Hi
I am trying to use the edma_test.c kernel module in our BeagleBone Black, compiling it in kernel 4.1.18-ti-r52 native environment but, unsuccesfully:
debian@beaglebone:~/Desktop/EDMA_teste$ make
make -C /lib/modules/4.1.18-ti-r52/build/ M=/home/debian/Desktop/EDMA_teste modules
make[1]: Entering directory '/usr/src/linux-headers-4.1.18-ti-r52'
CC [M] /home/debian/Desktop/EDMA_teste/edma_test.o
/home/debian/Desktop/EDMA_teste/edma_test.c:35:25: fatal error: mach/memory.h: No such file or directory
#include <mach/memory.h>
compilation terminated.
scripts/Makefile.build:264: recipe for target '/home/debian/Desktop/EDMA_teste/edma_test.o' failed
make[2]: *** [/home/debian/Desktop/EDMA_teste/edma_test.o] Error 1
Makefile:1384: recipe for target '_module_/home/debian/Desktop/EDMA_teste' failed
make[1]: *** [_module_/home/debian/Desktop/EDMA_teste] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.1.18-ti-r52'
Makefile:4: recipe for target 'all' failed
make: *** [all] Error 2
Follows the Makefile used:
obj-m += edma_test.o
all:
make -C /lib/modules/$(shell uname -r)/build/ M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build/ M=$(PWD) clean
Probably, this example it is not for AM335x EDMA.
Where can I find a proper example for AM335x?
/* * edma_test.c * * brief EDMA3 Test Application * * This file contains EDMA3 Test code. * * NOTE: THIS FILE IS PROVIDED ONLY FOR INITIAL DEMO RELEASE AND MAY BE * REMOVED AFTER THE DEMO OR THE CONTENTS OF THIS FILE ARE SUBJECT * TO CHANGE. * * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation version 2. * * This program is distributed "as is" WITHOUT ANY WARRANTY of any * kind, whether express or implied; without even the implied warranty * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. */ #include <linux/module.h> #include <linux/init.h> #include <linux/errno.h> #include <linux/types.h> #include <linux/interrupt.h> #include <asm/io.h> #include <linux/moduleparam.h> #include <linux/sysctl.h> #include <linux/mm.h> #include <linux/dma-mapping.h> #include <mach/memory.h> #include <mach/hardware.h> #include <mach/irqs.h> #include <asm/hardware/edma.h> #undef EDMA3_DEBUG /*#define EDMA3_DEBUG*/ #ifdef EDMA3_DEBUG #define DMA_PRINTK(ARGS...) printk(KERN_INFO "<%s>: ",__FUNCTION__);printk(ARGS) #define DMA_FN_IN printk(KERN_INFO "[%s]: start\n", __FUNCTION__) #define DMA_FN_OUT printk(KERN_INFO "[%s]: end\n",__FUNCTION__) #else #define DMA_PRINTK( x... ) #define DMA_FN_IN #define DMA_FN_OUT #endif #define MAX_DMA_TRANSFER_IN_BYTES (32768) #define STATIC_SHIFT 3 #define TCINTEN_SHIFT 20 #define ITCINTEN_SHIFT 21 #define TCCHEN_SHIFT 22 #define ITCCHEN_SHIFT 23 static volatile int irqraised1 = 0; static volatile int irqraised2 = 0; int edma3_memtomemcpytest_dma(int acnt, int bcnt, int ccnt, int sync_mode, int event_queue); int edma3_memtomemcpytest_dma_link(int acnt, int bcnt, int ccnt, int sync_mode, int event_queue); int edma3_memtomemcpytest_dma_chain(int acnt, int bcnt, int ccnt, int sync_mode, int event_queue); dma_addr_t dmaphyssrc1 = 0; dma_addr_t dmaphyssrc2 = 0; dma_addr_t dmaphysdest1 = 0; dma_addr_t dmaphysdest2 = 0; char *dmabufsrc1 = NULL; char *dmabufsrc2 = NULL; char *dmabufdest1 = NULL; char *dmabufdest2 = NULL; static int acnt = 512; static int bcnt = 8; static int ccnt = 8; module_param(acnt, int, S_IRUGO); module_param(bcnt, int, S_IRUGO); module_param(ccnt, int, S_IRUGO); static void callback1(unsigned lch, u16 ch_status, void *data) { switch(ch_status) { case DMA_COMPLETE: irqraised1 = 1; /*DMA_PRINTK ("\n From Callback 1: Channel %d status is: %u\n", lch, ch_status);*/ break; case DMA_CC_ERROR: irqraised1 = -1; DMA_PRINTK ("\nFrom Callback 1: DMA_CC_ERROR occured " "on Channel %d\n", lch); break; default: break; } } static void callback2(unsigned lch, u16 ch_status, void *data) { switch(ch_status) { case DMA_COMPLETE: irqraised2 = 1; /*DMA_PRINTK ("\n From Callback 1: Channel %d status is: %u\n", lch, ch_status);*/ break; case DMA_CC_ERROR: irqraised2 = -1; DMA_PRINTK ("\nFrom Callback 1: DMA_CC_ERROR occured " "on Channel %d\n", lch); break; default: break; } } static int __init edma_test_init(void) { int result = 0; int iterations = 0; int numTCs = 4; int modes = 2; int i,j; printk ("\nInitializing edma_test module\n"); DMA_PRINTK ( "\nACNT=%d, BCNT=%d, CCNT=%d", acnt, bcnt, ccnt); /* allocate consistent memory for DMA * dmaphyssrc1(handle)= device viewed address. * dmabufsrc1 = CPU-viewed address */ dmabufsrc1 = dma_alloc_coherent (NULL, MAX_DMA_TRANSFER_IN_BYTES, &dmaphyssrc1, 0); DMA_PRINTK( "\nSRC1:\t%x", dmaphyssrc1); if (!dmabufsrc1) { DMA_PRINTK ("dma_alloc_coherent failed for dmaphyssrc1\n"); return -ENOMEM; } dmabufdest1 = dma_alloc_coherent (NULL, MAX_DMA_TRANSFER_IN_BYTES, &dmaphysdest1, 0); DMA_PRINTK( "\nDST1:\t%x", dmaphysdest1); if (!dmabufdest1) { DMA_PRINTK("dma_alloc_coherent failed for dmaphysdest1\n"); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc1, dmaphyssrc1); return -ENOMEM; } dmabufsrc2 = dma_alloc_coherent (NULL, MAX_DMA_TRANSFER_IN_BYTES, &dmaphyssrc2, 0); DMA_PRINTK( "\nSRC2:\t%x", dmaphyssrc2); if (!dmabufsrc2) { DMA_PRINTK ("dma_alloc_coherent failed for dmaphyssrc2\n"); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc1, dmaphyssrc1); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufdest1, dmaphysdest1); return -ENOMEM; } dmabufdest2 = dma_alloc_coherent (NULL, MAX_DMA_TRANSFER_IN_BYTES, &dmaphysdest2, 0); DMA_PRINTK( "\nDST2:\t%x", dmaphysdest2); if (!dmabufdest2) { DMA_PRINTK ("dma_alloc_coherent failed for dmaphysdest2\n"); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc1, dmaphyssrc1); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufdest1, dmaphysdest1); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc2, dmaphyssrc2); return -ENOMEM; } for (iterations = 0 ; iterations < 10 ; iterations++) { DMA_PRINTK ("Iteration = %d\n", iterations); for (j = 0 ; j < numTCs ; j++) { //TC DMA_PRINTK ("TC = %d\n", j); for (i = 0 ; i < modes ; i++) { //sync_mode DMA_PRINTK ("Mode = %d\n", i); /* Run all EDMA3 test cases */ DMA_PRINTK ("Starting edma3_memtomemcpytest_dma\n"); result = edma3_memtomemcpytest_dma(acnt, bcnt, ccnt, i, j); if (0 == result) { printk("edma3_memtomemcpytest_dma passed\n"); } else { printk("edma3_memtomemcpytest_dma failed\n"); } if (0 == result) { DMA_PRINTK ("Starting edma3_memtomemcpytest_dma_link\n"); result = edma3_memtomemcpytest_dma_link(acnt, bcnt, ccnt, i, j); if (0 == result) { printk("edma3_memtomemcpytest_dma_link passed\n"); } else { printk("edma3_memtomemcpytest_dma_link failed\n"); } } if (0 == result) { DMA_PRINTK ("Starting edma3_memtomemcpytest_dma_chain\n"); result = edma3_memtomemcpytest_dma_chain(acnt, bcnt, ccnt, i, j); if (0 == result) { printk("edma3_memtomemcpytest_dma_chain passed\n"); } else { printk("edma3_memtomemcpytest_dma_chain failed\n"); } } } } } return result; } void edma_test_exit(void) { dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc1, dmaphyssrc1); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufdest1, dmaphysdest1); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufsrc2, dmaphyssrc2); dma_free_coherent(NULL, MAX_DMA_TRANSFER_IN_BYTES, dmabufdest2, dmaphysdest2); printk ("\nExiting edma_test module\n"); } /* DMA Channel, Mem-2-Mem Copy, ASYNC Mode, INCR Mode */ int edma3_memtomemcpytest_dma (int acnt, int bcnt, int ccnt, int sync_mode, int event_queue) { int result = 0; unsigned int dma_ch = 0; int i; int count = 0; unsigned int Istestpassed = 0u; unsigned int numenabled = 0; unsigned int BRCnt = 0; int srcbidx = 0; int desbidx = 0; int srccidx = 0; int descidx = 0; struct edmacc_param param_set; /* Initalize source and destination buffers */ for (count = 0u; count < (acnt*bcnt*ccnt); count++) { dmabufsrc1[count] = 'A' + (count % 26); dmabufdest1[count] = 0; } /* Set B count reload as B count. */ BRCnt = bcnt; /* Setting up the SRC/DES Index */ srcbidx = acnt; desbidx = acnt; /* A Sync Transfer Mode */ srccidx = acnt; descidx = acnt; result = edma_alloc_channel (EDMA_CHANNEL_ANY, callback1, NULL, event_queue); if (result < 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma::edma_alloc_channel failed for dma_ch, error:%d\n", result); return result; } dma_ch = result; edma_set_src (dma_ch, (unsigned long)(dmaphyssrc1), INCR, W8BIT); edma_set_dest (dma_ch, (unsigned long)(dmaphysdest1), INCR, W8BIT); edma_set_src_index (dma_ch, srcbidx, srccidx); edma_set_dest_index (dma_ch, desbidx, descidx); /* A Sync Transfer Mode */ edma_set_transfer_params (dma_ch, acnt, bcnt, ccnt, BRCnt, ASYNC); /* Enable the Interrupts on Channel 1 */ edma_read_slot (dma_ch, ¶m_set); param_set.opt |= (1 << ITCINTEN_SHIFT); param_set.opt |= (1 << TCINTEN_SHIFT); param_set.opt |= EDMA_TCC(EDMA_CHAN_SLOT(dma_ch)); edma_write_slot (dma_ch, ¶m_set); numenabled = bcnt * ccnt; for (i = 0; i < numenabled; i++) { irqraised1 = 0; /* * Now enable the transfer as many times as calculated above. */ result = edma_start(dma_ch); if (result != 0) { DMA_PRINTK ("edma3_memtomemcpytest_dma: davinci_start_dma failed \n"); break; } /* Wait for the Completion ISR. */ while (irqraised1 == 0u); /* Check the status of the completed transfer */ if (irqraised1 < 0) { /* Some error occured, break from the FOR loop. */ DMA_PRINTK ("edma3_memtomemcpytest_dma: Event Miss Occured!!!\n"); break; } } if (0 == result) { for (i = 0; i < (acnt*bcnt*ccnt); i++) { if (dmabufsrc1[i] != dmabufdest1[i]) { DMA_PRINTK ("\n edma3_memtomemcpytest_dma: Data write-read matching failed at = %u\n",i); Istestpassed = 0u; break; } } if (i == (acnt*bcnt*ccnt)) Istestpassed = 1u; edma_stop(dma_ch); edma_free_channel(dma_ch); } if (Istestpassed == 1u) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma: EDMA Data Transfer Successfull \n"); } else { DMA_PRINTK ("\nedma3_memtomemcpytest_dma: EDMA Data Transfer Failed \n"); } return result; } /* 2 DMA Channels Linked, Mem-2-Mem Copy, ASYNC Mode, INCR Mode */ int edma3_memtomemcpytest_dma_link(int acnt, int bcnt, int ccnt, int sync_mode, int event_queue) { int result = 0; unsigned int dma_ch1 = 0; unsigned int dma_ch2 = 0; int i; int count = 0; unsigned int Istestpassed1 = 0u; unsigned int Istestpassed2 = 0u; unsigned int numenabled = 0; unsigned int BRCnt = 0; int srcbidx = 0; int desbidx = 0; int srccidx = 0; int descidx = 0; struct edmacc_param param_set; /* Initalize source and destination buffers */ for (count = 0u; count < (acnt*bcnt*ccnt); count++) { dmabufsrc1[count] = 'A' + (count % 26); dmabufdest1[count] = 0; dmabufsrc2[count] = 'A' + (count % 26); dmabufdest2[count] = 0; } /* Set B count reload as B count. */ BRCnt = bcnt; /* Setting up the SRC/DES Index */ srcbidx = acnt; desbidx = acnt; /* A Sync Transfer Mode */ srccidx = acnt; descidx = acnt; result = edma_alloc_channel (EDMA_CHANNEL_ANY, callback1, NULL, event_queue); if (result < 0) { DMA_PRINTK ("edma3_memtomemcpytest_dma_link::edma_alloc_channel " "failed for dma_ch1, error:%d\n", result); return result; } dma_ch1 = result; edma_set_src (dma_ch1, (unsigned long)(dmaphyssrc1), INCR, W8BIT); edma_set_dest (dma_ch1, (unsigned long)(dmaphysdest1), INCR, W8BIT); edma_set_src_index (dma_ch1, srcbidx, srccidx); edma_set_dest_index (dma_ch1, desbidx, descidx); edma_set_transfer_params (dma_ch1, acnt, bcnt, ccnt, BRCnt, ASYNC); /* Enable the Interrupts on Channel 1 */ edma_read_slot (dma_ch1, ¶m_set); param_set.opt |= (1 << ITCINTEN_SHIFT); param_set.opt |= (1 << TCINTEN_SHIFT); param_set.opt |= EDMA_TCC(EDMA_CHAN_SLOT(dma_ch1)); edma_write_slot(dma_ch1, ¶m_set); /* Request a Link Channel */ result = edma_alloc_slot (0, EDMA_SLOT_ANY); if (result < 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link::edma_alloc_slot " "failed for dma_ch2, error:%d\n", result); return result; } dma_ch2 = result; edma_set_src (dma_ch2, (unsigned long)(dmaphyssrc2), INCR, W8BIT); edma_set_dest (dma_ch2, (unsigned long)(dmaphysdest2), INCR, W8BIT); edma_set_src_index (dma_ch2, srcbidx, srccidx); edma_set_dest_index (dma_ch2, desbidx, descidx); edma_set_transfer_params (dma_ch2, acnt, bcnt, ccnt, BRCnt, ASYNC); /* Enable the Interrupts on Channel 2 */ edma_read_slot (dma_ch2, ¶m_set); param_set.opt |= (1 << ITCINTEN_SHIFT); param_set.opt |= (1 << TCINTEN_SHIFT); param_set.opt |= EDMA_TCC(EDMA_CHAN_SLOT(dma_ch1)); edma_write_slot(dma_ch2, ¶m_set); /* Link both the channels */ edma_link(dma_ch1, dma_ch2); numenabled = bcnt * ccnt; for (i = 0; i < numenabled; i++) { irqraised1 = 0; /* * Now enable the transfer as many times as calculated above. */ result = edma_start(dma_ch1); if (result != 0) { DMA_PRINTK ("edma3_memtomemcpytest_dma_link: davinci_start_dma failed \n"); break; } /* Wait for the Completion ISR. */ while (irqraised1 == 0u); /* Check the status of the completed transfer */ if (irqraised1 < 0) { /* Some error occured, break from the FOR loop. */ DMA_PRINTK ("edma3_memtomemcpytest_dma_link: " "Event Miss Occured!!!\n"); break; } } if (result == 0) { for (i = 0; i < numenabled; i++) { irqraised1 = 0; /* * Now enable the transfer as many times as calculated above * on the LINK channel. */ result = edma_start(dma_ch1); if (result != 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link: davinci_start_dma failed \n"); break; } /* Wait for the Completion ISR. */ while (irqraised1 == 0u); /* Check the status of the completed transfer */ if (irqraised1 < 0) { /* Some error occured, break from the FOR loop. */ DMA_PRINTK ("edma3_memtomemcpytest_dma_link: " "Event Miss Occured!!!\n"); break; } } } if (0 == result) { for (i = 0; i < (acnt*bcnt*ccnt); i++) { if (dmabufsrc1[i] != dmabufdest1[i]) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link(1): Data " "write-read matching failed at = %u\n",i); Istestpassed1 = 0u; break; } } if (i == (acnt*bcnt*ccnt)) { Istestpassed1 = 1u; } for (i = 0; i < (acnt*bcnt*ccnt); i++) { if (dmabufsrc2[i] != dmabufdest2[i]) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link(2): Data " "write-read matching failed at = %u\n",i); Istestpassed2 = 0u; break; } } if (i == (acnt*bcnt*ccnt)) { Istestpassed2 = 1u; } edma_stop(dma_ch1); edma_free_channel(dma_ch1); edma_stop(dma_ch2); edma_free_slot(dma_ch2); edma_free_channel(dma_ch2); } if ((Istestpassed1 == 1u) && (Istestpassed2 == 1u)) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link: EDMA Data Transfer Successfull\n"); } else { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_link: EDMA Data Transfer Failed\n"); } return result; } /* 2 DMA Channels Chained, Mem-2-Mem Copy, A-SYNC Mode, INCR Mode */ int edma3_memtomemcpytest_dma_chain(int acnt, int bcnt, int ccnt, int sync_mode, int event_queue) { int result = 0; unsigned int dma_ch1 = 0; unsigned int dma_ch2 = 0; int i; int count = 0; unsigned int Istestpassed1 = 0u; unsigned int Istestpassed2 = 0u; unsigned int numenabled = 0; unsigned int BRCnt = 0; int srcbidx = 0; int desbidx = 0; int srccidx = 0; int descidx = 0; struct edmacc_param param_set; /* Initalize source and destination buffers */ for (count = 0u; count < (acnt*bcnt*ccnt); count++) { dmabufsrc1[count] = 'A' + (count % 26); dmabufdest1[count] = 0; dmabufsrc2[count] = 'A' + (count % 26); dmabufdest2[count] = 0; } /* Set B count reload as B count. */ BRCnt = bcnt; /* Setting up the SRC/DES Index */ srcbidx = acnt; desbidx = acnt; /* A Sync Transfer Mode */ srccidx = acnt; descidx = acnt; result = edma_alloc_channel (EDMA_CHANNEL_ANY, callback1, NULL, event_queue); if (result < 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_chain::davinci_request_dma" " failed for dma_ch1, error:%d\n", result); return result; } dma_ch1 = result; edma_set_src (dma_ch1, (unsigned long)(dmaphyssrc1), INCR, W8BIT); edma_set_dest (dma_ch1, (unsigned long)(dmaphysdest1), INCR, W8BIT); edma_set_src_index (dma_ch1, srcbidx, srccidx); edma_set_dest_index (dma_ch1, desbidx, descidx); edma_set_transfer_params (dma_ch1, acnt, bcnt, ccnt, BRCnt, ASYNC); /* Request another DMA Channel */ result = edma_alloc_channel (EDMA_CHANNEL_ANY, callback2, NULL, event_queue); if (result < 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_chain::davinci_request_dma " "failed for dma_ch2, error:%d\n", result); edma_free_channel(dma_ch1); return result; } dma_ch2 = result; edma_set_src (dma_ch2, (unsigned long)(dmaphyssrc2), INCR, W8BIT); edma_set_dest (dma_ch2, (unsigned long)(dmaphysdest2), INCR, W8BIT); edma_set_src_index (dma_ch2, srcbidx, srccidx); edma_set_dest_index (dma_ch2, desbidx, descidx); edma_set_transfer_params (dma_ch2, acnt, bcnt, ccnt, BRCnt, ASYNC); /* Chain both the channels */ edma_read_slot(dma_ch1, ¶m_set); param_set.opt |= (1 << TCCHEN_SHIFT); param_set.opt |= EDMA_TCC(EDMA_CHAN_SLOT(dma_ch2)); edma_write_slot(dma_ch1, ¶m_set); /* * Enable the Intermediate and Final Interrupts on Channel 1. * Also, Enable the Intermediate Chaining. */ edma_read_slot(dma_ch1, ¶m_set); param_set.opt |= (1 << ITCCHEN_SHIFT); param_set.opt |= (1 << TCINTEN_SHIFT); param_set.opt |= (1 << ITCINTEN_SHIFT); edma_write_slot(dma_ch1, ¶m_set); /* Enable the Intermediate and Final Interrupts on Channel 2 */ edma_read_slot(dma_ch2, ¶m_set); param_set.opt |= (1 << TCINTEN_SHIFT); param_set.opt |= (1 << ITCINTEN_SHIFT); edma_write_slot(dma_ch2, ¶m_set); numenabled = bcnt * ccnt; for (i = 0; i < numenabled; i++) { irqraised2 = 0; /* * Now enable the transfer for Master channel as many times * as calculated above. */ result = edma_start(dma_ch1); if (result != 0) { DMA_PRINTK ("\nedma3_memtomemcpytest_dma_chain: " "davinci_start_dma failed \n"); edma_stop(dma_ch1); edma_free_channel(dma_ch1); edma_free_channel(dma_ch2); return result; } /* * Transfer on the master channel (ch1Id) will finish after some * time. * Now, because of the enabling of intermediate chaining on channel * 1, after the transfer gets over, a sync event will be sent * to channel 2, which will trigger the transfer on it. * Also, Final and Intermediate Transfer Complete * Interrupts are enabled on channel 2, so we should wait for the * completion ISR on channel 2 first, before proceeding * ahead. */ while (irqraised2 == 0u); /* Check the status of the completed transfer */ if (irqraised2 < 0) { /* Some error occured, break from the FOR loop. */ DMA_PRINTK ("edma3_test_with_chaining: " "Event Miss Occured!!!\n"); break; } } /* Match the Source and Destination Buffers. */ for (i = 0; i < (acnt*bcnt*ccnt); i++) { if (dmabufsrc1[i] != dmabufdest1[i]) { DMA_PRINTK ( "\nedma3_memtomemcpytest_dma_chain(1): Data write-read matching failed at = %u\n",i); Istestpassed1 = 0u; break; } } if (i == (acnt*bcnt*ccnt)) { Istestpassed1 = 1u; } for (i = 0; i < (acnt*bcnt*ccnt); i++) { if (dmabufsrc2[i] != dmabufdest2[i]) { DMA_PRINTK ( "\nedma3_memtomemcpytest_dma_chain(2): Data write-read matching failed at = %u\n",i); Istestpassed2 = 0u; break; } } if (i == (acnt*bcnt*ccnt)) { Istestpassed2 = 1u; } edma_stop(dma_ch1); edma_free_channel(dma_ch1); edma_stop(dma_ch2); edma_free_slot(dma_ch2); edma_free_channel(dma_ch2); if((Istestpassed1 == 1u) && (Istestpassed2 == 1u)) { DMA_PRINTK ( "\nedma3_memtomemcpytest_dma_chain: EDMA Data Transfer Successfull\n"); } else { DMA_PRINTK ( "\nedma3_memtomemcpytest_dma_chain: EDMA Data Transfer Failed\n"); } return result; } module_init(edma_test_init); module_exit(edma_test_exit); MODULE_AUTHOR("Texas Instruments"); MODULE_LICENSE("GPL");
Sergio
