CCS/EK-TM4C1294XL: Load program error because of Verification failed
Expert 2355 points
Part Number: EK-TM4C1294XL
The error occurs on the TI EVM when loading program to EVM.
http://www.tij.co.jp/tool/jp/ek-tm4c1294xl
we change linker command file.
The additional change is allocate const-data table about 40kByte.
Define as below:
MEMORY
        INFO1 (RX) : origin = 0x000E0000, length = 0x00010000
And the build is success and no warning.
Also, go to debug mode error has occurred.
The error message is as below:
-Pop up error message:
Load program error
File: D:\xxxx\xxxx\xxx\***.out: a data verification error occured, file load failed.
-Console text
CORTEX_M4_0: GEL Output:
Memory Map Initialization Complete
CORTEX_M4_0: Error: Debug Port error occurred.
CORTEX_M4_0: File Loader: Verification failed: Values at address 0x000E7F80 do not match Please verify target memory and memory map.
CORTEX_M4_0: GEL: File: D:\xxxx\xxxx\xxx\***.out: a data verification error occurred, file load failed.
We would check what is issue.
Does anyone have check-list or same case?
kyt
    The address for which the error is reported is a valid address in flash.
    What is the full CCS version number?
    There was the bug CCBT-2023 in CCS 7.0.0 which caused data verification errors for some programs - see CCS/TM4C123GH6PM: Certain TiwaWare examples work on CSS v6, but not on CSS v7
    Bug CCBT-2023 is reported as fixed in CCS 7.1.0 - see the Release Notes for Code Composer Studio™ v7.1.0
    We checked difference of write code and Read out code(dump).
    It seems that clearly difference at particluar address.
    -absoluter address: real physical adress
    -relatve adress:The difference of before and absolute address
    CCS ver :7.1.0
    In this difference, there is only lead 4-byte data.
    Pls let me know if you have similar issue.
    aboslute
    Address
    Read out Write code match / unmatch Relative
    address
    0xE0280 0F,7B,61,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE
    0xE0500 5F,0F,7B,60,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 280
    0xE0700 7B,5E,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE0900 0F,7B,5D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE0B00 5B,0F,7B,5C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE0D00 7B,5A,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE0F00 0F,7B,59,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1100 57,0F,7B,58,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1300 7B,56,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1500 0F,7B,55,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1700 53,0F,7B,54,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1900 7B,52,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1B00 0F,7B,51,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1D00 4F,0F,3B,50,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE1F00 3B,4E,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2100 0F,3B,4D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2280 4B,0F,3B,4C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE2480 3B,4A,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2680 0F,3B,49,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2800 47,0F,3B,48,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE2A00 3B,46,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2C00 0F,3B,45,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE2D80 43,0F,3B,44,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE2F80 3B,42,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE3100 0F,3B,41,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE3300 3F,0F,3B,40,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE3480 3B,3E,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE3680 0F,3B,3D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE3800 3B,0F,7B,3C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE3980 7B,3A,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE3B80 0F,7B,39,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE3D00 37,0F,7B,38,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE3E80 7B,36,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4080 0F,7B,35,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 200
    0xE4200 33,0F,7B,34,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4300 1D,CA,B1,0C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE4380 7B,32,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 80
    0xE4500 0F,7B,31,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4680 2F,0F,7B,30,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4800 7B,2E,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4980 0F,7B,2D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4B00 2B,0F,7B,2C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4C80 7B,2A,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4E00 0F,7B,29,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE4F80 27,0F,7B,28,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5100 7B,26,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5280 0F,7B,25,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5400 23,0F,7B,24,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5580 7B,22,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5680 0F,7B,21,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE5800 1F,0F,7B,20,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5980 3B,1E,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5A80 0F,3B,1D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE5C00 1B,0F,3B,1C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5D80 3B,1A,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE5E80 0F,3B,19,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6000 17,0F,3B,18,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE6100 3B,16,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6280 0F,3B,15,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE6380 13,0F,3B,14,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6500 3B,12,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE6600 0F,3B,11,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6700 0F,0F,3B,10,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6880 3B,0E,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE6980 0F,3B,0D,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6A80 0B,0F,3B,0C,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6C00 7B,0A,0F,3B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 180
    0xE6D00 0F,7B,09,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6E00 07,0F,7B,08,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE6F00 7B,06,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE7000 0F,7B,05,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE7100 03,0F,7B,04,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE7200 7B,02,0F,7B,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    0xE7300 0F,7B,01,0F,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF, FALSE 100
    best regards,
    kyt
  • kyt said:
    CCS ver :7.1.0
    From your problem symptoms you may be suffering the same issue in CCS/EK-TM4C123GXL: Data Verification Error when using named memory sections + Debug port error when running custom Linker Command File. The problem in the referenced thread also occurred with CCS v7.1.0. Defect CCBT-2098 was raised, which is reported as fixed in CCS 7.2.0.
    Can you try CCS v.7.2.0 and see if that fixes the problem?
  • Thnks a lot.
    Your information is helpful of us.
    regards,
    kyt
