Part Number: TMDSEVM572X
I Want to set My HDMI external resolution from 800x600 to 1080p.
Did you try to add video=HDMI-A-1:1280x780 and make changes in /etc/weston.ini file?
Please check these guides:
processors.wiki.ti.com/.../Processor_Linux_SDK_Graphics_and_Display
http://processors.wiki.ti.com/index.php/Linux_Core_DSS_User's_Guide
BR
Margarita
Hello
First I add the line " video=HDMI-A-1:1280x780" in /etc/weston.ini as you suggested.
Later I tried to use the Ti proposal i.e.
I add to /etc/weston.ini the following
[output]
name=HDMI-A-I
mode=1024x768
In both cases I failed
The output of cat /proce/cmdline is
console=tty02,115200n8 root=PARTUUID-00000000-02 rw rootfstype=ext4 rootwait
and the output of mode test
root@am57xx-evm:~# modetest
trying to open device 'i915'...failed.
trying to open device 'radeon'...failed.
[ 3574.234985] omapdss error: HDMI I2C Master Error
trying to open device 'nouveau'...failed.
trying to open device 'vmwgfx'...failed.
trying to open device 'omapdrm'...success.
Encoders:
id crtc type possible crtcs possible clones
25 28 TMDS 0x00000001 0x00000000
29 32 TMDS 0x00000002 0x00000000
Connectors:
id encoder status type size (mm) modes encoders
26 25 connected HDMI-A 0x0 5 25
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1024x768 60 1024 1048 1184 1344 768 771 777 806 flags: nhsync, nvsync; type: driver
800x600 60 800 840 968 1056 600 601 605 628 flags: phsync, pvsync; type: driver
800x600 56 800 824 896 1024 600 601 603 625 flags: phsync, pvsync; type: driver
848x480 60 848 864 976 1088 480 486 494 517 flags: phsync, pvsync; type: driver
640x480 60 640 656 752 800 480 489 492 525 flags: nhsync, nvsync; type: driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
30 29 connected unknown 0x0 1 29
modes:
800x480 60 800 1010 1040 1056 480 502 515 525 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 0
CRTCs:
id fb pos size
28 44 (0,0) (1024x768)
props:
21 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
32 46 (0,0) (800x480)
props:
21 trans-key-mode:
flags: enum
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
27 28 44 0,0 0,0 0 0x00000001
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24
props:
5 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
31 32 46 0,0 0,0 0 0x00000002
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
props:
5 type:
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
33 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
34 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
BR
Gilad
Gilad Davara said:First I add the line " video=HDMI-A-1:1280x780" in /etc/weston.ini as you suggested.
No. This video=HDMI-A-1:1024x768 should be added in bootargs not in weston.ini.
Please check the first user guide that I linked.
BR
Margarita
