 08 09:39:56.799 2015] [ 0.339409] omap_timer 48046000.timer: could not find pctldev for node /pinmux@44e10800/timer2_pins, deferring probe [Tue Dec 08 09:39:56.799 2015] [ 0.339424] platform 48046000.timer: Driver omap_timer requests probe deferral [Tue Dec 08 09:39:56.799 2015] [ 0.339453] omap_timer 48048000.timer: could not find pctldev for node /pinmux@44e10800/timer3_pins, deferring probe [Tue Dec 08 09:39:56.799 2015] [ 0.339468] platform 48048000.timer: Driver omap_timer requests probe deferral [Tue Dec 08 09:39:56.799 2015] [ 0.339495] omap_timer 4804a000.timer: could not find pctldev for node /pinmux@44e10800/timer4_pins, deferring probe [Tue Dec 08 09:39:56.809 2015] [ 0.339509] platform 4804a000.timer: Driver omap_timer requests probe deferral [Tue Dec 08 09:39:56.809 2015] [ 0.342564] futex hash table entries: 256 (order: 1, 8192 bytes) [Tue Dec 08 09:39:56.809 2015] [ 0.459196] VFS: Disk quotas dquot_6.5.2 [Tue Dec 08 09:39:56.809 2015] [ 0.459583] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [Tue Dec 08 09:39:56.809 2015] [ 0.465129] NFS: Registering the id_resolver key type [Tue Dec 08 09:39:56.809 2015] [ 0.465206] Key type id_resolver registered [Tue Dec 08 09:39:56.809 2015] [ 0.465216] Key type id_legacy registered [Tue Dec 08 09:39:56.809 2015] [ 0.465254] jffs2: version 2.2. (NAND) (SUMMARY) c 2001-2006 Red Hat, Inc. [Tue Dec 08 09:39:56.809 2015] [ 0.466817] msgmni has been set to 992 [Tue Dec 08 09:39:56.809 2015] [ 0.469027] NET: Registered protocol family 38 [Tue Dec 08 09:39:56.809 2015] [ 0.469078] io scheduler noop registered [Tue Dec 08 09:39:56.809 2015] [ 0.469088] io scheduler deadline registered [Tue Dec 08 09:39:56.809 2015] [ 0.469527] io scheduler cfq registered (default) [Tue Dec 08 09:39:56.809 2015] [ 0.474808] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796 [Tue Dec 08 09:39:56.809 2015] [ 0.485244] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [Tue Dec 08 09:39:56.814 2015] [ 0.490497] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [Tue Dec 08 09:39:56.814 2015] [ 0.491632] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 104, base_baud = 3000000) is a 8250 [Tue Dec 08 09:39:56.814 2015] [ 1.471916] console [ttyS0] enabled [Tue Dec 08 09:39:56.814 2015] [ 1.476147] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [Tue Dec 08 09:39:56.814 2015] [ 1.484860] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 76, base_baud = 3000000) is a 8250 [Tue Dec 08 09:39:56.814 2015] [ 1.496024] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [Tue Dec 08 09:39:56.814 2015] [ 1.503241] [drm] Initialized drm 1.1.0 20060810 [Tue Dec 08 09:39:56.814 2015] [ 1.520303] brd: module loaded [Tue Dec 08 09:39:57.012 2015] [ 1.529953] loop: module loaded [Tue Dec 08 09:39:57.012 2015] [ 1.533810] (hci_tty): inside hci_tty_init [Tue Dec 08 09:39:57.012 2015] [ 1.538533] (hci_tty): allocated 249, 0 [Tue Dec 08 09:39:57.012 2015] [ 1.548542] mtdoops: mtd device (mtddev=name/number) must be supplied [Tue Dec 08 09:39:57.012 2015] [ 1.557661] of_dma_request_slave_channel: dma-names property of node '/ocp/spi@48030000' missing or empty [Tue Dec 08 09:39:57.012 2015] [ 1.567487] spi spi1.0: not using DMA for McSPI [Tue Dec 08 09:39:57.012 2015] [ 1.573145] pinctrl-single 44e10800.pinmux: pin 44e109b8.0 already requested by 48030000.spi; cannot claim for 481a2000.spi [Tue Dec 08 09:39:57.012 2015] [ 1.584472] pinctrl-single 44e10800.pinmux: pin-110 (481a2000.spi) status -22 [Tue Dec 08 09:39:57.012 2015] [ 1.591751] pinctrl-single 44e10800.pinmux: could not request pin 110 (44e109b8.0) from group spi2_pins on device pinctrl-single [Tue Dec 08 09:39:57.012 2015] [ 1.603461] omap2_mcspi 481a2000.spi: Error applying setting, reverse things back [Tue Dec 08 09:39:57.012 2015] [ 1.616342] usbcore: registered new interface driver asix [Tue Dec 08 09:39:57.012 2015] [ 1.622124] usbcore: registered new interface driver ax88179_178a [Tue Dec 08 09:39:57.012 2015] [ 1.628486] usbcore: registered new interface driver cdc_ether [Tue Dec 08 09:39:57.012 2015] [ 1.634629] usbcore: registered new interface driver smsc95xx [Tue Dec 08 09:39:57.022 2015] [ 1.640627] usbcore: registered new interface driver net1080 [Tue Dec 08 09:39:57.022 2015] [ 1.646664] usbcore: registered new interface driver cdc_subset [Tue Dec 08 09:39:57.022 2015] [ 1.652848] usbcore: registered new interface driver zaurus [Tue Dec 08 09:39:57.022 2015] [ 1.658709] usbcore: registered new interface driver cdc_ncm [Tue Dec 08 09:39:57.022 2015] [ 1.665200] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [Tue Dec 08 09:39:57.022 2015] [ 1.671808] ehci-pci: EHCI PCI platform driver [Tue Dec 08 09:39:57.022 2015] [ 1.676535] ehci-omap: OMAP-EHCI Host Controller driver [Tue Dec 08 09:39:57.022 2015] [ 1.682549] usbcore: registered new interface driver cdc_wdm [Tue Dec 08 09:39:57.022 2015] [ 1.688515] usbcore: registered new interface driver usb-storage [Tue Dec 08 09:39:57.022 2015] [ 1.696098] mousedev: PS/2 mouse device common for all mice [Tue Dec 08 09:39:57.022 2015] [ 1.704386] i2c-core: driver [rtc-ds1307] using legacy suspend method [Tue Dec 08 09:39:57.022 2015] [ 1.710870] i2c-core: driver [rtc-ds1307] using legacy resume method [Tue Dec 08 09:39:57.022 2015] [ 1.718858] i2c /dev entries driver [Tue Dec 08 09:39:57.022 2015] [ 1.722670] Driver for 1-wire Dallas network protocol. [Tue Dec 08 09:39:57.022 2015] [ 1.730930] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [Tue Dec 08 09:39:57.421 2015] [ 1.822507] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1 [Tue Dec 08 09:39:57.421 2015] [ 1.829507] omap-des 53701000.des: OMAP DES hw accel rev: 0.33 [Tue Dec 08 09:39:57.421 2015] [ 1.836941] omap-sham 53100000.sham: hw accel on OMAP rev 0.0 [Tue Dec 08 09:39:57.421 2015] [ 1.845132] usbcore: registered new interface driver usbhid [Tue Dec 08 09:39:57.421 2015] [ 1.850743] usbhid: USB HID core driver [Tue Dec 08 09:39:57.421 2015] [ 1.855105] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral [Tue Dec 08 09:39:57.421 2015] [ 1.864888] mmc0: new high speed SDHC card at address aaaa [Tue Dec 08 09:39:57.421 2015] [ 1.871597] mmcblk0: mmc0:aaaa SU08G 7.40 GiB [Tue Dec 08 09:39:57.421 2015] [ 1.878437] mmcblk0: p1 p2 [Tue Dec 08 09:39:57.421 2015] [ 1.882384] TCP: cubic registered [Tue Dec 08 09:39:57.421 2015] [ 1.885727] Initializing XFRM netlink socket [Tue Dec 08 09:39:57.421 2015] [ 1.890045] NET: Registered protocol family 17 [Tue Dec 08 09:39:57.421 2015] [ 1.898281] NET: Registered protocol family 15 [Tue Dec 08 09:39:57.421 2015] [ 1.905841] Key type dns_resolver registered [Tue Dec 08 09:39:57.421 2015] [ 1.910939] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517 [Tue Dec 08 09:39:57.421 2015] [ 1.919792] cpu cpu0: cpu0 clock notifier not ready, retry [Tue Dec 08 09:39:57.421 2015] [ 1.925439] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral [Tue Dec 08 09:39:57.437 2015] [ 1.933750] PM: no-rtc available, rtc-only mode disabled. [Tue Dec 08 09:39:57.438 2015] [ 1.935765] mmc1: BKOPS_EN bit is not set [Tue Dec 08 09:39:57.438 2015] [ 1.943310] ThumbEE CPU extension supported. [Tue Dec 08 09:39:57.438 2015] [ 1.945188] mmc1: new high speed MMC card at address 0001 [Tue Dec 08 09:39:57.438 2015] [ 1.951523] mmcblk1: mmc1:0001 S10008 7.12 GiB [Tue Dec 08 09:39:57.438 2015] [ 1.951711] mmcblk1boot0: mmc1:0001 S10008 partition 1 4.00 MiB [Tue Dec 08 09:39:57.438 2015] [ 1.961170] mmcblk1boot1: mmc1:0001 S10008 partition 2 4.00 MiB [Tue Dec 08 09:39:57.438 2015] [ 1.962408] mmcblk1: unknown partition table [Tue Dec 08 09:39:57.438 2015] [ 1.974143] mmcblk1boot1: unknown partition table [Tue Dec 08 09:39:57.438 2015] [ 1.983178] Registering SWP/SWPB emulation handler [Tue Dec 08 09:39:57.438 2015] [ 1.984162] mmcblk1boot0: unknown partition table [Tue Dec 08 09:39:57.438 2015] [ 1.995580] vmmcwl_fixed: disabling [Tue Dec 08 09:39:57.438 2015] [ 1.999102] regulator-dummy: disabling [Tue Dec 08 09:39:57.438 2015] [ 2.003949] Error: Driver 'tfp410' is already registered, aborting... [Tue Dec 08 09:39:57.438 2015] [ 2.016086] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.438 2015] [ 2.025389] vdd_core: 920 <--> 1140 mV at 1100 mV [Tue Dec 08 09:39:57.438 2015] [ 2.030841] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.438 2015] [ 2.039747] vdd_mpu: 920 <--> 1375 mV at 1330 mV [Tue Dec 08 09:39:57.445 2015] [ 2.044702] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.445 2015] [ 2.054614] vdcdc3: 1500 mV [Tue Dec 08 09:39:57.445 2015] [ 2.057677] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.445 2015] [ 2.067159] v1_0bat: 1000 mV [Tue Dec 08 09:39:57.445 2015] [ 2.070289] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.445 2015] [ 2.079277] v1_8bat: 1800 mV [Tue Dec 08 09:39:57.445 2015] [ 2.082474] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24 [Tue Dec 08 09:39:57.445 2015] [ 2.091901] LDO1: 1800 mV [Tue Dec 08 09:39:57.445 2015] [ 2.095242] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz [Tue Dec 08 09:39:57.445 2015] [ 2.101304] pinctrl-single 44e10800.pinmux: pin 44e10a48.0 already requested by 44e10800.pinmux; cannot claim for 4802a000.i2c [Tue Dec 08 09:39:57.445 2015] [ 2.112759] pinctrl-single 44e10800.pinmux: pin-146 (4802a000.i2c) status -22 [Tue Dec 08 09:39:57.445 2015] [ 2.119931] pinctrl-single 44e10800.pinmux: could not request pin 146 (44e10a48.0) from group i2c1_pins_default on device pinctrl-single [Tue Dec 08 09:39:57.445 2015] [ 2.132337] omap_i2c 4802a000.i2c: Error applying setting, reverse things back [Tue Dec 08 09:39:57.445 2015] [ 2.140713] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz [Tue Dec 08 09:39:57.503 2015] [ 2.160997] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz [Tue Dec 08 09:39:57.503 2015] [ 2.167154] omap_timer 48044000.timer: [cindy]Timer Device Probed. [Tue Dec 08 09:39:57.503 2015] [ 2.173719] omap_timer 48046000.timer: [cindy]Timer Device Probed. [Tue Dec 08 09:39:57.503 2015] [ 2.180195] omap_timer 48048000.timer: [cindy]Timer Device Probed. [Tue Dec 08 09:39:57.503 2015] [ 2.186889] omap_timer 4804a000.timer: [cindy]Timer Device Probed. [Tue Dec 08 09:39:57.503 2015] [ 2.193817] remoteproc0: wkup_m3 is available [Tue Dec 08 09:39:57.503 2015] [ 2.198291] remoteproc0: Note: remoteproc is still under development and considered experimental. [Tue Dec 08 09:39:57.503 2015] [ 2.207391] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [Tue Dec 08 09:39:57.503 2015] [ 2.217916] remoteproc0: [Cindy] firmware: direct-loading firmware path name /lib/firmware/updates/3.14.43-rt42-g2d2fe37-dirty/am335x-pm-firmware.elf [Tue Dec 08 09:39:57.503 2015] [ 2.231410] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22 [Tue Dec 08 09:39:57.643 2015] [ 2.257868] remoteproc0: [Cindy] firmware: direct-loading firmware path name /lib/firmware/updates/am335x-pm-firmware.elf [Tue Dec 08 09:39:57.643 2015] [ 2.269018] remoteproc0: [Cindy] firmware: direct-loading firmware path name /lib/firmware/3.14.43-rt42-g2d2fe37-dirty/am335x-pm-firmware.elf [Tue Dec 08 09:39:57.643 2015] [ 2.281876] remoteproc0: [Cindy] firmware: direct-loading firmware path name /lib/firmware/am335x-pm-firmware.elf [Tue Dec 08 09:39:57.643 2015] [ 2.292287] remoteproc0: Direct firmware load failed with error -2 [Tue Dec 08 09:39:57.643 2015] [ 2.298582] remoteproc0: Falling back to user helper [Tue Dec 08 09:39:57.643 2015] [ 2.301081] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [Tue Dec 08 09:39:57.643 2015] [ 2.301087] davinci_mdio 4a101000.mdio: detected phy mask fffdfffd [Tue Dec 08 09:39:57.643 2015] [ 2.317463] libphy: 4a101000.mdio: probed [Tue Dec 08 09:39:57.643 2015] [ 2.321536] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown [Tue Dec 08 09:39:57.643 2015] [ 2.329581] davinci_mdio 4a101000.mdio: phy[17]: device 4a101000.mdio:11, driver unknown [Tue Dec 08 09:39:57.643 2015] [ 2.338760] cpsw 4a100000.ethernet: Random MACID = 8a:5c:5d:24:ac:2c [Tue Dec 08 09:39:57.649 2015] [ 2.347575] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) [Tue Dec 08 09:39:57.649 2015] [ 2.358955] ALSA device list: [Tue Dec 08 09:39:57.649 2015] [ 2.362028] No soundcards found. [Tue Dec 08 09:39:57.663 2015] [ 2.404625] EXT4-fs (mmcblk0p2): recovery complete [Tue Dec 08 09:39:57.708 2015] [ 2.411717] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Tue Dec 08 09:39:57.708 2015] [ 2.419910] VFS: Mounted root (ext4 filesystem) on device 179:2. [Tue Dec 08 09:39:57.708 2015] [ 2.429927] devtmpfs: mounted [Tue Dec 08 09:39:57.708 2015] [ 2.433438] Freeing unused kernel memory: 268K (c081f000 - c0862000) [Tue Dec 08 09:39:57.721 2015] [ 2.468481] Unhandled fault: imprecise external abort (0x1406) at 0x4cb9f87c [Tue Dec 08 09:39:57.749 2015] [ 2.468864] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007 [Tue Dec 08 09:39:57.749 2015] [ 2.468864]
