Linux/LINUXEZSDK-SITARA: Kernel compilation fails
Part Number: LINUXEZSDK-SITARA
Other Parts Discussed in Thread: LM90, LM95245, TMP102, TFP410, TPS65217, TPS65218, TPS65910, TWL6040, TPS65090
Tool/software: Linux
Hi
I am using AM335x Starter Kit and linux sdk
Using below step to compile kernel image for source code comes with sdk but if fails after sometime without any error, not sure what is wrong
below are build log
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# export ARCH=arm
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# export PATH=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# export CROSS_COMPILE=arm-linux-gnueabihf-
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# make clean
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# make tisdk_am335x-evm_defconfig
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/bin2c
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# make -j4
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  HOSTCC  scripts/dtc/dtc.o
  HOSTCC  scripts/dtc/flattree.o
  HOSTCC  scripts/genksyms/genksyms.o
  GEN     include/generated/mach-types.h
  HOSTCC  scripts/dtc/fstree.o
  CC      scripts/mod/empty.o
  HOSTCC  scripts/genksyms/parse.tab.o
  HOSTCC  scripts/dtc/data.o
  HOSTCC  scripts/mod/mk_elfconfig
  HOSTCC  scripts/genksyms/lex.lex.o
  CC      scripts/mod/devicetable-offsets.s
  HOSTCC  scripts/dtc/livetree.o
  HOSTCC  scripts/kallsyms
  MKELF   scripts/mod/elfconfig.h
  GEN     scripts/mod/devicetable-offsets.h
  HOSTCC  scripts/mod/sumversion.o
  HOSTCC  scripts/dtc/treesource.o
  HOSTLD  scripts/genksyms/genksyms
  CC      kernel/bounds.s
  HOSTCC  scripts/dtc/srcpos.o
  HOSTCC  scripts/mod/modpost.o
  HOSTCC  scripts/dtc/checks.o
  CHK     include/generated/timeconst.h
  HOSTCC  scripts/dtc/util.o
  HOSTCC  scripts/dtc/dtc-lexer.lex.o
  CHK     include/generated/bounds.h
  CC      arch/arm/kernel/asm-offsets.s
  HOSTCC  scripts/mod/file2alias.o
  HOSTCC  scripts/dtc/dtc-parser.tab.o
  HOSTCC  scripts/conmakehash
  HOSTLD  scripts/dtc/dtc
  HOSTCC  scripts/sortextable
  HOSTLD  scripts/mod/modpost
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
  CC      init/main.o
  CHK     include/generated/compile.h
  HOSTCC  usr/gen_init_cpio
  CC      arch/arm/vfp/vfpmodule.o
  AS      arch/arm/vfp/entry.o
  AS      arch/arm/vfp/vfphw.o
  GEN     usr/initramfs_data.cpio.gz
  AS      usr/initramfs_data.o
  CC      arch/arm/kernel/elf.o
  LD      usr/built-in.o
  CC      arch/arm/vfp/vfpsingle.o
  AS      arch/arm/kernel/entry-common.o
  CC      arch/arm/mm/dma-mapping.o
  CC      arch/arm/kernel/irq.o
  CC      arch/arm/vfp/vfpdouble.o
  CC      arch/arm/kernel/opcodes.o
  LD      arch/arm/vfp/vfp.o
  LD      arch/arm/vfp/built-in.o
  CC      arch/arm/kernel/process.o
  CC      arch/arm/mm/extable.o
  CC      arch/arm/mm/fault.o
  CC      arch/arm/common/firmware.o
  CC      init/do_mounts.o
  CC      arch/arm/kernel/ptrace.o
  CC      arch/arm/mm/init.o
  LD      arch/arm/common/built-in.o
  CC      arch/arm/kernel/reboot.o
  CC      init/do_mounts_rd.o
  CC      arch/arm/kernel/return_address.o
  CC      arch/arm/mm/iomap.o
  CC      arch/arm/kernel/setup.o
  CC      init/do_mounts_initrd.o
  CC      arch/arm/mm/fault-armv.o
  CC      arch/arm/mm/flush.o
  CC      init/initramfs.o
  CC      arch/arm/kernel/signal.o
  CC      arch/arm/mm/idmap.o
  CC      init/calibrate.o
  AS      arch/arm/kernel/sigreturn_codes.o
  LD      arch/arm/probes/built-in.o
  CC      arch/arm/kernel/stacktrace.o
  CC      init/init_task.o
  CC      arch/arm/mm/ioremap.o
  CC      arch/arm/mm/mmap.o
  CC      arch/arm/kernel/sys_arm.o
  CC      arch/arm/kernel/time.o
  CC      init/version.o
  LD      init/mounts.o
  CC      arch/arm/kernel/traps.o
  CC      arch/arm/mm/pgd.o
  CC      arch/arm/mm/mmu.o
  LD      init/built-in.o
  LD      arch/arm/net/built-in.o
  CC      arch/arm/kernel/atags_parse.o
  CC      arch/arm/mm/pageattr.o
  CC      arch/arm/mm/proc-syms.o
  LD      arch/arm/crypto/built-in.o
  AS [M]  arch/arm/crypto/aes-armv4.o
  CC      arch/arm/kernel/atags_proc.o
  CC [M]  arch/arm/crypto/aes_glue.o
  AS [M]  arch/arm/crypto/aesbs-core.o
  CC      arch/arm/mm/alignment.o
  AS      arch/arm/kernel/entry-armv.o
  CC      arch/arm/kernel/cpuidle.o
  CC [M]  arch/arm/crypto/aesbs-glue.o
  LD      arch/arm/firmware/built-in.o
  CC      arch/arm/kernel/armksyms.o
  AS [M]  arch/arm/crypto/sha1-armv4-large.o
  CC      arch/arm/mm/highmem.o
  CC      arch/arm/kernel/module.o
  CC      arch/arm/mach-omap2/id.o
  CC [M]  arch/arm/crypto/sha1_glue.o
  CC      arch/arm/kernel/bios32.o
  AS      arch/arm/mm/abort-ev7.o
  AS      arch/arm/mm/pabort-v7.o
  AS      arch/arm/mm/cache-v7.o
  CC      arch/arm/mm/copypage-v6.o
  AS [M]  arch/arm/crypto/sha1-armv7-neon.o
  CC [M]  arch/arm/crypto/sha1_neon_glue.o
  CC      arch/arm/mach-omap2/io.o
  CC      arch/arm/kernel/isa.o
  CC      arch/arm/mm/context.o
  AS      arch/arm/kernel/sleep.o
  CC      arch/arm/kernel/suspend.o
  AS      arch/arm/mm/tlb-v7.o
  AS [M]  arch/arm/crypto/sha256-core.o
  CC      arch/arm/kernel/jump_label.o
  CC [M]  arch/arm/crypto/sha256_glue.o
  AS      arch/arm/mm/proc-v7.o
  CC      arch/arm/mach-omap2/control.o
  CC      arch/arm/kernel/insn.o
  CC      arch/arm/mm/l2c-common.o
  CC      arch/arm/kernel/patch.o
  CC      arch/arm/mm/cache-l2x0.o
  CC      arch/arm/mach-omap2/mux.o
  CC      arch/arm/kernel/machine_kexec.o
  CC [M]  arch/arm/crypto/sha256_neon_glue.o
  AS      arch/arm/mm/l2c-l2x0-resume.o
  AS      arch/arm/kernel/relocate_kernel.o
  LD      arch/arm/mm/built-in.o
  AS [M]  arch/arm/crypto/sha512-core.o
  CC      arch/arm/kernel/devtree.o
  CC      arch/arm/mach-omap2/devices.o
  CC [M]  arch/arm/crypto/sha512-glue.o
  CC [M]  arch/arm/crypto/sha512-neon-glue.o
  CC      arch/arm/kernel/hw_breakpoint.o
  CC      arch/arm/mach-omap2/fb.o
  CC      arch/arm/kernel/perf_regs.o
  AS [M]  arch/arm/crypto/aes-ce-core.o
  CC [M]  arch/arm/crypto/aes-ce-glue.o
  CC      arch/arm/mach-omap2/serial.o
  AS [M]  arch/arm/crypto/sha1-ce-core.o
  CC      arch/arm/kernel/perf_callchain.o
  CC      arch/arm/mach-omap2/timer.o
  CC [M]  arch/arm/crypto/sha1-ce-glue.o
  AS [M]  arch/arm/crypto/sha2-ce-core.o
  CC      arch/arm/plat-omap/sram.o
  CC      arch/arm/kernel/perf_event_xscale.o
  CC      arch/arm/kernel/perf_event_v6.o
  CC      arch/arm/kernel/perf_event_v7.o
  CC      arch/arm/mach-omap2/pm.o
  CC [M]  arch/arm/crypto/sha2-ce-glue.o
  CC      arch/arm/plat-omap/dma.o
  CC      arch/arm/mach-omap2/common.o
  AS [M]  arch/arm/crypto/ghash-ce-core.o
  CC [M]  arch/arm/crypto/ghash-ce-glue.o
  CC      arch/arm/kernel/efi.o
  CC      arch/arm/kernel/io.o
  CC      arch/arm/mach-omap2/gpio.o
  LD [M]  arch/arm/crypto/aes-arm.o
  LD [M]  arch/arm/crypto/aes-arm-bs.o
  LD [M]  arch/arm/crypto/sha1-arm.o
  LD [M]  arch/arm/crypto/sha1-arm-neon.o
  LD [M]  arch/arm/crypto/sha256-arm.o
  LD [M]  arch/arm/crypto/sha512-arm.o
  LD [M]  arch/arm/crypto/aes-arm-ce.o
  LD [M]  arch/arm/crypto/sha1-arm-ce.o
  LD [M]  arch/arm/crypto/sha2-arm-ce.o
  LD [M]  arch/arm/crypto/ghash-arm-ce.o
  AS      arch/arm/kernel/hyp-stub.o
  CC      arch/arm/mach-omap2/dma.o
  CC      arch/arm/plat-omap/counter_32k.o
  AS      arch/arm/kernel/smccc-call.o
  AS      arch/arm/kernel/head.o
  LDS     arch/arm/kernel/vmlinux.lds
  LD      arch/arm/kernel/built-in.o
  CC      arch/arm/plat-omap/dmtimer.o
  CC      kernel/fork.o
  CC      kernel/exec_domain.o
  CC      arch/arm/mach-omap2/wd_timer.o
  CC      arch/arm/mach-omap2/display.o
  CC      kernel/panic.o
  CC      arch/arm/plat-omap/i2c.o
  CC      arch/arm/mach-omap2/i2c.o
  LD      arch/arm/plat-omap/built-in.o
  CC      arch/arm/mach-omap2/hdq1w.o
  CC      kernel/cpu.o
  CC      arch/arm/mach-omap2/omap_hwmod.o
  CC      kernel/exit.o
  LD      certs/built-in.o
  CC      arch/arm/mach-omap2/omap_device.o
  CC      mm/filemap.o
  CC      kernel/softirq.o
  AS      arch/arm/mach-omap2/omap-headsmp.o
  CC      arch/arm/mach-omap2/sram.o
  CC      arch/arm/mach-omap2/drm.o
  CC      mm/mempool.o
  CC      kernel/resource.o
  CC      arch/arm/mach-omap2/omap_hwmod_reset.o
  CC      arch/arm/mach-omap2/omap_hwmod_common_data.o
  CC      arch/arm/mach-omap2/am33xx-restart.o
  CC      fs/open.o
  CC      kernel/sysctl.o
  CC      arch/arm/mach-omap2/opp.o
  CC      mm/oom_kill.o
  CC      arch/arm/mach-omap2/omap-pm-noop.o
  CC      arch/arm/mach-omap2/pm33xx-core.o
  CC      mm/maccess.o
  AS      arch/arm/mach-omap2/sleep33xx.o
  CC      fs/read_write.o
  CC      arch/arm/mach-omap2/pm-debug.o
  CC      mm/page_alloc.o
  CC      kernel/sysctl_binary.o
  CC      arch/arm/mach-omap2/prm_common.o
  CC      kernel/capability.o
  CC      arch/arm/mach-omap2/cm_common.o
  CC      fs/file_table.o
  CC      arch/arm/mach-omap2/prm33xx.o
  CC      arch/arm/mach-omap2/cm33xx.o
  CC      kernel/ptrace.o
  CC      arch/arm/mach-omap2/voltage.o
  CC      fs/super.o
  CC      arch/arm/mach-omap2/vc.o
  CC      arch/arm/mach-omap2/vp.o
  CC      mm/page-writeback.o
  CC      kernel/user.o
  CC      fs/char_dev.o
  CC      arch/arm/mach-omap2/powerdomain.o
  CC      kernel/signal.o
  CC      arch/arm/mach-omap2/powerdomain-common.o
  CC      fs/stat.o
  CC      arch/arm/mach-omap2/powerdomains33xx_data.o
  CC      arch/arm/mach-omap2/clockdomain.o
  CC      arch/arm/mach-omap2/clockdomains33xx_data.o
  CC      fs/exec.o
  CC      mm/readahead.o
  CC      arch/arm/mach-omap2/clock.o
  CC      arch/arm/mach-omap2/omap_hwmod_common_ipblock_data.o
  CC      kernel/sys.o
  CC      arch/arm/mach-omap2/omap_hwmod_33xx_data.o
  CC      mm/swap.o
  CC      arch/arm/mach-omap2/omap_hwmod_33xx_43xx_interconnect_data.o
  CC      fs/pipe.o
  CC      arch/arm/mach-omap2/omap_hwmod_33xx_43xx_ipblock_data.o
  CC      arch/arm/mach-omap2/pmu.o
  CC      mm/truncate.o
  CC      kernel/kmod.o
  CC      fs/namei.o
  CC      arch/arm/mach-omap2/board-generic.o
  CC      arch/arm/mach-omap2/pdata-quirks.o
  CC      kernel/workqueue.o
  CC      mm/vmscan.o
  CC      arch/arm/mach-omap2/board-flash.o
  CC      arch/arm/mach-omap2/hsmmc.o
  CC      arch/arm/mach-omap2/usb-musb.o
  CC      arch/arm/mach-omap2/omap_phy_internal.o
  CC      fs/fcntl.o
  CC      arch/arm/mach-omap2/usb-host.o
  CC      mm/shmem.o
  CC      kernel/pid.o
  CC      arch/arm/mach-omap2/gpmc-nand.o
  CC      fs/ioctl.o
  CC      arch/arm/mach-omap2/gpmc-smsc911x.o
  CC      kernel/task_work.o
  CC      arch/arm/mach-omap2/common-board-devices.o
  CC      kernel/extable.o
  CC      fs/readdir.o
  CC      arch/arm/mach-omap2/twl-common.o
  CC      kernel/params.o
  CC      arch/arm/mach-omap2/dss-common.o
  CC      fs/select.o
  CC      mm/util.o
  CC      arch/arm/mach-omap2/omap-iommu.o
  CC      kernel/kthread.o
  LD      arch/arm/mach-omap2/built-in.o
  CC      fs/dcache.o
  CC      mm/mmzone.o
  CC      mm/vmstat.o
  CC      mm/backing-dev.o
  CC      kernel/sys_ni.o
  CC      kernel/nsproxy.o
  CC      kernel/notifier.o
  CC      fs/inode.o
  CC      kernel/ksysfs.o
  CC      mm/mm_init.o
  CC      ipc/util.o
  CC      kernel/cred.o
  CC      mm/mmu_context.o
  CC      ipc/msgutil.o
  CC      fs/attr.o
  CC      mm/percpu.o
  CC      ipc/msg.o
  CC      kernel/reboot.o
  CC      fs/bad_inode.o
  CC      ipc/sem.o
  CC      kernel/async.o
  CC      fs/file.o
  CC      mm/slab_common.o
  CC      kernel/range.o
  CC      kernel/smpboot.o
  CC      ipc/shm.o
  CC      fs/filesystems.o
  CC      mm/compaction.o
  CC      kernel/ucount.o
  CC      kernel/groups.o
  CC      fs/namespace.o
  CC      ipc/syscall.o
  CC      ipc/ipc_sysctl.o
  CC      kernel/bpf/core.o
  CC      ipc/mqueue.o
  CC      mm/vmacache.o
  CC      mm/interval_tree.o
  CC      ipc/namespace.o
  CC      mm/list_lru.o
  CC      ipc/mq_sysctl.o
  CC      fs/seq_file.o
  LD      kernel/bpf/built-in.o
  CC      kernel/events/core.o
  LD      ipc/built-in.o
  CC      kernel/irq/irqdesc.o
  CC      mm/workingset.o
  CC      mm/debug.o
  CC      fs/xattr.o
  CC      kernel/irq/handle.o
  CC      kernel/irq/manage.o
  CC      mm/gup.o
  CC      fs/libfs.o
  CC      kernel/irq/spurious.o
  CC      mm/highmem.o
  CC      kernel/irq/resend.o
  CC      fs/fs-writeback.o
  CC      mm/memory.o
  CC      kernel/irq/chip.o
  CC      kernel/irq/dummychip.o
  CC      fs/pnode.o
  CC      kernel/irq/devres.o
  CC      fs/splice.o
  CC      kernel/events/ring_buffer.o
  CC      kernel/irq/generic-chip.o
  CC      mm/mincore.o
  CC      mm/mlock.o
  CC      kernel/events/callchain.o
  CC      kernel/irq/autoprobe.o
  CC      fs/sync.o
  CC      kernel/events/hw_breakpoint.o
  CC      kernel/irq/irqdomain.o
  CC      mm/mmap.o
  CC      fs/utimes.o
  LD      kernel/events/built-in.o
  CC      fs/stack.o
  CC      kernel/irq/proc.o
  CC      kernel/irq/pm.o
  CC      fs/fs_struct.o
  CC      fs/statfs.o
  CC      kernel/irq/msi.o
  CC      security/keys/gc.o
  CC      mm/mprotect.o
  CC      fs/fs_pin.o
  LD      kernel/irq/built-in.o
  CC      security/keys/key.o
  LD      kernel/livepatch/built-in.o
  CC      kernel/locking/mutex.o
  CC      fs/nsfs.o
  CC      mm/mremap.o
  CC      kernel/locking/semaphore.o
  CC      fs/buffer.o
  CC      security/keys/keyring.o
  CC      mm/msync.o
  CC      kernel/locking/rwsem.o
  CC      mm/rmap.o
  CC      kernel/locking/percpu-rwsem.o
  CC      security/keys/keyctl.o
  CC      kernel/locking/rtmutex.o
  CC      mm/vmalloc.o
  CC      security/keys/permission.o
  CC      kernel/locking/rwsem-xadd.o
  CC      fs/block_dev.o
  CC      security/keys/process_keys.o
  LD      kernel/locking/built-in.o
  CC      kernel/power/qos.o
  CC      security/keys/request_key.o
  CC      kernel/power/main.o
  CC      mm/pagewalk.o
  CC      security/keys/request_key_auth.o
  CC      mm/pgtable-generic.o
  CC      fs/direct-io.o
  CC      security/keys/user_defined.o
  CC      kernel/power/console.o
  CC      mm/process_vm_access.o
  CC      security/keys/proc.o
  CC      mm/init-mm.o
  CC      security/keys/sysctl.o
  CC      kernel/power/process.o
  CC      mm/nobootmem.o
  LD      security/keys/built-in.o
  CC      security/commoncap.o
  CC      kernel/power/suspend.o
  CC      mm/fadvise.o
  CC      fs/mpage.o
  CC      security/min_addr.o
  CC      mm/madvise.o
  CC      kernel/power/poweroff.o
  CC      security/device_cgroup.o
  LD      kernel/power/built-in.o
  CC      kernel/printk/printk.o
  LD      security/built-in.o
  CC      kernel/rcu/update.o
  CC      fs/proc_namespace.o
  CC      mm/memblock.o
  CC      kernel/rcu/sync.o
  CC      fs/autofs4/init.o
  CC      kernel/rcu/srcu.o
  CC      fs/autofs4/inode.o
  CC      mm/page_io.o
  CC      kernel/rcu/tree.o
  CC      fs/autofs4/root.o
  CC      kernel/printk/nmi.o
  CC      mm/swap_state.o
  LD      kernel/printk/built-in.o
  CC      mm/swapfile.o
  CC      fs/autofs4/symlink.o
  CC      fs/autofs4/waitq.o
  CC      fs/autofs4/expire.o
  LD      fs/cifs/built-in.o
  CC [M]  fs/cifs/cifsfs.o
  CC      fs/autofs4/dev-ioctl.o
  LD      kernel/rcu/built-in.o
  CC      kernel/sched/core.o
  LD      fs/autofs4/autofs4.o
  LD      fs/autofs4/built-in.o
  CC      kernel/time/time.o
  CC      mm/dmapool.o
  CC [M]  fs/cifs/cifssmb.o
  CC      kernel/time/timer.o
  CC      mm/slub.o
  CC      kernel/time/hrtimer.o
  CC      kernel/sched/loadavg.o
  CC      mm/migrate.o
  CC      kernel/sched/clock.o
  CC      kernel/time/itimer.o
  CC [M]  fs/cifs/cifs_debug.o
  CC      kernel/sched/cputime.o
  CC      kernel/time/posix-timers.o
  CC      mm/page_counter.o
  CC      kernel/sched/idle_task.o
  CC      mm/memcontrol.o
  CC      kernel/sched/fair.o
  CC [M]  fs/cifs/connect.o
  CC      kernel/time/posix-cpu-timers.o
  CC      kernel/time/timekeeping.o
  CC      kernel/sched/rt.o
  CC      kernel/sched/deadline.o
  CC [M]  fs/cifs/dir.o
  CC      kernel/sched/stop_task.o
  CC      kernel/time/ntp.o
  CC      kernel/sched/wait.o
  CC      kernel/time/clocksource.o
  CC      mm/vmpressure.o
  CC [M]  fs/cifs/file.o
  CC      kernel/sched/swait.o
  CC      mm/swap_cgroup.o
  CC      kernel/sched/completion.o
  CC      kernel/time/jiffies.o
  CC      mm/page_isolation.o
  CC      kernel/time/timer_list.o
  CC      kernel/sched/idle.o
  CC      kernel/time/timeconv.o
  CC      mm/early_ioremap.o
  CC      kernel/time/timecounter.o
  CC      kernel/sched/stats.o
  CC      kernel/time/posix-clock.o
  CC      mm/cma.o
  CC      kernel/sched/debug.o
  CC      mm/frame_vector.o
  CC      kernel/time/alarmtimer.o
  CC [M]  fs/cifs/inode.o
  LD      mm/built-in.o
  CC [M]  fs/cifs/link.o
  CC      kernel/time/clockevents.o
  CC      kernel/sched/cpuacct.o
  CC      kernel/time/tick-common.o
  CC      kernel/sched/cpufreq.o
  CC      fs/configfs/inode.o
  CC [M]  fs/cifs/misc.o
  LD      kernel/sched/built-in.o
  CC      fs/configfs/file.o
  CC      fs/configfs/dir.o
  CC      kernel/time/sched_clock.o
  CC      fs/debugfs/inode.o
  CC      kernel/time/tick-oneshot.o
  CC [M]  fs/cifs/netmisc.o
  CC      kernel/time/tick-sched.o
  CC [M]  fs/cifs/smbencrypt.o
  CC      fs/configfs/symlink.o
  CC      fs/debugfs/file.o
  CC      kernel/time/timekeeping_debug.o
  CC      fs/configfs/mount.o
  LD      kernel/time/built-in.o
  CC      kernel/kcmp.o
  CC [M]  fs/cifs/transport.o
  CC      fs/configfs/item.o
  CC      kernel/freezer.o
  LD      fs/debugfs/debugfs.o
  LD      fs/debugfs/built-in.o
  CC      kernel/futex.o
  LD      fs/configfs/configfs.o
  LD      fs/configfs/built-in.o
  CC      crypto/api.o
  CC [M]  fs/cifs/asn1.o
  CC      block/bio.o
  CC      crypto/cipher.o
  CC      kernel/up.o
  CC      crypto/compress.o
  CC [M]  fs/cifs/cifs_unicode.o
  CC      kernel/uid16.o
  CC      crypto/memneq.o
  CC      block/elevator.o
  CC      kernel/module.o
  CC [M]  fs/cifs/nterr.o
  CC      crypto/crypto_wq.o
  CC [M]  fs/cifs/cifsencrypt.o
  CC      crypto/algapi.o
  CC      block/blk-core.o
  CC [M]  fs/cifs/readdir.o
  CC      crypto/scatterwalk.o
  CC [M]  fs/cifs/ioctl.o
  CC      kernel/kallsyms.o
  CC      crypto/proc.o
  CC      kernel/acct.o
  CC [M]  fs/cifs/sess.o
  CC      crypto/aead.o
  CC      block/blk-tag.o
  CC      kernel/kexec_core.o
  CC      block/blk-sysfs.o
  CC [M]  fs/cifs/export.o
  CC      crypto/ablkcipher.o
  CC      block/blk-flush.o
  CC      kernel/kexec.o
  CC [M]  fs/cifs/smb1ops.o
  CC      kernel/cgroup.o
  CC      block/blk-settings.o
  CC      crypto/blkcipher.o
  CC [M]  fs/cifs/winucase.o
  CC [M]  fs/cifs/xattr.o
  CC      block/blk-ioc.o
  CC      crypto/skcipher.o
  CC [M]  fs/cifs/cifsacl.o
  CC      block/blk-map.o
  CC      crypto/ahash.o
  CC [M]  fs/cifs/smb2ops.o
  CC      block/blk-exec.o
  CC      crypto/shash.o
  CC      kernel/cgroup_freezer.o
  CC      block/blk-merge.o
  CC      kernel/cgroup_pids.o
  CC [M]  fs/cifs/smb2maperror.o
  CC      crypto/akcipher.o
  CC      kernel/utsname.o
  CC      kernel/pid_namespace.o
  CC [M]  fs/cifs/smb2transport.o
  CC      crypto/kpp.o
  CC      block/blk-softirq.o
  GZIP    kernel/config_data.gz
  CC      block/blk-timeout.o
  CC      kernel/seccomp.o
  CC      crypto/algboss.o
  CC [M]  fs/cifs/smb2misc.o
  CC      block/blk-lib.o
  CC      crypto/testmgr.o
  CC      kernel/utsname_sysctl.o
  CC      kernel/elfcore.o
  CC [M]  fs/cifs/smb2pdu.o
  CC      block/blk-mq.o
  CC      crypto/crypto_null.o
  CC      kernel/irq_work.o
  CC      kernel/cpu_pm.o
  CC      crypto/aes_generic.o
  CC      kernel/jump_label.o
  CC      kernel/membarrier.o
  CC      block/blk-mq-tag.o
  CC [M]  fs/cifs/smb2inode.o
  CC      crypto/deflate.o
  CC      kernel/memremap.o
  CC      crypto/crc32c_generic.o
  CHK     kernel/config_data.h
  UPD     kernel/config_data.h
  CC      kernel/configs.o
  CC      block/blk-mq-sysfs.o
  CC [M]  fs/cifs/smb2file.o
  LD      kernel/built-in.o
  LD      drivers/amba/built-in.o
  CC      crypto/lzo.o
  LD      drivers/android/built-in.o
  LD      drivers/ata/built-in.o
  CC [M]  drivers/ata/libata-core.o
  CC      crypto/rng.o
  CC      block/blk-mq-cpumap.o
  LD [M]  fs/cifs/cifs.o
  CC      fs/devpts/inode.o
  CC      block/ioctl.o
  LD      fs/devpts/devpts.o
  LD      fs/devpts/built-in.o
  LD      fs/efivarfs/built-in.o
  CC [M]  fs/efivarfs/inode.o
  CC [M]  crypto/crypto_engine.o
  CC [M]  fs/efivarfs/file.o
  CC      block/genhd.o
  CC [M]  fs/efivarfs/super.o
  CC [M]  crypto/seqiv.o
  LD [M]  fs/efivarfs/efivarfs.o
  LD      fs/exofs/built-in.o
  CC      fs/exportfs/expfs.o
  CC [M]  crypto/echainiv.o
  LD      fs/exportfs/exportfs.o
  LD      fs/exportfs/built-in.o
  CC      fs/ext4/balloc.o
  CC      block/scsi_ioctl.o
  CC [M]  crypto/cmac.o
  CC [M]  drivers/ata/libata-scsi.o
  CC [M]  crypto/hmac.o
  CC      block/partition-generic.o
  CC      fs/ext4/bitmap.o
  CC [M]  crypto/md4.o
  CC      fs/ext4/dir.o
  CC [M]  crypto/md5.o
  CC      block/ioprio.o
  CC [M]  drivers/ata/libata-eh.o
  CC      fs/ext4/file.o
  CC [M]  crypto/sha1_generic.o
  CC      block/badblocks.o
  CC      fs/ext4/fsync.o
  CC [M]  crypto/sha256_generic.o
  CC      block/partitions/check.o
  CC      fs/ext4/ialloc.o
  CC      block/partitions/cmdline.o
  CC [M]  crypto/sha512_generic.o
  CC      block/partitions/msdos.o
  CC      fs/ext4/inode.o
  CC [M]  drivers/ata/libata-transport.o
  CC      block/partitions/efi.o
  CC [M]  crypto/gf128mul.o
  LD      block/partitions/built-in.o
  CC      block/bounce.o
  CC [M]  drivers/ata/libata-trace.o
  CC [M]  crypto/ecb.o
  CC [M]  drivers/ata/libata-sff.o
  CC      block/bsg.o
  CC [M]  crypto/cbc.o
  CC [M]  crypto/ctr.o
  CC      fs/ext4/page-io.o
  CC      block/blk-cgroup.o
  CC [M]  crypto/gcm.o
  CC [M]  drivers/ata/libata-pmp.o
  CC      fs/ext4/ioctl.o
  CC [M]  crypto/ccm.o
  CC [M]  drivers/ata/ahci.o
  CC      block/noop-iosched.o
  CC      fs/ext4/namei.o
  CC      block/deadline-iosched.o
  CC [M]  drivers/ata/libahci.o
  CC [M]  crypto/cryptd.o
  CC      block/cfq-iosched.o
  CC [M]  crypto/des_generic.o
  CC      fs/ext4/super.o
  CC [M]  drivers/ata/ahci_platform.o
  CC [M]  drivers/ata/libahci_platform.o
  CC [M]  crypto/arc4.o
  CC      block/cmdline-parser.o
  CC [M]  crypto/authenc.o
  CC [M]  drivers/ata/sata_mv.o
  CC      block/blk-mq-pci.o
  CC [M]  crypto/authencesn.o
  LD      block/built-in.o
  CC [M]  crypto/drbg.o
  CC      fs/ext4/symlink.o
  CC      fs/ext4/hash.o
  CC [M]  crypto/jitterentropy.o
  LD [M]  drivers/ata/libata.o
  LD      drivers/auxdisplay/built-in.o
  CC      drivers/base/component.o
  CC [M]  crypto/jitterentropy-kcapi.o
  CC      drivers/block/brd.o
  CC      fs/ext4/resize.o
  CC [M]  crypto/tcrypt.o
  CC      drivers/base/core.o
  CC      drivers/block/loop.o
  CC      fs/ext4/extents.o
  CC [M]  crypto/ghash-generic.o
  CC      drivers/block/virtio_blk.o
  CC      drivers/base/bus.o
  CC [M]  crypto/af_alg.o
  LD      drivers/block/built-in.o
  CC [M]  crypto/algif_hash.o
  CC      drivers/base/dd.o
  CC      drivers/base/syscore.o
  CC [M]  crypto/algif_skcipher.o
  CC      sound/sound_core.o
  CC      fs/ext4/ext4_jbd2.o
  LD      sound/arm/built-in.o
  LD      sound/atmel/built-in.o
  CC      sound/core/sound.o
  CC      drivers/base/driver.o
  CC      fs/ext4/migrate.o
  CC      sound/core/init.o
  CC [M]  crypto/ablk_helper.o
  CC      drivers/base/class.o
  CC      fs/ext4/mballoc.o
  CC      sound/core/memory.o
  CC      drivers/base/platform.o
  LD      crypto/crypto.o
  LD      crypto/crypto_algapi.o
  LD      crypto/crypto_blkcipher.o
  LD      crypto/crypto_hash.o
  LD      crypto/cryptomgr.o
  LD [M]  crypto/jitterentropy_rng.o
  LD      crypto/built-in.o
  CC      drivers/base/cpu.o
  CC      sound/core/control.o
  LD      firmware/built-in.o
  CC      fs/ext4/block_validity.o
  CC      drivers/base/firmware.o
  CC      drivers/base/init.o
  CC      fs/fat/cache.o
  CC      sound/core/misc.o
  CC      drivers/base/map.o
  CC      drivers/base/devres.o
  CC      fs/fat/dir.o
  CC      sound/core/device.o
  CC      fs/ext4/move_extent.o
  CC      sound/core/info.o
  CC      drivers/base/attribute_container.o
  CC      fs/fat/fatent.o
  CC      drivers/base/transport_class.o
  CC      fs/ext4/mmp.o
  CC      sound/core/ctljack.o
  CC      sound/core/jack.o
  CC      drivers/base/topology.o
  CC      fs/ext4/indirect.o
  CC      drivers/base/container.o
  CC      sound/core/timer.o
  CC      fs/fat/file.o
  CC      drivers/base/property.o
  CC      fs/ext4/extents_status.o
  CC      fs/fat/inode.o
  CC      fs/ext4/xattr.o
  CC      sound/core/pcm.o
  CC      drivers/base/cacheinfo.o
  CC      drivers/base/devtmpfs.o
  CC      fs/fat/misc.o
  CC      sound/core/pcm_native.o
  CC      fs/ext4/xattr_user.o
  CC      drivers/base/dma-contiguous.o
  CC      fs/fat/nfs.o
  CC      fs/ext4/xattr_trusted.o
  CC      fs/fat/namei_vfat.o
  CC      drivers/base/power/sysfs.o
  CC      fs/ext4/inline.o
  CC      fs/fat/namei_msdos.o
  CC      drivers/base/power/generic_ops.o
  LD      fs/fat/fat.o
  LD      fs/fat/vfat.o
  LD      fs/fat/msdos.o
  LD      fs/fat/built-in.o
  CC      drivers/base/power/common.o
  CC      sound/core/pcm_lib.o
  CC      fs/ext4/readpage.o
  CC      fs/ext4/sysfs.o
  CC      drivers/base/power/qos.o
  CC      drivers/base/regmap/regmap.o
  CC      fs/ext4/acl.o
  CC      drivers/base/power/runtime.o
  CC      fs/ext4/xattr_security.o
  CC      sound/core/pcm_misc.o
  LD      fs/ext4/ext4.o
  LD      fs/ext4/built-in.o
  LD      fs/fscache/built-in.o
  CC [M]  fs/fscache/cache.o
  CC      drivers/base/regmap/regcache.o
  CC      drivers/base/power/wakeirq.o
  CC      sound/core/pcm_memory.o
  CC [M]  fs/fscache/cookie.o
  CC      drivers/base/regmap/regcache-rbtree.o
  CC      drivers/base/power/main.o
  CC      sound/core/memalloc.o
  CC      drivers/base/regmap/regcache-lzo.o
  CC [M]  fs/fscache/fsdef.o
  CC      drivers/base/regmap/regcache-flat.o
  CC      sound/core/pcm_timer.o
  CC [M]  fs/fscache/main.o
  CC      drivers/base/regmap/regmap-debugfs.o
  CC [M]  fs/fscache/netfs.o
  CC      sound/core/pcm_drm_eld.o
  CC      drivers/base/power/wakeup.o
  CC      drivers/base/regmap/regmap-i2c.o
  CC [M]  fs/fscache/object.o
  CC      sound/core/pcm_iec958.o
  CC      drivers/base/regmap/regmap-spi.o
  CC      sound/core/pcm_dmaengine.o
  CC      drivers/base/power/opp/core.o
  CC      drivers/base/regmap/regmap-mmio.o
  CC [M]  fs/fscache/operation.o
  CC [M]  sound/core/hwdep.o
  CC      drivers/base/regmap/regmap-irq.o
  CC      drivers/base/power/opp/cpu.o
  CC [M]  fs/fscache/page.o
  CC [M]  sound/core/rawmidi.o
  LD      drivers/base/regmap/built-in.o
  CC [M]  fs/fscache/proc.o
  CC      drivers/base/power/opp/of.o
  LD      sound/drivers/mpu401/built-in.o
  LD      sound/drivers/opl3/built-in.o
  LD      sound/drivers/opl4/built-in.o
  LD      sound/drivers/pcsp/built-in.o
  LD      sound/drivers/vx/built-in.o
  LD      sound/drivers/built-in.o
  CC      drivers/base/power/opp/debugfs.o
  LD [M]  fs/fscache/fscache.o
  CC      fs/jbd2/transaction.o
  CC      fs/jbd2/commit.o
  CC      drivers/base/power/opp/ti-opp-supply.o
  LD      sound/core/snd.o
  LD      sound/core/snd-timer.o
  LD      sound/core/snd-pcm.o
  LD      sound/core/snd-pcm-dmaengine.o
  LD [M]  sound/core/snd-hwdep.o
  LD [M]  sound/core/snd-rawmidi.o
  LD      sound/core/built-in.o
  LD      sound/firewire/built-in.o
  LD      sound/hda/built-in.o
  LD      drivers/base/power/opp/built-in.o
  CC      drivers/base/power/clock_ops.o
  LD      sound/i2c/other/built-in.o
  LD      sound/i2c/built-in.o
  LD      sound/isa/ad1816a/built-in.o
  LD      sound/isa/ad1848/built-in.o
  LD      sound/isa/cs423x/built-in.o
  LD      sound/isa/es1688/built-in.o
  LD      sound/isa/galaxy/built-in.o
  LD      sound/isa/gus/built-in.o
  LD      sound/isa/msnd/built-in.o
  LD      sound/isa/opti9xx/built-in.o
  LD      sound/isa/sb/built-in.o
  LD      sound/isa/wavefront/built-in.o
  LD      sound/isa/wss/built-in.o
  LD      sound/isa/built-in.o
  LD      sound/mips/built-in.o
  LD      sound/parisc/built-in.o
  LD      sound/pci/ac97/built-in.o
  LD      sound/pci/ali5451/built-in.o
  LD      sound/pci/asihpi/built-in.o
  LD      sound/pci/au88x0/built-in.o
  LD      sound/pci/aw2/built-in.o
  LD      sound/pci/ca0106/built-in.o
  LD      sound/pci/cs46xx/built-in.o
  LD      sound/pci/cs5535audio/built-in.o
  LD      sound/pci/ctxfi/built-in.o
  LD      sound/pci/echoaudio/built-in.o
  LD      sound/pci/emu10k1/built-in.o
  LD      sound/pci/hda/built-in.o
  LD      sound/pci/ice1712/built-in.o
  LD      sound/pci/korg1212/built-in.o
  LD      sound/pci/lola/built-in.o
  LD      sound/pci/lx6464es/built-in.o
  LD      sound/pcmcia/pdaudiocf/built-in.o
  LD      sound/pci/mixart/built-in.o
  LD      sound/pcmcia/vx/built-in.o
  LD      sound/pcmcia/built-in.o
  LD      sound/pci/nm256/built-in.o
  CC      fs/jbd2/recovery.o
  LD      sound/pci/oxygen/built-in.o
  LD      sound/pci/pcxhr/built-in.o
  LD      sound/pci/riptide/built-in.o
  LD      sound/pci/rme9652/built-in.o
  LD      sound/pci/trident/built-in.o
  LD      sound/pci/vx222/built-in.o
  LD      sound/pci/ymfpci/built-in.o
  LD      sound/pci/built-in.o
  LD      sound/ppc/built-in.o
  LD      sound/sh/built-in.o
  CC      sound/soc/soc-core.o
  LD      drivers/base/power/built-in.o
  CC      drivers/base/dma-mapping.o
  CC      drivers/base/dma-coherent.o
  CC      fs/jbd2/checkpoint.o
  CC      sound/soc/soc-dapm.o
  CC      drivers/base/firmware_class.o
  CC      fs/jbd2/revoke.o
  CC      fs/jbd2/journal.o
  CC      drivers/base/module.o
  CC      fs/kernfs/mount.o
  CC      drivers/base/soc.o
  CC      fs/kernfs/inode.o
  CC      drivers/base/pinctrl.o
  CC      drivers/base/devcoredump.o
  CC      fs/kernfs/dir.o
  CC      sound/soc/soc-jack.o
  LD      fs/jbd2/jbd2.o
  LD      fs/jbd2/built-in.o
  CC      fs/lockd/clntlock.o
  CC      sound/soc/soc-cache.o
  CC      drivers/base/platform-msi.o
  CC      fs/kernfs/file.o
  CC      sound/soc/soc-utils.o
  LD      drivers/base/built-in.o
  CC      fs/lockd/clntproc.o
  LD      drivers/bluetooth/built-in.o
  CC [M]  drivers/bluetooth/hci_ldisc.o
  CC      sound/soc/soc-pcm.o
  CC      fs/kernfs/symlink.o
  CC [M]  drivers/bluetooth/hci_h4.o
  LD      fs/kernfs/built-in.o
  CC [M]  drivers/bluetooth/hci_ll.o
  CC      fs/lockd/clntxdr.o
  CC      fs/lockd/host.o
  CC [M]  drivers/bluetooth/hci_h5.o
  CC      sound/soc/soc-io.o
  CC      sound/soc/soc-devres.o
  CC      fs/lockd/svc.o
  CC      fs/lockd/svclock.o
  CC [M]  drivers/bluetooth/btmrvl_main.o
  CC      sound/soc/soc-ops.o
  CC      sound/soc/soc-generic-dmaengine-pcm.o
  CC [M]  drivers/bluetooth/btmrvl_debugfs.o
  CC      fs/lockd/svcshare.o
  LD      sound/sparc/built-in.o
  CC      net/socket.o
  LD      sound/soc/adi/built-in.o
  LD      sound/soc/amd/built-in.o
  LD      sound/soc/atmel/built-in.o
  LD      sound/soc/au1x/built-in.o
  LD      sound/soc/bcm/built-in.o
  LD      sound/soc/blackfin/built-in.o
  CC [M]  drivers/bluetooth/btmrvl_sdio.o
  LD      sound/soc/cirrus/built-in.o
  CC      sound/soc/codecs/hdmi-codec.o
  CC      fs/lockd/svcproc.o
  CC [M]  sound/soc/codecs/ak4642.o
  LD [M]  drivers/bluetooth/hci_uart.o
  LD [M]  drivers/bluetooth/btmrvl.o
  CC      drivers/bus/omap-ocp2scp.o
  CC [M]  sound/soc/codecs/sgtl5000.o
  CC      fs/lockd/svcsubs.o
  LD      drivers/bus/built-in.o
  LD      drivers/cdrom/built-in.o
  CC [M]  drivers/cdrom/cdrom.o
  CC [M]  sound/soc/codecs/spdif_receiver.o
  LD      net/802/built-in.o
  CC [M]  net/802/p8022.o
  CC      fs/lockd/mon.o
  CC [M]  sound/soc/codecs/spdif_transmitter.o
  CC [M]  sound/soc/codecs/sti-sas.o
  CC [M]  net/802/psnap.o
  CC      drivers/char/mem.o
  CC      fs/lockd/xdr.o
  CC [M]  sound/soc/codecs/tlv320aic31xx.o
  CC [M]  net/802/stp.o
  CC      drivers/char/random.o
  CC      fs/lockd/clnt4xdr.o
  CC [M]  sound/soc/codecs/tlv320aic3x.o
  CC      net/8021q/vlan_core.o
  CC      fs/lockd/xdr4.o
  CC [M]  sound/soc/codecs/wm8978.o
  CC      drivers/char/misc.o
  CC [M]  net/8021q/vlan.o
  CC      fs/lockd/svc4proc.o
  CC      drivers/char/virtio_console.o
  LD      sound/soc/codecs/snd-soc-hdmi-codec.o
  LD [M]  sound/soc/codecs/snd-soc-ak4642.o
  LD [M]  sound/soc/codecs/snd-soc-sgtl5000.o
  LD [M]  sound/soc/codecs/snd-soc-spdif-rx.o
  LD [M]  sound/soc/codecs/snd-soc-spdif-tx.o
  LD [M]  sound/soc/codecs/snd-soc-sti-sas.o
  LD [M]  sound/soc/codecs/snd-soc-tlv320aic31xx.o
  LD [M]  sound/soc/codecs/snd-soc-tlv320aic3x.o
  LD [M]  sound/soc/codecs/snd-soc-wm8978.o
  LD      sound/soc/codecs/built-in.o
  CC      sound/soc/davinci/edma-pcm.o
  CC [M]  net/8021q/vlan_dev.o
  CC      sound/soc/davinci/davinci-mcasp.o
  CC      fs/lockd/procfs.o
  CC [M]  net/8021q/vlan_netlink.o
  LD      drivers/char/agp/built-in.o
  CC      drivers/char/hw_random/core.o
  LD      fs/lockd/lockd.o
  LD      fs/lockd/built-in.o
  CC      fs/nfs/client.o
  CC [M]  net/8021q/vlanproc.o
  CC [M]  sound/soc/davinci/davinci-evm.o
  CC      drivers/char/hw_random/omap-rng.o
  LD      sound/soc/davinci/snd-soc-edma.o
  LD      sound/soc/davinci/snd-soc-davinci-mcasp.o
  LD [M]  sound/soc/davinci/snd-soc-evm.o
  LD      sound/soc/davinci/built-in.o
  LD      sound/soc/dwc/built-in.o
  LD      sound/soc/fsl/built-in.o
  CC [M]  sound/soc/fsl/fsl_sai.o
  LD      net/8021q/built-in.o
  LD [M]  net/8021q/8021q.o
  LD      drivers/char/hw_random/rng-core.o
  LD      drivers/char/hw_random/built-in.o
  LD      drivers/char/built-in.o
  LD      net/bluetooth/built-in.o
  CC [M]  net/bluetooth/af_bluetooth.o
  LD      drivers/char/ipmi/built-in.o
  CC      drivers/clk/clk-devres.o
  CC      drivers/clk/clkdev.o
  CC      fs/nfs/dir.o
  LD [M]  sound/soc/fsl/snd-soc-fsl-sai.o
  LD      sound/soc/generic/built-in.o
  CC [M]  sound/soc/generic/simple-card-utils.o
  CC      drivers/clk/clk.o
  CC [M]  net/bluetooth/hci_core.o
  CC [M]  sound/soc/generic/simple-card.o
  LD [M]  sound/soc/generic/snd-soc-simple-card-utils.o
  LD [M]  sound/soc/generic/snd-soc-simple-card.o
  LD      sound/soc/img/built-in.o
  LD      sound/soc/intel/boards/built-in.o
  LD      sound/soc/intel/built-in.o
  LD      sound/soc/jz4740/built-in.o
  LD      sound/soc/kirkwood/built-in.o
  LD      sound/soc/mediatek/built-in.o
  LD      sound/soc/mxs/built-in.o
  LD      sound/soc/nuc900/built-in.o
  CC      sound/soc/omap/omap-pcm.o
  CC      drivers/clk/clk-divider.o
  CC [M]  sound/soc/omap/omap-hdmi-audio.o
  CC      fs/nfs/file.o
  LD      sound/soc/omap/snd-soc-omap.o
  LD [M]  sound/soc/omap/snd-soc-omap-hdmi-audio.o
  LD      sound/soc/omap/built-in.o
  LD      sound/soc/pxa/built-in.o
  LD      sound/soc/qcom/built-in.o
  LD      sound/soc/rockchip/built-in.o
  LD      sound/soc/samsung/built-in.o
  LD      sound/soc/sh/built-in.o
  LD      sound/soc/sirf/built-in.o
  LD      sound/soc/spear/built-in.o
  LD      sound/soc/sti/built-in.o
  LD      sound/soc/sunxi/built-in.o
  LD      sound/soc/tegra/built-in.o
  LD      sound/soc/txx9/built-in.o
  LD      sound/soc/ux500/built-in.o
  LD      sound/soc/xtensa/built-in.o
  LD      sound/soc/zte/built-in.o
  LD      sound/soc/snd-soc-core.o
  LD      sound/soc/built-in.o
  LD      sound/spi/built-in.o
  LD      sound/synth/built-in.o
  LD      sound/usb/6fire/built-in.o
  LD      sound/usb/bcd2000/built-in.o
  LD      sound/usb/caiaq/built-in.o
  LD      sound/usb/hiface/built-in.o
  LD      sound/usb/misc/built-in.o
  LD      sound/usb/usx2y/built-in.o
  CC [M]  sound/usb/card.o
  CC [M]  net/bluetooth/hci_conn.o
  CC      drivers/clk/clk-fixed-factor.o
  CC [M]  sound/usb/clock.o
  CC      drivers/clk/clk-fixed-rate.o
  CC      fs/nfs/getroot.o
  CC [M]  sound/usb/endpoint.o
  CC      drivers/clk/clk-gate.o
  CC      fs/nfs/inode.o
  CC [M]  net/bluetooth/hci_event.o
  CC      drivers/clk/clk-multiplier.o
  CC [M]  sound/usb/format.o
  CC      drivers/clk/clk-mux.o
  CC [M]  sound/usb/helper.o
  CC [M]  sound/usb/mixer.o
  CC      drivers/clk/clk-composite.o
  CC      drivers/clk/clk-fractional-divider.o
  CC      fs/nfs/super.o
  CC      drivers/clk/clk-gpio.o
  CC [M]  sound/usb/mixer_quirks.o
  CC      drivers/clk/clk-conf.o
  CC [M]  net/bluetooth/mgmt.o
  CC      drivers/clk/clk-palmas.o
  CC [M]  sound/usb/mixer_scarlett.o
  LD      drivers/clk/bcm/built-in.o
  LD      drivers/clk/mvebu/built-in.o
  CC      drivers/clk/ti/clk.o
  CC [M]  sound/usb/pcm.o
  CC      fs/nfs/io.o
  CC      drivers/clk/ti/autoidle.o
  CC      drivers/clk/ti/clockdomain.o
  CC      drivers/clk/ti/dpll.o
  CC      fs/nfs/direct.o
  CC [M]  sound/usb/proc.o
  CC      drivers/clk/ti/composite.o
  CC [M]  sound/usb/quirks.o
  CC      drivers/clk/ti/divider.o
  CC      drivers/clk/ti/gate.o
  CC [M]  sound/usb/stream.o
  CC      fs/nfs/pagelist.o
  CC [M]  net/bluetooth/hci_sock.o
  CC      drivers/clk/ti/fixed-factor.o
  CC [M]  sound/usb/midi.o
  CC      drivers/clk/ti/mux.o
  CC      drivers/clk/ti/apll.o
  CC      drivers/clk/ti/clkt_dpll.o
  CC      fs/nfs/read.o
  CC      drivers/clk/ti/clkt_iclk.o
  LD      sound/usb/built-in.o
  LD [M]  sound/usb/snd-usb-audio.o
  LD [M]  sound/usb/snd-usbmidi-lib.o
  CC      sound/last.o
  CC [M]  net/bluetooth/hci_sysfs.o
  CC      drivers/clk/ti/clkt_dflt.o
  LD      sound/soundcore.o
  LD      sound/built-in.o
  CC      drivers/clk/ti/clk-33xx.o
  AS      arch/arm/lib/ashldi3.o
  AS      arch/arm/lib/ashrdi3.o
  AS      arch/arm/lib/backtrace.o
  CC      drivers/clk/ti/dpll3xxx.o
  AS      arch/arm/lib/bswapsdi2.o
  AS      arch/arm/lib/call_with_stack.o
  AS      arch/arm/lib/changebit.o
  CC [M]  net/bluetooth/l2cap_core.o
  AS      arch/arm/lib/clear_user.o
  AS      arch/arm/lib/clearbit.o
  AS      arch/arm/lib/copy_from_user.o
  AS      arch/arm/lib/copy_page.o
  AS      arch/arm/lib/copy_to_user.o
  AS      arch/arm/lib/csumipv6.o
  AS      arch/arm/lib/csumpartial.o
  AS      arch/arm/lib/csumpartialcopy.o
  AS      arch/arm/lib/csumpartialcopyuser.o
  CC      fs/nfs/symlink.o
  AS      arch/arm/lib/delay-loop.o
  CC      arch/arm/lib/delay.o
  LD      drivers/clk/ti/built-in.o
  LD      drivers/clk/built-in.o
  CC      drivers/clocksource/clksrc-probe.o
  AS      arch/arm/lib/div64.o
  AS      arch/arm/lib/findbit.o
  AS      arch/arm/lib/getuser.o
  AS      arch/arm/lib/io-readsb.o
  AS      arch/arm/lib/io-readsl.o
  AS      arch/arm/lib/io-readsw-armv4.o
  AS      arch/arm/lib/io-writesb.o
  CC      drivers/clocksource/mmio.o
  AS      arch/arm/lib/io-writesl.o
  AS      arch/arm/lib/io-writesw-armv4.o
  CC      fs/nfs/unlink.o
  AS      arch/arm/lib/lib1funcs.o
  AS      arch/arm/lib/lshrdi3.o
  AS      arch/arm/lib/memchr.o
  AS      arch/arm/lib/memcpy.o
  AS      arch/arm/lib/memmove.o
  AS      arch/arm/lib/memset.o
  AS      arch/arm/lib/memzero.o
  AS      arch/arm/lib/muldi3.o
  AS      arch/arm/lib/putuser.o
  AS      arch/arm/lib/setbit.o
  CC      drivers/clocksource/timer-ti-32k.o
  AS      arch/arm/lib/strchr.o
  AS      arch/arm/lib/strrchr.o
  AS      arch/arm/lib/testchangebit.o
  AS      arch/arm/lib/testclearbit.o
  AS      arch/arm/lib/testsetbit.o
  AS      arch/arm/lib/ucmpdi2.o
  AR      arch/arm/lib/lib.a
  EXPORTS arch/arm/lib/lib-ksyms.o
  LD      arch/arm/lib/built-in.o
  CC      fs/nfs/write.o
  LD      drivers/clocksource/built-in.o
  CC      drivers/cpufreq/cpufreq.o
  CC      fs/nfs_common/nfsacl.o
  CC      fs/nfs_common/grace.o
  LD      fs/nfs_common/nfs_acl.o
  LD      fs/nfs_common/built-in.o
  CC      drivers/cpufreq/freq_table.o
  LD      net/bridge/netfilter/built-in.o
  CC [M]  net/bridge/netfilter/ebtables.o
  CC      drivers/cpufreq/cpufreq_stats.o
  CC      fs/nfs/namespace.o
  CC      drivers/cpufreq/cpufreq_performance.o
  CC [M]  net/bluetooth/l2cap_sock.o
  CC      drivers/cpufreq/cpufreq_powersave.o
  CC      drivers/cpufreq/cpufreq_userspace.o
  CC      drivers/cpufreq/cpufreq_ondemand.o
  CC      fs/nfs/mount_clnt.o
  CC      drivers/cpufreq/cpufreq_conservative.o
  CC [M]  net/bridge/netfilter/ebtable_broute.o
  CC [M]  net/bluetooth/smp.o
  CC      drivers/cpufreq/cpufreq_governor.o
  CC      fs/nfs/nfstrace.o
  CC [M]  net/bridge/netfilter/ebtable_filter.o
  CC      drivers/cpufreq/cpufreq_governor_attr_set.o
  CC      fs/nfs/nfsroot.o
  CC      drivers/cpufreq/cpufreq-dt.o
  CC [M]  net/bridge/netfilter/ebtable_nat.o
  CC      drivers/cpufreq/cpufreq-dt-platdev.o
  CC      fs/nfs/sysctl.o
  CC [M]  net/bridge/netfilter/ebt_802_3.o
  CC      drivers/cpufreq/ti-cpufreq.o
  CC [M]  net/bluetooth/lib.o
  CC      fs/nfs/nfs2super.o
  CC [M]  net/bridge/netfilter/ebt_among.o
  LD      drivers/cpufreq/built-in.o
  CC      drivers/cpuidle/cpuidle.o
  CC [M]  net/bluetooth/ecc.o
  CC      fs/nfs/proc.o
  CC [M]  net/bridge/netfilter/ebt_arp.o
  CC      drivers/cpuidle/driver.o
  CC [M]  net/bluetooth/hci_request.o
  CC [M]  net/bridge/netfilter/ebt_ip.o
  CC      drivers/cpuidle/governor.o
  CC      fs/nfs/nfs2xdr.o
  CC      drivers/cpuidle/sysfs.o
  CC      drivers/cpuidle/governors/ladder.o
  CC [M]  net/bridge/netfilter/ebt_ip6.o
  CC      drivers/cpuidle/governors/menu.o
  CC      fs/nfs/nfs3super.o
  CC [M]  net/bluetooth/mgmt_util.o
  LD      drivers/cpuidle/governors/built-in.o
  CC      drivers/cpuidle/dt_idle_states.o
  CC [M]  net/bridge/netfilter/ebt_limit.o
  CC      fs/nfs/nfs3client.o
  CC      drivers/cpuidle/cpuidle-arm.o
  CC [M]  net/bluetooth/sco.o
  LD      drivers/cpuidle/built-in.o
  LD      drivers/crypto/built-in.o
  CC [M]  drivers/crypto/omap-aes.o
  CC [M]  net/bridge/netfilter/ebt_mark_m.o
  CC      fs/nfs/nfs3proc.o
  CC [M]  net/bridge/netfilter/ebt_pkttype.o
  CC [M]  drivers/crypto/omap-aes-gcm.o
  CC [M]  net/bluetooth/a2mp.o
  CC [M]  net/bridge/netfilter/ebt_stp.o
  CC      fs/nfs/nfs3xdr.o
  CC [M]  drivers/crypto/omap-des.o
  CC [M]  net/bluetooth/amp.o
  CC [M]  net/bridge/netfilter/ebt_vlan.o
  CC [M]  drivers/crypto/omap-sham.o
  CC      fs/nfs/nfs3acl.o
  CC [M]  net/bluetooth/hci_debugfs.o
  CC [M]  net/bridge/netfilter/ebt_arpreply.o
  CC      fs/nfs/nfs4proc.o
  CC [M]  net/bridge/netfilter/ebt_mark.o
  LD [M]  drivers/crypto/omap-aes-driver.o
  CC      drivers/dma/dmaengine.o
  LD      net/bluetooth/rfcomm/built-in.o
  CC [M]  net/bluetooth/rfcomm/core.o
  CC [M]  net/bridge/netfilter/ebt_dnat.o
  CC [M]  net/bluetooth/rfcomm/sock.o
  CC      drivers/dma/virt-dma.o
  CC [M]  net/bridge/netfilter/ebt_redirect.o
  CC      drivers/dma/of-dma.o
  CC [M]  net/bridge/netfilter/ebt_snat.o
  LD [M]  net/bluetooth/rfcomm/rfcomm.o
  LD [M]  net/bluetooth/bluetooth.o
  CC [M]  net/bridge/netfilter/ebt_log.o
  CC      drivers/dma/omap-dma.o
  CC      fs/nfs/nfs4xdr.o
  CC      drivers/dma/dw/core.o
  CC [M]  net/bridge/netfilter/ebt_nflog.o
  CC [M]  net/bridge/br.o
  CC [M]  net/bridge/br_device.o
  CC      drivers/dma/dw/platform.o
  CC      fs/nls/nls_base.o
  LD      drivers/dma/dw/dw_dmac_core.o
  LD      drivers/dma/dw/dw_dmac.o
  LD      drivers/dma/dw/built-in.o
  LD      drivers/dma/qcom/built-in.o
  LD      drivers/dma/xilinx/built-in.o
  CC      drivers/dma/fsl-edma.o
  CC      fs/nls/nls_cp437.o
  CC      fs/nls/nls_iso8859-1.o
  CC [M]  net/bridge/br_fdb.o
  CC      fs/nfs/nfs4state.o
  CC      fs/nls/nls_utf8.o
  LD      fs/nls/built-in.o
  CC [M]  net/bridge/br_forward.o
  CC      drivers/dma/cppi41.o
  CC      fs/notify/fsnotify.o
  CC      drivers/dma/ti-dma-crossbar.o
  CC [M]  net/bridge/br_if.o
  CC      fs/notify/notification.o
  CC      drivers/dma/edma.o
  CC      fs/nfs/nfs4renewd.o
  CC      fs/notify/group.o
  CC [M]  net/bridge/br_input.o
  CC      fs/nfs/nfs4super.o
  CC      fs/notify/inode_mark.o
  CC      fs/notify/mark.o
  LD      drivers/dma/built-in.o
  CC      drivers/dma-buf/dma-buf.o
  CC      fs/nfs/nfs4file.o
  CC [M]  net/bridge/br_ioctl.o
  CC      fs/notify/vfsmount_mark.o
  CC      fs/nfs/delegation.o
  CC      drivers/dma-buf/fence.o
  CC      fs/notify/fdinfo.o
  CC      fs/notify/dnotify/dnotify.o
  CC [M]  net/bridge/br_stp.o
  CC      drivers/dma-buf/reservation.o
  LD      fs/notify/dnotify/built-in.o
  LD      fs/notify/fanotify/built-in.o
  CC      fs/notify/inotify/inotify_fsnotify.o
  CC      fs/notify/inotify/inotify_user.o
  CC      drivers/dma-buf/seqno-fence.o
  CC      fs/nfs/nfs4idmap.o
  CC [M]  net/bridge/br_stp_bpdu.o
  LD      fs/notify/inotify/built-in.o
  LD      fs/notify/built-in.o
  CC [M]  net/bridge/br_stp_if.o
  CC      drivers/dma-buf/fence-array.o
  CC      drivers/edac/edac_stub.o
  LD      drivers/dma-buf/built-in.o
  CC      lib/lockref.o
  CC      lib/bcd.o
  CC [M]  net/bridge/br_stp_timer.o
  CC      lib/div64.o
  CC      fs/nfs/callback.o
  CC      drivers/edac/edac_mc.o
  CC      lib/sort.o
  CC      lib/parser.o
  CC [M]  net/bridge/br_netlink.o
  CC      lib/halfmd4.o
  CC      fs/nfs/callback_xdr.o
  CC      lib/debug_locks.o
  CC      lib/random32.o
  CC      drivers/edac/edac_device.o
  CC      lib/bust_spinlocks.o
  CC      fs/nfs/callback_proc.o
  CC      lib/kasprintf.o
  CC [M]  net/bridge/br_sysfs_if.o
  CC      drivers/edac/edac_mc_sysfs.o
  CC      lib/bitmap.o
  CC      fs/nfs/nfs4namespace.o
  CC      drivers/edac/edac_module.o
  CC [M]  net/bridge/br_sysfs_br.o
  CC      lib/scatterlist.o
  CC      drivers/edac/edac_device_sysfs.o
  CC      fs/nfs/nfs4getroot.o
  CC      lib/gcd.o
  CC [M]  net/bridge/br_nf_core.o
  CC      lib/lcm.o
  CC      drivers/edac/wq.o
  CC      lib/list_sort.o
  CC      lib/uuid.o
  CC      lib/flex_array.o
  CC      fs/nfs/nfs4client.o
  CC [M]  net/bridge/br_multicast.o
  CC      drivers/edac/edac_pci.o
  CC      lib/iov_iter.o
  CC      drivers/edac/edac_pci_sysfs.o
  CC      fs/nfs/nfs4session.o
  LD      drivers/edac/edac_core.o
  LD      drivers/edac/built-in.o
  LD      drivers/extcon/built-in.o
  CC [M]  drivers/extcon/extcon.o
  CC      lib/clz_ctz.o
  CC      lib/bsearch.o
  CC      lib/find_bit.o
  CC      lib/llist.o
  CC      lib/memweight.o
  CC [M]  net/bridge/br_mdb.o
  CC      lib/kfifo.o
  CC      fs/nfs/dns_resolve.o
  CC [M]  drivers/extcon/devres.o
  CC [M]  drivers/extcon/extcon-palmas.o
  CC      lib/percpu-refcount.o
  CC      fs/nfs/nfs4trace.o
  CC [M]  net/bridge/br_switchdev.o
  CC [M]  drivers/extcon/extcon-usb-gpio.o
  CC      lib/percpu_ida.o
  LD [M]  drivers/extcon/extcon-core.o
  LD      drivers/firewire/built-in.o
  LD      drivers/firmware/broadcom/built-in.o
  CC      drivers/firmware/efi/efi.o
  CC [M]  net/bridge/br_netfilter_hooks.o
  CC      fs/nfs/nfs4sysctl.o
  CC      lib/rhashtable.o
  CC      drivers/firmware/efi/vars.o
  LD      fs/nfs/nfs.o
  LD      fs/nfs/nfsv2.o
  LD      fs/nfs/nfsv3.o
  LD      fs/nfs/nfsv4.o
  LD      fs/nfs/built-in.o
  CC      fs/ntfs/aops.o
  CC      lib/reciprocal_div.o
  CC      lib/once.o
  CC      lib/string_helpers.o
  CC [M]  net/bridge/br_netfilter_ipv6.o
  CC      drivers/firmware/efi/reboot.o
  CC      fs/ntfs/attrib.o
  CC      drivers/firmware/efi/memattr.o
  CC      drivers/firmware/efi/capsule.o
  CC      lib/hexdump.o
  LD      net/bridge/built-in.o
  LD [M]  net/bridge/bridge.o
  LD [M]  net/bridge/br_netfilter.o
  LD      net/can/built-in.o
  CC      fs/ntfs/collate.o
  CC [M]  net/can/af_can.o
  CC      lib/kstrtox.o
  CC      fs/ntfs/compress.o
  CC      drivers/firmware/efi/memmap.o
  CC      lib/pci_iomap.o
  CC      drivers/firmware/efi/esrt.o
  CC      lib/iomap_copy.o
  CC      fs/ntfs/debug.o
  CC [M]  net/can/proc.o
  CC      lib/devres.o
  CC      fs/ntfs/dir.o
  CC      drivers/firmware/efi/runtime-wrappers.o
  CC [M]  net/can/raw.o
  CC      drivers/firmware/efi/libstub/arm-stub.o
  CC      lib/hweight.o
  CC      lib/assoc_array.o
  CC      fs/ntfs/file.o
  CC      drivers/firmware/efi/libstub/arm32-stub.o
  CC      lib/bitrev.o
  CC      lib/rational.o
  CC      fs/ntfs/index.o
  CC      lib/crc16.o
  CC [M]  net/can/bcm.o
  CC      drivers/firmware/efi/libstub/efi-stub-helper.o
  HOSTCC  lib/gen_crc32table
  CC      lib/genalloc.o
  CC      fs/ntfs/inode.o
  CC      drivers/firmware/efi/libstub/fdt.o
  CC      lib/fonts/fonts.o
  CC      drivers/firmware/efi/libstub/gop.o
  CC [M]  net/can/gw.o
  CC      lib/fonts/font_8x8.o
  CC      lib/fonts/font_8x16.o
  CC      fs/ntfs/mft.o
  CC      drivers/firmware/efi/libstub/lib-fdt.o
  LD      lib/fonts/font.o
  LD      lib/fonts/built-in.o
  CC      lib/lz4/lz4_decompress.o
  CC      drivers/firmware/efi/libstub/lib-fdt_empty_tree.o
  CC      drivers/firmware/efi/libstub/lib-fdt_ro.o
  LD      lib/lz4/built-in.o
  CC      lib/lzo/lzo1x_compress.o
  CC      drivers/firmware/efi/libstub/lib-fdt_rw.o
  CC      drivers/firmware/efi/libstub/lib-fdt_sw.o
  LD [M]  net/can/can.o
  LD [M]  net/can/can-raw.o
  LD [M]  net/can/can-bcm.o
  LD [M]  net/can/can-gw.o
  CC      net/core/sock.o
  CC      fs/ntfs/mst.o
  CC      drivers/firmware/efi/libstub/lib-fdt_wip.o
  CC      lib/lzo/lzo1x_decompress_safe.o
  CC      drivers/firmware/efi/libstub/lib-sort.o
  CC      drivers/firmware/efi/libstub/string.o
  STUBCPY drivers/firmware/efi/libstub/arm-stub.stub.o
  CC      fs/ntfs/namei.o
  STUBCPY drivers/firmware/efi/libstub/arm32-stub.stub.o
  STUBCPY drivers/firmware/efi/libstub/efi-stub-helper.stub.o
  STUBCPY drivers/firmware/efi/libstub/fdt.stub.o
  STUBCPY drivers/firmware/efi/libstub/gop.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt_empty_tree.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt_ro.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt_rw.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt_sw.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-fdt_wip.stub.o
  STUBCPY drivers/firmware/efi/libstub/lib-sort.stub.o
  STUBCPY drivers/firmware/efi/libstub/string.stub.o
  AR      drivers/firmware/efi/libstub/lib.a
  EXPORTS drivers/firmware/efi/libstub/lib-ksyms.o
  LD      drivers/firmware/efi/libstub/built-in.o
  CC      drivers/firmware/efi/arm-init.o
  LD      lib/lzo/lzo_compress.o
  LD      lib/lzo/lzo_decompress.o
  LD      lib/lzo/built-in.o
  CC      lib/xz/xz_dec_syms.o
  CC      lib/xz/xz_dec_stream.o
  CC      fs/ntfs/runlist.o
  CC      drivers/firmware/efi/arm-runtime.o
  CC      lib/xz/xz_dec_lzma2.o
  CC [M]  drivers/firmware/efi/efivars.o
  CC      fs/ntfs/super.o
  CC      lib/xz/xz_dec_bcj.o
  CC [M]  drivers/firmware/efi/capsule-loader.o
  LD      lib/xz/xz_dec.o
  LD      lib/xz/built-in.o
  CC      lib/zlib_deflate/deflate.o
  CC      net/core/request_sock.o
  LD      drivers/firmware/efi/built-in.o
  LD      drivers/firmware/meson/built-in.o
  LD      drivers/firmware/built-in.o
  CC      drivers/gpio/devres.o
  CC      lib/zlib_deflate/deftree.o
  CC      fs/ntfs/sysctl.o
  CC      fs/ntfs/unistr.o
  CC      drivers/gpio/gpiolib.o
  CC      net/core/skbuff.o
  CC      fs/ntfs/upcase.o
  CC      lib/zlib_deflate/deflate_syms.o
  LD      lib/zlib_deflate/zlib_deflate.o
  LD      lib/zlib_deflate/built-in.o
  CC      lib/zlib_inflate/inffast.o
  LD      fs/ntfs/ntfs.o
  LD      fs/ntfs/built-in.o
  CC      fs/proc/task_mmu.o
  CC      lib/zlib_inflate/inflate.o
  CC      lib/zlib_inflate/infutil.o
  CC      lib/zlib_inflate/inftrees.o
  CC      fs/proc/inode.o
  CC      lib/zlib_inflate/inflate_syms.o
  CC      drivers/gpio/gpiolib-legacy.o
  LD      lib/zlib_inflate/zlib_inflate.o
  LD      lib/zlib_inflate/built-in.o
  CC      lib/bch.o
  CC      fs/proc/root.o
  CC      drivers/gpio/gpiolib-of.o
  CC      fs/proc/base.o
  CC      lib/textsearch.o
  CC      drivers/gpio/gpiolib-sysfs.o
  CC      net/core/datagram.o
  CC      lib/swiotlb.o
  CC      drivers/gpio/gpio-omap.o
  CC      fs/proc/generic.o
  CC      net/core/stream.o
  CC      lib/iommu-helper.o
  CC      drivers/gpio/gpio-pcf857x.o
  CC      lib/iommu-common.o
  CC      fs/proc/array.o
  CC      drivers/gpio/gpio-syscon.o
  CC      lib/syscall.o
  CC      net/core/scm.o
  CC      drivers/gpio/gpio-palmas.o
  CC      lib/nlattr.o
  CC      fs/proc/fd.o
  CC      drivers/gpio/gpio-tps65910.o
  CC [M]  drivers/gpio/gpio-pca953x.o
  CC      fs/proc/proc_tty.o
  CC      lib/dynamic_queue_limits.o
  CC      net/core/gen_stats.o
  CC      fs/proc/cmdline.o
  CC      lib/glob.o
  CC [M]  drivers/gpio/gpio-pisosr.o
  CC      fs/proc/consoles.o
  CC      lib/strncpy_from_user.o
  CC      fs/proc/cpuinfo.o
  CC [M]  drivers/gpio/gpio-tpic2810.o
  CC      fs/proc/devices.o
  CC      lib/strnlen_user.o
  CC      net/core/gen_estimator.o
  CC      fs/proc/interrupts.o
  LD      drivers/gpio/built-in.o
  CC      drivers/gpu/drm/drm_crtc_helper.o
  CC      lib/net_utils.o
  CC      fs/proc/loadavg.o
  CC      fs/proc/meminfo.o
  CC      lib/sg_split.o
  CC      net/core/net_namespace.o
  CC      fs/proc/stat.o
  CC      lib/sg_pool.o
  CC      drivers/gpu/drm/drm_dp_helper.o
  CC      fs/proc/uptime.o
  GEN     lib/oid_registry_data.c
Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: //usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 .) at ./lib/build_OID_registry line 14.
BEGIN failed--compilation aborted at ./lib/build_OID_registry line 14.
lib/Makefile:220: recipe for target 'lib/oid_registry_data.c' failed
make[1]: *** [lib/oid_registry_data.c] Error 2
Makefile:991: recipe for target 'lib' failed
make: *** [lib] Error 2
make: *** Waiting for unfinished jobs....
  CC      fs/proc/version.o
  LD      drivers/gpu/vga/built-in.o
  CC      drivers/gpu/drm/drm_probe_helper.o
  CC      fs/proc/softirqs.o
  CC      net/core/secure_seq.o
  CC      net/core/flow_dissector.o
  CC      fs/proc/namespaces.o
  CC      fs/proc/self.o
  CC      drivers/gpu/drm/drm_plane_helper.o
  CC      net/dns_resolver/dns_key.o
  CC      fs/proc/thread_self.o
  CC      fs/proc/proc_sysctl.o
  CC      net/dns_resolver/dns_query.o
  CC      drivers/gpu/drm/drm_dp_mst_topology.o
  CC      net/core/sysctl_net_core.o
  LD      net/dns_resolver/dns_resolver.o
  LD      net/dns_resolver/built-in.o
  CC      net/core/dev.o
  LD      fs/quota/built-in.o
  CC      drivers/gpu/drm/drm_atomic_helper.o
  CC      fs/proc/proc_net.o
  CC      fs/proc/kmsg.o
  CC      fs/proc/page.o
  LD      net/dsa/built-in.o
  CC [M]  net/dsa/dsa.o
  LD      fs/proc/proc.o
  LD      fs/proc/built-in.o
  CC      fs/ramfs/inode.o
  CC      drivers/gpu/drm/drm_kms_helper_common.o
  CC      fs/ramfs/file-mmu.o
  CC      drivers/gpu/drm/drm_dp_dual_mode_helper.o
  LD      fs/ramfs/ramfs.o
  LD      fs/ramfs/built-in.o
  CC      fs/squashfs/block.o
  CC [M]  net/dsa/slave.o
  CC      fs/squashfs/cache.o
  CC      drivers/gpu/drm/drm_simple_kms_helper.o
  CC      fs/squashfs/dir.o
  CC [M]  net/dsa/dsa2.o
  CC      fs/squashfs/export.o
  CC      drivers/gpu/drm/drm_modeset_helper.o
  CC      net/core/ethtool.o
  CC      fs/squashfs/file.o
  LD [M]  net/dsa/dsa_core.o
  CC      fs/squashfs/fragment.o
  CC      drivers/gpu/drm/drm_fb_helper.o
  CC      drivers/gpu/drm/drm_fb_cma_helper.o
  CC      fs/squashfs/id.o
  CC      fs/squashfs/inode.o
  CC      fs/squashfs/namei.o
  CC      fs/squashfs/super.o
  CC      net/core/dev_addr_lists.o
  CC      fs/squashfs/symlink.o
  CC      fs/squashfs/decompressor.o
  CC      drivers/hid/hid-core.o
  CC      drivers/gpu/drm/drm_auth.o
  CC      fs/squashfs/file_cache.o
  CC      net/core/dst.o
  CC      fs/squashfs/decompressor_single.o
  CC      drivers/gpu/drm/drm_bufs.o
  CC      fs/squashfs/lzo_wrapper.o
  CC      drivers/hid/hid-input.o
  CC      fs/squashfs/xz_wrapper.o
  CC      net/core/netevent.o
  CC      fs/squashfs/zlib_wrapper.o
  CC      drivers/gpu/drm/drm_cache.o
  CC      net/core/neighbour.o
  LD      fs/squashfs/squashfs.o
  LD      fs/squashfs/built-in.o
  CC      fs/sysfs/file.o
  CC      drivers/gpu/drm/drm_context.o
  CC      fs/sysfs/dir.o
  CC      fs/sysfs/symlink.o
  CC      drivers/hid/hid-debug.o
  CC      drivers/gpu/drm/drm_dma.o
  CC      fs/sysfs/mount.o
  CC      drivers/gpu/drm/drm_fops.o
  CC      fs/sysfs/group.o
  CC      drivers/hid/hid-generic.o
  LD      drivers/hid/usbhid/built-in.o
  CC [M]  drivers/hid/usbhid/hid-core.o
  LD      fs/sysfs/built-in.o
  CC      fs/ubifs/shrinker.o
  CC      drivers/gpu/drm/drm_gem.o
  CC      net/core/rtnetlink.o
  CC      fs/ubifs/journal.o
  CC [M]  drivers/hid/usbhid/hid-quirks.o
  CC      drivers/gpu/drm/drm_ioctl.o
  CC      fs/ubifs/file.o
  LD [M]  drivers/hid/usbhid/usbhid.o
  LD      drivers/hid/hid.o
  LD      drivers/hid/built-in.o
  CC      fs/ubifs/dir.o
  CC      drivers/gpu/drm/drm_irq.o
  CC      drivers/gpu/drm/drm_lock.o
  CC      fs/ubifs/super.o
  CC      net/core/utils.o
  CC      fs/ubifs/sb.o
  CC      drivers/gpu/drm/drm_memory.o
  CC      drivers/hwmon/hwmon.o
  CC      fs/ubifs/io.o
  CC      drivers/gpu/drm/drm_drv.o
  CC      net/core/link_watch.o
  CC      drivers/hwmon/gpio-fan.o
  CC      fs/ubifs/tnc.o
  CC      drivers/hwmon/iio_hwmon.o
  CC      drivers/gpu/drm/drm_vm.o
  CC      net/core/filter.o
  CC      drivers/hwmon/lm90.o
  CC      drivers/gpu/drm/drm_scatter.o
  CC      drivers/hwmon/lm95245.o
  CC      drivers/hwmon/tmp102.o
  CC      fs/ubifs/master.o
  CC      drivers/gpu/drm/drm_pci.o
  CC [M]  drivers/hwmon/ina2xx.o
  CC      fs/ubifs/scan.o
  CC      net/core/sock_diag.o
  CC [M]  drivers/hwmon/ntc_thermistor.o
  CC      drivers/gpu/drm/drm_platform.o
  CC      fs/ubifs/replay.o
  CC [M]  drivers/hwmon/pwm-fan.o
  CC      drivers/gpu/drm/drm_sysfs.o
  LD      drivers/hwmon/built-in.o
  CC      fs/ubifs/log.o
  CC      net/core/dev_ioctl.o
  CC      net/core/tso.o
  CC      drivers/gpu/drm/drm_hashtab.o
  CC      fs/ubifs/commit.o
  CC      fs/ubifs/gc.o
  CC      net/core/sock_reuseport.o
  CC      drivers/gpu/drm/drm_mm.o
  CC      net/ethernet/eth.o
  CC      fs/ubifs/orphan.o
  CC      net/core/flow.o
  LD      net/ethernet/built-in.o
  CC      drivers/gpu/drm/drm_crtc.o
  CC      fs/eventpoll.o
  CC      fs/ubifs/budget.o
  CC      net/core/net-sysfs.o
  CC      fs/ubifs/find.o
  CC      fs/ubifs/tnc_commit.o
  CC      drivers/gpu/drm/drm_fourcc.o
  CC      drivers/gpu/drm/drm_modes.o
  CC      fs/ubifs/compress.o
  CC      net/core/net-procfs.o
  CC      fs/ubifs/lpt.o
  CC      fs/ubifs/lprops.o
  CC      net/core/fib_rules.o
  CC      drivers/gpu/drm/drm_edid.o
  CC      drivers/gpu/drm/drm_info.o
  CC      fs/ubifs/recovery.o
  CC      drivers/hwspinlock/hwspinlock_core.o
  CC      net/core/ptp_classifier.o
  CC      fs/ubifs/ioctl.o
  CC      drivers/hwspinlock/omap_hwspinlock.o
  CC      fs/ubifs/lpt_commit.o
  CC      drivers/gpu/drm/drm_debugfs.o
  LD      drivers/hwspinlock/built-in.o
  CC      net/core/dst_cache.o
  CC      drivers/gpu/drm/drm_encoder_slave.o
  CC      fs/ubifs/tnc_misc.o
  LD      net/core/built-in.o
  CC      drivers/gpu/drm/drm_trace_points.o
  CC      net/hsr-prp/hsr_prp_main.o
  CC      net/ipv4/route.o
  CC      fs/ubifs/xattr.o
  CC      drivers/gpu/drm/drm_global.o
  CC      net/hsr-prp/hsr_main.o
  CC      drivers/gpu/drm/drm_prime.o
  CC      fs/ubifs/debug.o
  CC      net/hsr-prp/prp_main.o
  CC      drivers/gpu/drm/drm_rect.o
  CC      net/hsr-prp/hsr_prp_framereg.o
  CC      drivers/gpu/drm/drm_vma_manager.o
  CC      net/ipv4/inetpeer.o
  CC      fs/ubifs/misc.o
  CC      net/hsr-prp/hsr_prp_device.o
  CC      drivers/gpu/drm/drm_flip_work.o
  LD      fs/ubifs/ubifs.o
  LD      fs/ubifs/built-in.o
  CC      fs/anon_inodes.o
  CC      net/hsr-prp/hsr_netlink.o
  CC      fs/signalfd.o
  CC      net/ipv4/protocol.o
  CC      drivers/gpu/drm/drm_modeset_lock.o
  CC      fs/timerfd.o
  CC      net/hsr-prp/prp_netlink.o
  CC      net/ipv4/ip_input.o
  CC      drivers/gpu/drm/drm_atomic.o
  CC      fs/eventfd.o
  CC      net/hsr-prp/hsr_prp_slave.o
  CC      net/ipv4/ip_fragment.o
  CC      net/hsr-prp/hsr_prp_forward.o
  CC      fs/aio.o
  CC      net/hsr-prp/hsr_prp_debugfs.o
  CC      drivers/gpu/drm/drm_bridge.o
  CC      drivers/gpu/drm/drm_framebuffer.o
  CC      net/ipv4/ip_forward.o
  LD      net/hsr-prp/hsr-prp.o
  LD      net/hsr-prp/built-in.o
  CC      net/ipv4/ip_options.o
  CC      fs/locks.o
  CC      fs/binfmt_script.o
  CC      drivers/gpu/drm/drm_connector.o
  CC      fs/binfmt_elf.o
  CC      net/ipv4/ip_output.o
  CC      drivers/gpu/drm/drm_blend.o
  LD      drivers/hwtracing/intel_th/built-in.o
  CC      net/ipv6/af_inet6.o
  CC      fs/mbcache.o
  CC      drivers/gpu/drm/drm_encoder.o
  CC      fs/posix_acl.o
  CC      net/ipv4/ip_sockglue.o
  CC      drivers/gpu/drm/drm_mode_object.o
  CC      net/ipv6/anycast.o
  CC      fs/coredump.o
  CC      drivers/gpu/drm/drm_property.o
  CC      net/ipv6/ip6_output.o
  CC      fs/drop_caches.o
  CC      net/ipv4/inet_hashtables.o
  CC      fs/fhandle.o
  CC      drivers/gpu/drm/drm_plane.o
  LD      fs/built-in.o
  CC      drivers/gpu/drm/drm_color_mgmt.o
  CC      net/ipv4/inet_timewait_sock.o
  CC      drivers/i2c/i2c-boardinfo.o
  CC      net/ipv6/ip6_input.o
  CC      drivers/gpu/drm/drm_gem_cma_helper.o
  CC      drivers/i2c/i2c-core.o
  CC      net/ipv4/inet_connection_sock.o
  CC      drivers/gpu/drm/ati_pcigart.o
  CC      net/ipv6/addrconf.o
  CC      drivers/gpu/drm/drm_of.o
  CC      drivers/i2c/i2c-dev.o
  LD      drivers/gpu/drm/bridge/built-in.o
  LD      drivers/gpu/drm/hisilicon/built-in.o
  CC      net/ipv4/tcp.o
  CC      drivers/gpu/drm/i2c/tda998x_drv.o
  CC      drivers/i2c/algos/i2c-algo-bit.o
  LD      drivers/i2c/algos/built-in.o
  CC      drivers/i2c/busses/i2c-omap.o
  LD      drivers/gpu/drm/i2c/tda998x.o
  LD      drivers/gpu/drm/i2c/built-in.o
  CC      drivers/gpu/drm/omapdrm/displays/encoder-tpd12s015.o
  CC [M]  drivers/i2c/busses/i2c-emev2.o
  CC      drivers/gpu/drm/omapdrm/displays/encoder-tc358768.o
  LD      drivers/i2c/busses/built-in.o
  LD      drivers/i2c/muxes/built-in.o
  CC      drivers/i2c/i2c-slave-eeprom.o
  LD      drivers/i2c/built-in.o
  LD      drivers/gpu/drm/panel/built-in.o
  LD      net/key/built-in.o
  CC [M]  net/key/af_key.o
  CC      drivers/gpu/drm/omapdrm/displays/dra7-evm-encoder-tpd12s015.o
  CC      net/ipv6/addrlabel.o
  CC      net/ipv4/tcp_input.o
  CC      drivers/gpu/drm/omapdrm/displays/encoder-sii9022-video.o
  CC      net/ipv6/route.o
  CC      drivers/gpu/drm/omapdrm/displays/encoder-sii9022-audio.o
  CC      drivers/gpu/drm/omapdrm/displays/connector-hdmi.o
  CC      drivers/gpu/drm/omapdrm/displays/panel-dpi.o
  LD      drivers/gpu/drm/omapdrm/displays/encoder-sii9022.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_slave_compat.o
  LD      drivers/gpu/drm/omapdrm/displays/built-in.o
  CC      drivers/gpu/drm/omapdrm/dss/omapdss-boot-init.o
  DTC     drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb
  CC      drivers/gpu/drm/tilcdc/tilcdc_plane.o
  CC      drivers/gpu/drm/omapdrm/dss/base.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_crtc.o
  CC      drivers/gpu/drm/omapdrm/dss/display.o
  CC      net/ipv6/ip6_fib.o
  CC      net/ipv4/tcp_output.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_tfp410.o
  CC      drivers/gpu/drm/omapdrm/dss/dss-of.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_panel.o
  CC      drivers/gpu/drm/omapdrm/dss/output.o
  CC      net/ipv6/ipv6_sockglue.o
  CC      drivers/gpu/drm/omapdrm/dss/core.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_external.o
  CC      drivers/gpu/drm/tilcdc/tilcdc_drv.o
  CC      drivers/gpu/drm/omapdrm/dss/dss.o
  CC      net/ipv4/tcp_timer.o
  DTB     drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.S
  LD      drivers/gpu/drm/tilcdc/tilcdc.o
  AS      drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.o
  LD      drivers/gpu/drm/tilcdc/built-in.o
rm drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.S
  CC      net/ipv4/tcp_ipv4.o
  CC      net/ipv6/ndisc.o
  CC      drivers/gpu/drm/omapdrm/dss/dss_features.o
  CC      drivers/gpu/drm/omapdrm/dss/dispc.o
  CC      drivers/gpu/drm/omapdrm/dss/dispc_coefs.o
  CC      net/ipv6/udp.o
  CC      net/ipv4/tcp_minisocks.o
  LD      drivers/idle/built-in.o
  CC      drivers/gpu/drm/omapdrm/omap_drv.o
  CC      net/ipv4/tcp_cong.o
  CC      net/ipv6/udplite.o
  CC      drivers/gpu/drm/omapdrm/omap_irq.o
  CC      net/ipv6/raw.o
  CC      drivers/gpu/drm/omapdrm/dss/pll.o
  CC      net/ipv4/tcp_metrics.o
  CC      drivers/iio/industrialio-core.o
  CC      drivers/gpu/drm/omapdrm/dss/video-pll.o
  CC      drivers/gpu/drm/omapdrm/dss/dpi.o
  CC      net/ipv6/icmp.o
  CC      drivers/iio/industrialio-event.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi_common.o
  CC      net/ipv4/tcp_fastopen.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi_wp.o
  CC      drivers/iio/inkern.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi_pll.o
  CC      net/ipv4/tcp_rate.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi_phy.o
  CC      net/ipv6/mcast.o
  CC      drivers/iio/industrialio-buffer.o
  CC      net/ipv4/tcp_recovery.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi4.o
  CC      drivers/iio/industrialio-trigger.o
  CC      net/ipv4/tcp_offload.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi4_core.o
  LD      drivers/iio/accel/built-in.o
  LD      drivers/iio/adc/built-in.o
  CC [M]  drivers/iio/adc/ti_am335x_adc.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi5.o
  CC      net/ipv4/datagram.o
  CC      net/ipv6/reassembly.o
  CC [M]  drivers/iio/adc/vf610_adc.o
  CC      drivers/gpu/drm/omapdrm/dss/hdmi5_core.o
  LD      drivers/iio/amplifiers/built-in.o
  CC      drivers/iio/buffer/industrialio-triggered-buffer.o
  CC      net/ipv4/raw.o
  CC      drivers/gpu/drm/omapdrm/dss/dss6.o
  CC      drivers/iio/buffer/kfifo_buf.o
  CC      net/ipv6/tcp_ipv6.o
  CC      drivers/gpu/drm/omapdrm/dss/dispc6.o
  LD      drivers/iio/buffer/built-in.o
  LD      drivers/iio/chemical/built-in.o
  LD      drivers/iio/common/hid-sensors/built-in.o
  LD      drivers/iio/common/ms_sensors/built-in.o
  LD      drivers/iio/common/ssp_sensors/built-in.o
  LD      drivers/iio/common/st_sensors/built-in.o
  LD      drivers/iio/common/built-in.o
  LD      drivers/iio/dac/built-in.o
  LD      drivers/iio/dummy/built-in.o
  LD      drivers/iio/frequency/built-in.o
  LD      drivers/iio/gyro/built-in.o
  LD      drivers/iio/health/built-in.o
  LD      drivers/iio/humidity/built-in.o
  LD      drivers/iio/imu/bmi160/built-in.o
  LD      drivers/iio/imu/inv_mpu6050/built-in.o
  LD      drivers/iio/imu/built-in.o
  LD      drivers/iio/light/built-in.o
  CC [M]  drivers/iio/light/cm36651.o
  CC      net/ipv4/udp.o
  CC      drivers/gpu/drm/omapdrm/dss/dpi6.o
  CC      drivers/iio/magnetometer/ak8975.o
  LD      drivers/gpu/drm/omapdrm/dss/omapdss-base.o
  LD      drivers/gpu/drm/omapdrm/dss/omapdss.o
  LD      drivers/gpu/drm/omapdrm/dss/omapdss6.o
  LD      drivers/gpu/drm/omapdrm/dss/built-in.o
  CC      drivers/gpu/drm/omapdrm/omap_debugfs.o
  CC      net/ipv6/ping.o
  LD      drivers/iio/magnetometer/built-in.o
  LD      drivers/iio/orientation/built-in.o
  LD      drivers/iio/potentiometer/built-in.o
  LD      drivers/iio/pressure/built-in.o
  LD      drivers/iio/proximity/built-in.o
  LD      drivers/iio/temperature/built-in.o
  LD      drivers/iio/trigger/built-in.o
  LD      drivers/iio/industrialio.o
  LD      drivers/iio/built-in.o
  CC      net/ipv4/udplite.o
  CC      drivers/gpu/drm/omapdrm/omap_crtc.o
  CC      drivers/gpu/drm/omapdrm/omap_plane.o
  CC      net/ipv6/exthdrs.o
  CC      drivers/gpu/drm/omapdrm/omap_encoder.o
  CC      net/ipv4/udp_offload.o
  CC      net/ipv4/arp.o
  CC      drivers/gpu/drm/omapdrm/omap_connector.o
  CC      drivers/gpu/drm/omapdrm/omap_fb.o
  CC      net/ipv6/datagram.o
  CC      drivers/input/input.o
  CC      drivers/gpu/drm/omapdrm/omap_gem.o
  CC      net/ipv4/icmp.o
  CC      net/ipv6/ip6_flowlabel.o
  CC      drivers/input/input-compat.o
  CC      drivers/gpu/drm/omapdrm/omap_gem_dmabuf.o
  CC      drivers/input/input-mt.o
  CC      net/ipv4/devinet.o
  CC      drivers/gpu/drm/omapdrm/omap_dmm_tiler.o
  CC      drivers/input/ff-core.o
  CC      net/ipv6/inet6_connection_sock.o
  CC      drivers/input/input-leds.o
  CC      drivers/gpu/drm/omapdrm/tcm-sita.o
  CC      drivers/input/mousedev.o
  CC      drivers/gpu/drm/omapdrm/omap_fbdev.o
  CC      net/ipv6/udp_offload.o
  CC      net/ipv4/af_inet.o
  CC      drivers/gpu/drm/omapdrm/omap_wb.o
  CC      drivers/input/joydev.o
  CC      net/ipv6/sysctl_net_ipv6.o
  CC      drivers/gpu/drm/omapdrm/omap_wb_cap.o
  CC      drivers/input/evdev.o
  CC      net/ipv6/xfrm6_policy.o
  CC      drivers/gpu/drm/omapdrm/omap_wb_m2m.o
  CC      net/ipv4/igmp.o
  CC      net/ipv6/xfrm6_state.o
  CC      drivers/input/keyboard/atkbd.o
  LD      drivers/gpu/drm/omapdrm/omapdrm.o
  LD      drivers/gpu/drm/omapdrm/built-in.o
  LD      drivers/gpu/drm/drm_kms_helper.o
  LD      drivers/gpu/drm/drm.o
  LD      drivers/gpu/drm/built-in.o
  LD      drivers/gpu/built-in.o
  CC      drivers/input/keyboard/gpio_keys.o
  CC      net/ipv6/xfrm6_input.o
  LD      net/llc/built-in.o
  CC [M]  net/llc/llc_core.o
  CC [M]  drivers/input/keyboard/matrix_keypad.o
  CC [M]  net/llc/llc_input.o
  CC [M]  drivers/input/keyboard/qt1070.o
  CC [M]  drivers/input/keyboard/samsung-keypad.o
  CC      net/ipv6/xfrm6_output.o
  CC      net/ipv4/fib_frontend.o
  CC [M]  net/llc/llc_output.o
  LD      drivers/input/keyboard/built-in.o
  CC      drivers/input/misc/mpu3050.o
  CC [M]  drivers/input/misc/adxl34x.o
  CC      net/ipv6/xfrm6_protocol.o
  LD [M]  net/llc/llc.o
  CC      net/ipv6/netfilter.o
  CC      net/ipv4/fib_semantics.o
  CC [M]  drivers/input/misc/adxl34x-i2c.o
  CC [M]  drivers/input/misc/adxl34x-spi.o
  CC      net/ipv6/fib6_rules.o
  CC      net/ipv4/fib_trie.o
  CC [M]  drivers/input/misc/gpio_decoder.o
  CC      net/ipv6/proc.o
  CC [M]  drivers/input/misc/axp20x-pek.o
  CC      net/ipv4/inet_fragment.o
  LD      drivers/input/misc/built-in.o
  CC      drivers/input/mouse/elan_i2c_core.o
  CC      net/ipv6/xfrm6_mode_transport.o
  CC      drivers/input/mouse/elan_i2c_i2c.o
  CC      net/ipv6/xfrm6_mode_tunnel.o
  CC      net/ipv6/xfrm6_mode_beet.o
  CC      net/ipv4/ping.o
  CC      drivers/input/mouse/psmouse-base.o
  CC      net/ipv4/ip_tunnel_core.o
  LD      net/ipv6/netfilter/built-in.o
  CC      net/ipv6/sit.o
  CC      drivers/input/mouse/synaptics.o
  CC      net/ipv6/addrconf_core.o
  CC      net/ipv4/gre_offload.o
  CC      drivers/input/mouse/focaltech.o
  CC      net/ipv4/ip_tunnel.o
  CC      drivers/input/mouse/alps.o
  CC      net/ipv6/exthdrs_core.o
  CC      drivers/input/mouse/byd.o
  LD      net/mac80211/built-in.o
  CC [M]  net/mac80211/main.o
  CC      drivers/input/mouse/elantech.o
  CC      net/ipv6/ip6_checksum.o
  CC      net/ipv4/sysctl_net_ipv4.o
  CC [M]  net/mac80211/status.o
  CC      drivers/input/mouse/logips2pp.o
  CC      net/ipv6/ip6_icmp.o
  CC      net/ipv4/proc.o
  CC      drivers/input/mouse/trackpoint.o
  CC      drivers/input/mouse/cypress_ps2.o
  CC      net/ipv6/output_core.o
  CC      net/ipv4/tunnel4.o
  CC [M]  drivers/input/mouse/cyapa.o
  CC [M]  net/mac80211/driver-ops.o
  CC      net/ipv6/protocol.o
  CC [M]  drivers/input/mouse/cyapa_gen3.o
  CC      net/ipv4/ipconfig.o
  CC [M]  net/mac80211/sta_info.o
  CC [M]  drivers/input/mouse/cyapa_gen5.o
  CC      net/ipv6/ip6_offload.o
  CC      net/ipv4/netfilter.o
  CC [M]  drivers/input/mouse/cyapa_gen6.o
  CC      net/ipv6/tcpv6_offload.o
  LD      drivers/input/mouse/elan_i2c.o
  LD      drivers/input/mouse/psmouse.o
  LD [M]  drivers/input/mouse/cyapatp.o
  LD      drivers/input/mouse/built-in.o
  CC      drivers/input/touchscreen/of_touchscreen.o
  CC [M]  net/mac80211/wep.o
  CC      net/ipv6/exthdrs_offload.o
  CC [M]  drivers/input/touchscreen/atmel_mxt_ts.o
  LD      net/ipv4/netfilter/built-in.o
  CC [M]  net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.o
  CC      net/ipv6/inet6_hashtables.o
  CC [M]  net/mac80211/wpa.o
  CC [M]  net/ipv4/netfilter/nf_conntrack_proto_icmp.o
  CC [M]  drivers/input/touchscreen/edt-ft5x06.o
  CC      net/ipv6/mcast_snoop.o
  CC [M]  drivers/input/touchscreen/goodix.o
  CC [M]  net/ipv4/netfilter/nf_nat_l3proto_ipv4.o
  CC [M]  net/mac80211/scan.o
  CC [M]  drivers/input/touchscreen/mms114.o
  CC [M]  net/ipv6/ah6.o
  CC [M]  drivers/input/touchscreen/pixcir_i2c_ts.o
  CC [M]  net/ipv4/netfilter/nf_nat_proto_icmp.o
  CC [M]  drivers/input/touchscreen/st1232.o
  CC [M]  net/mac80211/offchannel.o
  CC [M]  net/ipv6/esp6.o
  CC [M]  net/ipv4/netfilter/nf_defrag_ipv4.o
  CC [M]  drivers/input/touchscreen/ti_am335x_tsc.o
  LD      drivers/input/touchscreen/built-in.o
  CC [M]  drivers/input/input-polldev.o
  CC [M]  net/ipv6/ipcomp6.o
  CC [M]  drivers/input/matrix-keymap.o
  CC [M]  net/ipv4/netfilter/nf_nat_masquerade_ipv4.o
  CC [M]  net/ipv6/xfrm6_tunnel.o
  LD      drivers/input/input-core.o
  LD      drivers/input/built-in.o
  CC      drivers/input/serio/serio.o
  CC [M]  net/mac80211/ht.o
  CC [M]  net/ipv4/netfilter/ip_tables.o
  CC      drivers/input/serio/serport.o
  CC [M]  net/ipv6/tunnel6.o
  CC      drivers/input/serio/libps2.o
  CC [M]  net/mac80211/agg-tx.o
  LD      drivers/input/serio/built-in.o
  CC      drivers/iommu/iommu.o
  CC [M]  net/ipv6/mip6.o
  CC [M]  net/ipv4/netfilter/iptable_filter.o
  CC [M]  net/ipv6/ip6_tunnel.o
  CC      drivers/iommu/iommu-traces.o
  CC [M]  net/mac80211/agg-rx.o
  CC [M]  net/ipv4/netfilter/iptable_nat.o
  CC      drivers/iommu/iommu-sysfs.o
  CC      drivers/iommu/of_iommu.o
  CC [M]  net/mac80211/vht.o
  CC [M]  net/ipv4/netfilter/ipt_MASQUERADE.o
  LD      net/ipv6/ipv6.o
  LD      net/ipv6/built-in.o
  CC [M]  net/mac80211/ibss.o
  CC      drivers/iommu/omap-iommu.o
  CC [M]  net/ipv4/netfilter/arp_tables.o
  CC [M]  net/ipv4/netfilter/arpt_mangle.o
  CC      drivers/iommu/omap-iommu-debug.o
  CC [M]  net/mac80211/iface.o
  CC      drivers/irqchip/irqchip.o
  LD      drivers/iommu/built-in.o
  CC      drivers/irqchip/irq-omap-intc.o
  CC [M]  net/ipv4/netfilter/arptable_filter.o
  CC [M]  net/mac80211/rate.o
  LD      drivers/irqchip/built-in.o
  CC      drivers/leds/led-core.o
  LD [M]  net/ipv4/netfilter/nf_conntrack_ipv4.o
  LD [M]  net/ipv4/netfilter/nf_nat_ipv4.o
  CC      net/ipv4/inet_diag.o
  CC      drivers/leds/led-class.o
  CC      drivers/leds/led-triggers.o
  CC      net/netfilter/core.o
  CC [M]  net/mac80211/michael.o
  CC      drivers/leds/leds-gpio.o
  CC      net/ipv4/tcp_diag.o
  CC [M]  net/mac80211/tkip.o
  CC      drivers/leds/leds-tlc591xx.o
  CC      net/netfilter/nf_log.o
  CC      drivers/leds/leds-pwm.o
  CC      net/ipv4/tcp_cubic.o
  CC      drivers/leds/trigger/ledtrig-timer.o
  CC [M]  net/mac80211/aes_ccm.o
  CC      drivers/leds/trigger/ledtrig-oneshot.o
  CC      net/ipv4/xfrm4_policy.o
  CC      net/netfilter/nf_queue.o
  CC      drivers/leds/trigger/ledtrig-heartbeat.o
  CC      drivers/leds/trigger/ledtrig-backlight.o
  CC [M]  net/mac80211/aes_gcm.o
  CC      net/ipv4/xfrm4_state.o
  CC      drivers/leds/trigger/ledtrig-gpio.o
  CC      net/netfilter/nf_sockopt.o
  CC [M]  net/mac80211/aes_cmac.o
  CC      drivers/leds/trigger/ledtrig-cpu.o
  CC      net/ipv4/xfrm4_input.o
  CC      drivers/leds/trigger/ledtrig-default-on.o
  CC [M]  net/mac80211/aes_gmac.o
  CC      drivers/leds/trigger/ledtrig-transient.o
  CC [M]  net/netfilter/nf_conntrack_core.o
  CC      drivers/leds/trigger/ledtrig-camera.o
  CC      net/ipv4/xfrm4_output.o
  CC [M]  net/mac80211/cfg.o
  LD      drivers/leds/trigger/built-in.o
  CC [M]  drivers/leds/led-class-flash.o
  LD      drivers/leds/built-in.o
  LD      drivers/lguest/built-in.o
  LD      drivers/macintosh/built-in.o
  CC      drivers/mailbox/mailbox.o
  CC      net/ipv4/xfrm4_protocol.o
  CC      drivers/mailbox/omap-mailbox.o
  CC [M]  net/netfilter/nf_conntrack_standalone.o
  CC [M]  net/ipv4/ah4.o
  CC [M]  net/mac80211/ethtool.o
  LD      drivers/mailbox/built-in.o
  CC      drivers/media/cec-edid.o
  CC [M]  net/netfilter/nf_conntrack_expect.o
  LD      drivers/media/common/b2c2/built-in.o
  LD      drivers/media/common/saa7146/built-in.o
  LD      drivers/media/common/siano/built-in.o
  LD      drivers/media/common/v4l2-tpg/built-in.o
  CC [M]  drivers/media/common/v4l2-tpg/v4l2-tpg-core.o
  CC [M]  net/ipv4/esp4.o
  CC [M]  net/mac80211/rx.o
  CC [M]  net/netfilter/nf_conntrack_helper.o
  CC [M]  net/ipv4/ipcomp.o
  CC [M]  drivers/media/common/v4l2-tpg/v4l2-tpg-colors.o
  LD [M]  drivers/media/common/v4l2-tpg/v4l2-tpg.o
  LD      drivers/media/common/built-in.o
  LD      drivers/media/firewire/built-in.o
  LD      drivers/media/i2c/soc_camera/built-in.o
  CC [M]  drivers/media/i2c/adv7180.o
  CC [M]  net/ipv4/xfrm4_tunnel.o
  CC [M]  drivers/media/i2c/ov1063x.o
  CC [M]  net/netfilter/nf_conntrack_proto.o
  CC [M]  net/ipv4/xfrm4_mode_beet.o
  CC [M]  drivers/media/i2c/ov490.o
  CC [M]  net/mac80211/spectmgmt.o
  CC [M]  net/ipv4/xfrm4_mode_transport.o
  CC [M]  drivers/media/i2c/mt9t11x.o
  CC [M]  net/netfilter/nf_conntrack_l3proto_generic.o
  CC [M]  net/mac80211/tx.o
  CC [M]  net/ipv4/xfrm4_mode_tunnel.o
  CC [M]  drivers/media/i2c/ml86v7667.o
  CC [M]  net/netfilter/nf_conntrack_proto_generic.o
  CC [M]  drivers/media/i2c/ov2659.o
  LD      net/ipv4/built-in.o
  LD      drivers/media/mmc/siano/built-in.o
  LD      drivers/media/mmc/built-in.o
  LD      drivers/media/i2c/built-in.o
  CC      drivers/memory/omap-gpmc.o
  CC [M]  net/netfilter/nf_conntrack_proto_tcp.o
  LD      drivers/media/pci/b2c2/built-in.o
  LD      drivers/media/pci/ddbridge/built-in.o
  LD      drivers/media/pci/dm1105/built-in.o
  LD      drivers/media/pci/mantis/built-in.o
  LD      drivers/media/pci/netup_unidvb/built-in.o
  LD      drivers/media/pci/ngene/built-in.o
  LD      drivers/media/pci/pluto2/built-in.o
  LD      drivers/media/pci/pt1/built-in.o
  LD      drivers/media/pci/pt3/built-in.o
  LD      drivers/media/pci/saa7146/built-in.o
  LD      drivers/media/pci/smipcie/built-in.o
  LD      drivers/media/pci/ttpci/built-in.o
  LD      drivers/media/pci/built-in.o
  LD      drivers/media/platform/omap/built-in.o
  LD      drivers/media/platform/soc_camera/built-in.o
  CC [M]  drivers/media/platform/soc_camera/soc_camera.o
  CC [M]  drivers/memory/ti-emif-pm.o
  CC [M]  net/netfilter/nf_conntrack_proto_udp.o
  AS [M]  drivers/memory/ti-emif-sram-pm.o
  LD      drivers/memory/built-in.o
  LD [M]  drivers/memory/ti-emif-sram.o
  CC [M]  net/netfilter/nf_conntrack_extend.o
  CC [M]  net/mac80211/key.o
  CC [M]  drivers/media/platform/soc_camera/soc_mediabus.o
  CC [M]  drivers/media/platform/soc_camera/soc_camera_platform.o
  CC      drivers/mfd/act8945a.o
  CC [M]  net/netfilter/nf_conntrack_acct.o
  CC      drivers/mfd/lp873x.o
  LD      drivers/media/platform/ti-vpe/built-in.o
  LD      drivers/media/platform/vivid/built-in.o
  CC [M]  drivers/media/platform/vivid/vivid-core.o
  CC      drivers/mfd/lp87565.o
  CC [M]  net/mac80211/util.o
  CC      drivers/mfd/tps65217.o
  CC [M]  net/netfilter/nf_conntrack_seqadj.o
  CC [M]  drivers/media/platform/vivid/vivid-ctrls.o
  CC      drivers/mfd/tps65218.o
  CC [M]  net/netfilter/nf_conntrack_proto_sctp.o
  CC      drivers/mfd/tps65910.o
  CC [M]  drivers/media/platform/vivid/vivid-vid-common.o
  CC      drivers/mfd/twl6040.o
  CC [M]  net/netfilter/nf_nat_core.o
  CC [M]  drivers/media/platform/vivid/vivid-vbi-gen.o
  CC [M]  net/mac80211/wme.o
  CC      drivers/mfd/mfd-core.o
  CC [M]  drivers/media/platform/vivid/vivid-vid-cap.o
  CC [M]  net/mac80211/chan.o
  CC      drivers/mfd/tps6586x.o
  CC      drivers/mfd/omap-usb-host.o
  CC [M]  net/netfilter/nf_nat_proto_unknown.o
  CC [M]  drivers/media/platform/vivid/vivid-vid-out.o
  CC      drivers/mfd/omap-usb-tll.o
  CC [M]  net/netfilter/nf_nat_proto_common.o
  CC      drivers/mfd/tps65090.o
  CC [M]  net/mac80211/trace.o
  CC      drivers/mfd/palmas.o
  CC [M]  drivers/media/platform/vivid/vivid-kthread-cap.o
  CC [M]  net/netfilter/nf_nat_proto_udp.o
  CC [M]  net/mac80211/mlme.o
  CC      drivers/mfd/syscon.o
  CC [M]  drivers/mfd/ti_am335x_tscadc.o
  CC [M]  drivers/media/platform/vivid/vivid-kthread-out.o
  CC [M]  net/netfilter/nf_nat_proto_tcp.o
  CC [M]  drivers/mfd/axp20x.o
  CC [M]  drivers/media/platform/vivid/vivid-radio-rx.o
  CC [M]  net/netfilter/nf_nat_helper.o
  CC [M]  drivers/mfd/axp20x-i2c.o
  CC [M]  drivers/media/platform/vivid/vivid-radio-tx.o
  LD      drivers/mfd/built-in.o
  CC [M]  drivers/media/platform/vivid/vivid-radio-common.o
  LD      drivers/media/radio/built-in.o
  CC [M]  net/mac80211/tdls.o
  CC [M]  net/netfilter/nf_nat_proto_sctp.o
  CC [M]  drivers/media/platform/vivid/vivid-rds-gen.o
  CC [M]  drivers/media/platform/vivid/vivid-sdr-cap.o
  CC [M]  drivers/media/platform/vivid/vivid-vbi-cap.o
  CC [M]  net/netfilter/x_tables.o
  LD      drivers/media/rc/keymaps/built-in.o
  LD      drivers/media/rc/built-in.o
  CC [M]  drivers/media/platform/vivid/vivid-vbi-out.o
  CC [M]  net/netfilter/xt_tcpudp.o
  CC [M]  drivers/media/platform/vivid/vivid-osd.o
  CC [M]  net/mac80211/ocb.o
  CC [M]  net/mac80211/led.o
  CC [M]  net/netfilter/xt_mark.o
  LD [M]  drivers/media/platform/vivid/vivid.o
  LD      drivers/media/platform/built-in.o
  LD      drivers/media/spi/built-in.o
  LD      drivers/media/tuners/built-in.o
  LD      drivers/media/usb/b2c2/built-in.o
  LD      drivers/media/usb/dvb-usb/built-in.o
  LD      drivers/media/usb/dvb-usb-v2/built-in.o
  LD      drivers/media/usb/gspca/built-in.o
  CC [M]  drivers/media/usb/gspca/gspca.o
  CC      drivers/media/v4l2-core/v4l2-dev.o
  CC [M]  net/netfilter/xt_nat.o
  CC [M]  net/mac80211/pm.o
  CC [M]  net/netfilter/xt_CLASSIFY.o
  CC [M]  drivers/media/usb/gspca/autogain_functions.o
  CC      drivers/media/v4l2-core/v4l2-ioctl.o
  CC [M]  net/netfilter/xt_IDLETIMER.o
  LD [M]  drivers/media/usb/gspca/gspca_main.o
  LD      drivers/media/usb/s2255/built-in.o
  LD      drivers/media/usb/siano/built-in.o
  LD      drivers/media/usb/stkwebcam/built-in.o
  CC [M]  net/mac80211/rc80211_minstrel.o
  LD      drivers/media/usb/ttusb-budget/built-in.o
  LD      drivers/media/usb/ttusb-dec/built-in.o
  LD      drivers/media/usb/uvc/built-in.o
  CC [M]  drivers/media/usb/uvc/uvc_driver.o
  CC [M]  net/netfilter/xt_comment.o
  CC [M]  net/netfilter/xt_cpu.o
  CC [M]  net/mac80211/rc80211_minstrel_ht.o
  CC      drivers/media/v4l2-core/v4l2-device.o
  CC [M]  drivers/media/usb/uvc/uvc_queue.o
  CC [M]  net/netfilter/xt_iprange.o
  CC [M]  drivers/media/usb/uvc/uvc_v4l2.o
  CC      drivers/media/v4l2-core/v4l2-fh.o
  CC [M]  net/netfilter/xt_length.o
  LD [M]  net/mac80211/mac80211.o
  CC [M]  net/netfilter/xt_limit.o
  CC      drivers/media/v4l2-core/v4l2-event.o
  CC [M]  drivers/media/usb/uvc/uvc_video.o
  CC [M]  drivers/media/usb/uvc/uvc_ctrl.o
  CC      drivers/media/v4l2-core/v4l2-ctrls.o
  CC [M]  net/netfilter/xt_mac.o
  CC      drivers/media/v4l2-core/v4l2-subdev.o
  CC [M]  net/netfilter/xt_multiport.o
  CC [M]  drivers/media/usb/uvc/uvc_status.o
  CC [M]  drivers/media/usb/uvc/uvc_isight.o
  CC [M]  net/netfilter/xt_pkttype.o
  CC      net/netlink/af_netlink.o
  CC [M]  drivers/media/usb/uvc/uvc_debugfs.o
  CC      drivers/media/v4l2-core/v4l2-clk.o
  CC [M]  drivers/media/usb/uvc/uvc_entity.o
  CC [M]  net/netfilter/xt_policy.o
  LD [M]  drivers/media/usb/uvc/uvcvideo.o
  CC      drivers/media/v4l2-core/v4l2-async.o
  LD      drivers/media/usb/zr364xx/built-in.o
  LD      drivers/media/usb/built-in.o
  CC      net/netlink/genetlink.o
  CC [M]  net/netfilter/xt_sctp.o
  CC      drivers/media/v4l2-core/v4l2-of.o
  CC      drivers/media/v4l2-core/v4l2-mc.o
  CC      drivers/media/media-device.o
  LD      net/netfilter/netfilter.o
  LD [M]  net/netfilter/nf_conntrack.o
  LD [M]  net/netfilter/nf_nat.o
  LD      net/netfilter/built-in.o
  CC      drivers/misc/ad525x_dpot.o
  LD      net/netlink/built-in.o
  CC      net/packet/af_packet.o
  CC      drivers/media/v4l2-core/v4l2-common.o
  CC      drivers/misc/ad525x_dpot-i2c.o
  CC      drivers/misc/ics932s401.o
  CC      net/rfkill/core.o
  CC      drivers/media/v4l2-core/v4l2-dv-timings.o
  CC      drivers/misc/apds9802als.o
  CC      drivers/media/v4l2-core/v4l2-mem2mem.o
  CC      drivers/misc/isl29003.o
  CC      net/rfkill/input.o
  CC      net/rfkill/rfkill-gpio.o
  LD      drivers/misc/cb710/built-in.o
  CC      drivers/misc/eeprom/at24.o
  CC      drivers/media/v4l2-core/videobuf2-core.o
  LD      net/rfkill/rfkill.o
  LD      net/rfkill/built-in.o
  CC      drivers/media/v4l2-core/videobuf2-v4l2.o
  CC      drivers/misc/eeprom/eeprom_93cx6.o
  LD      net/packet/built-in.o
  LD      net/rpmsg/built-in.o
  CC [M]  net/rpmsg/rpmsg_proto.o
  LD      drivers/misc/eeprom/built-in.o
  LD      drivers/misc/lis3lv02d/built-in.o
  LD      drivers/misc/mic/bus/built-in.o
  LD      drivers/misc/mic/built-in.o
  LD      drivers/misc/ti-st/built-in.o
  CC      drivers/misc/sram.o
  CC [M]  drivers/misc/pci_endpoint_test.o
  CC      net/sched/sch_generic.o
  CC      drivers/media/v4l2-core/videobuf2-memops.o
  CC      drivers/media/media-devnode.o
  LD      drivers/misc/built-in.o
  CC      drivers/media/media-entity.o
  CC      drivers/mmc/card/block.o
  CC      drivers/media/v4l2-core/videobuf2-dma-contig.o
  CC [M]  drivers/media/v4l2-core/videobuf-core.o
  CC      net/sched/sch_mq.o
  CC [M]  drivers/media/v4l2-core/videobuf2-vmalloc.o
  CC      net/sched/sch_api.o
  CC      net/sched/sch_blackhole.o
  CC      drivers/mmc/card/queue.o
  LD      drivers/media/v4l2-core/videodev.o
  LD      drivers/media/v4l2-core/built-in.o
  LD      drivers/media/media.o
  LD      drivers/media/built-in.o
  CC      drivers/mmc/core/core.o
  CC      drivers/mmc/core/bus.o
  LD      drivers/mmc/card/mmc_block.o
  LD      drivers/mmc/card/built-in.o
  CC      drivers/mmc/core/host.o
  LD      net/sctp/built-in.o
  CC [M]  net/sctp/sm_statetable.o
  CC      drivers/mmc/core/mmc.o
  CC [M]  net/sctp/sm_statefuns.o
  CC      drivers/mmc/core/mmc_ops.o
  CC      net/sched/cls_api.o
  CC      net/sched/act_api.o
  CC      drivers/mmc/core/sd.o
  CC [M]  net/sctp/sm_sideeffect.o
  CC      drivers/mmc/core/sd_ops.o
  CC      net/sched/sch_fifo.o
  CC      drivers/mmc/core/sdio.o
  CC      drivers/mmc/core/sdio_ops.o
  CC      net/sunrpc/clnt.o
  CC [M]  net/sctp/protocol.o
  CC      drivers/mmc/core/sdio_bus.o
  CC      net/sched/ematch.o
  CC      drivers/mmc/core/sdio_cis.o
  CC [M]  net/sctp/endpointola.o
  CC [M]  net/sched/act_police.o
  CC      drivers/mmc/core/sdio_io.o
  CC [M]  net/sched/act_gact.o
  CC      net/sunrpc/xprt.o
  CC [M]  net/sctp/associola.o
  CC      drivers/mmc/core/sdio_irq.o
  CC      drivers/mmc/core/quirks.o
  CC [M]  net/sched/act_mirred.o
  CC      drivers/mmc/core/slot-gpio.o
  CC [M]  net/sctp/transport.o
  CC      drivers/mmc/core/pwrseq.o
  CC      net/sunrpc/socklib.o
  CC [M]  net/sched/act_ipt.o
  CC      drivers/mmc/core/debugfs.o
  CC [M]  net/sctp/chunk.o
  CC [M]  net/sched/act_nat.o
  CC      drivers/mmc/core/pwrseq_simple.o
  CC      net/sunrpc/xprtsock.o
  CC      drivers/mmc/core/pwrseq_emmc.o
  CC [M]  net/sctp/sm_make_chunk.o
  LD      drivers/mmc/core/mmc_core.o
  LD      drivers/mmc/core/built-in.o
  CC      drivers/mmc/host/omap.o
  CC [M]  net/sched/act_pedit.o
  CC      net/sunrpc/sched.o
  CC [M]  net/sched/act_simple.o
  CC      drivers/mmc/host/omap_hsmmc.o
  CC [M]  net/sched/act_skbedit.o
  CC [M]  net/sctp/ulpevent.o
  CC [M]  net/sched/act_csum.o
  CC      net/sunrpc/auth.o
  CC [M]  net/sctp/inqueue.o
  LD      drivers/mmc/host/built-in.o
  LD      drivers/mmc/built-in.o
  CC      drivers/mtd/mtdcore.o
  CC [M]  net/sctp/outqueue.o
  CC [M]  net/sched/sch_cbq.o
  CC      drivers/mtd/mtdsuper.o
  CC      net/sunrpc/auth_null.o
  CC      drivers/mtd/mtdconcat.o
  CC [M]  net/sctp/ulpqueue.o
  CC      net/sunrpc/auth_unix.o
  CC [M]  net/sched/sch_htb.o
  CC      net/sunrpc/auth_generic.o
  CC [M]  net/sctp/tsnmap.o
  CC      drivers/mtd/mtdpart.o
  CC      net/sunrpc/svc.o
  CC [M]  net/sctp/bind_addr.o
  CC [M]  net/sched/sch_hfsc.o
  CC      drivers/mtd/mtdchar.o
  CC [M]  net/sctp/socket.o
  CC      net/sunrpc/svcsock.o
  CC [M]  net/sched/sch_red.o
  CC      drivers/mtd/ofpart.o
  CC      drivers/mtd/cmdlinepart.o
  CC [M]  net/sched/sch_gred.o
  CC      drivers/mtd/mtd_blkdevs.o
  CC      net/sunrpc/svcauth.o
  CC      drivers/mtd/mtdblock.o
  CC      net/sunrpc/svcauth_unix.o
  CC [M]  net/sched/sch_ingress.o
  CC      drivers/mtd/chips/chipreg.o
  CC [M]  net/sched/sch_dsmark.o
  LD      drivers/mtd/chips/built-in.o
  CC      drivers/mtd/devices/m25p80.o
  CC      net/sunrpc/addr.o
  LD      drivers/mtd/devices/built-in.o
  LD      drivers/mtd/lpddr/built-in.o
  LD      drivers/mtd/maps/built-in.o
  CC      drivers/mtd/nand/nand_base.o
  CC [M]  net/sctp/primitive.o
  CC [M]  net/sched/sch_sfb.o
  CC [M]  net/sctp/output.o
  CC      net/sunrpc/rpcb_clnt.o
  CC [M]  net/sched/sch_sfq.o
  CC [M]  net/sctp/input.o
  CC      net/sunrpc/timer.o
  CC      drivers/mtd/nand/nand_bbt.o
  CC [M]  net/sched/sch_tbf.o
  CC      drivers/mtd/nand/nand_timings.o
  CC      net/sunrpc/xdr.o
  CC [M]  net/sctp/debug.o
  CC [M]  net/sched/sch_teql.o
  CC      drivers/mtd/nand/nand_ecc.o
  CC [M]  net/sctp/ssnmap.o
  CC      drivers/mtd/nand/nand_ids.o
  CC [M]  net/sched/sch_prio.o
  CC      net/sunrpc/sunrpc_syms.o
  CC      drivers/mtd/nand/denali.o
  CC [M]  net/sctp/auth.o
  CC [M]  net/sched/sch_multiq.o
  CC      net/sunrpc/cache.o
  CC [M]  net/sched/sch_netem.o
  CC [M]  net/sctp/offload.o
  CC      drivers/mtd/nand/denali_dt.o
  CC      drivers/mtd/nand/omap2.o
  CC [M]  net/sctp/proc.o
  CC [M]  net/sched/sch_drr.o
  CC      net/sunrpc/rpc_pipe.o
  CC      drivers/mtd/nand/omap_elm.o
  CC [M]  net/sctp/sysctl.o
  CC [M]  net/sched/sch_mqprio.o
  CC      drivers/mtd/nand/brcmnand/iproc_nand.o
  CC [M]  net/sctp/ipv6.o
  CC      net/sunrpc/svc_xprt.o
  CC [M]  net/sched/sch_choke.o
  CC      drivers/mtd/nand/brcmnand/bcm63138_nand.o
  CC      drivers/mtd/nand/brcmnand/bcm6368_nand.o
  CC      drivers/mtd/nand/brcmnand/brcmstb_nand.o
  CC [M]  net/sctp/sctp_diag.o
  CC [M]  net/sched/sch_qfq.o
  CC      drivers/mtd/nand/brcmnand/brcmnand.o
  LD [M]  net/sctp/sctp.o
  CC      net/sunrpc/xprtmultipath.o
  CC      net/sunrpc/stats.o
  CC [M]  net/sched/sch_codel.o
  LD      drivers/mtd/nand/brcmnand/built-in.o
  LD      drivers/mtd/nand/nand.o
  LD      drivers/mtd/nand/omap2_nand.o
  LD      drivers/mtd/nand/built-in.o
  LD      drivers/mtd/onenand/built-in.o
  CC      drivers/mtd/spi-nor/spi-nor.o
  CC      net/switchdev/switchdev.o
  CC [M]  net/sched/sch_fq_codel.o
  CC      net/sunrpc/sysctl.o
  CC      drivers/mtd/spi-nor/cadence-quadspi.o
  LD      net/switchdev/built-in.o
  CC      net/sunrpc/auth_gss/auth_gss.o
  LD      net/sunrpc/sunrpc.o
  LD      drivers/mtd/tests/built-in.o
  CC [M]  drivers/mtd/tests/oobtest.o
  CC [M]  net/sched/cls_u32.o
  LD      drivers/mtd/spi-nor/built-in.o
  CC      drivers/mtd/ubi/vtbl.o
  CC [M]  drivers/mtd/tests/mtd_test.o
  CC      drivers/mtd/ubi/vmt.o
  CC [M]  drivers/mtd/tests/pagetest.o
  CC      net/sunrpc/auth_gss/gss_generic_token.o
  CC [M]  net/sched/cls_route.o
  CC [M]  drivers/mtd/tests/readtest.o
  CC      net/sunrpc/auth_gss/gss_mech_switch.o
  CC      drivers/mtd/ubi/upd.o
  CC [M]  net/sched/cls_fw.o
  CC [M]  drivers/mtd/tests/speedtest.o
  CC      drivers/mtd/ubi/build.o
  CC [M]  drivers/mtd/tests/stresstest.o
  CC [M]  net/sched/cls_rsvp.o
  CC      net/sunrpc/auth_gss/svcauth_gss.o
  CC [M]  drivers/mtd/tests/subpagetest.o
  CC      drivers/mtd/ubi/cdev.o
  CC [M]  net/sched/cls_tcindex.o
  CC [M]  drivers/mtd/tests/torturetest.o
  CC      drivers/mtd/ubi/kapi.o
  CC      net/sunrpc/auth_gss/gss_rpc_upcall.o
  CC [M]  drivers/mtd/tests/mtd_nandecctest.o
  CC [M]  net/sched/cls_rsvp6.o
  CC [M]  drivers/mtd/tests/nandbiterrs.o
  CC      drivers/mtd/ubi/eba.o
  CC      net/sunrpc/auth_gss/gss_rpc_xdr.o
  LD [M]  drivers/mtd/tests/mtd_oobtest.o
  LD [M]  drivers/mtd/tests/mtd_pagetest.o
  LD [M]  drivers/mtd/tests/mtd_readtest.o
  LD [M]  drivers/mtd/tests/mtd_speedtest.o
  LD [M]  drivers/mtd/tests/mtd_stresstest.o
  LD [M]  drivers/mtd/tests/mtd_subpagetest.o
  LD [M]  drivers/mtd/tests/mtd_torturetest.o
  LD [M]  drivers/mtd/tests/mtd_nandbiterrs.o
  CC      net/unix/af_unix.o
  CC [M]  net/sched/cls_basic.o
  LD      net/sunrpc/auth_gss/auth_rpcgss.o
  LD      net/sunrpc/auth_gss/built-in.o
  LD      net/sunrpc/built-in.o
  CC      net/unix/garbage.o
  CC      drivers/mtd/ubi/io.o
  CC [M]  net/sched/cls_flow.o
  CC      drivers/mtd/ubi/wl.o
  CC [M]  net/sched/em_cmp.o
  CC      net/unix/sysctl_net_unix.o
  CC [M]  net/sched/em_nbyte.o
  CC      drivers/mtd/ubi/attach.o
  CC      drivers/net/mii.o
  CC [M]  net/sched/em_u32.o
  LD      net/unix/unix.o
  LD      net/unix/built-in.o
  CC      drivers/net/Space.o
  CC      drivers/mtd/ubi/misc.o
  CC [M]  net/sched/em_meta.o
  CC      drivers/mtd/ubi/debug.o
  CC      drivers/net/loopback.o
  LD      net/wireless/built-in.o
  CC [M]  net/wireless/core.o
  LD      drivers/mtd/ubi/ubi.o
  LD      drivers/mtd/ubi/built-in.o
  LD      drivers/mtd/mtd.o
  LD      drivers/mtd/built-in.o
  CC [M]  net/wireless/sysfs.o
  LD      drivers/net/can/c_can/built-in.o
  CC [M]  drivers/net/can/c_can/c_can.o
  CC [M]  net/sched/em_text.o
  LD      drivers/nfc/built-in.o
  LD      net/sched/built-in.o
  CC [M]  drivers/net/can/c_can/c_can_platform.o
  CC [M]  net/wireless/radiotap.o
  LD      drivers/nvme/host/built-in.o
  LD      drivers/nvme/target/built-in.o
  LD      drivers/nvme/built-in.o
  CC      net/xfrm/xfrm_policy.o
  CC      net/sysctl_net.o
  LD      drivers/net/can/m_can/built-in.o
  CC [M]  drivers/net/can/m_can/m_can.o
  CC [M]  net/wireless/util.o
  CC [M]  net/wireless/reg.o
  LD      drivers/net/can/rcar/built-in.o
  CC [M]  drivers/net/can/rcar/rcar_can.o
  LD      drivers/net/can/softing/built-in.o
  LD      drivers/net/can/spi/built-in.o
  CC [M]  drivers/net/can/spi/mcp251x.o
  CC      net/xfrm/xfrm_state.o
  CC      drivers/nvmem/core.o
  CC [M]  net/wireless/scan.o
  LD      drivers/net/can/usb/built-in.o
  LD      drivers/nvmem/nvmem_core.o
  CC [M]  drivers/net/can/dev.o
  LD      drivers/nvmem/built-in.o
  CC      net/xfrm/xfrm_hash.o
  CC [M]  net/wireless/nl80211.o
  CC      net/xfrm/xfrm_input.o
  LD      drivers/net/can/built-in.o
  LD [M]  drivers/net/can/can-dev.o
  LD      drivers/net/dsa/b53/built-in.o
  LD      drivers/net/dsa/mv88e6xxx/built-in.o
  LD      drivers/net/dsa/built-in.o
  LD      drivers/net/ethernet/broadcom/built-in.o
  CC [M]  drivers/net/ethernet/broadcom/tg3.o
  LD      drivers/net/ethernet/intel/built-in.o
  LD      drivers/net/ethernet/intel/e1000/built-in.o
  CC [M]  drivers/net/ethernet/intel/e1000/e1000_main.o
  CC      net/xfrm/xfrm_output.o
  CC      net/xfrm/xfrm_sysctl.o
  CC      net/xfrm/xfrm_replay.o
  CC [M]  drivers/net/ethernet/intel/e1000/e1000_hw.o
  CC [M]  net/xfrm/xfrm_algo.o
  CC [M]  drivers/net/ethernet/intel/e1000/e1000_ethtool.o
  CC [M]  net/xfrm/xfrm_user.o
  CC [M]  net/wireless/mlme.o
  CC [M]  drivers/net/ethernet/intel/e1000/e1000_param.o
  CC [M]  net/xfrm/xfrm_ipcomp.o
  LD [M]  drivers/net/ethernet/intel/e1000/e1000.o
  LD      drivers/net/ethernet/intel/e1000e/built-in.o
  CC [M]  drivers/net/ethernet/intel/e1000e/82571.o
  CC [M]  net/wireless/ibss.o
  LD      net/xfrm/built-in.o
  CC [M]  net/wireless/sme.o
  CC [M]  drivers/net/ethernet/intel/e1000e/ich8lan.o
  CC [M]  drivers/net/ethernet/intel/e1000e/80003es2lan.o
  CC [M]  drivers/net/ethernet/intel/e1000e/mac.o
  CC [M]  net/wireless/chan.o
  CC [M]  net/wireless/ethtool.o
  CC [M]  net/wireless/mesh.o
  CC      drivers/net/phy/phy.o
  CC [M]  drivers/net/ethernet/intel/e1000e/manage.o
  CC [M]  drivers/net/ethernet/intel/e1000e/nvm.o
  CC [M]  net/wireless/ap.o
  LD      drivers/net/ethernet/marvell/built-in.o
  CC [M]  drivers/net/ethernet/marvell/skge.o
  CC [M]  net/wireless/trace.o
  CC [M]  drivers/net/ethernet/intel/e1000e/phy.o
  CC      drivers/net/phy/phy_device.o
  CC [M]  net/wireless/ocb.o
  CC [M]  drivers/net/ethernet/intel/e1000e/param.o
  LD [M]  net/wireless/cfg80211.o
  LD      net/built-in.o
  CC [M]  drivers/net/ethernet/intel/e1000e/ethtool.o
  CC      drivers/net/phy/mdio_bus.o
  CC      drivers/net/phy/mdio_device.o
  CC      drivers/net/phy/swphy.o
  CC      drivers/of/base.o
  CC      drivers/of/device.o
  CC      drivers/net/phy/at803x.o
  CC [M]  drivers/net/ethernet/intel/e1000e/netdev.o
  CC [M]  drivers/net/ethernet/intel/e1000e/ptp.o
  CC      drivers/net/phy/dp83848.o
  CC      drivers/of/platform.o
  CC      drivers/net/phy/dp83867.o
  CC      drivers/net/phy/fixed_phy.o
  LD      drivers/net/usb/built-in.o
  CC [M]  drivers/net/usb/pegasus.o
  CC      drivers/of/dynamic.o
  CC      drivers/net/phy/marvell.o
  CC      drivers/of/fdt.o
  CC [M]  drivers/net/usb/r8152.o
  CC      drivers/net/phy/micrel.o
  CC      drivers/of/fdt_address.o
  CC      drivers/net/phy/realtek.o
  LD [M]  drivers/net/ethernet/intel/e1000e/e1000e.o
  CC      drivers/net/ethernet/micrel/ks8851.o
  CC      drivers/of/address.o
  CC      drivers/net/phy/smsc.o
  LD      drivers/net/ethernet/micrel/built-in.o
  LD      drivers/net/ethernet/packetengines/built-in.o
  LD      drivers/net/phy/libphy.o
  CC      drivers/net/ethernet/smsc/smsc911x.o
  LD      drivers/net/phy/built-in.o
  CC      drivers/net/ethernet/ti/cpsw-common.o
  CC      drivers/of/irq.o
  CC [M]  drivers/net/usb/asix_devices.o
  CC      drivers/net/ethernet/ti/davinci_mdio.o
  CC      drivers/of/of_net.o
  CC      drivers/net/ethernet/ti/davinci_cpdma.o
  CC [M]  drivers/net/usb/asix_common.o
  LD      drivers/net/ethernet/smsc/built-in.o
  CC [M]  drivers/net/usb/ax88172a.o
  CC      drivers/of/of_mdio.o
  CC      drivers/of/of_pci.o
  CC [M]  drivers/net/usb/ax88179_178a.o
  CC      drivers/net/ethernet/ti/cpsw-phy-sel.o
  CC      drivers/pci/access.o
  CC      drivers/of/of_pci_irq.o
  CC      drivers/net/ethernet/ti/cpsw_ale.o
  CC [M]  drivers/net/usb/cdc_ether.o
  CC      drivers/of/of_reserved_mem.o
  CC      drivers/pci/bus.o
  CC      drivers/of/resolver.o
  CC [M]  drivers/net/usb/smsc75xx.o
  CC      drivers/pci/probe.o
  CC      drivers/of/overlay.o
  CC      drivers/net/ethernet/ti/cpts.o
In file included from drivers/net/ethernet/ti/cpts.c:36:0:
drivers/net/ethernet/ti/ptp_bc.h: In function 'ptp_bc_clock_unregister':
drivers/net/ethernet/ti/ptp_bc.h:30:1: warning: no return statement in function returning non-void [-Wreturn-type]
  LD      drivers/of/built-in.o
  CC      drivers/net/ethernet/ti/cpsw.o
At top level:
drivers/net/ethernet/ti/ptp_bc.h:28:12: warning: 'ptp_bc_clock_unregister' defined but not used [-Wunused-function]
 static int ptp_bc_clock_unregister(int clkid)
  CC [M]  drivers/net/usb/smsc95xx.o
  CC      drivers/pci/host-bridge.o
  CC [M]  drivers/net/usb/net1080.o
  CC      drivers/pci/remove.o
  LD      drivers/net/wireless/admtek/built-in.o
  LD      drivers/net/wireless/ath/built-in.o
  CC [M]  drivers/net/usb/cdc_subset.o
  LD      drivers/net/wireless/atmel/built-in.o
  LD      drivers/net/wireless/broadcom/built-in.o
  LD      drivers/net/wireless/broadcom/brcm80211/built-in.o
  LD      drivers/net/wireless/broadcom/brcm80211/brcmfmac/built-in.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.o
  CC [M]  drivers/net/ethernet/ti/prueth.o
  CC      drivers/pci/pci.o
  CC [M]  drivers/net/usb/zaurus.o
  CC [M]  drivers/net/usb/usbnet.o
  CC [M]  drivers/net/ethernet/ti/iep.o
  CC      drivers/pci/pci-driver.o
In file included from drivers/net/ethernet/ti/iep.c:17:0:
  CC [M]  drivers/net/usb/cdc_ncm.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/chip.o
  CC [M]  drivers/net/ethernet/ti/pruss_node_tbl.o
  LD      drivers/net/ethernet/ti/ti_cpsw.o
  LD [M]  drivers/net/ethernet/ti/ti_prueth.o
  LD      drivers/net/ethernet/ti/built-in.o
  LD      drivers/net/ethernet/built-in.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/fwil.o
  CC      drivers/pci/search.o
  CC      drivers/pci/pci-sysfs.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/fweh.o
  LD [M]  drivers/net/usb/asix.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/fwsignal.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/p2p.o
  LD      drivers/net/wireless/broadcom/brcm80211/brcmutil/built-in.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmutil/utils.o
  CC      drivers/pci/rom.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/proto.o
  CC      drivers/net/virtio_net.o
  CC      drivers/pci/setup-res.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmutil/d11.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/common.o
  CC      drivers/pci/irq.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/core.o
  LD [M]  drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/firmware.o
  CC      drivers/pci/vpd.o
  CC      drivers/pci/setup-bus.o
  CC      drivers/pci/dwc/pcie-designware.o
  CC      drivers/pci/dwc/pcie-designware-host.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/feature.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/btcoex.o
  CC      drivers/pci/vc.o
  CC      drivers/pci/dwc/pcie-designware-ep.o
  CC      drivers/pci/proc.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/vendor.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/bcdc.o
  CC      drivers/pci/dwc/pci-dra7xx.o
  CC      drivers/pci/slot.o
  CC      drivers/pci/endpoint/pci-epc-core.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.o
  LD      drivers/pci/dwc/built-in.o
  CC      drivers/pci/endpoint/pci-epf-core.o
  CC      drivers/pci/quirks.o
  CC      drivers/pci/endpoint/pci-epc-mem.o
  CC      drivers/pci/host/pci-host-common.o
  CC      drivers/pci/endpoint/pci-ep-cfs.o
  CC      drivers/pci/host/pci-host-generic.o
  LD      drivers/pci/host/built-in.o
  CC      drivers/perf/arm_pmu.o
  CC      drivers/pci/endpoint/functions/pci-epf-test.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/bcmsdh.o
  CC      drivers/pci/pcie/aspm.o
  LD      drivers/pci/endpoint/functions/built-in.o
  LD      drivers/pci/endpoint/built-in.o
  CC      drivers/pci/msi.o
  LD      drivers/perf/built-in.o
  CC      drivers/pci/pcie/portdrv_core.o
  CC [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/of.o
  CC      drivers/pci/setup-irq.o
  LD [M]  drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.o
  LD      drivers/net/wireless/cisco/built-in.o
  LD      drivers/net/wireless/intel/built-in.o
  LD      drivers/net/wireless/intel/iwlwifi/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-io.o
  LD      drivers/net/wireless/intersil/built-in.o
  LD      drivers/net/wireless/marvell/built-in.o
  LD      drivers/net/wireless/marvell/mwifiex/built-in.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/main.o
  CC      drivers/pci/pcie/portdrv_pci.o
  CC      drivers/pci/pcie/portdrv_bus.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/init.o
  CC      drivers/pci/pcie/aer/aerdrv_errprint.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-drv.o
  CC      drivers/pci/pcie/aer/aerdrv_core.o
  CC      drivers/pci/pcie/aer/aerdrv.o
  CC      drivers/phy/phy-core.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/cfp.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-debug.o
  LD      drivers/pci/pcie/aer/aerdriver.o
  LD      drivers/pci/pcie/aer/built-in.o
  CC      drivers/pci/pcie/pme.o
  CC      drivers/phy/phy-omap-control.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/cmdevt.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-notif-wait.o
  LD      drivers/pci/pcie/pcieportdrv.o
  LD      drivers/pci/pcie/built-in.o
  CC      drivers/pci/syscall.o
  CC      drivers/phy/phy-omap-usb2.o
  CC      drivers/pci/ecam.o
  CC      drivers/phy/phy-ti-pipe3.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-eeprom-read.o
  CC      drivers/pci/of.o
  LD      drivers/phy/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-eeprom-parse.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/util.o
  LD      drivers/pci/built-in.o
  CC      drivers/pinctrl/core.o
  CC      drivers/pinctrl/pinctrl-utils.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/txrx.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-phy-db.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-nvm-parse.o
  CC      drivers/pinctrl/pinmux.o
  CC      drivers/pinctrl/pinconf.o
  LD      drivers/platform/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/pcie/drv.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/wmm.o
  CC      drivers/pinctrl/devicetree.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/11n.o
  CC      drivers/pinctrl/pinconf-generic.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/pcie/rx.o
  CC      drivers/pinctrl/pinctrl-palmas.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/11ac.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/pcie/tx.o
  CC      drivers/pinctrl/pinctrl-single.o
  LD      drivers/pinctrl/bcm/built-in.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/11n_aggr.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/pcie/trans.o
  LD      drivers/pinctrl/freescale/built-in.o
  LD      drivers/pinctrl/nomadik/built-in.o
  CC      drivers/pinctrl/ti/pinctrl-ti-iodelay.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/11n_rxreorder.o
  LD      drivers/pinctrl/ti/built-in.o
  LD      drivers/pinctrl/built-in.o
  LD      drivers/net/wireless/mediatek/built-in.o
  LD      drivers/power/avs/built-in.o
  CC      drivers/power/reset/gpio-poweroff.o
  CC      drivers/power/reset/gpio-restart.o
  CC      drivers/power/reset/syscon-reboot.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/scan.o
  LD      drivers/power/reset/built-in.o
  CC      drivers/power/supply/power_supply_core.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-trans.o
  CC      drivers/power/supply/power_supply_sysfs.o
  LD      drivers/net/wireless/ralink/built-in.o
  LD      drivers/net/wireless/ralink/rt2x00/built-in.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00dev.o
  CC      drivers/power/supply/power_supply_leds.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-1000.o
  CC      drivers/power/supply/act8945a_charger.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/join.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-2000.o
  CC      drivers/power/supply/sbs-battery.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-5000.o
  CC      drivers/power/supply/tps65090-charger.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00mac.o
  CC [M]  drivers/power/supply/axp20x_usb_power.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-6000.o
  CC [M]  drivers/power/supply/max17040_battery.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_ioctl.o
  CC [M]  drivers/power/supply/max17042_battery.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-7000.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-8000.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00config.o
  LD      drivers/power/supply/power_supply.o
  LD      drivers/power/supply/built-in.o
  LD      drivers/power/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-9000.o
  LD      drivers/net/wireless/realtek/built-in.o
  CC      drivers/pps/pps.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/iwl-a000.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_cmd.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00queue.o
  CC      drivers/pps/kapi.o
  LD      drivers/net/wireless/intel/iwlwifi/dvm/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/main.o
  CC      drivers/pps/sysfs.o
  LD      drivers/pps/clients/built-in.o
  LD      drivers/pps/generators/built-in.o
  LD      drivers/pps/pps_core.o
  LD      drivers/pps/built-in.o
  CC      drivers/ptp/ptp_clock.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/uap_cmd.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00link.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/rs.o
  CC      drivers/ptp/ptp_chardev.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/ie.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00crypto.o
  CC      drivers/ptp/ptp_sysfs.o
  LD      drivers/ptp/ptp.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_cmdresp.o
  LD      drivers/ptp/built-in.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00firmware.o
  LD      drivers/net/wireless/rsi/built-in.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_event.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/mac80211.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00leds.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/ucode.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/uap_event.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2x00usb.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2800lib.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/tx.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_tx.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sta_rx.o
  LD      drivers/net/wireless/intel/iwlwifi/mvm/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/fw.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/lib.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/uap_txrx.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/mac80211.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/calib.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/cfg80211.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/tt.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/sta.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/nvm.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/ethtool.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/ops.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/rx.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/11h.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/power.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/phy-ctxt.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/tdls.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/scan.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/mac-ctxt.o
  CC [M]  drivers/net/wireless/ralink/rt2x00/rt2800usb.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/debugfs.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/rxon.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/utils.o
  LD [M]  drivers/net/wireless/ralink/rt2x00/rt2x00lib.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/devices.o
  CC [M]  drivers/net/wireless/marvell/mwifiex/sdio.o
  CC      drivers/pwm/core.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/rx.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/dvm/led.o
  CC      drivers/pwm/sysfs.o
  CC      drivers/pwm/pwm-tiecap.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/rxmq.o
  LD [M]  drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.o
  CC      drivers/pwm/pwm-tiehrpwm.o
  LD [M]  drivers/net/wireless/marvell/mwifiex/mwifiex.o
  LD [M]  drivers/net/wireless/marvell/mwifiex/mwifiex_sdio.o
  LD [M]  drivers/net/wireless/intel/iwlwifi/iwlwifi.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/tx.o
  CC      drivers/pwm/pwm-tipwmss.o
  CC      drivers/ras/ras.o
  CC [M]  drivers/pwm/pwm-fsl-ftm.o
  CC      drivers/ras/debugfs.o
  LD      drivers/net/wireless/st/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/binding.o
  LD      drivers/pwm/built-in.o
  CC      drivers/net/wireless/ti/wilink_platform_data.o
  LD      drivers/ras/built-in.o
  CC      drivers/regulator/core.o
  LD      drivers/net/wireless/ti/wl18xx/built-in.o
  CC [M]  drivers/net/wireless/ti/wl18xx/main.o
  CC [M]  drivers/net/wireless/ti/wl18xx/acx.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/quota.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/sta.o
  CC [M]  drivers/net/wireless/ti/wl18xx/tx.o
  CC [M]  drivers/net/wireless/ti/wl18xx/io.o
  LD      drivers/net/wireless/zydas/built-in.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/sf.o
  CC [M]  drivers/net/wireless/ti/wl18xx/debugfs.o
  CC      drivers/regulator/dummy.o
  CC      drivers/regulator/fixed-helper.o
  CC [M]  drivers/net/wireless/ti/wl18xx/scan.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/scan.o
  CC      drivers/regulator/helpers.o
  CC      drivers/regulator/devres.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/time-event.o
  CC [M]  drivers/net/wireless/ti/wl18xx/cmd.o
  CC      drivers/regulator/of_regulator.o
  CC      drivers/regulator/fixed.o
  CC [M]  drivers/net/wireless/ti/wl18xx/event.o
  LD      drivers/remoteproc/built-in.o
  CC [M]  drivers/remoteproc/remoteproc_core.o
  CC      drivers/regulator/act8945a-regulator.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/rs.o
  CC      drivers/regulator/gpio-regulator.o
  LD [M]  drivers/net/wireless/ti/wl18xx/wl18xx.o
  LD      drivers/net/wireless/ti/wlcore/built-in.o
  CC [M]  drivers/net/wireless/ti/wlcore/main.o
  CC      drivers/regulator/lp873x-regulator.o
  CC [M]  drivers/remoteproc/remoteproc_debugfs.o
  CC      drivers/regulator/lp87565-regulator.o
  CC [M]  drivers/remoteproc/remoteproc_sysfs.o
  CC      drivers/regulator/palmas-regulator.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/power.o
  CC [M]  drivers/remoteproc/remoteproc_virtio.o
  CC      drivers/regulator/pbias-regulator.o
  CC [M]  drivers/remoteproc/remoteproc_elf_loader.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/coex.o
  CC      drivers/regulator/ti-abb-regulator.o
  CC [M]  drivers/remoteproc/wkup_m3_rproc.o
  CC [M]  drivers/remoteproc/pruss_soc_bus.o
  CC      drivers/regulator/tps62360-regulator.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/tt.o
  CC [M]  drivers/remoteproc/pruss.o
  CC [M]  drivers/net/wireless/ti/wlcore/cmd.o
  CC      drivers/regulator/tps65023-regulator.o
  CC      drivers/regulator/tps6507x-regulator.o
  CC [M]  drivers/remoteproc/pruss_intc.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/offloading.o
  CC      drivers/regulator/tps65090-regulator.o
  CC [M]  drivers/remoteproc/pru_rproc.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/tdls.o
  CC [M]  drivers/net/wireless/ti/wlcore/io.o
  CC      drivers/regulator/tps65217-regulator.o
  LD [M]  drivers/remoteproc/remoteproc.o
  CC [M]  drivers/net/wireless/ti/wlcore/event.o
  CC      drivers/regulator/tps65218-regulator.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/led.o
  CC      drivers/regulator/tps6524x-regulator.o
  CC      drivers/regulator/tps6586x-regulator.o
  CC [M]  drivers/net/wireless/ti/wlcore/tx.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/tof.o
  CC [M]  drivers/net/wireless/ti/wlcore/rx.o
  CC      drivers/regulator/tps65910-regulator.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/fw-dbg.o
  CC [M]  drivers/net/wireless/intel/iwlwifi/mvm/d3.o
  LD      drivers/regulator/built-in.o
  CC      drivers/reset/core.o
  LD      drivers/reset/hisilicon/built-in.o
  CC      drivers/reset/reset-ti-syscon.o
  CC [M]  drivers/net/wireless/ti/wlcore/ps.o
  CC [M]  drivers/net/wireless/ti/wlcore/acx.o
  LD      drivers/reset/built-in.o
  CC [M]  drivers/net/wireless/ti/wlcore/boot.o
  LD [M]  drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.o
  LD      drivers/rpmsg/built-in.o
  CC [M]  drivers/rpmsg/rpmsg_core.o
  CC [M]  drivers/rpmsg/virtio_rpmsg_bus.o
  CC [M]  drivers/net/wireless/ti/wlcore/init.o
  CC      drivers/rtc/rtc-lib.o
  CC [M]  drivers/rpmsg/rpmsg_pru.o
  CC      drivers/rtc/hctosys.o
  CC      drivers/rtc/systohc.o
  LD      drivers/scsi/arm/built-in.o
  CC [M]  drivers/scsi/scsi.o
  CC [M]  drivers/scsi/hosts.o
  CC      drivers/rtc/class.o
  CC [M]  drivers/net/wireless/ti/wlcore/debugfs.o
  CC      drivers/rtc/interface.o
  CC      drivers/rtc/rtc-efi-platform.o
  CC [M]  drivers/scsi/scsi_ioctl.o
  CC [M]  drivers/scsi/scsicam.o
  CC      drivers/rtc/rtc-dev.o
  CC [M]  drivers/scsi/scsi_error.o
  CC [M]  drivers/net/wireless/ti/wlcore/scan.o
  CC      drivers/rtc/rtc-proc.o
  CC [M]  drivers/net/wireless/ti/wlcore/sysfs.o
  CC      drivers/rtc/rtc-sysfs.o
  CC [M]  drivers/rtc/rtc-ds1307.o
  CC [M]  drivers/net/wireless/ti/wlcore/vendor_cmd.o
  CC [M]  drivers/scsi/scsi_lib.o
  CC [M]  drivers/rtc/rtc-efi.o
  LD      drivers/soc/bcm/built-in.o
  LD      drivers/soc/fsl/built-in.o
  LD      drivers/soc/ti/built-in.o
  CC [M]  drivers/soc/ti/pm33xx.o
  CC [M]  drivers/net/wireless/ti/wlcore/spi.o
  CC [M]  drivers/rtc/rtc-omap.o
  CC [M]  drivers/soc/ti/wkup_m3_ipc.o
  CC [M]  drivers/rtc/rtc-palmas.o
  CC [M]  drivers/net/wireless/ti/wlcore/sdio.o
  LD      drivers/soc/built-in.o
  CC [M]  drivers/rtc/rtc-tps6586x.o
  CC      drivers/spi/spi.o
  CC [M]  drivers/scsi/scsi_common.o
  LD [M]  drivers/net/wireless/ti/wlcore/wlcore.o
  LD [M]  drivers/net/wireless/ti/wlcore/wlcore_spi.o
  LD [M]  drivers/net/wireless/ti/wlcore/wlcore_sdio.o
  LD      drivers/net/wireless/ti/built-in.o
  LD      drivers/net/wireless/built-in.o
  LD      drivers/net/built-in.o
  CC [M]  drivers/scsi/scsi_lib_dma.o
  CC [M]  drivers/scsi/scsi_scan.o
  CC [M]  drivers/rtc/rtc-tps65910.o
  LD      drivers/rtc/rtc-core.o
  LD      drivers/rtc/built-in.o
  CC [M]  drivers/scsi/scsi_sysfs.o
  CC      drivers/spmi/spmi.o
  CC      drivers/staging/android/ion/ion.o
  LD      drivers/spmi/built-in.o
  CC      drivers/staging/android/ion/ion-ioctl.o
  CC [M]  drivers/scsi/scsi_devinfo.o
  CC      drivers/spi/spi-omap2-mcspi.o
  CC      drivers/tee/tee_core.o
  CC      drivers/staging/android/ion/ion_heap.o
  CC [M]  drivers/scsi/scsi_sysctl.o
  CC      drivers/spi/spi-ti-qspi.o
  CC      drivers/tee/tee_shm.o
  CC [M]  drivers/scsi/scsi_proc.o
  CC      drivers/staging/android/ion/ion_page_pool.o
  CC [M]  drivers/spi/spidev.o
  CC      drivers/tee/tee_shm_pool.o
  CC [M]  drivers/scsi/scsi_trace.o
  CC      drivers/staging/android/ion/ion_system_heap.o
  CC [M]  drivers/scsi/scsi_logging.o
  CC [M]  drivers/spi/spi-bitbang.o
  CC      drivers/tee/optee/core.o
  CC      drivers/staging/android/ion/ion_carveout_heap.o
  CC      drivers/tee/optee/call.o
  CC [M]  drivers/spi/spi-gpio.o
  CC      drivers/staging/android/ion/ion_chunk_heap.o
  CC [M]  drivers/scsi/scsi_pm.o
  CC      drivers/tee/optee/rpc.o
  CC      drivers/staging/android/ion/ion_cma_heap.o
  LD      drivers/spi/built-in.o
  CC      drivers/tee/optee/supp.o
  CC      drivers/staging/android/ion/ti/ti_ion.o
  CC [M]  drivers/scsi/sd.o
  LD      drivers/tee/optee/optee.o
  LD      drivers/tee/optee/built-in.o
  LD      drivers/tee/tee.o
  LD      drivers/tee/built-in.o
  CC [M]  drivers/scsi/sr.o
  LD      drivers/staging/android/ion/ti/built-in.o
  CC [M]  drivers/scsi/sr_ioctl.o
  LD      drivers/staging/android/ion/built-in.o
  LD      drivers/staging/android/built-in.o
  LD      drivers/staging/iio/accel/built-in.o
  LD      drivers/staging/iio/adc/built-in.o
  LD      drivers/staging/iio/addac/built-in.o
  LD      drivers/staging/iio/cdc/built-in.o
  LD      drivers/staging/iio/frequency/built-in.o
  LD      drivers/staging/iio/gyro/built-in.o
  LD      drivers/staging/iio/impedance-analyzer/built-in.o
  LD      drivers/staging/iio/light/built-in.o
  LD      drivers/staging/iio/meter/built-in.o
  LD      drivers/staging/iio/resolver/built-in.o
  LD      drivers/staging/iio/trigger/built-in.o
  LD      drivers/staging/iio/built-in.o
  LD      drivers/staging/media/built-in.o
  LD      drivers/staging/built-in.o
  CC      drivers/thermal/thermal_core.o
  CC      drivers/thermal/thermal_hwmon.o
  CC      drivers/thermal/of-thermal.o
  CC      drivers/tty/tty_io.o
  CC      drivers/thermal/fair_share.o
  CC      drivers/thermal/gov_bang_bang.o
  CC [M]  drivers/scsi/sr_vendor.o
  CC      drivers/tty/n_tty.o
  CC      drivers/thermal/step_wise.o
  LD      drivers/scsi/built-in.o
  LD [M]  drivers/scsi/scsi_mod.o
  LD [M]  drivers/scsi/sd_mod.o
  LD [M]  drivers/scsi/sr_mod.o
  CC      drivers/thermal/user_space.o
  LD      drivers/uio/built-in.o
  CC [M]  drivers/uio/uio.o
  CC      drivers/thermal/power_allocator.o
  CC      drivers/thermal/cpu_cooling.o
  CC      drivers/tty/tty_ioctl.o
  LD      drivers/thermal/samsung/built-in.o
  CC      drivers/tty/tty_ldisc.o
  LD      drivers/usb/class/built-in.o
  CC [M]  drivers/usb/class/cdc-acm.o
  CC      drivers/thermal/ti-soc-thermal/ti-bandgap.o
  CC      drivers/thermal/ti-soc-thermal/ti-thermal-common.o
  CC      drivers/tty/tty_buffer.o
  LD      drivers/usb/common/built-in.o
  CC [M]  drivers/usb/common/common.o
  LD      drivers/usb/core/built-in.o
  CC [M]  drivers/usb/core/usb.o
  CC      drivers/tty/tty_port.o
  LD      drivers/thermal/ti-soc-thermal/ti-soc-thermal.o
  LD      drivers/thermal/ti-soc-thermal/built-in.o
  LD      drivers/thermal/thermal_sys.o
  LD      drivers/thermal/built-in.o
  CC [M]  drivers/usb/core/hub.o
  LD [M]  drivers/usb/common/usb-common.o
  CC [M]  drivers/usb/core/hcd.o
  LD      drivers/usb/dwc3/built-in.o
  CC [M]  drivers/usb/dwc3/core.o
  CC      drivers/tty/tty_mutex.o
  CC      drivers/tty/tty_ldsem.o
  CC      drivers/tty/pty.o
  CC [M]  drivers/usb/dwc3/debug.o
  CC      drivers/video/hdmi.o
  CC [M]  drivers/usb/dwc3/trace.o
  CC      drivers/tty/sysrq.o
  CC [M]  drivers/usb/dwc3/host.o
  CC      drivers/video/backlight/backlight.o
  CC [M]  drivers/usb/core/urb.o
  CC [M]  drivers/usb/dwc3/gadget.o
  CC      drivers/tty/hvc/hvc_console.o
  CC      drivers/video/backlight/generic_bl.o
  CC [M]  drivers/usb/core/message.o
  CC      drivers/video/backlight/gpio_backlight.o
  LD      drivers/tty/hvc/built-in.o
  LD      drivers/tty/ipwireless/built-in.o
  CC      drivers/tty/serial/serial_core.o
  CC      drivers/video/backlight/pwm_bl.o
  CC [M]  drivers/usb/dwc3/ep0.o
  CC      drivers/video/backlight/led_bl.o
  CC [M]  drivers/usb/core/driver.o
  CC [M]  drivers/usb/dwc3/debugfs.o
  LD      drivers/video/backlight/built-in.o
  CC      drivers/video/console/dummycon.o
  CC      drivers/tty/serial/earlycon.o
  CC      drivers/video/console/fbcon.o
  CC [M]  drivers/usb/dwc3/dwc3-omap.o
  CC [M]  drivers/usb/core/config.o
  CC      drivers/tty/serial/8250/8250_core.o
  CC [M]  drivers/usb/dwc3/dwc3-of-simple.o
  CC [M]  drivers/usb/core/file.o
  LD [M]  drivers/usb/dwc3/dwc3.o
  LD      drivers/usb/gadget/built-in.o
  CC [M]  drivers/usb/gadget/usbstring.o
  CC      drivers/tty/serial/8250/8250_port.o
  CC [M]  drivers/usb/core/buffer.o
  CC [M]  drivers/usb/gadget/config.o
  CC      drivers/video/console/bitblit.o
  CC [M]  drivers/usb/core/sysfs.o
  CC [M]  drivers/usb/gadget/epautoconf.o
  CC      drivers/video/console/softcursor.o
  CC [M]  drivers/usb/core/endpoint.o
  CC      drivers/tty/serial/8250/8250_dma.o
  CC [M]  drivers/usb/gadget/composite.o
  CC      drivers/video/console/fbcon_rotate.o
  CC [M]  drivers/usb/core/devio.o
  CC      drivers/tty/serial/8250/8250_pci.o
  CC      drivers/video/console/fbcon_cw.o
  CC [M]  drivers/usb/gadget/functions.o
  CC      drivers/video/console/fbcon_ud.o
  CC [M]  drivers/usb/core/notify.o
  CC      drivers/tty/serial/8250/8250_early.o
  CC [M]  drivers/usb/gadget/configfs.o
  CC      drivers/tty/serial/8250/8250_fsl.o
  CC [M]  drivers/usb/core/generic.o
  CC      drivers/video/console/fbcon_ccw.o
  CC      drivers/tty/serial/8250/8250_omap.o
  CC [M]  drivers/usb/core/quirks.o
  CC [M]  drivers/usb/gadget/u_f.o
  CC [M]  drivers/usb/core/devices.o
  LD      drivers/video/console/built-in.o
  CC      drivers/video/fbdev/core/fb_cmdline.o
  CC      drivers/tty/serial/8250/8250_of.o
  LD      drivers/usb/gadget/function/built-in.o
  CC [M]  drivers/usb/gadget/function/f_acm.o
  CC      drivers/video/fbdev/core/fb_notify.o
  CC [M]  drivers/usb/core/port.o
  LD      drivers/tty/serial/8250/8250.o
  LD      drivers/tty/serial/8250/8250_base.o
  LD      drivers/tty/serial/8250/built-in.o
  CC      drivers/tty/serial/bcm63xx_uart.o
  CC [M]  drivers/usb/gadget/function/f_loopback.o
  CC [M]  drivers/usb/core/of.o
  CC      drivers/video/fbdev/core/fbmem.o
  CC [M]  drivers/usb/gadget/function/f_sourcesink.o
  CC [M]  drivers/usb/core/hcd-pci.o
  LD      drivers/tty/serial/built-in.o
  CC      drivers/tty/vt/vt_ioctl.o
  CC [M]  drivers/usb/gadget/function/u_serial.o
  CC      drivers/video/fbdev/core/fbmon.o
  LD [M]  drivers/usb/core/usbcore.o
  CC [M]  drivers/usb/gadget/function/f_serial.o
  CC      drivers/tty/vt/vc_screen.o
  CC      drivers/tty/vt/selection.o
  CC      drivers/video/fbdev/core/fbcmap.o
  CC [M]  drivers/usb/gadget/function/f_obex.o
  CC      drivers/tty/vt/keyboard.o
  CC [M]  drivers/usb/gadget/function/u_ether.o
  CC      drivers/video/fbdev/core/fbsysfs.o
  CC      drivers/video/fbdev/core/modedb.o
  CC      drivers/usb/host/pci-quirks.o
  CC      drivers/video/fbdev/core/fbcvt.o
  CC [M]  drivers/usb/gadget/function/f_ncm.o
  CC      drivers/tty/vt/consolemap.o
  CC      drivers/video/fbdev/core/fb_defio.o
  CC [M]  drivers/usb/host/ehci-hcd.o
  CC [M]  drivers/usb/gadget/function/f_ecm.o
  CC      drivers/video/fbdev/core/cfbfillrect.o
  CONMK   drivers/tty/vt/consolemap_deftbl.c
  CC      drivers/tty/vt/vt.o
  CC [M]  drivers/usb/gadget/function/f_eem.o
  CC      drivers/video/fbdev/core/cfbcopyarea.o
  CC [M]  drivers/usb/gadget/function/f_subset.o
  CC      drivers/video/fbdev/core/cfbimgblt.o
  CC [M]  drivers/usb/gadget/function/f_rndis.o
  CC      drivers/video/fbdev/core/sysfillrect.o
  SHIPPED drivers/tty/vt/defkeymap.c
  CC      drivers/tty/vt/consolemap_deftbl.o
  CC [M]  drivers/usb/host/ehci-pci.o
  CC      drivers/tty/vt/defkeymap.o
  LD      drivers/tty/vt/built-in.o
  LD      drivers/tty/built-in.o
  CC [M]  drivers/usb/host/ehci-platform.o
  CC      drivers/video/fbdev/core/syscopyarea.o
  CC      drivers/video/display_timing.o
  CC [M]  drivers/usb/gadget/function/rndis.o
  CC [M]  drivers/usb/host/ehci-omap.o
  CC [M]  drivers/usb/host/ohci-hcd.o
  CC      drivers/video/fbdev/core/sysimgblt.o
  CC      drivers/video/fbdev/core/fb_sys_fops.o
  CC [M]  drivers/usb/gadget/function/f_mass_storage.o
  CC      drivers/video/videomode.o
  CC [M]  drivers/usb/host/ohci-pci.o
  LD      drivers/video/fbdev/core/fb.o
  LD      drivers/video/fbdev/core/built-in.o
  LD      drivers/video/fbdev/omap2/omapfb/displays/built-in.o
  LD      drivers/video/fbdev/omap2/omapfb/dss/built-in.o
  LD      drivers/video/fbdev/omap2/omapfb/built-in.o
  LD      drivers/video/fbdev/omap2/built-in.o
  CC      drivers/video/fbdev/efifb.o
  CC      drivers/video/fbdev/ssd1307fb.o
  CC [M]  drivers/usb/host/ohci-platform.o
  CC [M]  drivers/usb/gadget/function/storage_common.o
  CC [M]  drivers/usb/host/xhci.o
  CC      drivers/video/fbdev/simplefb.o
  CC      drivers/video/of_display_timing.o
  CC [M]  drivers/usb/gadget/function/f_fs.o
  CC      drivers/virtio/virtio.o
  LD      drivers/video/fbdev/built-in.o
  CC      drivers/video/of_videomode.o
  LD      drivers/video/built-in.o
  CC      drivers/virtio/virtio_ring.o
  LD      drivers/usb/gadget/legacy/built-in.o
  CC [M]  drivers/usb/gadget/legacy/zero.o
  CC [M]  drivers/usb/gadget/legacy/audio.o
  CC      drivers/virtio/virtio_mmio.o
  CC [M]  drivers/usb/host/xhci-mem.o
  CC [M]  drivers/usb/gadget/legacy/ether.o
  CC [M]  drivers/usb/gadget/function/f_uac1.o
  CC      drivers/virtio/virtio_pci_modern.o
  CC [M]  drivers/usb/gadget/legacy/inode.o
  CC [M]  drivers/usb/gadget/function/u_uac1.o
  CC      drivers/virtio/virtio_pci_common.o
  CC [M]  drivers/usb/gadget/function/f_uac2.o
  CC [M]  drivers/usb/host/xhci-ring.o
  CC      drivers/virtio/virtio_pci_legacy.o
  CC [M]  drivers/usb/gadget/legacy/g_ffs.o
  CC [M]  drivers/usb/gadget/function/f_uvc.o
  LD      drivers/virtio/virtio_pci.o
  LD      drivers/virtio/built-in.o
  CC [M]  drivers/usb/gadget/function/uvc_queue.o
  CC [M]  drivers/usb/gadget/legacy/mass_storage.o
  LD      drivers/usb/isp1760/built-in.o
  CC [M]  drivers/usb/isp1760/isp1760-core.o
  CC [M]  drivers/usb/gadget/function/uvc_v4l2.o
  CC [M]  drivers/usb/gadget/legacy/serial.o
  CC [M]  drivers/usb/isp1760/isp1760-if.o
  CC [M]  drivers/usb/host/xhci-hub.o
  CC [M]  drivers/usb/gadget/legacy/printer.o
  CC [M]  drivers/usb/gadget/function/uvc_video.o
  CC [M]  drivers/usb/isp1760/isp1760-hcd.o
  CC [M]  drivers/usb/gadget/legacy/gmidi.o
  CC [M]  drivers/usb/gadget/function/uvc_configfs.o
  CC [M]  drivers/usb/gadget/legacy/cdc2.o
  CC [M]  drivers/usb/host/xhci-dbg.o
  CC [M]  drivers/usb/gadget/legacy/hid.o
  CC [M]  drivers/usb/host/xhci-trace.o
  CC [M]  drivers/usb/isp1760/isp1760-udc.o
  CC [M]  drivers/usb/gadget/function/f_midi.o
  CC [M]  drivers/usb/gadget/legacy/dbgp.o
  CC [M]  drivers/usb/host/xhci-pci.o
  CC [M]  drivers/usb/gadget/legacy/multi.o
  CC [M]  drivers/usb/host/xhci-plat.o
  CC [M]  drivers/usb/gadget/function/f_hid.o
  LD [M]  drivers/usb/isp1760/isp1760.o
  CC [M]  drivers/usb/gadget/function/f_printer.o
  CC [M]  drivers/usb/gadget/legacy/webcam.o
  CC [M]  drivers/usb/host/r8a66597-hcd.o
  LD      drivers/w1/masters/built-in.o
  CC [M]  drivers/w1/masters/omap_hdq.o
  CC [M]  drivers/usb/gadget/legacy/ncm.o
  LD [M]  drivers/usb/gadget/function/usb_f_acm.o
  LD [M]  drivers/usb/gadget/function/usb_f_ss_lb.o
  LD [M]  drivers/usb/gadget/function/usb_f_serial.o
  LD [M]  drivers/usb/gadget/function/usb_f_obex.o
  LD [M]  drivers/usb/gadget/function/usb_f_ncm.o
  LD [M]  drivers/usb/gadget/function/usb_f_ecm.o
  LD [M]  drivers/usb/gadget/function/usb_f_eem.o
  LD [M]  drivers/usb/gadget/function/usb_f_ecm_subset.o
  LD [M]  drivers/usb/gadget/function/usb_f_rndis.o
  LD [M]  drivers/usb/gadget/function/usb_f_mass_storage.o
  LD [M]  drivers/usb/gadget/function/usb_f_fs.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac1.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac2.o
  LD [M]  drivers/usb/gadget/function/usb_f_uvc.o
  LD [M]  drivers/usb/gadget/function/usb_f_midi.o
  LD [M]  drivers/usb/gadget/function/usb_f_hid.o
  LD [M]  drivers/usb/gadget/function/usb_f_printer.o
  CC [M]  drivers/usb/gadget/legacy/acm_ms.o
  LD      drivers/w1/slaves/built-in.o
  CC [M]  drivers/w1/w1.o
  LD      drivers/usb/gadget/udc/built-in.o
  CC [M]  drivers/usb/gadget/udc/core.o
  LD [M]  drivers/usb/gadget/legacy/g_zero.o
  LD [M]  drivers/usb/gadget/legacy/g_audio.o
  LD [M]  drivers/usb/gadget/legacy/g_ether.o
  LD [M]  drivers/usb/gadget/legacy/gadgetfs.o
  LD [M]  drivers/usb/gadget/legacy/g_mass_storage.o
  LD [M]  drivers/usb/gadget/legacy/g_serial.o
  LD [M]  drivers/usb/gadget/legacy/g_printer.o
  LD [M]  drivers/usb/gadget/legacy/g_midi.o
  LD [M]  drivers/usb/gadget/legacy/g_cdc.o
  LD [M]  drivers/usb/gadget/legacy/g_hid.o
  LD [M]  drivers/usb/gadget/legacy/g_dbgp.o
  LD [M]  drivers/usb/gadget/legacy/g_multi.o
  LD [M]  drivers/usb/gadget/legacy/g_webcam.o
  LD [M]  drivers/usb/gadget/legacy/g_ncm.o
  LD [M]  drivers/usb/gadget/legacy/g_acm_ms.o
  CC      drivers/watchdog/watchdog_core.o
  LD      drivers/usb/host/built-in.o
  LD [M]  drivers/usb/host/xhci-hcd.o
  LD [M]  drivers/usb/host/xhci-plat-hcd.o
  LD [M]  drivers/usb/gadget/libcomposite.o
  CC      drivers/watchdog/watchdog_dev.o
  CC [M]  drivers/w1/w1_int.o
  CC [M]  drivers/usb/gadget/udc/trace.o
  LD      drivers/usb/misc/built-in.o
  CC [M]  drivers/usb/misc/usbtest.o
  CC [M]  drivers/watchdog/omap_wdt.o
  LD [M]  drivers/usb/gadget/udc/udc-core.o
  CC [M]  drivers/w1/w1_family.o
  LD      drivers/watchdog/watchdog.o
  LD      drivers/watchdog/built-in.o
  CC [M]  drivers/w1/w1_netlink.o
  CC [M]  drivers/w1/w1_io.o
  LD      drivers/usb/musb/built-in.o
  CC [M]  drivers/usb/musb/musb_core.o
  LD      drivers/w1/built-in.o
  LD [M]  drivers/w1/wire.o
  CC [M]  drivers/usb/musb/musb_trace.o
  CC [M]  drivers/usb/musb/musb_virthub.o
  CC [M]  drivers/usb/musb/musb_host.o
  CC      drivers/usb/phy/phy.o
  CC      drivers/usb/phy/of.o
  CC [M]  drivers/usb/musb/musb_gadget_ep0.o
  CC [M]  drivers/usb/phy/phy-generic.o
  CC [M]  drivers/usb/phy/phy-am335x-control.o
  CC [M]  drivers/usb/musb/musb_gadget.o
  LD      drivers/usb/serial/built-in.o
  CC [M]  drivers/usb/serial/usb-serial.o
  CC [M]  drivers/usb/serial/generic.o
  CC [M]  drivers/usb/phy/phy-am335x.o
  CC [M]  drivers/usb/phy/phy-gpio-vbus-usb.o
  CC [M]  drivers/usb/phy/phy-isp1301.o
  CC [M]  drivers/usb/musb/musb_debugfs.o
  LD      drivers/usb/storage/built-in.o
  CC [M]  drivers/usb/storage/scsiglue.o
  CC [M]  drivers/usb/serial/bus.o
  LD      drivers/usb/phy/built-in.o
  CC [M]  drivers/usb/storage/protocol.o
  CC [M]  drivers/usb/musb/musb_cppi41.o
  LD [M]  drivers/usb/serial/usbserial.o
  CC [M]  drivers/usb/musb/omap2430.o
  CC [M]  drivers/usb/musb/am35x.o
  CC [M]  drivers/usb/musb/musb_dsps.o
  CC [M]  drivers/usb/storage/transport.o
  CC [M]  drivers/usb/musb/musb_am335x.o
  CC [M]  drivers/usb/storage/usb.o
  CC [M]  drivers/usb/storage/initializers.o
  LD [M]  drivers/usb/musb/musb_hdrc.o
  CC [M]  drivers/usb/storage/sierra_ms.o
  CC [M]  drivers/usb/storage/option_ms.o
  CC [M]  drivers/usb/storage/usual-tables.o
  LD [M]  drivers/usb/storage/usb-storage.o
  LD      drivers/usb/built-in.o
  LD      drivers/built-in.o
Build stop here and no image is generated at boot folder
  • The software team have been notified. They will respond here.
  • Hi Hinge,
    Dattatray Hinge said:
    root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# make -j4
    You should make zImage:
    ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$make zImage -j4
    Refer to the below wiki for details:
    You can also build the kernel (with modules and DTS files) from the main folder, using the Makefile:
    ti-processor-sdk-linux-am335x-evm-04.02.00.09$make linux
    processors.wiki.ti.com/.../Processor_SDK_Linux_Getting_Started_Guide
  • Dattatray Hinge said:
    root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59# export PATH=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
    Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: //usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    If you have problems with Perl strict.pm, do NOT export the PATH variable, but use only the below command to generate kernel image:
    ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- distclean
    ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- tisdk_am335x-evm_defconfig
    ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- zImage
    Thus the compilation process ends with below console messages:
     OBJCOPY arch/arm/boot/zImage
     Kernel: arch/arm/boot/zImage is ready
    Pavel
  • Below command gives error as no target
    $ ti-processor-sdk-linux-am335x-evm-04.02.00.09$make linux
    I think some steps are missing, please send me all commands that need to build kernel with modules and DTS files
  • Dattatray,
    "make linux" is working fine on my side, nothing more is required.
    Can you test the below sequence?
    ti-processor-sdk-linux-am335x-evm-04.02.00.09$ make clean
    ti-processor-sdk-linux-am335x-evm-04.02.00.09$ make linux
    If still doesn't work, please provide me full console log output (put it in txt file and attach the txt file here) for analysis. Provide me also your ti-processor-sdk-linux-am335x-evm-04.02.00.09/Rules.make file.
    Check also if below wiki will be in help:
    processors.wiki.ti.com/.../Processor_Linux_SDK_Top-Level_Makefile
    Pavel
  • Hi Pavel,
    I tried above commands in both sdk version v04.01.00.06 and v04.02.00.09
    below are the outcome, I think config file need to build
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- clean
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- linux
    HOSTCC scripts/basic/fixdep
    HOSTCC scripts/kconfig/conf.o
    SHIPPED scripts/kconfig/zconf.tab.c
    SHIPPED scripts/kconfig/zconf.lex.c
    SHIPPED scripts/kconfig/zconf.hash.c
    HOSTCC scripts/kconfig/zconf.tab.o
    HOSTLD scripts/kconfig/conf
    scripts/kconfig/conf --silentoldconfig Kconfig
    *** Configuration file ".config" not found!
    *** Please run some configurator (e.g. "make oldconfig" or
    *** "make menuconfig" or "make xconfig").
    scripts/kconfig/Makefile:37: recipe for target 'silentoldconfig' failed
    make[2]: *** [silentoldconfig] Error 1
    Makefile:546: recipe for target 'silentoldconfig' failed
    make[1]: *** [silentoldconfig] Error 2
    make: *** No rule to make target 'linux'. Stop.
    Pls find attach Rules.make file
    #platform
    PLATFORM=am335x-evm
    #defconfig
    DEFCONFIG=tisdk_am335x-evm_defconfig
    #Architecture
    ARCH=armv7-a
    #u-boot machine
    UBOOT_MACHINE=am335x_evm_config
    #Points to the root of the TI SDK
    export TI_SDK_PATH=/home/dattatray/ti-processor-sdk-linux-am335x-evm-04.01.00.06
    #root of the target file system for installing applications
    DESTDIR=/home/dattatray/ti-processor-sdk-linux-am335x-evm-04.01.00.06/targetNFS
    #Points to the root of the Linux libraries and headers matching the
    #demo file system.
    export LINUX_DEVKIT_PATH=$(TI_SDK_PATH)/linux-devkit
    #Cross compiler prefix
    export CROSS_COMPILE=$(LINUX_DEVKIT_PATH)/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-
    #Default CC value to be used when cross compiling.  This is so that the
    #GNU Make default of "cc" is not used to point to the host compiler
    export CC=$(CROSS_COMPILE)gcc
    #Location of environment-setup file
    export ENV_SETUP=$(LINUX_DEVKIT_PATH)/environment-setup
    #The directory that points to the SDK kernel source tree
    LINUXKERNEL_INSTALL_DIR=$(TI_SDK_PATH)/board-support/linux-4.9.41+gitAUTOINC+e3a80a1c5c-ge3a80a1c5c
    CFLAGS= -march=armv7-a -marm -mfpu=neon  -mfloat-abi=hard
    #Strip modules when installing to conserve disk space
    INSTALL_MOD_STRIP=1
    SDK_PATH_TARGET=$(TI_SDK_PATH)/linux-devkit/sysroots/armv7ahf-neon-linux-gnueabi/
    # Set EXEC_DIR to install example binaries
    EXEC_DIR=/home/dattatray/ti-processor-sdk-linux-am335x-evm-04.01.00.06/targetNFS/home/root/am335x-evm
    MAKE_JOBS=8
    Dattatray,
    You are messing up two methods (compiling from top level and from linux kernel source).
    Please execute the below sequence:
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- distclean
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- tisdk_am335x-evm_defconfig
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm CROSS_COMPILE=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- zImage
    This is the correct method for compiling kernel image (zImage) from the linux kernel source. You should end up with zImage generated.
    The other method is to compile zImage plus modules plus dtb files from top-level. In this method, please execute the below commands:
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06$ make clean
    sdkusr@sdkusr-XPS14-L:~/ti-processor-sdk-linux-am335x-evm-04.01.00.06$ make linux
    Pavel
  • oops my bad, I forget to change directory,
    Thanks Pavel, It is working now.
