AM5728: eMMC boot on GP EVM
Part Number: AM5728
Other Parts Discussed in Thread: 4430, 4460, 4428, PMP
           I had boot AM5728 EVM by sd_card.Its working fine.
           Now,i want to do same procedure(boot up) by eMMC.
           Please,tell me steps from beginning like how can load image to eMMC and boot up EVM board by eMMC.
Thanks in advance.
    Please check this user guide:
    processors.wiki.ti.com/.../Linux_Core_U-Boot_User's_Guide
    Hope this helps.
    BR
    Margarita
  • Thanks for reply,
    Actually,i have already checked this document.
    But i am confusing to use it.
    Means i cannot understand properly.
    If anyone can tell me steps,its great for me.
    Please,let me inform if anyone has done this process before.
    Please check these threads they could be in help:
    e2e.ti.com/.../544905
    e2e.ti.com/.../582940
    BR
    Margarita
    Thanks for reply.I have checked above threads.But it could not helpful.
    If anyone can tell me steps from beginning,its good for me.
    I can not found steps for it anywhere.
    If anyone want to boot by using sd_card,they can follow steps from below link:
    processors.wiki.ti.com/.../Processor_SDK_Linux_create_SD_card_script
    This is described from beginning.
    Same for eMMC,if i can know steps it will be helpful to me.
  • Hello Margarita,
    Please,tell me steps from beginning.
    I had refer user guide,but its confusing me.
    Thanks in advance.
    Please check my previous answer. These threads actually contains the steps.
    Refer the user guide also.
    BR
    Margarita
  • Hello Margarita,
    I follow the steps.
    But i could not get output.
    You can tell me first step,i will show you result of it.
    Let me help to start the process please.
    Anyone can help me to boot_up evm using eMMC.
    Thanks in advance.
    Whenever i execute the commands from the user_guide,result is as below:
    sudo dpkg-reconfigure dash
    [sudo] password for kishan:
    Removing 'diversion of /bin/sh to /bin/sh.distrib by dash'
    Adding 'diversion of /bin/sh to /bin/sh.distrib by bash'
    Removing 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by dash'
    Adding 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by bash'
    kishan@kishan-ThinkPad-T430s:~$ make am57xx_evm_defconfig
    make: *** No rule to make target 'am57xx_evm_defconfig'. Stop.
  • Part Number: AM5728
              I want to boot_up AM5728 EVM board by using eMMC.
              I also referring user_guide.Which link as below:
              http://processors.wiki.ti.com/index.php/Linux_Core_U-Boot_User's_Guide
          There is first step is for partitioning.
          I want to confirm that where should i execute 'uuidgen' command.
          Host means at console port or on my system terminal.
    Thanks in advance.
    In the guide is written :
    " In this case we need to use the uuidgen program on the host to create the UUIDs
    used for the disk and each partition. "
    means host machine.
    BR
    Margarita
  • Hello Margarita,
    Thanks for reply,
    Please help me to complete this booting process.
    I had execute that command from my machine.
    Then result as below:
    $ uuidgen
    06e32858-05da-4aef-8d95-3bf5c2d9c30d
    kishan@kishan-ThinkPad-T430s:~$ uuidgen
    c0dbda5e-b50b-411f-976f-9a443055fda8
    Now,there is line avialable in user_guide as below:
    U-Boot # printenv partitions
    uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}
    U-Boot # setenv uuid_gpt_disk ...first uuid...
    U-Boot # setenv uuid_gpt_rootfs ...second uuid...
    U-Boot # gpt write mmc 1 ${partitions}
    These all commands should be execute in U-BOOT mode.Right?
    Now, when i am trying to go into U_BOOT mode,
    There are some errors occur.
    Please,check this command: "host$ sudo dfu-util c 1 -i 0 -a 0 -D "u-boot.img" -R"
    This is for U-boot mode.Right?
    Please,tell me.
    Thanks again.
    U-Boot # ... means in u-boot;
    host$... or $ means host machine.
    target#....means board when the fs is loaded.
    BR
    Margarita
  • Okay,
    Thanks for confirm.
    If you can tell me after executing uuidgen command,how can i go into u-boot mode.
    Because i am stuck at there.
    Thanks.
    Please check this thread, could be in help.
    e2e.ti.com/.../2318025
    BR
    Margarita
  • Hello Margarita,
    I have checked that post.
    There is an issue after U-BOOT mode.
    If you know the step,let me tell how can i go into u-boot mode.
    Thanks.
    I mean to follow Steve Kipisz steps.
    BR
    Margarita
  • Hello kishan,
    Here I am posting you the exact steps to boot AM572x EVM from eMMC.
    Download and install the latest AM57x Processor SDK.
    Copy these files <Processor SDK>/board-support/prebuilt-images/MLO-am57xx-evm, <Processor SDK>/board-support/prebuilt-images/u-boot-am57xx-evm.img and <Processor SDK>/filesystem/tisdk-rootfs-image-am57xx-evm.tar.xz to your SD card.
    Put the SD card to your AM572x EVM and boot the board. Then type these commands:
    am57xx-evm login: root
    root@am57xx-evm:~# echo 0 > /sys/block/mmcblk1boot0/force_ro
    root@am57xx-evm:~# echo 0 > /sys/block/mmcblk1boot1/force_ro
    root@am57xx-evm:~# dd if=/dev/zero of=/dev/mmcblk1boot0 bs=512
    root@am57xx-evm:~# dd if=/dev/zero of=/dev/mmcblk1boot1 bs=512
    root@am57xx-evm:~# dd if=MLO-am57xx-evm of=/dev/mmcblk1boot0 bs=512
    root@am57xx-evm:~# dd if=u-boot-am57xx-evm.img of=/dev/mmcblk1boot0 bs=512 seek=768
    root@am57xx-evm:~# umount /dev/mmcblk1p1
    root@am57xx-evm:~# umount /dev/mmcblk1p2
    root@am57xx-evm:~# fdisk /dev/mmcblk1
    Type:
    1. p - print the partition table
    2. o -  create a new empty DOS partition table
    3. p - print the partition table
    4. n - add a new partition
    5. Press 4 times Enter and take the default values
    6. p - print the partition table
    7. w - write table to disk and exit
    root@am57xx-evm:~# mkfs.ext4 -t ext4 /dev/mmcblk1p1
    Press 'y' if it ask you to proceed anyway.
    root@am57xx-evm:~# mkdir rootfs
    root@am57xx-evm:~# mount /dev/mmcblk1p1 rootfs/
    root@am57xx-evm:~# tar xvf tisdk-rootfs-image-am57xx-evm.tar.xz -C rootfs/
    root@am57xx-evm:~# sync
    root@am57xx-evm:~# shutdown now
    Eject the SD card from the board and press the power on button.
    Enter these settings in U-Boot console:
    => mmc dev 1 1
    => mmc bootbus 1 2 0 2
    => mmc partconf 1 1 1 0
    => mmc rst-function 1 1
    => setenv bootpart 1:1
    => saveenv
    => boot
    Your board will boot from eMMC hereafter.
    Kemal
  • Hello Kemal,
    I followed the steps as you mentioned above, but I was not able to boot from eMMC.
    Here are the steps which I did to boot from eMMC:
    1) Flashed sd-card with pre-built images provide with SDK
    2) Copied all 3 files which you mentioned in /tmp directories of rootfs (the permission for /home/root was not available).
    3) As I boot the board, the files in /tmp was not present.
    4) I copied it using usb (pen-drive).
    5) Then I followed your steps(commands) mentioned in above post.
    After removing sd-card the board was not booted as I was not able to find any log on console.
    Also board power-off automatically after sometime. It works perfectly with sd-card.
    Omkareshwar
  • It is normal the board to power-off automatically after sometime.
    Can you stop the board in U-Boot console while booting from SD card and enter these commands:
    => mmc dev 1 1
    Then remove the SD card, and try to boot from eMMC again.
  • Hello Kemal,
    I have also facing same issue.
    I have tried to stop the board in U-Boot console while booting from SD card and enter these commands:
    => mmc dev 1 1
    But,it has not boot.So,i restart the board,and it can boot-up with sd_card,but cannot boot-up by eMMC.
    Kishan.
  • Are there any logs printed out? Can you boot from SD card and post the feedback from this command?
    root@am57xx-evm:~# hexdump /dev/mmcblk1boot0
  • Hello Kemal,
    As you said here is the log of "root@am57xx-evm:~# hexdump /dev/mmcblk1boot0"
    0000000 0040 0000 000c 0000 0000 0000 0000 0000
    0000010 0000 0000 4843 4553 5454 4e49 5347 0000
    0000020 ffff ffff ffff ffff ffff ffff ffff ffff
    0000040 c0c1 c0c0 0100 0000 0000 0000 0000 0000
    0000050 0000 0000 0000 0000 0000 0000 0000 0000
    0000200 ccca 0001 0000 4030 000f ea00 f014 e59f
    0000210 f014 e59f f014 e59f f014 e59f f014 e59f
    0000220 f014 e59f f014 e59f 0040 4030 0040 4030
    0000230 0040 4030 0040 4030 0040 4030 0040 4030
    0000240 0040 4030 beef dead fffe ebff 0069 ea00
    0000250 0f31 ee10 0a0f e200 0a01 e350 0068 0a00
    0000260 0000 e10f 101f e200 001a e331 001f 13c0
    0000270 0013 1380 00c0 e380 f000 e129 0f10 ee11
    0000280 0a02 e3c0 0f10 ee01 00a4 e59f 0f10 ee0c
    0000290 0007 eb00 0025 eb00 0bb6 eb00 0f15 ee07
    00002a0 0f9a ee07 0f95 ee07 ff1e e12f ffe7 eaff
    00002b0 ffea eaff 0000 e3a0 0f17 ee08 0f15 ee07
    00002c0 0fd5 ee07 0f9a ee07 0f95 ee07 0f10 ee11
    00002d0 0a02 e3c0 0007 e3c0 0002 e380 0b02 e380
    00002e0 0a01 e380 0f10 ee01 500e e1a0 1f10 ee10
    00002f0 3a21 e1a0 300f e203 400f e201 2203 e1a0
    0000300 2002 e184 0030 e352 0007 aa00 0020 e352
    0000310 0005 ba00 0f10 ee3f 0080 e380 003e e92d
    0000320 0265 fb00 f06f f57f 003e e8bd f005 e1a0
    0000330 0b3a ea00 0000 4030 40a4 e59f 000f e894
    0000340 60ff e3a0 c000 e3a0 f04f f57f f05f f57f
    0000350 0070 e160 0004 ea00 f000 e320 c0fe e3a0
    0000360 f04f f57f f05f f57f 0070 e160 4070 e59f
    0000370 0010 e584 406c e59f 5000 e3a0 5000 e584
    0000380 4064 e59f f004 e320 ff14 e12f 4030 e92d
    0000390 404c e59f 000f e884 0004 e1a0 1040 e3a0
    00003a0 1001 e080 0b3b fa00 4040 e59f 5040 e59f
    00003b0 5000 e584 402c e59f 5010 e3a0 5000 e584
    00003c0 f004 e320 f002 e320 f000 e320 5000 e594
    00003d0 0000 e355 fffa 1aff 4004 e59f 0010 e594
    00003e0 8030 e8bd aa00 4031 1800 4828 8a64 0003
    00003f0 1804 4828 0130 4030 1088 e59f 0000 e581
    0000400 ff92 eaff 0028 e28f d000 e580 1004 e28f
    0000410 0074 e59f 0007 ea00 0014 e28f d000 e590
    0000420 0f10 ee91 1064 e59f 0001 e180 0f10 ee81
    0000430 ff8a eaff 0000 0000 5ff0 e92d c000 e1a0
    0000440 0001 e1a0 f04f f57f f05f f57f 0070 e160
    0000450 9ff0 e8bd 5ff0 e92d 60ff e3a0 c000 e3a0
    0000460 f04f f57f f05f f57f 0070 e160 0004 ea00
    0000470 f000 e320 c0fe e3a0 f04f f57f f05f f57f
    0000480 0070 e160 9ff0 e8bd bc24 4037 0102 0000
    0000490 1004 0000 4b07 681b 681b 681b 681b f3bf
    00004a0 8f5f f003 030f 2b07 bf9a 4a03 f852 0023
    00004b0 2000 4770 aa40 4031 0d80 4031 2000 4770
    00004c0 2300 b530 4293 f101 0108 db00 bd30 f851
    00004d0 5c04 f3bf 8f5f f851 4c08 3301 5105 e7f1
    00004e0 b537 4c66 6823 681b 6edb 681b f3bf 8f5f
    00004f0 f423 2370 f423 7343 f443 2320 f443 7382
    0000500 f3bf 8f5f 6822 6812 6ed1 600b 6f13 681b
    0000510 f3bf 8f5f f023 4340 f043 4380 f3bf 8f5f
    0000520 6822 6812 6f11 600b 6f53 681b f3bf 8f5f
    0000530 f423 3370 f443 3320 f3bf 8f5f 6822 6812
    0000540 6f51 600b 6f93 681b f3bf 8f5f f423 2370
    0000550 f423 7340 f443 2370 f443 7300 f3bf 8f5f
    0000560 6822 6812 6f91 600b 6fd3 681b f3bf 8f5f
    0000570 f023 534c f043 5308 f3bf 8f5f 6822 6812
    0000580 6fd1 600b f8d2 3080 681b f3bf 8f5f f443
    0000590 2370 f3bf 8f5f 6822 6812 f8d2 1080 600b
    00005a0 f8d2 3088 681b f3bf 8f5f f3c3 030d f043
    00005b0 5312 f443 1312 f3bf 8f5f 6822 a801 4625
    00005c0 6812 f8d2 2088 6013 f04f 4398 689b 0f5b
    00005d0 2b04 d155 f000 fda2 9b01 681a f3bf 8f5f
    00005e0 6823 681b f8d3 30bc 601a 9b01 681a f3bf
    00005f0 8f5f 6823 681b f8d3 30c0 601a 9b01 681a
    0000600 f3bf 8f5f 6823 681b f8d3 30c4 601a 9b01
    0000610 681a f3bf 8f5f 6823 681b f8d3 30c8 601a
    0000620 9b01 685a f3bf 8f5f 6823 681b f8d3 30cc
    0000630 601a 9b01 685a f3bf 8f5f 6823 681b f8d3
    0000640 30d0 601a 9b01 68da f3bf 8f5f 6823 681b
    0000650 f8d3 30d4 601a 9b01 691a f3bf 8f5f 6823
    0000660 681b f8d3 30d8 601a 9b01 695a f3bf 8f5f
    0000670 6823 681b f8d3 30dc 601a e0a9 aa40 4031
    0000680 f000 fd4c 9b01 689a f3bf 8f5f 6823 681b
    0000690 f8d3 30b4 601a 9b01 681a f3bf 8f5f 6823
    00006a0 681b f8d3 30bc 601a 9b01 681a f3bf 8f5f
    00006b0 6823 681b f8d3 30c0 601a 9b01 689a f3bf
    00006c0 8f5f 6823 681b f8d3 30b8 601a 9b01 681a
    00006d0 f3bf 8f5f 6823 681b f8d3 30c4 601a 9b01
    00006e0 681a f3bf 8f5f 6823 681b f8d3 30c8 601a
    00006f0 9b01 68da f3bf 8f5f 6823 681b f8d3 30d4
    0000700 601a 9b01 691a f3bf 8f5f 6823 681b f8d3
    0000710 30d8 601a 4b34 681a f002 427f f1b2 6fe0
    0000720 d011 9a01 6951 f3bf 8f5f 6822 6812 f8d2
    0000730 20dc 6011 9a01 6851 f3bf 8f5f 6822 6812
    0000740 f8d2 20d0 6011 9a01 6851 f3bf 8f5f 682a
    0000750 6812 f8d2 20cc 6011 9a01 6991 f3bf 8f5f
    0000760 682a 6812 f8d2 2140 6011 681a 0d12 0512
    0000770 f1b2 6fe4 d008 9a01 6991 f3bf 8f5f 682a
    0000780 6812 f8d2 2144 6011 681b f003 437f f1b3
    0000790 4fa8 d11f 682b 681b f8d3 3134 681b f3bf
    00007a0 8f5f f423 1380 f3bf 8f5f 682a 6812 f8d2
    00007b0 1134 600b f8d2 313c 681b f3bf 8f5f f423
    00007c0 1380 f3bf 8f5f 682a 6812 f8d2 213c 6013
    00007d0 b003 bd30 9b01 6a1a f3bf 8f5f 682b 681b
    00007e0 f8d3 30e0 e748 bf00 bc00 4037 b5f8 f001
    00007f0 f955 4b8b 681c f004 437f f1b3 4fa8 f040
    0000800 810e 4b88 4d88 4e89 eb03 0240 f992 1001
    0000810 f913 2010 462b 0112 ea42 0241 2100 6828
    0000820 6800 f8d0 011c 5808 f3bf 8f5f 4030 ea40
    0000830 0e02 f3bf 8f5f 682f 683f f8d7 011c f841
    0000840 e000 3104 2910 d1ea 4979 f424 3400 428c
    0000850 d140 4978 680a 6812 f8d2 21f4 6812 f3bf
    0000860 8f5f f442 7280 f3bf 8f5f 6809 6809 f8d1
    0000870 11f4 600a 2200 6819 6809 f8d1 111c 5851
    0000880 f3bf 8f5f f421 6100 f3bf 8f5f 6818 6800
    0000890 f8d0 011c 5011 6819 6809 f8d1 111c 5851
    00008a0 f3bf 8f5f f3c1 3107 2900 d0f4 6819 6809
    00008b0 f8d1 111c 5851 f3bf 8f5f f021 4180 f3bf
    00008c0 8f5f 6818 6800 f8d0 011c 5011 3204 2a10
    00008d0 d1d1 bdf8 f8d7 1180 6809 f3bf 8f5f 4031
    00008e0 430a f3bf 8f5f 6829 6809 f8d1 1180 600a
    00008f0 2200 6819 6809 f8d1 111c 5851 f3bf 8f5f
    0000900 f041 0101 f3bf 8f5f 6818 6800 f8d0 411c
    0000910 5111 f8d0 111c 5851 f3bf 8f5f f021 4180
    0000920 f3bf 8f5f 6818 6800 f8d0 411c 5111 3204
    0000930 2a10 d1de f8d0 2180 6812 f3bf 8f5f f042
    0000940 0201 f3bf 8f5f 6819 6809 f8d1 0180 6002
    0000950 f8d1 2180 6812 f3bf 8f5f f022 4280 f3bf
    0000960 8f5f 6819 6809 f8d1 1180 600a 4931 680a
    0000970 6812 f8d2 21f4 6812 f3bf 8f5f f442 7280
    0000980 f3bf 8f5f 6808 6800 f8d0 41f4 6022 f8d0
    0000990 243c 6812 f3bf 8f5f f442 7280 f3bf 8f5f
    00009a0 6809 6809 f8d1 143c 600a 2200 6819 6809
    00009b0 f8d1 111c 5851 f3bf 8f5f f3c1 3107 2900
    00009c0 d0f4 6819 6809 f8d1 111c 5851 f3bf 8f5f
    00009d0 f021 0101 f3bf 8f5f 6818 6800 f8d0 011c
    00009e0 5011 3204 2a10 d1e1 681a 6812 f8d2 2180
    00009f0 6812 f3bf 8f5f f3c2 3207 2a00 d0f4 681a
    0000a00 6812 f8d2 2180 6812 f3bf 8f5f f022 0201
    0000a10 f3bf 8f5f 681b 681b f8d3 3180 601a bdf8
    0000a20 bc00 4037 4e74 4031 aa40 4031 f801 ffff
    0000a30 0100 5430 aaac 4031 4770 0000 b513 4604
    0000a40 a801 f000 fb6b f1b4 4f98 d10b 9b01 69da
    0000a50 f3bf 8f5f 4b0a 681b 681b f8d3 3140 601a
    0000a60 b002 bd10 f1b4 4f9a d1fa 9b01 69da f3bf
    0000a70 8f5f 4b03 681b 681b f8d3 3144 e7ef bf00
    0000a80 aa40 4031 ee3f 1f10 f44f 7082 f441 718c
    0000a90 f010 ba76 b508 f000 fedb 4b28 681a f3bf
    0000aa0 8f5f 4b27 429a 4b27 d03c d816 4926 428a
    0000ab0 d033 d809 f5a1 21ac 428a d025 f501 219c
    0000ac0 428a d031 2200 e023 4920 428a d032 f501
    0000ad0 11ca 428a d1f6 4a1e e01a 491e 428a d02b
    0000ae0 d809 f5a1 3130 428a d020 f501 4100 428a
    0000af0 d1e8 4a19 e00c 4919 428a d019 f501 3130
    0000b00 428a d1df 4a16 e003 4a16 4290 d00a 4a16
    0000b10 601a e8bd 4008 f7ff bfb5 4a12 4290 d0e8
    0000b20 4a12 e7f5 4a12 e7f3 4a12 e7f1 4a12 e7ef
    0000b30 4a12 e7ed 4a12 e7eb 4a12 e7e9 c204 4ae0
    0000b40 202f 1b94 bc00 4037 802f 0b99 c02f 0b9b
    0000b50 0100 0762 c02f 1b9b 0200 5432 002f 2b99
    0000b60 0210 0722 c0f2 412f 0100 5430 0100 5432
    0000b70 0200 5430 0100 0752 0110 0752 0200 0752
    0000b80 0100 0722 0200 0722 4b0e 681a 6812 6b92
    0000b90 6812 f3bf 8f5f 6002 681a 6812 6bd2 6812
    0000ba0 f3bf 8f5f 6042 681a 6812 6c12 6812 f3bf
    0000bb0 8f5f 681b 6082 681b 6c5b 681b f3bf 8f5f
    0000bc0 60c3 4770 aa40 4031 2300 60c3 6083 6043
    0000bd0 6003 4770 b51f 2210 2100 4668 f006 fe22
    0000be0 4668 f7ff ffd1 4a09 6813 0d1b 051b f1b3
    0000bf0 6fec d108 f8bd 300a f003 0303 2b02 bf0c
    0000c00 4b03 4b04 6013 b005 f85d fb04 bc00 4037
    0000c10 0102 0762 0103 0762 4770 0000 4b07 681a
    0000c20 4b07 429a 4b07 f3bf 8f5f 681b bf0c 2202
    0000c30 2201 681b f8d3 3440 601a 4770 bc00 4037
    0000c40 0100 5430 aaac 4031 f3bf 8f5f 4b01 2201
    0000c50 601a 4770 7b00 4ae0 4b06 681b 681b f8d3
    0000c60 3444 6818 f3bf 8f5f f020 0015 0440 0c40
    0000c70 4770 bf00 aaac 4031 4b04 6818 f3bf 8f5f
    0000c80 f020 0015 0440 0c40 4770 bf00 7b04 4ae0
    0000c90 4a09 6813 681b f8d3 3448 681b f3bf 8f5f
    0000ca0 ea6f 2393 ea6f 2383 f3bf 8f5f 6812 6812
    0000cb0 f8d2 2448 6013 4770 aaac 4031 4770 4601
    0000cc0 f44f 7082 f010 b95c 4602 2150 2051 f00d
    0000cd0 b9cb 0000 b570 4606 4c20 6823 681b f8d3
    0000ce0 308c 681d f3bf 8f5f f025 6280 f3bf 8f5f
    0000cf0 6823 200a f025 6540 681b f8d3 308c 601a
    0000d00 f006 fe22 f3bf 8f5f 6823 4630 681b f8d3
    0000d10 308c 601d f7ff ffd8 6823 681b f8d3 308c
    0000d20 681d f3bf 8f5f f045 6200 f3bf 8f5f 6823
    0000d30 2096 f045 6540 681b f8d3 308c 601a f006
    0000d40 fe03 f3bf 8f5f 6823 2096 681b f8d3 308c
    0000d50 601d e8bd 4070 f006 bdf7 bf00 aa40 4031
    0000d60 4b01 6003 4770 bf00 4e97 4031 4b55 b573
    0000d70 4604 681b 681b f003 437f f1b3 4fa8 d134
    0000d80 f1b0 4f98 f101 033c bf0c 2001 2002 f504
    0000d90 7200 3150 681e f3bf 8f5f 4615 f845 6b08
    0000da0 f853 6b04 f3bf 8f5f 428b 6056 462a d1f1
    0000db0 aa01 4669 f002 fbce f504 740a 2300 9a01
    0000dc0 4293 d301 b002 bd70 9a00 f852 1023 f3bf
    0000dd0 8f5f 4622 f842 1b08 9900 f851 1023 f3bf
    0000de0 8f5f 6061 3301 4614 e7e9 f1b0 4f98 6d4d
    0000df0 6b4e aa01 4669 bf0c 2001 2002 f002 fbaa
    0000e00 9b00 0fed 681b f3bf 8f5f f8c4 3200 9b00
    0000e10 681b f3bf 8f5f 0171 f8c4 3204 d418 0132
    0000e20 d429 01b3 d43a 2d00 d0cc f504 742a 2354
    0000e30 9a00 58d2 f3bf 8f5f 6022 9a00 58d2 f3bf
    0000e40 8f5f 3304 6062 2b8c f104 0408 d1f0 e7b9
    0000e50 f504 7202 2304 9900 58c9 f3bf 8f5f 6011
    0000e60 9900 58c9 f3bf 8f5f 3304 6051 2b18 f102
    0000e70 0208 d1f0 e7d3 f504 720c 2318 9900 58c9
    0000e80 f3bf 8f5f 6011 9900 58c9 f3bf 8f5f 3304
    0000e90 6051 2b2c f102 0208 d1f0 e7c2 f504 7216
    0000ea0 232c 9900 58c9 f3bf 8f5f 6011 9900 58c9
    0000eb0 f3bf 8f5f 3304 6051 2b64 f102 0208 d1f0
    0000ec0 e7b1 bf00 0da0 4031 4770 0000 b508 4b1e
    0000ed0 4a1e 681b 681b 4293 d00c d818 4a1c 4293
    0000ee0 d008 d80b f5a2 7288 4293 d003 f502 7280
    0000ef0 4293 d114 2314 6003 4816 bd08 4a16 4293
    0000f00 d0f8 32f0 4293 d0f5 f5a2 7280 e7f0 4a13
    0000f10 4293 d014 d808 4a12 441a 2a01 d9ea 4811
    0000f20 f007 f99f 2000 bd08 4a0f 4293 d007 f502
    0000f30 7280 4293 d003 f5a2 3200 4293 d1ef 230c
    0000f40 6003 480a bd08 bf00 0da0 4031 0100 0762
    0000f50 0210 0722 0da4 4031 0110 0752 0100 5430
    0000f60 fefe f89d 4e82 4031 0100 5432 0e44 4031
    0000f70 b51f ab04 f803 2d01 2201 9200 f008 ff2c
    0000f80 b005 f85d fb04 0000 b510 b09e 4c49 2100
    0000f90 6823 681b 9106 f8d3 231c f8d3 0350 9201
    0000fa0 f8d3 22dc 9019 9202 f8d3 2238 9203 f8d3
    0000fb0 2274 9204 f8d3 24d4 9205 f8d3 2210 9211
    0000fc0 f8d3 2244 9212 f8d3 2248 9213 f8d3 227c
    0000fd0 9214 f8d3 2414 9215 f8d3 2344 9216 f8d3
    0000fe0 2348 9217 f8d3 234c 9218 f8d3 0354 911d
    0000ff0 9110 901a f8d3 0394 901b f8d3 0398 901c
    0001000 f8d3 0418 9007 f8d3 02e0 9008 f8d3 02e4
    0001010 9009 f8d3 0330 900a f8d3 0410 900b f8d3
    0001020 03b8 900c f8d3 0364 900d f8d3 04d0 900e
    0001030 f8d3 03ac 900f a801 6811 f441 7180 6011
    0001040 f8d3 12e0 680a f042 7280 600a f8d3 12e4
    0001050 680a f042 7280 600a f8d3 12e0 680a f022
    0001060 62c0 600a f8d3 12e4 680a f022 62c0 600a
    0001070 a911 f8d3 2418 6813 f043 7380 6013 aa07
    0001080 2301 f001 f827 6823 681b f8d3 13ac 680a
    0001090 f042 7280 600a f8d3 1438 680a f442 7200
    00010a0 600a f8d3 2438 6813 f443 7380 6013 b01e
    00010b0 bd10 bf00 aaac 4031 b57f 2300 4a0a a801
    00010c0 9301 6812 6812 9305 f8d2 14e0 f8d2 24e4
    00010d0 9103 a903 9204 aa06 f842 3d10 2301 f000
    00010e0 fff9 b007 f85d fb04 aaac 4031 b51f 2300
    00010f0 4a09 4668 9300 6812 6812 9303 f8d2 14e0
    0001100 f8d2 24e4 9101 a901 9202 2201 f001 f844
    0001110 b005 f85d fb04 bf00 aaac 4031 4b20 4a21
    0001120 681b 681b 4293 d019 d81a 4a1f 4293 d034
    0001130 d80a f5a2 7288 4293 d02d f502 7280 4293
    0001140 d02b 481a f007 b88d 4a19 4293 d006 32f0
    0001150 4293 d003 f5a2 7280 4293 d1f2 4b15 e014
    0001160 4a15 4293 d010 d804 4a14 441a 2a01 d8e8
    0001170 e7f4 4a13 4293 d00a f502 7280 4293 d008
    0001180 f5a2 3200 4293 d1dc 4b0e 6003 4770 4b0e
    0001190 e7fb 4b0e e7f9 4b0e e7f7 4b0e e7f5 bf00
    00011a0 0da0 4031 0100 0762 0210 0722 4e9c 4031
    00011b0 0110 0752 1858 4031 0100 5430 fefe f89d
    00011c0 0100 5432 187c 4031 18a0 4031 18c4 4031
    00011d0 1810 4031 1834 4031 4b1b b510 6800 681b
    00011e0 681b f003 437f f1b3 4fa8 bf0b f04f 54f8
    00011f0 f04f 74f8 f04f 5200 f04f 7200 f3bf 8f5f
    0001200 4202 d01e 1422 4020 f012 0ff0 bf06 1622
    0001210 2319 2311 0714 bf04 1112 3304 0794 bf04
    0001220 1092 3302 07d2 680a bf58 3301 3b01 fa20
    0001230 f303 f022 021f f442 6280 4313 2000 600b
    0001240 bd10 f04f 30ff bd10 0da0 4031 f04f 30ff
    0001250 4770 b5f8 4614 6945 f3bf 8f5f 580b f3bf
    0001260 8f5f 0c1e d018 b1ca b29b b2ad fb02 f706
    0001270 435d 4639 4628 f00f ee5e 200a 4348 0071
    0001280 4361 f00f ede6 4639 4604 4628 f00f ede0
    0001290 eb00 0080 4420 bdf8 4630 bdf8 4610 bdf8
    00012a0 b508 6943 f3bf 8f5f 0c1b 041b f443 733b
    00012b0 f043 0303 f3bf 8f5f 6143 f100 020c 68c3
    00012c0 2100 f043 0301 60c3 2001 4b03 f001 ff45
    00012d0 fab0 f080 0940 bd08 4240 000f b508 f100
    00012e0 020c 68c3 2100 f043 0302 60c3 2002 4b04
    00012f0 f001 ff33 2800 bf0c 2008 2000 bd08 bf00
    0001300 4240 000f b538 4604 b170 4b23 681b 681a
    0001310 f8d2 108c 680b f043 6380 600b f8d2 208c
    0001320 6813 f043 6300 6013 4d1c 682b 681a f8d2
    0001330 144c 680b f043 0301 600b 2102 4b18 4608
    0001340 f8d2 244c f001 ff09 b910 2002 40a0 bd38
    0001350 4b11 681b 681a f8d2 11c0 680b f023 0304
    0001360 ea43 0384 600b f8d2 31c0 681b f3bf 8f5f
    0001370 682b 2002 681a f8d2 144c 680b f023 0301
    0001380 600b 2100 4b06 f8d2 244c f001 fee6 2800
    0001390 d0db 2000 bd38 bf00 aa40 4031 aaac 4031
    00013a0 4240 000f e92d 4df3 460d 9000 4692 b91a
    00013b0 2000 b002 e8bd 8df0 4c37 2258 2118 6823
    00013c0 681b f8d3 01bc f7ff ff44 4606 2800 d05f
    00013d0 6823 f44f 7284 211c 681b f8d3 01bc f7ff
    00013e0 ff38 4680 2800 d055 3506 f04f 0b00 45d3
    00013f0 d0de f835 2c02 4b29 f835 7c04 9201 08d0
    0001400 fba0 0103 4638 f3c1 048f 4631 f00f ecd2
    0001410 4631 4404 4638 f00f ed82 230a fb03 f001
    0001420 4641 f00f ecc8 9a01 4607 f44f 7166 4610
    0001430 f00f ed74 4b1a b289 fb81 0103 4b19 440f
    0001440 fba7 0103 08c8 2816 d910 fb00 f008 4631
    0001450 fb04 0706 4638 f00f ecae 4631 4604 4638
    0001460 f00f ed5c 4608 4641 f00f eca4 0164 f000
    0001470 001f f440 3025 f404 7478 4320 f3bf 8f5f
    0001480 f835 2c06 f10b 0b01 9b00 3506 50d0 e7ae
    0001490 2003 e78e 2005 e78c aa40 4031 8357 08e7
    00014a0 aaab 2aaa cccd cccc b510 f3bf 8f5f f64a
    00014b0 21aa 4c0c 6823 681b f8d3 21bc 62d1 f8d3
    00014c0 01bc f7ff feed b958 2001 f7ff ff1b b938
    00014d0 6823 e8bd 4010 681b f8d3 01bc f7ff befe
    00014e0 bd10 bf00 aa40 4031 b508 4603 b910 f7ff
    00014f0 ff09 4603 f3bf 8f5f 4a11 f64a 21ab 3301
    0001500 6812 6812 f8d2 21bc 62d1 2b09 d817 e8df
    0001510 f003 1614 0e05 0a10 1612 0c16 4809 e8bd
    0001520 4008 f004 b909 4808 e7f9 4808 e7f7 4808
    0001530 e7f5 4808 e7f3 4808 e7f1 4808 e7ef bd08
    0001540 aa40 4031 4fe9 4031 5018 4031 5041 4031
    0001550 5084 4031 50b0 4031 50d2 4031 50f4 4031
    0001560 e92d 41f0 4607 4688 4615 461e f3bf 8f5f
    0001570 4c16 f64a 21aa 6823 681b f8d3 21bc 62d1
    0001580 f8d3 01bc f7ff fe8c b9a0 6823 681b f8d3
    0001590 01bc f7ff fea3 6823 4642 4639 681b 6e18
    00015a0 f7fe ff8e 6823 4632 4629 681b f8d3 01bc
    00015b0 f7ff fef8 f3bf 8f5f 6823 f64a 22ab 681b
    00015c0 f8d3 31bc 62da e8bd 81f0 bf00 aa40 4031
    00015d0 e92d 45f7 461f 4b63 681b 6819 0d09 0509
    00015e0 f1b1 6fec d004 4860 f004 f8a6 2501 e003
    00015f0 2a04 d005 f04f 35ff 4628 b003 e8bd 85f0
    0001600 2208 495a 6878 f006 f8bb 4605 2800 d1f1
    0001610 f04f 4698 f8d6 3110 f3bf 8f5f 2b00 f280
    0001620 809e 00db f140 809b 4601 2210 68b8 f006
    0001630 fe63 4629 4604 2210 68f8 f006 fe5d f8d6
    0001640 1110 4607 f3bf 8f5f 07cb d508 f8d6 3114
    0001650 f3bf 8f5f 041a f102 4200 4294 d203 078e
    0001660 d45d 4843 e7c0 ea6f 4313 ea6f 4303 4413
    0001670 429c d8f4 f04f 4698 f8d6 a110 f3bf 8f5f
    0001680 f001 ff1f f001 fcef 483a f004 f855 483a
    0001690 f004 f852 f3bf 8f5f f04f 0800 f8c6 8110
    00016a0 6822 f3bf 8f5f ea87 0302 f3bf 8f5f 6023
    00016b0 6821 f3bf 8f5f 4831 9101 4621 9700 f006
    00016c0 fdd0 482f f004 f838 f3bf 8f5f f8c6 a110
    00016d0 6822 f3bf 8f5f 482b 4621 f006 fdc2 f8d6
    00016e0 7130 f3bf 8f5f f8d6 60a4 f3bf 8f5f 4826
    00016f0 f004 f92a 4604 b120 4642 4641 f006 fe34
    0001700 4604 4822 f004 f818 0730 d502 4820 f004
    0001710 f813 06f1 d516 b9ac 481e f006 fde2 f04f
    0001720 4398 f8d3 3118 f3bf 8f5f 041a f102 4200
    0001730 4294 d396 ea6f 4313 ea6f 4303 4413 429c
    0001740 d88f e797 06b2 d502 4813 f003 fff5 b11f
    0001750 4639 4812 f006 fd85 f001 fb28 e74c 4810
    0001760 e742 bf00 0da0 4031 5112 4031 514f 4031
    0001770 5244 4031 527a 4031 528c 4031 52ae 4031
    0001780 5316 4031 5337 4031 535d 4031 5157 4031
    0001790 5169 4031 5195 4031 51c0 4031 51ec 4031
    00017a0 5212 4031 f3bf 8f5f 4b03 2000 6418 f3bf
    00017b0 8f5f 222b 639a 4770 2000 4803 f640 13c4
    00017c0 4358 4b09 fba0 0103 098b 4908 6bca f3bf
    00017d0 8f5f 2b00 dc00 4770 6bc8 f3bf 8f5f 1a1b
    00017e0 4413 4602 e7f5 bf00 4dd3 1062 2000 4803
    00017f0 4b11 b510 6bda f3bf 8f5f 4b10 fba2 2303
    0001800 f8d9 20b4 0ad9 464b 4291 d30c f8d9 00b4
    0001810 f8d9 20b0 440a 1a12 f8c3 20b0 f8c3 10b4
    0001820 f8d3 00b0 bd10 f8d9 40b4 f8d9 00b0 4a04
    0001830 4408 4402 1b12 e7ef 2000 4803 1759 d1b7
    0001840 36e2 001a b510 4604 f7ff ffd2 1b00 bd10
    0001850 ee10 0f10 4770 4770 6b43 f3bf 8f5f 2b00
    0001860 d1fa 4770 b508 f3bf 8f5f f64a 23aa 4a05
    0001870 6493 4610 f7ff fff0 f3bf 8f5f f245 5355
    0001880 6493 bd08 4000 4ae1 b508 f7ff f903 f001
    0001890 fead f7ff f99f f7ff f9df b108 f000 fe48
    00018a0 f7ff ffe0 f001 fee2 f7fe ffa0 f7fe fe18
    00018b0 f000 fcaa f001 faaa f002 fa00 f001 fe60
    00018c0 f001 fe6e e8bd 4008 f000 bcd8 4b3a e92d
    00018d0 4df0 b088 2400 f04f 0e01 46a3 4621 9303
    00018e0 2300 469a 4618 e9cd 3404 e9cd 3406 9b03
    00018f0 f8d3 c000 2300 f00c 427f f112 4600 f143
    0001900 37ff 4634 4e2d 463d 2700 42af bf08 42a6
    0001910 d32d f3cc 5802 f3cc 4c01 fa0e f808 f1bc
    0001920 0f02 4644 ea4f 75e4 ea4f 6605 ea46 2618
    0001930 9601 ea4f 6608 9600 d033 ea50 0401 d003
    0001940 428b bf08 4282 d201 4610 4619 ea5a 040b
    0001950 d007 e9dd 6700 18b6 415f 45bb bf08 45b2
    0001960 d205 e9dd ab00 eb1a 0a02 eb4b 0b03 9b03
    0001970 3304 461a 9303 4b12 429a d1b8 e9dd 3404
    0001980 428c bf08 4283 d313 455c bf08 4553 d20f
    0001990 e9dd 3406 ebba 0000 1ac3 4618 b008 e8bd
    00019a0 8df0 e9cd 2304 e9dd 3400 e9cd 3406 e7de
    00019b0 ebba 0000 e7f2 bf00 0040 4e00 fffe 7fff
    00019c0 0050 4e00 b510 f7ff ff5f f001 ff97 f001
    00019d0 f913 464c f7ff ff7a 6320 bd10 4b04 681b
    00019e0 681b 681b 6818 f3bf 8f5f f3c0 1082 4770
    00019f0 aa40 4031 4b1e e92d 41f3 681c 6821 f3c1
    0001a00 2703 f3c1 1803 0f0a 0c0e f7ff ffe7 2803
    0001a10 bf96 4b18 4d18 f853 5020 6823 0d1b 051b
    0001a20 f1b3 6fec d11a 4b15 f001 010f 4c14 2902
    0001a30 bf18 461c b1a2 4813 f006 fc13 f8cd 8000
    0001a40 463b 462a 4631 4810 f006 fc0b b154 4621
    0001a50 480e b002 e8bd 41f0 f006 bc03 2400 e7e9
    0001a60 480b e7e9 480b b002 e8bd 41f0 f003 be64
    0001a70 0da0 4031 1ba4 4031 5366 4031 536c 4031
    0001a80 5368 4031 5370 4031 5379 4031 5387 4031
    0001a90 5375 4031 a5d5 4031 f7ff bfac 4b0a 681b
    0001aa0 681a 4b0a 429a d00c 4b09 681b 681b f8d3
    0001ab0 33fc 6818 f3bf 8f5f f000 0007 3801 b240
    0001ac0 4770 2006 4770 bf00 0da0 4031 0100 4430
    0001ad0 aaac 4031 b508 f7ff ffe1 b2c0 4b01 f853
    0001ae0 0020 bd08 1bb4 4031 f991 3008 2b00 db02
    0001af0 f3bf 8f5f 6103 f991 3009 2b00 db02 f3bf
    0001b00 8f5f 6143 f991 300a 2b00 db02 f3bf 8f5f
    0001b10 6183 f991 300b 2b00 db02 f3bf 8f5f 61c3
    0001b20 f991 300c 2b00 db02 f3bf 8f5f 6203 f991
    0001b30 300d 2b00 db02 f3bf 8f5f 6243 f991 300e
    0001b40 2b00 db02 f3bf 8f5f 6303 f991 300f 2b00
    0001b50 db02 f3bf 8f5f 6343 f991 3010 2b00 db02
    0001b60 f3bf 8f5f 6383 f991 3011 2b00 db02 f3bf
    0001b70 8f5f 63c3 4770 b510 4604 f7ff ff8f 2214
    0001b80 6823 fb02 3000 bd10 b510 4604 f7ff ff86
    0001b90 2214 6863 fb02 3000 bd10 b510 4604 f7ff
    0001ba0 ff7d 2214 68a3 fb02 3000 bd10 b510 4604
    0001bb0 f7ff ff74 2214 6963 fb02 3000 bd10 b510
    0001bc0 460c 6849 3801 6823 4408 1ac0 f00f e8f2
    0001bd0 68a3 4418 bd10 0000 b570 4605 4614 460e
    0001be0 2900 d02e 6993 4798 6923 b163 4915 68e0
    0001bf0 f008 fdb1 1e03 da06 68e2 4913 4813 e8bd
    0001c00 4070 f006 bb2e 6923 b11b 2100 68e0 f008
    0001c10 fdd7 f44f 707a 4621 4370 f7ff ffd0 69e3
    0001c20 b2c2 b2e9 7d20 4798 b118 4629 4808 f006
    0001c30 fb18 6923 b12b 68e0 2101 e8bd 4070 f008
    0001c40 bdbf bd70 53e8 4031 5394 4031 53f2 4031
    0001c50 5411 4031 e92d 4dff 2700 4604 4605 46b8
    0001c60 4638 f001 fc87 f855 3020 eb05 0680 2b00
    0001c70 f040 80bc 3701 3530 2f06 d1f1 2001 4f7d
    0001c80 f001 fc78 300c 6da2 f854 1020 2501 6c20
    0001c90 f7ff ffa2 f001 fcf6 2000 4e77 f001 fc6a
    0001ca0 6aa2 eb04 0880 f854 1020 6920 f7ff ff94
    0001cb0 683b 681a 6833 6819 6ae3 9502 9301 f8d2
    0001cc0 3318 9300 f8d2 3460 f8d1 1148 f8d2 245c
    0001cd0 f8d8 0014 f001 f820 2002 f001 fc4b eb04
    0001ce0 0880 f8d4 2088 6f20 f8d8 1060 f7ff ff74
    0001cf0 683b 681a 6833 6819 f8d4 308c 9502 9301
    0001d00 f8d2 3314 9300 f8d2 3468 f8d1 114c f8d2
    0001d10 2464 f8d8 0074 f000 ffff 2003 f001 fc2a
    0001d20 eb04 0880 f8d4 20b8 f8d4 00a0 f8d8 1090
    0001d30 f7ff ff52 683b 681a 6833 6819 f8d4 30bc
    0001d40 9502 9301 f8d2 3314 9300 f8d2 3480 f8d1
    0001d50 1158 f8d2 247c f8d8 00a4 f000 ffdd 2004
    0001d60 f001 fc08 eb04 0880 f8d4 20e8 f8d4 00d0
    0001d70 f8d8 10c0 f7ff ff30 683b 681a 6833 6819
    0001d80 f8d4 30ec 9502 9301 f8d2 3314 9300 f8d2
    0001d90 3478 f8d1 1154 f8d2 2474 f8d8 00d4 f000
    0001da0 ffbb 2005 f001 fbe6 eb04 0880 f8d4 2118
    0001db0 f8d4 0100 f8d8 10f0 f7ff ff0e 683b 681a
    0001dc0 6833 6819 f8d4 311c 9502 9301 f8d2 3314
    0001dd0 9300 f8d2 3470 f8d1 1150 f8d2 246c f8d8
    0001de0 0104 f000 ff99 b004 e8bd 8df0 6971 b149
    0001df0 f895 2024 2a10 d02c 2a20 d038 481f f006
    0001e00 fa30 6833 46a2 f04f 0b00 6033 45aa f4bf
    0001e10 af31 4658 f001 fbae f85a 1020 eb0a 0e80
    0001e20 b191 6aaa f8da 3028 6952 695b 429a d10b
    0001e30 692a f8da 3010 429a d106 6833 4299 bf38
    0001e40 f8ce 3000 f8c6 8000 f10a 0a30 f10b 0b01
    0001e50 e7dc 880b b29b f3bf 8f5f 2b00 d1d2 6833
    0001e60 f895 2024 6971 4806 f006 f9fb e7c9 680b
    0001e70 e7f1 bf00 aaac 4031 aa40 4031 5497 4031
    0001e80 54bc 4031 4b3c b570 4c3c 681b 681d 4b3c
    0001e90 681b 6818 f7ff fe78 6823 4606 681a f8d2
    0001ea0 1238 680b f023 0303 f043 0302 600b 4b35
    0001eb0 f8d2 1244 680a f3bf 8f5f 3b01 d12b 4832
    0001ec0 f006 f9cf 6823 681b f8d3 1248 4b2d 680a
    0001ed0 f3bf 8f5f 3b01 d121 482b f006 f9c2 f996
    0001ee0 3008 02db b29b f443 63e1 f043 0301 f3bf
    0001ef0 8f5f 6822 2001 6812 f8d2 10dc 600b 2100
    0001f00 4b20 f8d2 20dc f001 f928 b950 481f f003
    0001f10 fc13 f005 f83f 03d0 d4cc e7d3 03d2 d4d6
    0001f20 e7dd 4b1b 429d d026 6823 681a f8d2 1238
    0001f30 680b f043 0303 600b 4b12 f8d2 1244 680a
    0001f40 f3bf 8f5f 3b01 d111 480f f006 f98a 6823
    0001f50 681b f8d3 1248 4b0b 680a f3bf 8f5f 3b01
    0001f60 d107 4809 e8bd 4070 f006 b97b 03d0 d4e6
    0001f70 e7ed 03d2 d4f0 bd70 0da0 4031 aaac 4031
    0001f80 aa44 4031 4240 000f 544e 4031 5478 4031
    0001f90 0100 5430 6803 4602 b510 2100 4604 2001
    0001fa0 f023 0307 f043 0306 f842 3b04 4b05 f001
    0001fb0 f8d4 b928 4621 4804 e8bd 4010 f006 b951
    0001fc0 bd10 bf00 4240 000f 53a3 4031 b5f8 4604
    0001fd0 4616 460d 2900 d03c 68c7 f3bf 8f5f 6843
    0001fe0 f3bf 8f5f 07db d522 680a f3c7 230a 4293
    0001ff0 d11d 684a f007 037f 4293 d118 f7ff ffca
    0002000 4629 4620 f7ff fd70 b31e 6823 4622 2101
    0002010 4608 f043 0307 f842 3b04 4b0e f001 f89d
    0002020 b9b8 4621 480c f006 f91c f004 ffb3 4620
    0002030 f7ff ffb0 682b 4a09 ea02 2203 4b08 403b
    0002040 431a 686b f003 037f 4313 f3bf 8f5f 60e3
    0002050 e7d6 bdf8 4240 000f 5432 4031 ff00 0007
    0002060 0080 fff8 b538 4b17 4c17 681b 681a 4b17
    0002070 4413 f1b3 6f7d d217 6823 681b 6d1d 4628
    0002080 f7ff ff88 6823 681a f8d2 10e4 680b f023
    0002090 7340 600b f8d2 20e4 6813 f043 6380 6013
    00020a0 68eb f423 0380 60eb 4b09 681b 6818 f7ff
    00020b0 fd62 6823 4601 2201 681b 6d18 e8bd 4038
    00020c0 f7ff bf84 0da0 4031 aaac 4031 ff00 bb9f
    00020d0 aa44 4031 e92d 4df0 1f05 f500 74c6 4616
    00020e0 4698 4628 f850 2f04 b13a 6813 42a0 f023
    00020f0 0303 f043 0302 6013 d1f4 f8df b098 f1a1
    0002100 0a04 f501 77c6 f85a 1f04 b199 680b f023
    0002110 0303 f043 0301 600b f1b8 0f00 d008 4b1c
    0002120 680a f3bf 8f5f 3b01 d12b 4658 f006 f899
    0002130 4557 d1e8 f8df a05c 1f37 f506 76c6 f857
    0002140 1f04 b199 680b f023 0303 f043 0302 600b
    0002150 f1b8 0f00 d008 4b0e 680a f3bf 8f5f 3b01
    0002160 d112 4650 f006 f87d 42be d1e8 f855 3f04
    0002170 b12b 681a 42a5 f042 0203 601a d1f6 e8bd
    0002180 8df0 03d0 d4cc e7d3 03d2 d4e5 e7ec bf00
    0002190 4240 000f 544e 4031 e92d 41f0 4604 f8df
    00021a0 8064 4617 1f0e f501 75c6 f856 1f04 b189
    00021b0 680b f023 0303 600b b157 4b11 680a f3bf
    00021c0 8f5f 3b01 f3c2 4001 d10c 4640 f006 f849
    00021d0 42ae d1ea 1f21 f504 74c6 f851 2f04 b922
    00021e0 e8bd 81f0 2803 d1e9 e7f2 6813 428c f023
    00021f0 0303 f043 0301 6013 d1ef e8bd 81f0 bf00
    0002200 4240 000f 53bd 4031 b508 4b1b 681b 681b
    0002210 f8d3 131c 680a f022 0203 f042 0202 600a
    0002220 f8d3 13b0 680a f022 0203 f042 0202 600a
    0002230 f8d3 13b4 680a f022 0203 f042 0202 600a
    0002240 f8d3 13b8 680a f022 0203 f042 0202 600a
    0002250 f8d3 13bc 680a f022 0203 f042 0202 600a
    0002260 f8d3 231c 6813 f043 0303 6013 f7fe fe8c
    0002270 e8bd 4008 f7ff ba96 aaac 4031 e92d 45f8
    0002280 4b3e 4d3f 681b 6818 f7ff fce4 682b 6818
    0002290 f7ff fc7a f04f 4398 4601 689b f3bf 8f5f
    00022a0 4c38 0f5b 2b04 6823 bf0c 2200 2201 681b
    00022b0 68d8 f7ff fe8b f3bf 8f5f 6823 f44f 7288
    00022c0 681b 681b 601a 682b 6818 f7ff fc66 6823
    00022d0 4601 2201 681b f8d3 015c f7ff fe77 f7ff
    00022e0 fec1 f7ff fbf7 682b 4606 6818 f7ff fc5e
    00022f0 4925 4607 6843 4a25 fb03 1101 fba6 2302
    0002300 0998 683b fb03 1000 6823 f8d3 8000 3801
    0002310 f00e ed50 f8d8 a19c 4639 2201 f8da 6000
    0002320 f026 467f ea46 6600 f8ca 6000 f8d8 0190
    0002330 f7ff fe4c 682b 681e f7ff fbb0 69b1 b111
    0002340 2314 fb03 1100 6823 2201 681b f8d3 00b4
    0002350 f7ff fe3c 682b 681d f7ff fba0 69e9 b111
    0002360 2314 fb03 1100 6823 2201 681b f8d3 00e0
    0002370 f7ff fe2c e8bd 45f8 f7fe bc8a aaa8 4031
    0002380 aa44 4031 aaac 4031 d090 0003 4dd3 1062
    0002390 b510 4c05 6823 b12b 2101 4804 f007 fd36
    00023a0 2300 6023 bd10 bf00 aad0 4031 86a0 0001
    00023b0 b573 4604 a801 460d 07ed f7fe fcd1 4b2e
    00023c0 482e 6819 f3bf 8f5f 6525 680b 4283 bf0c
    00023d0 6ca3 6c23 f3bf 8f5f ea83 2213 ea83 4613
    00023e0 4332 f012 0fff d104 0e1e b2da 4296 bf08
    00023f0 4613 07db d4e6 9b01 f993 2003 f045 030a
    0002400 f3bf 8f5f 6523 f3bf 8f5f f44f 60fa 6422
    0002410 f000 fea0 9b01 f993 2000 f045 0301 f3bf
    0002420 8f5f 6523 f3bf 8f5f 9b01 6422 f993 2004
    0002430 f045 0310 f3bf 8f5f 6523 f3bf 8f5f 9b01
    0002440 6422 f993 2001 f045 4380 f043 0302 f3bf
    0002450 8f5f 6523 f3bf 8f5f 9b01 6422 f993 3002
    0002460 2b00 dd07 f045 0503 f3bf 8f5f 6525 f3bf
    0002470 8f5f 6423 b002 bd70 0da0 4031 0200 4430
    0002480 4b22 e92d 45f7 4604 f500 7600 f06f 4860
    0002490 681b 681b f003 437f f1b3 6fe0 bf14 f500
    00024a0 75a2 f500 75a4 a801 f7fe fd10 4918 f06f
    00024b0 4c40 680b 681b f8d3 2238 2300 6817 6013
    00024c0 f8dd e004 4573 f100 0008 d10c f3bf 8f5f
    00024d0 2300 f8c4 30d8 680b 681b f8d3 3238 601f
    00024e0 b003 e8bd 85f0 f850 2c08 3301 4462 f855
    00024f0 a022 f850 2c04 4442 f846 a032 f850 2c04
    0002500 00d2 3a04 f846 a002 e7dc bf00 0da0 4031
    0002510 aaac 4031 6b83 f3bf 8f5f f423 63fe f443
    0002520 7300 f3bf 8f5f 6383 6b83 f3bf 8f5f 4770
    0002530 b508 f04f 4098 f7ff ffed 4b07 681b 681b
    0002540 0d1b 051b f1b3 6fe4 d005 f04f 409a e8bd
    0002550 4008 f7ff bfdf bd08 0da0 4031 6e03 f3bf
    0002560 8f5f f443 6380 f3bf 8f5f 6603 4770 0000
    0002570 4b2d b510 681a 6812 f002 427f f1b2 6fe0
    0002580 bf14 690a 694a f3bf 8f5f 6142 698a f3bf
    0002590 8f5f 61c2 69ca f3bf 8f5f 6242 6a0a f3bf
    00025a0 8f5f 62c2 681a 6814 4a20 4294 d127 f3bf
    00025b0 8f5f 2200 6382 6a8a f3bf 8f5f f8c0 209c
    00025c0 6aca f3bf 8f5f f8c0 20c8 6b0a f3bf 8f5f
    00025d0 f8c0 20cc 6b8a f3bf 8f5f 681b f8c0 20e8
    00025e0 4a13 681b 4293 d804 f003 427f f1b2 6fe0
    00025f0 d110 f3bf 8f5f f04f 6325 6543 bd10 f3bf
    0002600 8f5f f24f 22f0 6382 f3bf 8f5f f24f 02f0
    0002610 63c2 e7d0 4a07 4293 f3bf 8f5f bf8c f04f
    0002620 6323 4b05 e7e9 bf00 0da0 4031 0100 4430
    0002630 00ff 5430 00ff 4460 00ff 0a00 b5f0 4604
    0002640 b085 467d f1b0 4f98 a903 bf0c 2001 2002
    0002650 f000 ff56 9b03 f105 4500 2b00 d043 4b5b
    0002660 429d d93c f7fe faf8 b138 4b59 681b 681b
    0002670 f003 437f f1b3 6fe0 d131 9d03 68ab 0f5b
    0002680 2b04 d132 68e3 f023 4380 60e3 6923 f043
    0002690 4300 6123 686b f3bf 8f5f 60a3 6b6b f3bf
    00026a0 8f5f f8c4 30e4 4629 4620 f7fe fb5f 2100
    00026b0 4620 f7ff fe7d 68ab 071b d503 2101 4620
    00026c0 f7ff fe76 68ab f3bf 8f5f 60a3 6bab f3bf
    00026d0 8f5f f8c4 30e4 6923 f023 4300 6123 9903
    00026e0 4620 f7ff ff45 b005 bdf0 4e39 6833 681b
    00026f0 f003 437f f1b3 4fa8 d16e 692b f3bf 8f5f
    0002700 6123 686b f3bf 8f5f 60a3 6b6b f3bf 8f5f
    0002710 f8c4 30e4 69ab f3bf 8f5f 61a3 69eb f3bf
    0002720 8f5f 6223 6a2b f3bf 8f5f 62a3 6aab f3bf
    0002730 8f5f f8c4 3098 68eb f3bf 8f5f 60e3 686b
    0002740 f3bf 8f5f 60a3 4629 4620 f7fe fb0f 6d6b
    0002750 f3bf 8f5f f8c4 30d8 f3bf 8f5f f44f 7300
    0002760 2082 63a3 f7ff f82a 6bab f3bf 8f5f f8c4
    0002770 30e4 6bab f3bf 8f5f 2082 f8c4 30e8 f7ff
    0002780 f81d f3bf 8f5f 2300 63a3 f3bf 8f5f f04f
    0002790 4300 f8c4 30dc f8d4 30dc f3bf 8f5f 2082
    00027a0 f7ff f80c 4620 f7fe f949 f3bf 8f5f 2302
    00027b0 2082 f8c4 30dc f7ff f801 f3bf 8f5f 4b05
    00027c0 2082 f8c4 30dc f7fe fff9 e788 fffe 7fff
    00027d0 0da0 4031 5973 0033 f7fe fa3e b130 4620
    00027e0 f7ff febc f3bf 8f5f 2300 63a3 4629 4620
    00027f0 f7fe fabc 692b f043 4300 f3bf 8f5f 6123
    0002800 69ab f3bf 8f5f 61a3 69eb f3bf 8f5f 6223
    0002810 6a2b f3bf 8f5f 62a3 f3bf 8f5f f04f 6325
    0002820 6563 6aab f3bf 8f5f f8c4 3098 6aeb f3bf
    0002830 8f5f f8c4 30c8 6b2b f3bf 8f5f f8c4 30cc
    0002840 6d6b f3bf 8f5f f8c4 30d8 6dab f3bf 8f5f
    0002850 f8c4 30dc 6b6b f3bf 8f5f f8c4 30e4 6deb
    0002860 f3bf 8f5f f8c4 3120 692b f3bf 8f5f 6123
    0002870 68eb f3bf 8f5f 60e3 686b f3bf 8f5f f44f
    0002880 707a 60a3 f7fe ff9a 696b f3bf 8f5f 6123
    0002890 6d6b 2b00 da53 6833 681b 0d1b 051b f1b3
    00028a0 6fec d114 f1b4 4f98 d111 6f2b 2b00 da0e
    00028b0 f3bf 8f5f 2300 f8c4 3114 f3bf 8f5f f8c4
    00028c0 3118 f3bf 8f5f f04f 4300 f8c4 3110 f8d4
    00028d0 3318 f443 7380 f8c4 3318 f8d4 331c f443
    00028e0 7380 f8c4 331c 6923 f043 4300 6123 f3bf
    00028f0 8f5f f04f 4300 f44f 7096 f8c4 30dc f7fe
    0002900 ff5d 6863 f3bf 8f5f f013 0f70 d07d f1b4
    0002910 4f98 d078 f1b4 4f9a bf0c 2102 2100 486d
    0002920 f005 fc9f 6833 681b 0d1b 051b f1b3 6fec
    0002930 f47f aed5 f3bf 8f5f 2300 f8c4 3110 f1b4
    0002940 4f98 f47f aecc 6833 681b 0d1b 051b f1b3
    0002950 6fec f47f aec4 6f2b 2b00 f6bf aec0 6f6b
    0002960 f3bf 8f5f f8c4 3114 6fab f3bf 8f5f f8c4
    0002970 3118 6f2b f3bf 8f5f f8c4 3110 6f2b 07da
    0002980 d511 6f6e f7fe fb98 2101 4853 0c33 0432
    0002990 041b f102 4200 f503 3380 9300 2300 f00c
    00029a0 f9c9 f7fe fba3 6f2b 079b d511 6fad f7fe
    00029b0 fb83 2101 4848 0c2b 042a 041b f102 4200
    00029c0 f503 3380 9300 2300 f00c f9b4 f7fe fb8e
    00029d0 f04f 4398 f8d3 2130 f3bf 8f5f f3bf 8f5f
    00029e0 f8c3 2130 f3bf 8f5f f04f 32ff f8c3 2138
    00029f0 f3bf 8f5f 2201 f8c3 2140 f3bf 8f5f 2238
    0002a00 f8c3 20ac e66b 2101 e789 6923 f023 4300
    0002a10 6123 f8d4 20e4 f3bf 8f5f 0117 d513 0150
    0002a20 d529 0191 d53f 6bab f3bf 8f5f f8c4 30e4
    0002a30 6bab f3bf 8f5f f8c4 30e8 f3bf 8f5f 2300
    0002a40 f8c4 30d8 e76e f504 73ae f504 710c f504
    0002a50 77b8 f103 0e04 681b f3bf 8f5f f3bf 8f5f
    0002a60 4608 f840 3b08 f3bf 8f5f 45be 604b 4673
    0002a70 4601 d1ee e7d3 f504 7102 f504 73b8 f504
    0002a80 77c2 f103 0e04 681b f3bf 8f5f f3bf 8f5f
    0002a90 4608 f840 3b08 f3bf 8f5f 45be 604b 4673
    0002aa0 4601 d1ee e7bd f504 7216 f504 73c2 f504
    0002ab0 70d6 1d1f 681b f3bf 8f5f f3bf 8f5f 4611
    0002ac0 f841 3b08 f3bf 8f5f 4287 6053 463b 460a
    0002ad0 d1ef e7a8 54e9 4031 0000 4330 4b08 4909
    0002ae0 681b 681b 428b d101 f7ff bd38 4906 428b
    0002af0 d104 f3bf 8f5f f04f 4300 6383 4770 bf00
    0002b00 0da0 4031 0200 4430 0100 4430 b5f7 4604
    0002b10 a801 f000 fcd9 f3bf 8f5f 2300 60e3 f3bf
    0002b20 8f5f 60a3 f3bf 8f5f 6063 f3bf 8f5f 6023
    0002b30 9b01 68db f3bf 8f5f 60e3 9b01 689b f3bf
    0002b40 8f5f 60a3 9b01 685b f3bf 8f5f 6063 9b01
    0002b50 681b f3bf 8f5f 6023 9b01 7c1a b1c2 68da
    0002b60 f3bf 8f5f 4b1e 60da 9a01 6892 f3bf 8f5f
    0002b70 609a 9a01 6852 f3bf 8f5f 605a 9a01 6812
    0002b80 f3bf 8f5f 601a 4a17 6813 f443 7380 6013
    0002b90 4c15 2300 f8df e05c 461e 4814 461d 4914
    0002ba0 461f 6003 600b 6822 f3c2 2201 2a03 d104
    0002bb0 2301 6003 600b b003 bdf0 2a01 d00c 2a02
    0002bc0 d101 2301 461e 3404 4574 d1ec b105 6007
    0002bd0 2b00 d0f0 600e e7ee 4615 4617 e7f3 bf00
    0002be0 f040 482a 2000 482a 0040 4e00 aad4 4031
    0002bf0 aad8 4031 0050 4e00 b5f8 f04f 4398 689c
    0002c00 0f64 467f 4b3d f107 4700 429f d90d 2c04
    0002c10 d12e f7fe f821 b928 4b39 681b 681b 68d8
    0002c20 f7ff f9b8 4837 f7ff ff71 4d37 682b b11b
    0002c30 f04f 4098 f7ff fd02 4e34 6833 b11b f04f
    0002c40 409a f7ff fcfb 4b2d 429f d91c f7fe f804
    0002c50 b958 682b b11b f04f 4098 f7ff ff3f 6833
    0002c60 b11b f04f 409a f7ff ff39 2c04 d112 e00c
    0002c70 2c03 d1d7 f3bf 8f5f 4b21 2200 681b 681b
    0002c80 689b 601a e7ce 2c04 d119 f7ff f8fb 4b1b
    0002c90 429f d914 f7fe fe1a f04f 32ff b980 2701
    0002ca0 f04f 4000 4097 4639 f002 fda5 4287 4601
    0002cb0 d003 463a 4816 f005 fad4 2c03 d003 bdf8
    0002cc0 3201 0840 e7ea f7fd ffc7 2800 d1f7 4b11
    0002cd0 681b 681b f003 437f f1b3 6fe0 d0ef 682b
    0002ce0 b11b f04f 4098 f7ff fbcb 6833 2b00 d0e6
    0002cf0 f04f 409a e8bd 40f8 f7ff bbc2 fffe 7fff
    0002d00 aaac 4031 0040 4e00 aad4 4031 aad8 4031
    0002d10 5505 4031 0da0 4031 e92d 45f8 ac08 4698
    0002d20 4616 ccb0 b38a b383 b37c 2f01 d02f 2f03
    0002d30 d12b 2702 46ba bb68 f3bf 8f5f 2300 6033
    0002d40 f3bf 8f5f f8c8 3000 4629 6833 4628 f443
    0002d50 537c 6033 6822 432a 6022 6833 f043 0301
    0002d60 ea43 030a 6033 f8d8 2000 4b0e f042 0204
    0002d70 4317 4622 f8c8 7000 f000 f9ef b910 480a
    0002d80 f002 fcda 6823 431d 6025 e8bd 85f8 f04f
    0002d90 0a04 e7d0 2900 d0cf f7fe fa1e 2800 d0cb
    0002da0 e8bd 85f8 4240 000f 5553 4031 f000 bb86
    0002db0 b538 f8d9 3000 eb03 00c0 6c84 6cc5 0d64
    0002dc0 eb04 5555 42a5 d800 bd38 4620 220d 2300
    0002dd0 3401 f000 fac0 e7f5 b538 0d44 eb04 5551
    0002de0 42a5 d200 bd38 4620 220d 2300 3401 f000
    0002df0 fab2 e7f5 ee13 3f10 f023 0303 f043 0301
    0002e00 ee03 3f10 f3bf 8f6f 4770 0000 4b20 b510
    0002e10 681c f104 433f f503 0350 f5b3 2f00 d830
    0002e20 7a20 280b d02e 2843 d001 2845 d12d f7fd
    0002e30 fb31 1f43 2b02 bf8c 2300 2301 f8c9 00c8
    0002e40 464a 7a21 4288 d117 3805 2802 d814 6861
    0002e50 f101 433f f503 0350 f5b3 2f00 d811 6989
    0002e60 f101 433f f503 0350 f5b3 2f00 d809 688b
    0002e70 1e59 2902 bf28 2303 f8c2 30cc 7aa3 f882
    0002e80 30d0 bd10 2300 200a e7d8 2300 e7d6 bf00
    0002e90 bc24 4037 f8d9 00c8 4770 f8d9 00cc 4770
    0002ea0 b508 f000 ffcd 2101 4802 e8bd 4008 f006
    0002eb0 bfad bf00 86a0 0001 4a02 b508 68c3 6810
    0002ec0 4798 bf00 bc24 4037 f05f f57f 0f30 ee30
    0002ed0 3ba0 e1a0 300e e213 001c 0a00 a000 e3a0
    0002ee0 20aa e08a 1230 e1a0 1007 e201 0002 e351
    0002ef0 0013 ba00 af10 ee40 f06f f57f 1f10 ee30
    0002f00 2007 e201 2004 e282 43ff e300 41a1 e014
    0002f10 5f14 e16f 7fff e307 76a1 e017 9007 e1a0
    0002f20 6514 e1a0 b006 e18a 6219 e1a0 b006 e18b
    0002f30 bf5e ee07 9001 e259 fff8 aaff 4001 e254
    0002f40 fff5 aaff a002 e28a 000a e153 ffe3 caff
    0002f50 a000 e3a0 af10 ee40 f04e f57f f06f f57f
    0002f60 ff1e e12f 4ef0 e92d ffd6 ebff 4ef0 e8bd
    0002f70 ff1e e12f f05f f57f 0f30 ee30 3ba0 e1a0
    0002f80 300e e213 001c 0a00 a000 e3a0 20aa e08a
    0002f90 1230 e1a0 1007 e201 0002 e351 0013 ba00
    0002fa0 af10 ee40 f06f f57f 1f10 ee30 2007 e201
    0002fb0 2004 e282 43ff e300 41a1 e014 5f14 e16f
    0002fc0 7fff e307 76a1 e017 9007 e1a0 6514 e1a0
    0002fd0 b006 e18a 6219 e1a0 b006 e18b bf56 ee07
    0002fe0 9001 e259 fff8 aaff 4001 e254 fff5 aaff
    0002ff0 a002 e28a 000a e153 ffe3 caff a000 e3a0
    0003000 af10 ee40 f04e f57f f06f f57f ff1e e12f
    0003010 4ef0 e92d ffd6 ebff 4ef0 e8bd ff1e e12f
    0003020 d010 e59f d007 e3cd 9000 e3a0 5000 e92d
    0003030 fa07 fbff 9000 e8bd ff30 4037 2300 ee07
    0003040 3f15 ee07 3fd5 f3bf 8f4f f3bf 8f6f 4770
    0003050 4770 4770 4770 b508 f7ff ef84 e8bd 4008
    0003060 f7ff bff8 4770 b508 f7ff efd2 e8bd 4008
    0003070 f7ff bff8 b508 f7ff ffeb f7ff fff4 2300
    0003080 ee08 3f17 ee08 3f16 ee08 3f15 f3bf 8f4f
    0003090 f3bf 8f6f bd08 4770 b538 4604 460d f000
    00030a0 f90f ee30 3f10 f003 0307 2201 3304 409a
    00030b0 4253 4023 429d d807 f3bf 8f4f 4629 4620
    00030c0 e8bd 4038 f7ff bfe7 ee07 3f3e 4413 e7f1
    00030d0 4770 b570 4605 460e f000 f8f2 ee30 4f10
    00030e0 4631 4628 f000 f8ec b140 f004 0407 2301
    00030f0 3404 fa03 f404 462b 429e d807 f3bf 8f4f
    0003100 4631 4628 e8bd 4070 f7ff bfe2 ee07 3f36
    0003110 4423 e7f1 4770 b508 07c3 d50d f000 f9d1
    0003120 f7ff ff97 f7ff ff9f f000 f9c4 f7ff ff86
    0003130 f7ff fff0 2000 bd08 f000 f9bc f7ff ff7e
    0003140 f7ff ff89 f7ff ff7a f000 f9b0 e7f0 2003
    0003150 f7ff bfe1 3801 d1fd 4770 b530 2400 3401
    0003160 6815 f3bf 8f5f 4005 428d d003 429c d1f6
    0003170 2000 bd30 2001 bd30 d050 e59f d007 e3cd
    0003180 000d e1a0 0577 fa00 d000 e1a0 9000 e1a0
    0003190 0577 fa00 0000 e3a0 fa09 faff 0331 fa00
    00031a0 0000 e350 d000 11a0 9000 11a0 0020 e59f
    00031b0 3020 e59f 1000 e3a0 2000 e053 1198 fa00
    00031c0 0009 e1a0 102c e599 e00c e59f ff1e e12f
    00031d0 ff30 4037 0000 80a0 0b80 80a3 3b31 4030
    00031e0 460d b508 68c4 f7ff ffb2 462a f04f 31ff
    00031f0 2000 47a0 b510 f890 4025 f890 3024 ea43
    0003200 2304 f890 4026 ea43 4304 f890 4027 ea43
    0003210 6304 4c12 42a3 d11f f890 4029 f890 3028
    0003220 ea43 2304 f890 402a ea43 4304 f890 402b
    0003230 ea43 6304 600b f890 102d f890 302c ea43
    0003240 2301 f890 102e ea43 4301 f890 102f 2000
    0003250 ea43 6301 6013 bd10 2001 bd10 2818 016f
    0003260 f8d9 2000 2300 b500 b089 9305 6c91 9303
    0003270 9307 e88d 000a 2302 6cd1 9104 6d11 6d52
    0003280 9102 4669 9206 aa04 f001 fbd4 b009 f85d
    0003290 fb04 2000 4770 4770 b508 4808 f002 fa4c
    00032a0 f24c 3050 f004 fb50 f7ff fff3 f7ff fff3
    00032b0 2000 f7fd fcb3 2000 bd08 bf00 5571 4031
    00032c0 068b d105 f010 0f3f bf0c 2001 2000 4770
    00032d0 2000 4770 b082 2300 9301 9b01 2b63 dd01
    00032e0 b002 4770 4600 9b01 3301 e7f5 b538 4605
    00032f0 f3ef 8300 f003 031f 2b1a d123 ee91 2f10
    0003300 f7ff ffe8 2d04 d102 0753 d51a 2505 f3ef
    0003310 8300 f003 031f 2b1a d117 ee91 4f10 f7ff
    0003320 ffd9 2d05 d101 f7ff fe96 ea24 0405 f3ef
    0003330 8300 f003 031f 2b1a d10a ee81 4f10 f3bf
    0003340 8f6f bd38 ee11 2f10 e7da ee11 4f10 e7e6
    0003350 ee01 4f10 e7f3 f8d9 10c0 b510 0544 f444
    0003360 6488 eb01 00c0 4322 e9c0 2300 bd10 0000
    0003370 2804 b538 4605 d162 f3ef 8300 f003 031f
    0003380 2b1a d172 ee91 4f10 f014 0401 d157 f7ff
    0003390 fe71 4620 2201 f44f 0380 3401 f7ff ffdb
    00033a0 f5b4 6f00 d1f5 2000 f7ff fd02 2001 f7ff
    00033b0 fcff 483b f44f 1100 f7ff fd0e 2300 464c
    00033c0 4618 f8d4 20c0 f8d4 10c0 441a f502 4280
    00033d0 eb01 2143 3308 2b20 6050 f041 0103 6011
    00033e0 d1ef f3ef 8300 f003 031f 4a2e 2b1a 4b2e
    00033f0 d13e ee82 3f50 f8d9 30c0 f503 4380 ec40
    0003400 3f42 ee8a 2f12 f04f 33ff ee03 3f10 f7ff
    0003410 fcf1 f3ef 8300 f003 031f 2b1a d133 ee91
    0003420 2f10 f7ff ff57 f042 0201 f3ef 8300 f003
    0003430 031f 2b1a d12a ee81 2f10 f3bf 8f6f f3ef
    0003440 8300 f003 031f 2b1a d123 ee91 2f10 f7ff
    0003450 ff41 4315 f3ef 8300 f003 031f 2b1a d11b
    0003460 ee81 5f10 f3bf 8f6f bd38 ee11 4f10 e78b
    0003470 ee02 3f50 f8d9 30c0 f503 4380 ec40 3f02
    0003480 ee0a 2f12 e7bf ee11 2f10 e7ca ee01 2f10
    0003490 e7d3 ee11 2f10 e7da ee01 5f10 e7e2 bf00
    00034a0 0000 4030 8800 ffcc 0f00 8000 f44f 5080
    00034b0 f7ff bf5e f44f 5080 f7ff bf18 2004 f7ff
    00034c0 bf57 2004 f7ff bf12 b510 4604 4807 f000
    00034d0 fb5f b110 4b06 6023 bd10 4806 f000 fb58
    00034e0 b108 4b05 e7f7 4b05 e7f5 bf00 579e 4031
    00034f0 1c50 4031 57a7 4031 1ce0 4031 1f04 4031
    0003500 2801 b510 460c d002 2802 d00f bd10 480b
    0003510 f000 fb3e b110 4b0a 6023 bd10 4809 f000
    0003520 fb37 b108 4b08 e7f7 4b08 e7f5 4805 f000
    0003530 fb2f 2800 d1ef 4b06 e7ee bf00 579e 4031
    0003540 1bd4 4031 57a7 4031 1c64 4031 1cf4 4031
    0003550 1dfc 4031 2801 d002 2802 d005 4770 4b03
    0003560 600b 2323 6013 4770 4b01 e7f9 1d70 4031
    0003570 1e78 4031 3803 2802 bf8c 2001 2003 4770
    0003580 2150 b508 2000 f000 faa3 4601 b120 4803
    0003590 e8bd 4008 f004 be65 bd08 bf00 5780 4031
    00035a0 b510 480b f000 faf4 4c0a b118 6823 4a0a
    00035b0 601a bd10 4809 f000 faeb 2800 d1f6 4808
    00035c0 f000 fae6 6823 b108 4a06 e7f1 4a06 e7ef
    00035d0 582b 4031 aaa8 4031 abfc 4031 57a7 4031
    00035e0 579e 4031 aadc 4031 ad1c 4031 4b0d 4a0e
    00035f0 681b 601a 4b0d 4a0e 681b 681b 0d1b 051b
    0003600 f1b3 6fe4 d107 6813 4a0a 601a 4b0a 4a0b
    0003610 681b 601a 4770 f1b3 6fec 6813 bf0c 4a08
    0003620 4a08 e7f2 aaac 4031 106c 4031 0da0 4031
    0003630 aa44 4031 aa48 4031 aa40 4031 0ea4 4031
    0003640 aa68 4031 aa88 4031 b510 2036 4906 f007
    0003650 f882 2036 f007 f95a 4604 2036 f007 f8a3
    0003660 fab4 f084 0940 bd10 55a3 4031 4b03 2204
    0003670 4903 681b 681b 6e18 f7fc bf22 aa40 4031
    0003680 3ce8 4031 e92d 45f8 4855 f000 fa81 2800
    0003690 d14b 4854 f000 fa7c 2800 d14c 4852 f000
    00036a0 fa77 2800 d14d 4b51 f04f 08db 4d50 4e51
    00036b0 681b 681a 4b50 429a 4b50 bf0e 2752 276e
    00036c0 461e f7fd fef1 4604 2800 d16f f8df a170
    00036d0 4642 4629 f8da 3000 681b 6e18 f7fc fef0
    00036e0 4847 f000 fa55 2800 d031 4845 f000 fa50
    00036f0 2800 d160 4843 f000 fa4b 2800 d166 4840
    0003700 f000 fa46 b140 f000 fa5b 2203 4601 483e
    0003710 f004 f836 2800 d057 493c f8da 3000 221d
    0003720 681b 6e18 f7fc fecc e016 274c f04f 08d9
    0003730 4e37 4d38 e7c5 274c f04f 08d9 4e36 4d37
    0003740 e7bf 272d f04f 08b2 4e35 4d36 e7b9 482d
    0003750 f000 fa1e 2800 d1c8 4823 f000 fa19 b188
    0003760 f7ff ff72 f8da 3000 2800 482f bf18 2221
    0003770 492e bf08 2220 681b bf1c 2403 4601 6e18
    0003780 f7fc fe9e f8da 3000 463a 4631 681b f8d3
    0003790 01bc f7fd fe07 b144 f8da 3000 4622 4924
    00037a0 681b f8d3 01bc f7fd fdfd 4604 4620 e8bd
    00037b0 45f8 f7fd be99 f000 fa03 2203 4601 481d
    00037c0 f003 ffde 2800 d195 491b e7a6 f000 f9f8
    00037d0 2203 4601 4819 f003 ffd3 2800 d0f4 e78e
    00037e0 582b 4031 57a7 4031 579e 4031 0da0 4031
    00037f0 3408 4031 49f4 4031 0110 0752 4be0 4031
    0003800 55ca 4031 55d3 4031 57dc 4031 1f18 4031
    0003810 4664 4031 2678 4031 482c 4031 2d40 4031
    0003820 4544 4031 20e8 4031 3be0 4031 3ae0 4031
    0003830 4652 4031 57d2 4031 2000 4031 57d7 4031
    0003840 aa40 4031 b538 460d 4913 f500 7380 4602
    0003850 428b d012 f501 31c0 428b d118 4b0f 4a10
    0003860 4c10 681b 681b 0d1b 051b f1b3 6fe4 bf18
    0003870 4614 6821 b919 2000 bd38 4c0b e7f9 4628
    0003880 f003 ff73 b908 6860 bd38 3408 e7f1 4907
    0003890 4807 f004 fce6 e7ee c100 4809 0da0 4031
    00038a0 af84 4031 af64 4031 af4c 4031 5580 4031
    00038b0 57b0 4031 4b03 681b 6818 4b03 1ac3 4258
    00038c0 4158 4770 0da0 4031 0110 0752 b508 f009
    00038d0 ff31 b958 f001 fd20 f001 fd5a 4806 f001
    00038e0 fe5f f110 30ff bf18 2001 bd08 f009 ff1a
    00038f0 2863 d1ef 2001 bd08 57e1 4031 b508 20cb
    0003900 4904 f006 ff28 2101 20cb f006 ff59 2000
    0003910 bd08 bf00 5702 4031 b510 4604 482d f000
    0003920 f937 b310 482b f000 f933 b180 f000 f948
    0003930 2203 4601 4828 f003 ff23 b940 4927 4620
    0003940 f003 ff13 3000 bf18 2001 4240 bd10 4821
    0003950 f000 f91e b1d8 f000 f933 2203 4601 4820
    0003960 f003 ff0e b998 491f e7e9 481f f000 f910
    0003970 b178 481d f000 f90c b148 f000 f921 2203
    0003980 4601 481a f003 fefc b908 4919 e7d7 4919
    0003990 e7d5 4819 f000 f8fc b950 4818 f000 f8f8
    00039a0 b970 4817 f000 f8f4 b988 f04f 30ff bd10
    00039b0 4914 4620 f003 fed9 2800 d1ee 2000 bd10
    00039c0 4911 4620 f003 fed1 2800 d1ea e7f6 490f
    00039d0 e7b5 bf00 55ca 4031 57d2 4031 570d 4031
    00039e0 57dc 4031 5725 4031 55d3 4031 57d7 4031
    00039f0 574e 4031 573c 4031 582b 4031 57a7 4031
    0003a00 579e 4031 575f 4031 576a 4031 5775 4031
    0003a10 b510 4604 f003 fed1 4623 1b1a 4619 4290
    0003a20 dc00 bd10 780a 3301 3a20 2a5e d9f5 2300
    0003a30 700b bd10 e92d 41ff 4604 460d 4617 4698
    0003a40 f7fe fca6 2c00 da09 b2ed 4628 f006 f99a
    0003a50 4604 b150 4620 b004 e8bd 81f0 4620 f006
    0003a60 f951 4604 2800 d0ef e7f4 2604 4601 9600
    0003a70 ab03 2202 4628 f006 f995 4604 2800 d1e9
    0003a80 9b03 429f d01f 4601 9600 ab03 2202 4628
    0003a90 f006 f988 b960 2201 9b03 429f d115 f8cd
    0003aa0 8000 2100 9b0a 4628 f006 f97c 4604 e7d1
    0003ab0 4621 9600 ab03 2201 4628 f006 f973 4604
    0003ac0 2800 d1c7 e7e7 2202 e7e6 f04f 34ff e7c1
    0003ad0 b530 b097 4c25 4b26 4a26 6023 2300 7123
    0003ae0 7363 74a3 77e3 ab02 9300 234e f7ff ffa2
    0003af0 4605 2800 d133 9b02 2209 a903 481e 6023
    0003b00 f003 fed5 481c f7ff ff83 f89d 3014 2b1a
    0003b10 d128 f89d 3015 bb2b f89d 3016 bb13 f89d
    0003b20 3017 b9fb 4915 2205 4815 f003 fec0 4814
    0003b30 f7ff ff6e 220d a906 4812 f003 feb8 4811
    0003b40 f7ff ff66 2221 a909 480f f003 feb0 480e
    0003b50 f7ff ff5e 2212 a911 480c f003 fe84 4628
    0003b60 b017 bd30 2205 a905 e7de bf00 bc28 4037
    0003b70 d12c adea 55aa ee33 bc2c 4037 5834 4031
    0003b80 bc35 4037 bc3a 4037 bc47 4037 bc68 4037
    0003b90 b508 4601 4b07 681a 4b07 429a d007 2208
    0003ba0 4806 f003 fded fab0 f080 0940 bd08 2000
    0003bb0 bd08 bf00 bc28 4037 d12c adea bc2c 4037
    0003bc0 4800 4770 bc35 4037 4770 0000 b508 f04f
    0003bd0 4008 f001 fee1 2800 da07 f002 fc45 4601
    0003be0 480b e8bd 4008 f004 bb3c 2100 f04f 4008
    0003bf0 f000 ffca 4601 b908 4806 e7f2 f04f 4008
    0003c00 f7ff fb2e 4601 b108 4803 e7ea bd08 bf00
    0003c10 58d5 4031 58e3 4031 5908 4031 4770 4770
    0003c20 f44f 3348 6103 4b04 60c3 6083 2311 7103
    0003c30 4b02 6003 4770 bf00 0000 8080 592c 4031
    0003c40 680a 4b1c b513 4604 4608 429a d11b 6963
    0003c50 f013 0f01 690b ba1b d00e 60a3 694b ba1b
    0003c60 60e3 68cb ba1b 6123 3020 f810 3c04 6020
    0003c70 7123 2000 b002 bd10 60e3 3b40 60a3 68cb
    0003c80 ba1b 3340 e7ef aa01 4669 f7ff fab3 b960
    0003c90 4b09 6023 2305 7123 f04f 4302 60a3 60e3
    0003ca0 e89d 000c 1a9b 6123 e7e3 4620 f7ff ffb8
    0003cb0 e7df bf00 0527 5619 5926 4031 f44f 5200
    0003cc0 b508 f8c9 2098 2200 f8c9 209c f002 fdd6
    0003cd0 b948 2001 f005 fcb4 b928 f8d9 3004 f443
    0003ce0 4380 f8c9 3004 bd08 b508 f8d9 3004 045b
    0003cf0 d507 f8d9 3004 2000 f443 6380 f8c9 3004
    0003d00 bd08 f002 fdbb b920 2001 f005 fc99 2800
    0003d10 d0ef bd08 b510 4604 f7ff f8bc 6020 bd10
    0003d20 f8d9 2000 f04f 4100 b510 f8d9 4000 6491
    0003d30 f001 fda6 64e0 bd10 b580 b08e ae03 2100
    0003d40 2214 4630 f003 fd6e 4a36 f8c9 2000 f7ff
    0003d50 ffe7 f44f 42a0 f8c9 20c4 f001 fd91 f8d9
    0003d60 30c4 f1c3 4300 4418 f8c9 00c0 f7ff f81e
    0003d70 f44f 0100 482c f001 fcf1 f8d9 2004 f442
    0003d80 7200 f8c9 2004 f8d9 3004 055b d404 f7ff
    0003d90 ffab b108 f003 f8fe 4f24 2500 f7fd fd02
    0003da0 f7ff f87e 2218 2100 a808 f003 fd3b 4630
    0003db0 f7ff ffb0 f856 3025 b14b 4c1d 463a 4294
    0003dc0 d109 481c f001 fcb8 3501 2d05 d1f2 481a
    0003dd0 f001 fcb2 e7de 6861 428b d00a 340c e7ee
    0003de0 f7ff fef4 f7ff ff1a f04f 4108 a808 f7ff
    0003df0 f9f7 6821 4811 f004 fa34 6863 a901 a808
    0003e00 9301 2300 9302 68a3 4798 2800 d1dc f7ff
    0003e10 f99e f89d 3024 2b05 d0e2 f7ff ff00 a808
    0003e20 f7ff f84a afa4 4031 0000 80a8 b61c 4031
    0003e30 b5ec 4031 5851 4031 5870 4031 5839 4031
    0003e40 f44f 32e1 b508 f8c9 2008 f009 fbe3 2201
    0003e50 4804 f8c9 201c f001 fc6f e8bd 4008 f7fd
    0003e60 be1b bf00 589b 4031 4b0a 4649 b510 22d8
    0003e70 4c09 f8c9 3094 f44f 1380 f8c9 3098 2300
    0003e80 f8c9 309c 4620 f003 fcee 4620 f005 fb54
    0003e90 4620 bd10 0000 81f0 ff20 81ff b570 4605
    0003ea0 68ee 460c 4610 b14e f002 013f 1860 b926
    0003eb0 68a9 4408 3801 f00c efcc bd70 68a9 f00d
    0003ec0 e83a e7f3 e92d 4df0 460d 688e b086 4680
    0003ed0 4628 685c f1c6 4600 9201 f506 06ff 2200
    0003ee0 ba24 f506 46ff 3403 3641 f024 0403 1b36
    0003ef0 4621 f026 063f f7ff ffd1 4633 4602 9901
    0003f00 4628 692f 47b8 b928 f06f 0604 4630 b006
    0003f10 e8bd 8df0 4946 4630 f002 f85a 1e03 9302
    0003f20 da02 f04f 36ff e7f1 9902 4630 f001 fe23
    0003f30 f1b0 0a00 dbf5 4651 4a3e 4630 f000 fc27
    0003f40 4651 4607 4a3c 4630 f000 fc21 4651 4683
    0003f50 4a3a 4630 f000 fc1b 2311 f8c8 0008 f888
    0003f60 3004 463b 4423 f8c8 000c 461a 4682 4659
    0003f70 4628 4698 f7ff ff92 68eb 9003 2b00 d043
    0003f80 f028 003f 9901 4653 9a03 692f 1841 4628
    0003f90 47b8 9b03 4283 d1b7 68eb 2b00 d039 f008
    0003fa0 013f 465a 4451 4650 f003 fc5d 4630 aa05
    0003fb0 9902 f000 fbfb 1e06 dba8 9905 4628 44da
    0003fc0 f10a 083f 440c 4631 4622 9405 f7ff ff66
    0003fd0 68eb f028 083f 4683 b303 f024 003f 9901
    0003fe0 4643 692c 465a 4401 4628 47a0 4583 d18b
    0003ff0 68eb 9805 b1bb f000 013f 4632 4441 4650
    0004000 2600 f003 fc30 e781 68a9 4640 f00c ef20
    0004010 e7b8 68a9 4640 f00c ef8e e7c2 68a9 4620
    0004020 f00c ef16 e7db 68a9 f00c ef84 e7e5 bf00
    0004030 5933 4031 593b 4031 5947 4031 6023 4031
    0004040 b570 460c 6800 4615 461e f006 fe07 4621
    0004050 6e44 4633 462a 46a4 e8bd 4070 4760 0000
    0004060 e92d 41f0 4690 4e21 b086 4605 4608 460c
    0004070 f006 fdf4 4633 6e47 2201 4641 47b8 b938
    0004080 481b f001 fb59 f04f 30ff b006 e8bd 81f0
    0004090 6832 4b18 429a d111 2300 4642 9302 a901
    00040a0 9304 4628 6f63 9401 9303 4b13 9305 4633
    00040b0 f7ff ff08 2800 d1e3 2000 e7e6 4631 4628
    00040c0 f7ff fdbe 2800 d1db 6928 6f61 3801 4408
    00040d0 f00c ee70 4606 4620 f006 fdc0 68ab 4632
    00040e0 6e44 4641 47a0 4286 d0e6 e7c9 ffc0 807f
    00040f0 5951 4031 0dd0 edfe 3e39 4030 2805 b508
    0004100 d00a d303 2807 d801 2001 bd08 4803 f004
    0004110 f8a8 f06f 0012 bd08 2000 bd08 5982 4031
    0004120 b5f8 4606 6808 460f f7ff ffe8 1e04 db09
    0004130 2000 f008 f887 4605 b130 462c 4601 4851
    0004140 f004 f88f 4620 bdf8 4620 f006 fd3d 4605
    0004150 2800 f040 808b f06f 0112 484b f004 f881
    0004160 f06f 0412 e7ee 6838 f7fe fe97 2802 d01e
    0004170 2803 d03d 2801 d173 f7ff fba8 b978 4628
    0004180 f006 fd6c f04f 4308 6e47 f44f 7200 f44f
    0004190 51a8 47b8 2800 d140 483c f001 facd f44f
    00041a0 7240 4629 4630 f7ff ff5b 2800 d0ca f7ff
    00041b0 fb8d 2800 d03e 4628 f006 fd50 4b34 4601
    00041c0 2201 4630 f000 f87e 2800 d0bb f7ff fb7e
    00041d0 2800 d03a 4628 f006 fd41 4b2d 4601 2201
    00041e0 4630 f000 f93b 2800 bf18 f06f 0401 e7a9
    00041f0 f895 706d 4628 f3c7 07c2 2f07 bf08 2700
    0004200 f006 fd2c 4639 f00a fdc5 4607 2800 d0b3
    0004210 4820 463c f001 fa90 e794 f44f 52b8 4629
    0004220 4630 f7ff ff1d 2800 d1b9 7933 2b05 d089
    0004230 4819 e7b2 4628 f006 fd11 2201 4601 4630
    0004240 f000 f89a 2800 d1b6 e77c 4628 f006 fd06
    0004250 2201 4601 4630 f000 f96f 2800 d1ba e771
    0004260 480e f06f 0415 f001 fa67 e76b f007 ffe0
    0004270 4604 2800 f43f af77 4621 4809 f003 fff1
    0004280 e760 bf00 59a5 4031 5aa4 4031 5a16 4031
    0004290 5a7e 4031 59f4 4031 5a43 4031 5a89 4031
    00042a0 59cf 4031 b530 b087 461c ad04 2300 e88d
    00042b0 002c 460a 68c0 4621 f00b fd54 b900 9804
    00042c0 b007 bd30 b5f0 461d 4e23 4607 b087 4608
    00042d0 6833 b9c3 4611 f00b f895 4604 b188 4602
    00042e0 491e 481f f003 ffbd 2c00 dc05 4623 462a
    00042f0 491c 481d f003 ffb5 2c00 bfcc 2000 2001
    0004300 e019 2301 6033 4e19 2240 4628 4631 f00b
    0004310 fd17 1e04 ddea 6832 4b15 429a d10d 4b15
    0004320 2200 a901 4638 9504 9305 2301 9303 4633
    0004330 9202 f7ff fdc7 b007 bdf0 4631 4638 f7ff
    0004340 fc7f 4604 2800 d1cf 4602 68b9 4628 f00b
    0004350 fcf7 4604 e7c8 bf00 0000 80a0 5ae4 4031
    0004360 5b25 4031 5afc 4031 5b40 4031 ffc0 807f
    0004370 0dd0 edfe 409d 4030 e92d 41f0 4607 f8df
    0004380 80d8 460d 4616 f8d8 3000 b983 4611 4628
    0004390 f00b f838 4604 b138 4602 4923 4823 f003
    00043a0 ff60 4620 e8bd 81f0 2301 f8c8 3000 4820
    00043b0 f001 faca 4604 b908 481e e028 2200 f04f
    00043c0 4108 f00b fcbd 1e02 dc13 4621 481a f003
    00043d0 ff48 2200 f04f 4108 4818 f00b fcb1 1e03
    00043e0 dc1a 4a16 f04f 34ff 4915 4816 f003 ff39
    00043f0 e7d7 4815 f001 faa8 4603 b158 4632 4629
    0004400 4638 f7ff ff5f 4604 2800 d0ca 480f f001
    0004410 f993 e7de 480e e7fa 4632 4629 4638 4b0d
    0004420 e8bd 41f0 f7ff bf4e 5ae4 4031 5b25 4031
    0004430 5c71 4031 5c1e 4031 5b66 4031 5c65 4031
    0004440 5b0f 4031 5b40 4031 5ba6 4031 5bb8 4031
    0004450 5bd6 4031 5c6a 4031 0000 80a0 b5f0 b0a7
    0004460 4614 460f 2278 2100 4606 a808 461d f003
    0004470 f9d9 4621 aa08 4638 f003 ffc2 4604 b130
    0004480 4825 f003 feee f04f 30ff b027 bdf0 a908
    0004490 4638 f00c fb7b 4620 f00c fb30 4604 b930
    00044a0 4602 491e 481e f003 fedc 0fe0 e7ed a904
    00044b0 4628 f00c faf1 1e04 da09 481a f001 f93c
    00044c0 4623 462a 4915 4818 f003 fecb e7ed 2240
    00044d0 2300 af06 e9cd 2300 9702 2200 2300 4813
    00044e0 f00b fd76 1e04 da01 4811 e7e7 490f 4630
    00044f0 f7ff fba6 1e04 da01 480e e7df e9dd 2304
    0004500 9702 68b0 e9cd 2300 2200 2300 f00b fd60
    0004510 1e04 daca e7d4 bf00 5cab 4031 5c82 4031
    0004520 5cca 4031 5ce5 4031 5b40 4031 ffc0 807f
    0004530 5cfe 4031 5d17 4031 e92d 41f0 b0a6 460c
    0004540 4615 2100 2278 4607 a808 f003 f96b aa08
    0004550 4629 4620 f003 ff54 4606 b138 4835 f003
    0004560 fe80 f04f 30ff b026 e8bd 81f0 a908 4620
    0004570 f00c fb0c 4630 f00c fac1 4602 b920 492e
    0004580 482e f003 fe6e e7ec 482d ae06 f001 f9dc
    0004590 4680 2800 d045 a904 f00c fa7e 2800 da03
    00045a0 4828 f001 f8c9 e010 e9dd 2304 f04f 4008
    00045b0 9602 e9cd 2300 2200 2300 f00b fd09 1e02
    00045c0 da1f 4641 4820 f003 fe4c a904 481f f00c
    00045d0 fa63 2800 da02 481b f001 f8ae e9dd 2304
    00045e0 f04f 4008 9602 e9cd 2300 2300 2200 f00b
    00045f0 fcef 1e03 da17 4a15 490f 4815 f003 fe31
    0004600 e7af 4814 f001 f9a0 4603 b140 462a 4621
    0004610 4638 f7ff ff23 2800 d0a5 480f e7c1 480f
    0004620 e7bf 480f e7bd 4b0f 462a 4621 4638 f7ff
    0004630 ff15 e798 5cab 4031 5c95 4031 5cca 4031
    0004640 5c71 4031 5ce5 4031 5b66 4031 5c65 4031
    0004650 5b40 4031 5ba6 4031 5bb8 4031 5bd6 4031
    0004660 5c1e 4031 5c6a 4031 6800 b510 4614 6840
    0004670 f009 fe0f 2800 bf0c 4620 2000 bd10 0000
    0004680 2300 b5f0 4a32 b087 4606 4619 4618 f009
    0004690 fe2f 4605 b938 f06f 0412 482e f001 f84c
    00046a0 4620 b007 bdf0 f7ff f911 bb10 4c2a 2240
    00046b0 f44f 11f0 6868 4623 f009 fdeb 6822 4b27
    00046c0 429a d116 4621 4630 f7ff faba 4604 b980
    00046d0 68b3 f44f 11f0 6932 6868 f009 fdda f04f
    00046e0 4308 f44f 2200 f44f 11a0 6868 f009 fdd1
    00046f0 e7d6 4f19 2240 f44f 2180 6868 463b f009
    0004700 fdc8 4604 2800 d1cb 683a 4b15 429a d10f
    0004710 2301 9002 9303 f44f 2280 4b12 a901 9004
    0004720 4630 9501 9305 463b f7ff fbcc 4604 e7b7
    0004730 4639 4630 f7ff fa84 4604 2800 d1b0 68b3
    0004740 f44f 2180 6932 6868 f009 fda3 e7ee bf00
    0004750 e000 0493 5d3f 4031 0000 8080 0527 5619
    0004760 0dd0 edfe 4461 4030 f5a0 5003 3818 f020
    0004770 000f 4770 4603 f100 02d8 2100 4293 d303
    0004780 30e0 f8c9 0094 4770 f843 1b04 e7f6 b507
    0004790 ab01 f001 fb90 9b01 2b04 bf0a 6800 f04f
    00047a0 30ff ba00 b003 f85d fb04 0000 2300 e92d
    00047b0 45f7 4688 6013 4604 4617 4931 f001 fc08
    00047c0 1e06 da04 f06f 0015 b003 e8bd 85f0 f8df
    00047d0 a0bc 4631 4620 f001 f9ce 4605 2d00 da0e
    00047e0 4828 f003 fd3e 4f28 4631 4e28 4620 f001
    00047f0 f9c2 4605 2d00 da32 f06f 0001 e7e4 ab01
    0004800 4652 4629 4620 f001 fb56 b920 4920 4821
    0004810 f003 fd27 e7d6 f7ff f87f b128 4629 4620
    0004820 f001 f9bd 4605 e7d9 4a1b ab01 4629 4620
    0004830 f001 fb41 4602 2800 d0c4 4641 4620 f001
    0004840 fa7b 1e05 dbbe 4629 4a14 4620 f7ff ff9f
    0004850 4a13 4629 6038 4620 f7ff ff99 e7b4 ab01
    0004860 4632 4629 4620 f001 fb26 4601 4638 f003
    0004870 fcf8 4629 4620 f001 f992 4605 e7ba bf00
    0004880 5d64 4031 5da8 4031 5dce 4031 5d74 4031
    0004890 5d55 4031 5d80 4031 5da4 4031 593b 4031
    00048a0 5947 4031 e92d 4dff 4696 4688 2600 2700
    00048b0 9003 f11e 3eff d223 980c f04f 0a00 f04f
    00048c0 0b00 eb02 0e00 eb01 018e f113 33ff d222
    00048d0 9803 2400 2500 f112 32ff d226 42bd bf08
    00048e0 42b4 d32d eb1a 0a06 eb4b 0b07 455d bf08
    00048f0 4554 d225 1ba0 eb65 0107 b004 e8bd 8df0
    0004900 46b3 f858 6b04 f04f 0a00 465f fa96 fc86
    0004910 ea4a 060c e7cd f851 eb04 4655 2400 46ab
    0004920 fa9e fe8e ea44 0a0e e7cf 2300 9401 9300
    0004930 f850 3b04 e9dd 4500 ba1b ea44 0403 e7ca
    0004940 f04f 30ff 2100 e7d8 b5f8 4606 460f 461c
    0004950 4615 b112 f001 fda6 6028 b14c 2300 4a06
    0004960 4639 4630 f001 faa7 b118 6803 ba1b 6023
    0004970 bdf8 2301 e7fb bf00 5ed5 4031 e92d 4df3
    0004980 4606 9f0a 4601 f04f 0a00 f04f 0b00 e9cd
    0004990 2300 463b f113 33ff d223 ea4f 0887 4630
    00049a0 2100 4642 4446 f002 ff3d e9dd 4500 eb14
    00049b0 040a eb45 050b 2f01 dd0c 0e2b 022a ea43
    00049c0 6305 f402 027f 4313 0a2a f402 427f 4313
    00049d0 f846 3c08 ba24 2000 f846 4c04 b002 e8bd
    00049e0 8df0 f851 2b04 4655 2400 46ab ba12 ea44
    00049f0 0a02 e7cf b5f8 4606 460f 4615 f001 f99c
    0004a00 1c43 4604 d105 462a 4639 4630 f001 fd1c
    0004a10 4604 2c00 da08 4620 f001 fd26 462a 4603
    0004a20 4902 4803 f003 fc1d 4620 bdf8 5e03 4031
    0004a30 5e1b 4031 2b02 e92d 4df0 4606 b08c 460f
    0004a40 4690 461c dd0b f04f 35ff 2302 4622 4947
    0004a50 4847 f003 fc06 4628 b00c e8bd 8df0 f000
    0004a60 ff9b 1e05 da07 f001 fcff 4940 4602 4841
    0004a70 f003 fbf7 e7ef 4a40 2100 4630 f7ff ffba
    0004a80 1e05 dbe8 2307 4a3d 9300 4629 4b3a 4630
    0004a90 f001 fc4f f1b0 0a00 da08 f001 fce5 4937
    0004aa0 4602 4837 4655 f003 fbdc e7d4 b90c 2500
    0004ab0 e7d1 2100 4630 f001 fcf5 2100 4682 4630
    0004ac0 f001 fd0a ea4f 018a ea4f 0b80 9002 aa04
    0004ad0 2300 eb0b 0001 9003 429c dc12 ea24 74e4
    0004ae0 4459 ab04 4a27 4361 4630 9100 4629 f001
    0004af0 fc20 1e05 dadb f001 fcb7 4922 4602 4820
    0004b00 e7b6 f1ba 0f02 d123 eb07 0ec3 f857 0033
    0004b10 f8de e004 fa90 fc80 f8c2 c004 fa9e fe8e
    0004b20 f8c2 e000 9802 eb02 0c01 2802 d117 eb08
    0004b30 0ec3 f858 0033 f8de e004 ba00 fa9e fe8e
    0004b40 f842 e001 f8cc 0004 9803 3301 4402 e7c3
    0004b50 f857 0033 fa90 fe80 f8c2 e000 e7e2 f858
    0004b60 0033 fa90 fe80 f842 e001 e7ed 5dd5 4031
    0004b70 5e27 4031 5e1f 4031 5e7d 4031 5e84 4031
    0004b80 5e90 4031 5eaf 4031 e92d 4cf0 460d b087
    0004b90 4606 2800 d03b f001 f880 2400 4607 46b2
    0004ba0 f04f 0b00 42bc da0f ab04 aa02 4621 4630
    0004bb0 f001 f857 e9dd 2302 459b bf08 4592 d124
    0004bc0 4621 4630 f001 fb97 68f3 f505 5182 6a34
    0004bd0 f3c6 000b 310f ba1a 180b ba24 4413 4423
    0004be0 4632 f423 637f f023 030f 1a1c 4630 ba23
    0004bf0 6073 2300 9400 9301 f001 fb51 ea10 0020
    0004c00 bf38 4620 b007 e8bd 8cf0 3401 e7ca e7f9
    0004c10 e92d 4df0 b096 4605 468a 4690 f001 fa2d
    0004c20 1e06 db18 4c59 ab0e aa0d 4631 4628 68e7
    0004c30 47b8 9a0d 940a 1e53 2b03 d802 9b0e 2b00
    0004c40 dc0d 2200 4651 4628 f001 f885 4950 4602
    0004c50 4850 f003 fb06 f04f 30ff 2100 e012 0092
    0004c60 4641 a812 f002 fdff 4631 4628 f001 fa05
    0004c70 1e03 9306 da15 9c0d 2300 2000 2100 ad12
    0004c80 42a3 d102 b016 e8bd 8df0 2200 9005 9204
    0004c90 f855 2023 3301 e9dd 0104 ba12 ea40 0002
    0004ca0 e7ee 9b0a aa0f 9906 4628 68dc ab10 47a0
    0004cb0 9c0f 1e63 2b03 d802 9b10 2b00 dc02 2200
    0004cc0 4631 e7c0 9b0e 4631 4a33 4628 9f0d 9307
    0004cd0 ab11 f001 f8f0 9003 b110 9b11 2b00 d127
    0004ce0 2300 f04f 0a00 f04f 0b00 a812 42bb d112
    0004cf0 00a2 2100 f002 fd96 9b0a 4652 9400 a812
    0004d00 6959 465b 4788 2800 d1a5 9b0f 9e06 930d
    0004d10 9b10 930e e7a8 2200 f8cd a024 9208 f850
    0004d20 2023 3301 e9dd ab08 ba12 ea4a 0a02 e7dd
    0004d30 bfb8 3303 eb04 0807 109b 9311 9b07 4498
    0004d40 ea4f 0388 930b 9b11 4598 dc84 4e0f 463a
    0004d50 9400 a812 9b07 9903 6936 47b0 2900 4682
    0004d60 bf08 f1b0 3fff 468b d108 9b11 9a03 eba3
    0004d70 0308 9311 9b0b 441a 9203 e7e4 9b03 00a2
    0004d80 a812 eb03 0187 f002 fd6e e7b5 affc 4031
    0004d90 5dec 4031 5eb3 4031 5ece 4031 e92d 4df0
    0004da0 f5ad 7d06 af00 4605 460e 4614 f002 fd05
    0004db0 300a 4925 f020 0007 462a ebad 0d00 4668
    0004dc0 46e8 f003 fa41 4669 1d38 f002 fc47 b3a0
    0004dd0 f8d7 320c 466d f8d4 a000 00db 4650 3318
    0004de0 ebad 0d03 f002 fce9 466b 4602 4651 1d38
    0004df0 f002 fc7c b1a8 4640 f002 fcdf 3001 f000
    0004e00 fcc1 6060 b1a8 4641 f002 fc9b 4630 f002
    0004e10 fcd4 3001 f000 fcb6 60a0 b148 4631 f002
    0004e20 fc90 2000 46ad f507 7706 46bd e8bd 8df0
    0004e30 6060 f06f 000b 46ad e7f5 f8d7 1214 4803
    0004e40 f003 fa0f 2016 e7ee 657e 4031 6583 4031
    0004e50 e92d 45f8 460f 4690 4604 2800 d049 212c
    0004e60 4620 f002 fc9e 4605 bb88 4620 f002 fca5
    0004e70 b928 1c6c 2d00 d1f2 4628 e8bd 85f8 3001
    0004e80 f000 fc80 4606 b918 f06f 000b e8bd 85f8
    0004e90 4621 f002 fc56 213a 4630 f002 fc82 4604
    0004ea0 b128 2300 1c60 7023 f002 f88c 4604 4630
    0004eb0 f002 f888 4606 f002 fc80 2800 d0d9 4642
    0004ec0 4621 4630 47b8 2800 d0d3 e8bd 85f8 ebb0
    0004ed0 0a04 d0ce f10a 0001 f000 fc54 4606 2800
    0004ee0 d0d2 4652 4621 f002 fc34 2300 f806 300a
    0004ef0 e7d1 2001 e8bd 85f8 b530 4615 b085 b19a
    0004f00 b190 2300 9101 aa01 490a 9302 9303 f7ff
    0004f10 ff9f 4604 b928 9b02 b14b 9903 4628 f002
    0004f20 fc10 4620 b005 bd30 f06f 0415 e7f9 f06f
    0004f30 0401 e7f6 4b95 4030 b530 b140 780c 2c30
    0004f40 d105 784c f004 04df 2c58 d100 3102 440b
    0004f50 4c09 e003 f015 0f04 e008 3101 4299 d006
    0004f60 780d 5d65 2800 d0f5 f015 0f44 d1f5 b902
    0004f70 bd30 6011 bd30 bf00 8b30 4031 b570 4605
    0004f80 f002 fc1b b168 4e07 7829 4630 f002 fc09
    0004f90 4604 b108 1b80 bd70 7829 4803 f003 f961
    0004fa0 4620 bd70 671d 4031 6632 4031 b570 4605
    0004fb0 f002 fc03 2801 d90b 4e06 7869 4630 f002
    0004fc0 fbf0 b108 1b80 bd70 7869 4803 f003 f949
    0004fd0 2000 bd70 6718 4031 65f5 4031 b537 4604
    0004fe0 2500 2302 aa01 4621 2001 f7ff ffa5 9b01
    0004ff0 42a3 d00f 1ca2 4293 d107 7822 2a30 d104
    0005000 7862 f002 02df 2a58 d004 2d05 781a d004
    0005010 2a3a d004 f04f 30ff e006 2a00 d1fa 3501
    0005020 1c5c 2d06 d1dd 2000 b003 bd30 4b1d e92d
    0005030 41f3 2400 f8df 8080 4605 781b 6806 f88d
    0005040 4005 f88d 3004 f8d8 3000 f88d 4006 4f16
    0005050 b12b 4816 f000 fc78 f8c8 4000 6038 6838
    0005060 b9c8 aa01 4631 4812 f7ff ff46 b980 a801
    0005070 f002 fba3 b160 a801 f7ff ff80 f000 0407
    0005080 a801 f7ff ff93 4b0b f853 0020 4320 60e8
    0005090 b002 e8bd 81f0 aa01 4631 f7ff ff2d 2800
    00050a0 d0e5 e7de 5d52 4031 0004 80a0 659e 4031
    00050b0 65a5 4031 3d08 4031 b014 4031 e92d 4dff
    00050c0 4606 460c 9301 4617 b1a2 f8d0 a004 4b56
    00050d0 6835 2c00 bf08 461c 2f01 d017 68f3 f003
    00050e0 0307 9300 3b01 2b05 d810 e8df f003 1505
    00050f0 4837 2a65 4692 e7ea f04f 33ff aa03 4621
    0005100 2000 f7ff ff19 9b03 781b b9d3 9b01 f013
    0005110 0002 d057 2000 e01e f04f 33ff aa03 4621
    0005120 2001 f7ff ff09 9b03 781a b952 1ca2 4293
    0005130 d1ec 7823 2b30 d1e9 7863 f003 03df 2b58
    0005140 d1e4 9a00 4629 4b39 4839 5c9b 4622 f003
    0005150 f888 f04f 30ff b004 e8bd 8df0 7823 f003
    0005160 02df 2a59 d009 2a54 d007 f1a3 0230 2a01
    0005170 d903 f003 03d7 2b46 d1e3 7863 e7c5 46a3
    0005180 f04f 0800 2303 aa03 4659 2000 f7ff fed4
    0005190 9b03 455b d0d5 f1b8 0f03 781a d009 2a2e
    00051a0 d1cf f108 0801 f103 0b01 f1b8 0f04 d1e9
    00051b0 e7ac 2a00 d0f5 e7c4 4620 f7ff ff0f 2800
    00051c0 d0a4 e7be 2f01 d008 d326 2f02 d1c3 68f3
    00051d0 0699 d50b 4629 4817 e004 68f3 0718 d599
    00051e0 4815 4629 f003 f83d 2001 e7b4 065a d591
    00051f0 4c0d 4628 f000 f9e9 4651 2800 bf18 4604
    0005200 480e 4622 f003 f82d 4621 4650 f002 faad
    0005210 2800 f43f af7f e7dd 68f3 06db f57f af7a
    0005220 4629 4807 e7de bf00 a5d6 4031 671d 4031
    0005230 6666 4031 66c3 4031 66a6 4031 66e3 4031
    0005240 66fb 4031 e92d 41f0 2400 f8df 8094 b0c0
    0005250 4607 22fc 6805 4621 a801 9400 f002 fae2
    0005260 f8d8 3000 4e19 b12b 4819 f000 fb6d f8c8
    0005270 4000 6030 6830 b9a8 466a 4629 4815 f7ff
    0005280 fe3b b960 4668 f002 fa98 b140 4e12 2400
    0005290 4d12 1bad 10ed 42a5 eb06 08c4 dc09 b040
    00052a0 e8bd 81f0 466a 4629 f7ff fe26 2800 d0e9
    00052b0 e7e2 f856 1034 4668 f002 fa57 b108 3401
    00052c0 e7e9 f8d8 3004 60bb e7e9 bf00 0008 80a0
    00052d0 6724 4031 672f 4031 b4c8 4031 b4c8 4031
    00052e0 b018 4031 2900 f04f 0000 bf0c f44f 1318
    00052f0 f44f 1320 6013 4770 2001 4770 b508 f7ff
    0005300 fffb 4601 2006 4b03 781a e8bd 4008 f009
    0005310 bd54 bf00 000d 80a0 4a05 2000 b508 f8c9
    0005320 2020 2201 f8c9 2024 f006 ff8c 2000 bd08
    0005330 6935 4031 2000 4770 b570 4604 b1d0 f006
    0005340 ff77 b9c8 4620 f7ff fff5 4606 f7ff ffd4
    0005350 4605 4620 f005 fc82 4b08 4629 7ac2 2006
    0005360 701a 4632 f009 fd29 b138 4805 f000 f9e4
    0005370 4804 bd70 4804 bd70 4804 bd70 000d 80a0
    0005380 68fd 4031 68e0 4031 68bc 4031 68cf 4031
    0005390 e92d 4df0 f5ad 2d80 b0a8 f7ff ffad f005
    00053a0 fc13 4607 f7ff ffc8 9001 b948 4601 aa06
    00053b0 4638 f7ff ff97 b158 2501 f7ff ff9f b115
    00053c0 9801 f000 f917 f50d 2d80 b028 e8bd 8df0
    00053d0 aa07 2101 4638 f7ff ff85 4605 2800 d1eb
    00053e0 9a06 4638 f10d 045f f50d 3600 f024 043f
    00053f0 369f 9203 f026 063f f005 fc30 6f7b 4683
    0005400 f503 30ff f1c3 0800 f200 10ff 4619 ea00
    0005410 0008 9302 f00b ecce 9a03 4682 9b02 1e50
    0005420 4418 4619 ea00 0008 f00b ecc4 f8db 8064
    0005430 4601 4623 4652 4658 47c0 9a07 ebba 0300
    0005440 bf18 f04f 33ff 4683 4638 9303 9205 f005
    0005450 fc05 f8d7 8074 9002 f508 30ff f1c8 0300
    0005460 f200 10ff 4641 4018 9304 f00b eca4 9a05
    0005470 4607 9b04 4641 1e50 4440 4018 f00b ec9a
    0005480 9b02 4601 463a 9802 f8d3 8064 4633 47c0
    0005490 4287 d14f 462f 9b03 433b d11e 4a28 1d61
    00054a0 2000 f001 fd31 6823 4298 d11b b9ff 2701
    00054b0 4a23 1d71 2000 f001 fd27 6833 1a1b 4258
    00054c0 4158 e004 481f 462f f000 f936 4628 ea50
    00054d0 0307 d10a 4b1c 9301 e76e 481c f000 f92c
    00054e0 45da d0db 2f00 d1f5 e7e2 b147 b910 464b
    00054f0 2201 e006 7922 7933 2aff d110 b97b 464b
    0005500 2202 625a 2100 f8d9 3024 2b01 bf18 4634
    0005510 4b0f 7922 4620 701a f000 f8b2 e74d 2bff
    0005520 d105 2a00 d0e3 429a 464b d2e1 e7e8 429a
    0005530 d8dd e7f8 45da d1c5 f04f 37ff e7ab bf00
    0005540 fffb 0001 683d 4031 6834 4031 686a 4031
    0005550 000c 80a0 f8d9 3020 5cc0 4770 f8d9 2024
    0005560 b11a f8d9 3020 4418 4770 4b01 e7fb bf00
    0005570 6935 4031 b508 f7ff fff1 7800 bd08 0000
    0005580 f8d9 1004 07c9 d501 f7ff bff4 f8d9 3024
    0005590 b10b f7ff bfdf 4b01 5c18 4770 6935 4031
    00055a0 b508 f000 f9d1 b158 7800 2831 d00b f000
    00055b0 00df 2859 d007 f1a0 0354 4258 4158 bd08
    00055c0 f04f 30ff bd08 2001 bd08 b538 f8d9 5024
    00055d0 f8d9 4004 f8d9 2004 f022 0280 f8c9 2004
    00055e0 2200 f8c9 2024 f000 f9af f8c9 5024 f8c9
    00055f0 4004 bd38 b51f 4604 b370 7803 2b21 d127
    0005600 2400 1c41 4816 f002 fe2c 2300 9400 9303
    0005610 f641 3237 9302 9301 4912 4813 f001 fb1c
    0005620 b940 4b12 4912 4a13 9300 237b 6809 4812
    0005630 f002 fe17 f8d9 2004 f042 0280 f8c9 2004
    0005640 f8d9 2004 f442 5200 f8c9 2004 b004 bd10
    0005650 f000 f872 2404 e7d8 4808 f000 f86d e7d4
    0005660 84b8 4031 6935 4031 b01c 4031 691a 4031
    0005670 0028 80a0 8502 4031 85a7 4031 84e6 4031
    0005680 b510 1d44 b086 b199 4601 2204 a805 f002
    0005690 f8ea 4a18 4621 2000 f001 fc36 9b05 4298
    00056a0 d006 2400 4814 f7ff ffa5 4620 b006 bd10
    00056b0 2300 4621 9303 9302 9301 9300 4a0d 480f
    00056c0 f001 faca 4604 b138 f8d9 3004 2401 f043
    00056d0 0380 f8c9 3004 e7e8 4b09 490a 4a0a 9300
    00056e0 23de 6809 4809 f002 fdbc 4809 f7ff ff82
    00056f0 e7db bf00 fffb 0001 6834 4031 b01c 4031
    0005700 692a 4031 0028 80a0 8502 4031 846c 4031
    0005710 84a9 4031 f8d9 201c 4601 b14a f8d9 3004
    0005720 079b d503 4b03 6858 6b03 4718 f007 bfe2
    0005730 4770 bf00 001c 80a0 f8d9 201c 4601 b14a
    0005740 f8d9 3004 079b d503 4b03 6858 6b43 4718
    0005750 f007 bfd9 4770 bf00 001c 80a0 460a 4906
    0005760 b410 1884 6008 4905 600c 4905 bc10 6008
    0005770 2100 f002 b857 bf00 0018 80a0 0014 80a0
    0005780 0010 80a0 f8d9 309c f8d9 1098 4403 428b
    0005790 bf9f f8d9 0094 3303 f8d9 109c f023 0303
    00057a0 bf9a f8c9 309c 1840 2000 4770 f8d9 3094
    00057b0 b510 f8d9 409c 4423 3b01 4403 4240 4018
    00057c0 f8d9 3094 1ac9 f8d9 3098 4401 4299 bf97
    00057d0 3103 2000 f021 0103 f8c9 109c bd10 fb01
    00057e0 f200 b510 4610 f7ff ffcd 2100 4604 f002
    00057f0 f819 4620 bd10 b5f0 4602 088c 08c8 b0a1
    0005800 2300 461e b968 6815 af20 eb07 0783 6010
    0005810 f847 5c80 6817 b977 2301 429c d819 4608
    0005820 e00f f852 5020 f84d 5023 43c5 f842 5020
    0005830 3301 1040 e7e5 eb0d 0383 2101 6015 428c
    0005840 d801 b021 bdf0 f853 5d04 f842 5021 0049
    0005850 e7f5 3e01 f852 7023 f85d 5026 0098 f842
    0005860 5023 43dd 42af ea4f 0343 d0d6 eb0d 0186
    0005870 429c d9e6 f851 5d04 f842 5023 005b e7f7
    0005880 f8d9 0030 4770 b5f8 460d 4604 b938 f04f
    0005890 36ff e013 f814 3b01 4635 2b3d d00e 7827
    00058a0 4628 f7ff fe6d 1c6e 4287 d0f3 7823 2b00
    00058b0 d1ed 4628 f7ff fe64 283d d1e8 4630 bdf8
    00058c0 e92d 4df0 4607 f8df a07c 460e 4690 2500
    00058d0 4628 f7ff fe55 b118 462c e007 4554 dd04
    00058e0 f04f 35ff 4628 e8bd 8df0 3401 4620 f7ff
    00058f0 fe47 2800 d1f2 4629 4638 f7ff ffc4 2800
    0005900 db14 eb06 0b08 4634 eba0 0a06 455c eb0a
    0005910 0004 eba4 0506 d10b b115 2300 f804 3c01
    0005920 463a 4641 4806 f002 fc9c e7db 1c65 e7cf
    0005930 f7ff fe26 f804 0b01 2800 d1e7 e7d2 bf00
    0005940 85e4 4031 ffff 0001 b510 4649 f8d9 4004
    0005950 b08a f014 0480 d012 4a0e 2300 9307 9303
    0005960 9202 aa05 9300 ab0a 9006 9201 e913 000f
    0005970 f000 ffde 9805 b100 6840 b00a bd10 2220
    0005980 3168 f7ff ff9d 2800 bfcc f109 0068 4620
    0005990 e7f3 bf00 b01c 4031 6803 4a10 ba1b 4293
    00059a0 d10b 6943 ba1b 2b0f d911 6983 ba1b 2b12
    00059b0 bf34 2000 f06f 0009 4770 4a09 4293 d109
    00059c0 6a43 2b00 bf14 2000 f06f 0006 4770 f06f
    00059d0 0009 4770 f06f 0008 4770 bf00 feed d00d
    00059e0 0112 2ff2 6883 b530 ba1b 18cb d201 189d
    00059f0 d301 2000 bd30 6844 ba24 42a5 d8f9 6944
    0005a00 ba24 2c10 d905 1889 d2f3 6a42 ba12 4291
    0005a10 d8ef 4418 bd30 0000 f06f 0307 e92d 41f0
    0005a20 4617 6013 2204 4680 460e f7ff ffdb b908
    0005a30 2509 e034 6805 f06f 030a 603b 1d34 ba2d
    0005a40 1e6b 2b08 d8f4 a201 f852 f023 5869 4030
    0005a50 5881 4030 589d 4030 5881 4030 5829 4030
    0005a60 5829 4030 5829 4030 5829 4030 5881 4030
    0005a70 4621 2201 4640 3401 f7ff ffb4 2800 d0d7
    0005a80 7803 4621 2b00 d1f4 1ba2 4631 4640 f7ff
    0005a90 ffa9 2800 d0cc 3403 f024 0403 603c 4628
    0005aa0 e8bd 81f0 2204 4621 4640 f7ff ff9b 2800
    0005ab0 d0be 6803 f106 040c ba1b 441c e7e4 bf00
    0005ac0 1e0b b507 9101 da04 f06f 0003 b003 f85d
    0005ad0 fb04 079b d1f8 aa01 f7ff ff9e 2801 d1f3
    0005ae0 9801 e7f3 1e0b b507 9101 da04 f06f 0003
    0005af0 b003 f85d fb04 079b d1f8 aa01 f7ff ff8c
    0005b00 2803 d1f3 9801 e7f3 2300 b573 4299 4606
    0005b10 4615 9301 db05 f7ff ffd3 2800 4604 9001
    0005b20 db0f 9c01 aa01 4630 4621 f7ff ff75 2802
    0005b30 d00a 2809 d011 2801 d1f3 b115 682b 3301
    0005b40 602b 4620 b002 bd70 2d00 d0ea 682b 3b01
    0005b50 2b00 602b dae5 9c01 e7f3 9c01 2c00 da07
    0005b60 f114 0f08 d1ed 2d00 bf08 f04f 34ff e7e8
    0005b70 f04f 34ff e7e5 b507 2300 aa02 f842 3d04
    0005b80 f7ff ffc2 2800 db07 9b01 2b01 bf18 f04f
    0005b90 30ff b003 f85d fb04 f04f 30ff e7f9 b537
    0005ba0 4605 ac02 2301 f844 3d04 4622 4628 f7ff
    0005bb0 ffab 1e01 db07 9b01 2b00 dd04 2b01 d1f4
    0005bc0 4608 b003 bd30 f04f 31ff e7f9 b5f8 4604
    0005bd0 4610 460d 4617 f001 fdf0 1c46 1bad 4425
    0005be0 42ac d902 2400 4620 bdf8 4632 4639 4620
    0005bf0 f001 fe8d 2800 d0f6 3401 e7f1 b570 460a
    0005c00 460d 212f 4606 f001 fe91 4604 462a 213a
    0005c10 4630 f001 fe8b b12c b118 42a0 bf28 4620
    0005c20 bd70 4620 bd70 b537 4605 460c aa01 4621
    0005c30 4628 f7ff fef1 2803 d006 2809 9c01 d106
    0005c40 2c00 bfa8 f06f 040a 4620 b003 bd30 2804
    0005c50 d0ec f04f 34ff e7f7 68c3 ba1b 440b 4418
    0005c60 4770 e92d 41f0 4606 4688 4617 461d f7ff
    0005c70 fe93 b980 6934 ba24 eb04 1108 1874 5871
    0005c80 6863 ba09 ba1b 6079 603b 68a2 68e1 ba12
    0005c90 ba09 e885 0006 e8bd 81f0 6903 b530 ba1b
    0005ca0 4403 2000 689a 3310 f853 1c04 ba15 ba0c
    0005cb0 ea54 0205 d100 bd30 3001 e7f3 e92d 45f7
    0005cc0 4606 4688 4617 461d f7ff fe66 4604 bb20
    0005cd0 4644 f105 0a01 9001 2c00 9b01 da21 2b00
    0005ce0 bfb8 f04f 34ff e018 4652 1d21 4630 f7ff
    0005cf0 fe79 4680 b1c8 462a 4639 f001 fe08 b9a0
    0005d00 f818 3005 b14b 462a 2140 4638 f001 fe0e
    0005d10 b958 f818 3005 2b40 d107 4620 b003 e8bd
    0005d20 85f0 2b00 dbdb 2b01 d0de 4621 aa01 4630
    0005d30 f7ff feea 4604 e7cf b570 4605 460e 4614
    0005d40 4610 f001 fd3a 4622 4603 4631 4628 e8bd
    0005d50 4070 f7ff bfb3 b5f8 4605 6887 460e 4614
    0005d60 ba3f f7ff fe19 b978 4631 4628 f7ff fea8
    0005d70 2800 db09 443e 4435 3504 b11c 4628 f001
    0005d80 fd1c 6020 4628 bdf8 b104 6020 2000 bdf8
    0005d90 b510 4604 f7ff fe94 1e01 db04 4620 e8bd
    0005da0 4010 f7ff bf40 bd10 b510 4604 f7ff fe9a
    0005db0 1e01 db04 4620 e8bd 4010 f7ff bf34 bd10
    0005dc0 b570 4604 460e 4615 f7ff fe8c 2800 da03
    0005dd0 b15d 6028 2000 bd70 68a0 ba00 4430 4420
    0005de0 b125 6843 ba1b 602b bd70 4628 bd70 e92d
    0005df0 4df3 4698 4607 4692 f108 0b01 9e0a f7ff
    0005e00 ffc7 4604 2c00 da03 b106 6034 2500 e018
    0005e10 4632 4621 4638 f7ff ffd3 4605 b1a8 6881
    0005e20 4638 ba09 f7ff ff18 4659 9001 f001 fcdd
    0005e30 4540 9b01 d10c 4642 4651 4618 f001 fd67
    0005e40 b930 4628 b002 e8bd 8df0 f06f 040c e7db
    0005e50 4621 4638 f7ff ffa8 4604 e7d3 b5f7 461f
    0005e60 4605 460e 4614 4610 f001 fca7 9700 4603
    0005e70 4622 4631 4628 f7ff ffba b003 bdf0 b513
    0005e80 9c04 9400 f7ff ffb3 b100 300c b002 bd10
    0005e90 b538 4614 461a 4605 f7ff ff92 4602 b148
    0005ea0 b12c 6881 4628 ba09 f7ff fed6 6020 f102
    0005eb0 000c bd38 bd38 b5f7 461f 4605 460e 4614
    0005ec0 4610 f001 fc7a 9700 4603 4622 4631 4628
    0005ed0 f7ff ffd5 b003 bdf0 b537 ab01 4a0c 4604
    0005ee0 460d f7ff ffe8 b110 9b01 2b04 d009 ab01
    0005ef0 4a08 4629 4620 f7ff ffde b120 9b01 2b04
    0005f00 d103 6800 ba00 b003 bd30 2000 e7fb bf00
    0005f10 8643 4031 863d 4031 b573 460d 4908 4604
    0005f20 4616 f000 f855 1e01 f04f 0000 db05 9000
    0005f30 4633 462a 4620 f7ff ffa2 b002 bd70 bf00
    0005f40 8634 4031 e92d 41f0 4680 460c 4616 f7ff
    0005f50 fd23 4605 bbb0 7823 19a7 2b2f d013 4631
    0005f60 4620 f7ff fe4b 2800 bf14 4606 463e 4621
    0005f70 1b32 4640 f7ff ffd0 4601 b330 4640 4634
    0005f80 f000 f826 4605 7823 b1e3 42bc d21a 4626
    0005f90 e000 4616 4632 f812 3b01 2b2f d0f9 b18b
    0005fa0 2b3a d00f 1bb9 4630 f7ff fe28 2800 bf14
    0005fb0 4604 463c 4629 1ba3 4632 4640 f7ff fe7e
    0005fc0 1e05 dae0 4628 e8bd 81f0 f06f 0504 e7f9
    0005fd0 b538 4605 460c 4608 f001 fbef 4621 4602
    0005fe0 4628 e8bd 4038 f7ff bfad e92d 45f7 4682
    0005ff0 460f 4615 4698 f7ff fccf b9d8 2d00 db2a
    0006000 f06f 040c ae02 f846 0d04 4287 da02 f06f
    0006010 0003 e00f 9b01 429d bf08 4604 4287 d10c
    0006020 f1b8 0f00 d001 f8c8 3000 429d bfd4 4620
    0006030 f04f 30ff b003 e8bd 85f0 4601 4632 4650
    0006040 f7ff fd62 2800 dae0 1c42 d0e0 1d03 bf08
    0006050 f06f 000a e7ee f04f 30ff e7eb b507 2200
    0006060 ab01 f7ff ffc2 2800 d005 db01 f06f 000c
    0006070 b003 f85d fb04 9801 e7fa b570 4604 460d
    0006080 f7ff ffec 1e02 db07 4629 4620 2300 3a01
    0006090 e8bd 4070 f7ff bfa9 bd70 1e4b b570 3303
    00060a0 4605 460e d817 f7ff fc77 4604 b940 4602
    00060b0 f04f 31ff 4628 f7ff fd27 2800 4604 da01
    00060c0 4620 bd70 4621 4628 f7ff ff06 4286 d0f7
    00060d0 2200 4621 e7ee f06f 0405 e7f1 6903 b510
    00060e0 ba1b 2b27 d913 6884 4419 ba24 42a1 d80e
    00060f0 68c3 4414 ba1b 429c d809 6842 6a00 ba12
    0006100 ba00 4418 4290 bf94 2000 2001 bd10 2001
    0006110 bd10 b5f8 460e 68c4 2a00 6a01 ba24 ba09
    0006120 440c 4404 db14 18b1 428c d311 4286 d30f
    0006130 1a9f 4427 42b8 d80b 6845 ba2d 4405 42af
    0006140 d809 1ba4 18f0 1aa2 f001 fbc8 2000 bdf8
    0006150 f06f 0003 bdf8 f06f 0002 bdf8 b570 4616
    0006160 461c 0112 011b 4605 f7ff ffd3 b958 68ab
    0006170 1ba4 0124 ba1b 4423 ba1b 60ab 68eb ba1b
    0006180 441c ba24 60ec bd70 b570 4605 4616 461c
    0006190 f7ff ffbf b950 6a6b ba1a 1ba3 441a ba12
    00061a0 626a 68ea ba12 4413 ba1b 60eb bd70 e92d
    00061b0 41f0 4604 68c5 4688 ba2d 4405 4608 f001
    00061c0 fafc 6a21 4607 4642 4628 ba09 f7ff fcfe
    00061d0 b110 1b40 e8bd 81f0 6a26 3701 68e1 4602
    00061e0 463b 4620 ba36 ba09 4431 4421 f7ff ff91
    00061f0 b950 6a23 463a 4641 19a8 ba1b 443b ba1b
    0006200 6223 f001 fb30 4630 e8bd 81f0 e92d 41f0
    0006210 4606 4614 461d 9f06 f7ff fc52 f1b0 0800
    0006220 db1c 4621 4630 f7ff ffc2 1e04 db19 68b1
    0006230 1ceb f023 0303 2200 330c 4630 ba09 4441
    0006240 4431 6039 f7ff ffa0 4680 b938 683b f04f
    0006250 7240 ba24 ba2d 601a 609c 605d 4640 e8bd
    0006260 81f0 46a0 e7fa b538 4604 f7ff fb95 b9a8
    0006270 6965 ba2d 2d10 d90c 6a62 2110 4620 ba12
    0006280 f7ff ff2c b940 2d11 d008 f04f 5388 6163
    0006290 bd38 f06f 0009 bd38 f06f 000b bd38 e92d
    00062a0 4df3 4692 4605 469b 9f0a f8dd 802c f7ff
    00062b0 ffda 4602 b9d8 9001 4628 f7ff fcee 692c
    00062c0 2301 9a01 ba24 eb04 1400 4628 192e 4631
    00062d0 f7ff ff44 4602 b950 fa9a f38a fa9b f18b
    00062e0 5129 ba3f 6073 fa98 f388 60b3 60f7 4610
    00062f0 b002 e8bd 8df0 e92d 41f0 4606 6904 460f
    0006300 f7ff ffb1 ba24 4605 b980 4630 f7ff fcc5
    0006310 4287 da09 eb04 1107 462b 4630 4431 2201
    0006320 e8bd 41f0 f7ff bf1a f04f 35ff 4628 e8bd
    0006330 81f0 e92d 45f0 b085 4606 460f 4690 469a
    0006340 9d0c f7ff ff90 4604 bb58 4642 ab03 4639
    0006350 4630 f7ff fd83 9a03 9002 b968 4610 3201
    0006360 d107 ab02 4642 9300 4639 462b 4630 f7ff
    0006370 ff4d b180 4604 e014 1ceb 3203 f100 010c
    0006380 f023 0303 f022 0203 4630 f7ff fefd b960
    0006390 9b02 ba2a 605a 9802 462a 4651 300c f001
    00063a0 fa62 4620 b005 e8bd 85f0 1c43 d1e2 e7d8
    00063b0 e92d 4df3 4604 460d 4693 469a f7ff ff53
    00063c0 2800 d13b 4653 465a 4629 4620 f7ff fc76
    00063d0 2800 da36 1c43 d131 aa01 4629 4620 f7ff
    00063e0 fb1b f8dd 8004 aa01 4620 4641 f7ff fb14
    00063f0 3803 2801 d9f5 68a5 f10a 0704 f027 0703
    0006400 2200 f107 0308 4620 ba2d 4445 1966 4631
    0006410 f7ff feba b990 f04f 7380 4601 5163 1d34
    0006420 463a 4620 f001 f9fe 4652 4659 4620 443e
    0006430 f001 fa19 4640 f04f 7300 6073 b002 e8bd
    0006440 8df0 f06f 0001 e7f9 b570 4605 460e 4614
    0006450 4610 f001 f9b2 4622 4603 4631 4628 e8bd
    0006460 4070 f7ff bfa5 0000 2800 dc0c d00d f110
    0006470 0f12 d90c 4b07 4240 f853 0020 4b06 2800
    0006480 bf08 4618 4770 4805 4770 4805 4770 4802
    0006490 4770 bf00 3d18 4031 866c 4031 864b 4031
    00064a0 8661 4031 b507 ab01 4a0a f7ff fd04 b160
    00064b0 9b01 2b04 d10b 6800 ba00 1e43 2b04 bf28
    00064c0 f06f 000d b003 f85d fb04 2002 e7fa f06f
    00064d0 000d e7f7 8a67 4031 b507 ab01 4a0a f7ff
    00064e0 fcea b158 9b01 2b04 d10a 6800 ba00 2805
    00064f0 bf28 f06f 000d b003 f85d fb04 2002 e7fa
    0006500 f06f 000d e7f7 bf00 5ed5 4031 b513 461c
    0006510 ab01 f7ff fcd0 b120 9b01 2b03 bf84 6804
    0006520 ba24 4620 b002 bd10 b513 461c ab01 f7ff
    0006530 fcc2 b120 9b01 2b03 bf84 6804 ba24 4620
    0006540 b002 bd10 b537 461d ab01 9c06 f7ff fcb3
    0006550 b920 f04f 33ff 6023 b003 bd30 9b01 42ab
    0006560 bfb4 f06f 030b 2300 e7f5 0000 b508 2300
    0006570 4a06 f7ff fca0 b130 4905 f001 f8f6 fab0
    0006580 f080 0940 bd08 2001 bd08 bf00 8a7e 4031
    0006590 8a85 4031 e92d 4df0 4604 b086 4615 4608
    00065a0 469b 460f f001 f909 aa03 4629 4680 4620
    00065b0 f7ff fbd1 4921 4682 4620 f7ff fd09 4601
    00065c0 4620 f7ff fbe5 2800 4605 dc02 f06f 0601
    00065d0 e02a ab05 aa04 4629 4620 f7ff fc59 9a05
    00065e0 4606 9b03 429a db23 7803 2b2f d120 4402
    00065f0 f812 2c01 b9e2 4642 4639 9804 9301 f001
    0006600 f8bf 9b01 b9a0 4619 4630 f001 f8de 4651
    0006610 3001 f001 f8aa 4606 b950 9804 f001 fed6
    0006620 1c43 d005 f8cb 0000 4630 b006 e8bd 8df0
    0006630 4629 4620 f7ff fbb8 e7c5 bf00 8634 4031
    0006640 b570 460d 4604 b150 4905 f7ff fcc1 462a
    0006650 4601 2300 4620 e8bd 4070 f7ff bc2c bd70
    0006660 8a76 4031 b510 4604 f7ff ffea 4601 b120
    0006670 4620 e8bd 4010 f7ff bcab f04f 30ff bd10
    0006680 f8d9 2058 b508 b92a 4808 f7ff f855 f04f
    0006690 30ff bd08 f8d9 2058 0792 d1f5 f8d9 0058
    00066a0 f7ff f97a 2800 d1ef bd08 bf00 8a8a 4031
    00066b0 b57f 461d 9c08 ab04 2600 f843 6d04 9300
    00066c0 00a3 f7ff ff3f 9a03 b912 4613 42a3 db02
    00066d0 4610 b004 bd70 f850 1023 ba09 f845 1023
    00066e0 3301 e7f3 b507 ab01 f7ff fbe5 3000 bf18
    00066f0 2001 b003 f85d fb04 e92d 4dff 4698 ab03
    0006700 4683 9d0e f7ff fbd7 b158 9b03 2400 f023
    0006710 0303 18c3 9301 9b01 4298 d305 9b0d 2b00
    0006720 db15 f06f 0401 e012 6806 f100 0a04 ba36
    0006730 b376 f1b8 0f00 d102 9b0d 429c d124 4631
    0006740 4658 f7ff fcaa 4607 b928 f06f 0415 4620
    0006750 b004 e8bd 8df0 f1b8 0f00 d017 f04f 33ff
    0006760 4601 4642 4658 f7ff fed1 1c43 d0ed 9a01
    0006770 eb0a 0380 429a d3e8 9b0d 429c d11d 2e00
    0006780 d0cf b94d 2400 e7e2 f04f 37ff 980c e7ee
    0006790 f04f 37ff 4630 e7ef 2810 602f bf28 2010
    00067a0 3508 f845 0c04 2300 4283 d0eb f85a 2023
    00067b0 3301 ba12 f845 2b04 e7f6 eb0a 0080 3401
    00067c0 e7a9 2200 2300 b5d0 f111 31ff d202 4610
    00067d0 4619 bdd0 f850 4b04 4617 2600 463b ba24
    00067e0 ea46 0204 e7f0 e92d 4df3 4680 9d0a 468a
    00067f0 461f 9c0b 2d01 9e0c f89d b034 d905 f04f
    0006800 35ff 4628 b002 e8bd 8df0 2c01 d8f7 ab01
    0006810 f7ff fb51 2800 d0f2 192a 9b01 437a f023
    0006820 0303 eb00 0282 4418 eb02 0785 eb07 0384
    0006830 4298 d3e4 f1bb 0f00 d00c 4651 4640 f7fe
    0006840 f9e7 4605 2e00 d0dc 4621 4638 f7ff ffb9
    0006850 6030 e7d6 4629 4610 f7ff ffb3 e7f1 b52f
    0006860 2500 9302 1b5b bf18 2301 9301 2301 9300
    0006870 462b 9503 f7ff ffb7 b004 bd20 4a02 f8c9
    0006880 2058 f7ff befd bf00 b9c4 4031 e92d 41f0
    0006890 2500 4680 460f 4616 462c 42bc db02 4628
    00068a0 e8bd 81f0 f856 1024 b131 4640 f000 ff5d
    00068b0 b910 2501 f846 0024 3401 e7ee b570 460c
    00068c0 b921 2216 4b14 601a 2000 bd70 680b 2b00
    00068d0 d1fa f040 0501 2603 fb06 f306 429d d812
    00068e0 4631 4628 f00a eb1a b159 2300 6065 60a3
    00068f0 2114 1c68 f7fe ff73 6020 3000 bf18 2001
    0006900 bd70 3502 e7e7 4631 4628 f00a eb08 2900
    0006910 d0e6 3602 e7e0 bf00 0028 80a0 b918 4b03
    0006920 2216 601a 4770 2300 6003 4770 0028 80a0
    0006930 e92d 4df0 b088 ac08 f8dd b044 e904 000f
    0006940 f8dd 8010 9c12 4640 9f05 f000 ff36 eb08
    0006950 0300 4598 d136 6861 2514 f00a eae0 460b
    0006960 2900 bf08 2301 435d 9300 6823 195a 595b
    0006970 2b00 f000 808a 1c59 9900 bf18 2100 9101
    0006980 9900 4299 f040 80a7 6851 4640 f000 feed
    0006990 2800 f040 80a0 9b10 2b01 d135 2f00 d033
    00069a0 f8d4 a00c f1ba 0f00 d011 6820 2202 9b13
    00069b0 4639 4428 3004 47d0 b148 2201 4b81 2000
    00069c0 601a e0fc f813 2d01 eb02 1000 e7c1 6823
    00069d0 442b f8d3 a00c f1ba 0f00 d007 9b13 2202
    00069e0 4639 4640 47d0 b108 2216 e7e7 6823 4638
    00069f0 eb03 0805 f000 ff05 6823 f8c8 0008 442b
    0006a00 689b b90b 220c e7d9 6823 9800 441d 3504
    0006a10 f8cb 5000 b008 e8bd 8df0 6851 4640 f000
    0006a20 fea4 2800 d177 9b10 2b01 d125 b327 68e3
    0006a30 461e b143 6820 2202 9b13 4639 4450 3004
    0006a40 47b0 2800 d1b9 6823 4453 68db 461e b133
    0006a50 9b13 2202 4639 4640 47b0 2800 d1c4 6823
    0006a60 4638 4453 9303 f000 fecc 9b03 6098 6823
    0006a70 4453 689b 2b00 d0c5 6823 4628 4453 3304
    0006a80 f8cb 3000 1c6b d046 e7c4 9d00 9301 e047
    0006a90 9d00 e045 6823 442b 68de b19e 9b13 2200
    0006aa0 4639 4640 47b0 b168 6823 2000 195a 60d0
    0006ab0 6110 f04f 32ff 515a 68a3 4413 2216 60a3
    0006ac0 4b40 e07b 6823 2001 441d 3504 f8cb 5000
    0006ad0 e7a0 2203 e772 6861 9800 3902 f00a ea1e
    0006ae0 9d00 1c4b 9302 9b02 429d bf9b 6863 9a02
    0006af0 9b02 1a9b bf94 18ed 1aed 9b00 42ab d0c7
    0006b00 2314 9900 fb03 fa05 6823 eb03 020a f853
    0006b10 300a 4299 d081 6823 f853 300a 2b00 d1e2
    0006b20 9b10 2b01 d1d5 68a2 6863 429a f43f af6a
    0006b30 9b01 4640 9a00 2b00 bf08 462b 461d 2314
    0006b40 435d 6823 515a eb03 0a05 f000 fe5a 6823
    0006b50 f8ca 0004 4638 195e f000 fe53 60b0 6820
    0006b60 4428 6843 2b00 f43f af4d 6883 2b00 f43f
    0006b70 af49 68a3 3004 3301 60a3 f7fe fb63 6820
    0006b80 4428 3004 f7fe fa52 68e6 2e00 d082 6820
    0006b90 2200 9b13 4639 4428 3004 47b0 2800 f43f
    0006ba0 af79 6823 2000 195a 60d0 6110 f04f 32ff
    0006bb0 515a 68a3 4413 9a10 60a3 4b02 601a f8cb
    0006bc0 0000 e727 0028 80a0 e92d 45f0 b08b ab05
    0006bd0 2600 4607 460d 9301 ab0a 9006 4690 9603
    0006be0 9102 9600 e913 000f f7ff fea2 4604 b930
    0006bf0 4b18 2203 601a 4620 b00b e8bd 85f0 f8d5
    0006c00 a00c f1ba 0f00 d00a 4643 2201 4631 9805
    0006c10 47d0 b120 2201 4b0f 2400 601a e7eb 2314
    0006c20 435c 682b 4423 68de b13e 4643 2201 2100
    0006c30 4638 47b0 b108 2216 e7ed 9b05 2200 609a
    0006c40 60da f04f 32ff 682b 511a 2401 68ab 4413
    0006c50 60ab e7d0 0028 80a0 e92d 4df0 b08c af04
    0006c60 4698 468b 6cbb 4615 4606 ea4f 0a83 f10a
    0006c70 030a f023 0307 ebad 0d03 ab04 607b b930
    0006c80 4b7a 2216 601a 3720 46bd e8bd 8df0 1c50
    0006c90 f7fe fd78 4604 b918 4b74 220c 601a e7f2
    0006ca0 4659 462a f000 fddf 2300 eb04 0b05 5563
    0006cb0 6cbb b123 4652 6cf9 6878 f000 fdd4 6c3b
    0006cc0 07db d404 6833 b113 4630 f7ff fe27 6833
    0006cd0 b113 b975 2001 e7d6 08e8 4631 3040 f5b0
    0006ce0 7f00 bf28 f44f 7000 f7ff fde8 2800 d1f0
    0006cf0 e7c9 6c7b b143 1e68 4623 2200 4420 455b
    0006d00 d201 7819 bb61 1aad eb04 0b05 7823 2b20
    0006d10 d037 2b09 d035 2b23 d036 4621 780a 460b
    0006d20 3101 2a3d d003 b17a 4590 d1f7 4642 469a
    0006d30 f81a 1f01 b119 4590 d001 4588 d153 2a3d
    0006d40 bf02 2200 701a 4653 2200 1c5d 701a 6cbb
    0006d50 2b00 d140 6c3a 4631 4620 f7ff ff35 e01a
    0006d60 290d d109 4283 d207 f893 e001 f1be 0f0a
    0006d70 d102 3201 3301 e7c2 eba3 0e02 f88e 1000
    0006d80 e7f8 1c65 462c e7c1 4625 f814 3b01 b10b
    0006d90 4543 d1f9 3501 455d d202 782b 2b00 d1f1
    0006da0 f8d7 a004 2400 4d32 f8df 80cc 6cbb 429c
    0006db0 da90 f8da 0000 b150 4631 6c3a f7ff ff04
    0006dc0 f8da 1000 2800 d14f 4640 f001 fa4a 3401
    0006dd0 f10a 0a04 e7ea 687a 4620 6cb9 f7ff fd56
    0006de0 2800 d0d8 e7b6 2200 701a 4653 4652 461d
    0006df0 f815 1b01 b109 4588 d107 2300 7013 7820
    0006e00 b970 4b1a 2216 601a e73d 295c d103 7859
    0006e10 2900 bf18 462b f813 1b01 f802 1b01 e7e6
    0006e20 6cbb b9cb 6c3b 613c f8c7 a014 9303 f107
    0006e30 030c 9301 2301 9300 f107 0320 9602 e913
    0006e40 000f f7ff fd75 68fb 2b00 d1a4 4652 4621
    0006e50 4808 f001 fa06 e79e 687a 4620 6cb9 f7ff
    0006e60 fd15 2800 d097 e7dd 4628 e7ae 0028 80a0
    0006e70 8aff 4031 8a97 4031 8ac8 4031 b5f0 078c
    0006e80 d00e b16a 4c1f f811 3b01 3a01 ea83 0300
    0006e90 b2db f854 3023 ea83 2010 d001 078b d1f2
    0006ea0 4c18 f002 0303 f022 0203 460e 188f 42b7
    0006eb0 d110 3a04 4411 b163 4c12 3103 18ca f811
    0006ec0 3f01 4043 4291 b2db f854 3023 ea83 2010
    0006ed0 d1f5 bdf0 f856 5b04 4068 b2c5 f854 5025
    0006ee0 ea85 2510 b2e8 f854 0020 ea80 2515 b2e8
    0006ef0 f854 0020 ea80 2015 b2c5 f854 5025 ea85
    0006f00 2010 e7d4 3d60 4031 b508 43c0 f7ff ffb6
    0006f10 43c0 bd08 e92d 4df3 4688 e9d0 4500 460e
    0006f20 2700 9001 42a9 d82c 4628 f009 ef44 fb00
    0006f30 fb08 2200 1aa4 4603 eb65 050b 2001 2100
    0006f40 2e01 f177 0e00 db03 42af bf08 42a6 d31b
    0006f50 42bd bf08 42b4 d304 1ba4 eb65 0507 1812
    0006f60 414b 0849 ea4f 0030 087f ea4f 0636 ea50
    0006f70 0e01 d1ed 9901 4620 e9c1 2300 b002 e8bd
    0006f80 8df0 2200 2300 e7d9 19b6 417f 1800 4149
    0006f90 e7d6 0000 4804 b508 f7fe fbce f06f 001d
    0006fa0 f7fc fe12 e7fe bf00 8c30 4031 4904 4603
    0006fb0 4618 3301 7802 5c8a 0692 d4f9 4770 bf00
    0006fc0 8b30 4031 b510 f7ff fff1 4604 f000 fbf5
    0006fd0 b138 4908 3801 4420 42a0 4603 d203 2200
    0006fe0 705a 4620 bd10 781a 3801 5c8a 0692 d4f3
    0006ff0 e7f5 bf00 8b30 4031 f8d0 3200 2bff bfcf
    0007000 4b04 1c5a f8c0 2200 54c1 bfc8 f8c0 3210
    and much more .......
    here the last few line of output:
    015e100 0000 0400 0000 0300 0000 0c00 0000 ca04
    015e110 0000 cb00 0000 7700 0000 0000 0000 0300
    015e120 0000 0300 0000 cf04 7872 0000 0000 0300
    015e130 0000 0400 0000 4601 0000 0800 0000 0300
    015e140 0000 0400 0000 4d01 6366 006b 0000 0200
    015e150 0000 0100 6e72 4067 3834 3930 3030 3030
    015e160 0000 0000 0000 0300 0000 0d00 0000 1b00
    015e170 6974 6f2c 616d 3470 722d 676e 0000 0000
    015e180 0000 0300 0000 0400 0000 e401 6e72 0067
    015e190 0000 0300 0000 0800 0000 1401 0948 0000
    015e1a0 0000 0020 0000 0300 0000 0c00 0000 e300
    015e1b0 0000 0000 0000 2f00 0000 0400 0000 0300
    015e1c0 0000 0400 0000 4601 0000 0800 0000 0300
    015e1d0 0000 0400 0000 4d01 6366 006b 0000 0200
    015e1e0 0000 0100 6d6f 7061 645f 6377 5f33 4034
    015e1f0 3834 3439 3030 3030 0000 0000 0000 0300
    015e200 0000 0800 0000 1b00 6974 642c 6377 0033
    015e210 0000 0300 0000 0c00 0000 e401 7375 5f62
    015e220 746f 5f67 7373 0034 0000 0300 0000 0800
    015e230 0000 1401 9448 0000 0100 0000 0000 0300
    015e240 0000 0c00 0000 e300 0000 0000 0000 5a01
    015e250 0000 0400 0000 0300 0000 0400 0000 0000
    015e260 0000 0100 0000 0300 0000 0400 0000 0f00
    015e270 0000 0100 0000 0300 0000 0400 0000 b708
    015e280 0000 0200 0000 0300 0000 0000 0000 ee01
    015e290 0000 0300 0000 0900 0000 4f04 6964 6173
    015e2a0 6c62 6465 0000 0000 0000 0100 7375 4062
    015e2b0 3834 3539 3030 3030 0000 0000 0000 0300
    015e2c0 0000 0a00 0000 1b00 6e73 7370 642c 6377
    015e2d0 0033 0000 0000 0300 0000 0800 0000 1401
    015e2e0 9548 0000 0100 0070 0000 0300 0000 0c00
    015e2f0 0000 e300 0000 0000 0000 5901 0000 0400
    015e300 0000 0300 0000 0000 0000 940a 0000 0300
    015e310 0000 0b00 0000 c108 6968 6867 732d 6570
    015e320 6465 0000 0000 0300 0000 0400 0000 cf08
    015e330 746f 0067 0000 0200 0000 0200 0000 0200
    015e340 0000 0100 6874 7265 616d 2d6c 6f7a 656e
    015e350 0073 0000 0000 0100 7063 5f75 6874 7265
    015e360 616d 006c 0000 0300 0000 0400 0000 a30a
    015e370 0000 fa00 0000 0300 0000 0400 0000 b90a
    015e380 0000 f401 0000 0300 0000 0800 0000 c70a
    015e390 0000 ea00 0000 0000 0000 0300 0000 0800
    015e3a0 0000 d70a 0000 0000 0000 d007 0000 0100
    015e3b0 7274 7069 0073 0000 0000 0100 7063 5f75
    015e3c0 6c61 7265 0074 0000 0000 0300 0000 0400
    015e3d0 0000 e40a 0100 905f 0000 0300 0000 0400
    015e3e0 0000 f00a 0000 d007 0000 0300 0000 0800
    015e3f0 0000 2d01 6170 7373 7669 0065 0000 0300
    015e400 0000 0400 0000 1801 0000 eb00 0000 0300
    015e410 0000 0400 0000 1e01 0000 eb00 0000 0200
    015e420 0000 0100 7063 5f75 7263 7469 0000 0000
    015e430 0000 0300 0000 0400 0000 e40a 0100 289a
    015e440 0000 0300 0000 0400 0000 f00a 0000 d007
    015e450 0000 0300 0000 0900 0000 2d01 7263 7469
    015e460 6369 6c61 0000 0000 0000 0200 0000 0200
    015e470 0000 0100 6f63 6c6f 6e69 2d67 616d 7370
    015e480 0000 0000 0000 0100 616d 3070 0000 0000
    015e490 0000 0300 0000 0400 0000 fb0a 0000 eb00
    015e4a0 0000 0300 0000 0c00 0000 000b 0000 ec00
    015e4b0 ffff ffff ffff ffff 0000 0200 0000 0200
    015e4c0 0000 0200 0000 0100 7067 5f75 6874 7265
    015e4d0 616d 006c 0000 0300 0000 0400 0000 a30a
    015e4e0 0000 fa00 0000 0300 0000 0400 0000 b90a
    015e4f0 0000 f401 0000 0300 0000 0800 0000 c70a
    015e500 0000 ea00 0000 0100 0000 0300 0000 0800
    015e510 0000 d70a 0000 0000 0000 d007 0000 0100
    015e520 7274 7069 0073 0000 0000 0100 7067 5f75
    015e530 7263 7469 0000 0000 0000 0300 0000 0400
    015e540 0000 e40a 0100 289a 0000 0300 0000 0400
    015e550 0000 f00a 0000 d007 0000 0300 0000 0900
    015e560 0000 2d01 7263 7469 6369 6c61 0000 0000
    015e570 0000 0200 0000 0200 0000 0200 0000 0100
    015e580 6f63 6572 745f 6568 6d72 6c61 0000 0000
    015e590 0000 0300 0000 0400 0000 a30a 0000 fa00
    015e5a0 0000 0300 0000 0400 0000 b90a 0000 f401
    015e5b0 0000 0300 0000 0800 0000 c70a 0000 ea00
    015e5c0 0000 0200 0000 0300 0000 0800 0000 d70a
    015e5d0 0000 0000 0000 d007 0000 0100 7274 7069
    015e5e0 0073 0000 0000 0100 6f63 6572 635f 6972
    015e5f0 0074 0000 0000 0300 0000 0400 0000 e40a
    015e600 0100 289a 0000 0300 0000 0400 0000 f00a
    015e610 0000 d007 0000 0300 0000 0900 0000 2d01
    015e620 7263 7469 6369 6c61 0000 0000 0000 0200
    015e630 0000 0200 0000 0200 0000 0100 7364 6570
    015e640 6576 745f 6568 6d72 6c61 0000 0000 0300
    015e650 0000 0400 0000 a30a 0000 fa00 0000 0300
    015e660 0000 0400 0000 b90a 0000 f401 0000 0300
    015e670 0000 0800 0000 c70a 0000 ea00 0000 0300
    015e680 0000 0300 0000 0800 0000 d70a 0000 0000
    015e690 0000 d007 0000 0100 7274 7069 0073 0000
    015e6a0 0000 0100 7364 6570 6576 635f 6972 0074
    015e6b0 0000 0300 0000 0400 0000 e40a 0100 289a
    015e6c0 0000 0300 0000 0400 0000 f00a 0000 d007
    015e6d0 0000 0300 0000 0900 0000 2d01 7263 7469
    015e6e0 6369 6c61 0000 0000 0000 0200 0000 0200
    015e6f0 0000 0200 0000 0100 7669 5f61 6874 7265
    015e700 616d 006c 0000 0300 0000 0400 0000 a30a
    015e710 0000 fa00 0000 0300 0000 0400 0000 b90a
    015e720 0000 f401 0000 0300 0000 0800 0000 c70a
    015e730 0000 ea00 0000 0400 0000 0300 0000 0800
    015e740 0000 d70a 0000 0000 0000 d007 0000 0100
    015e750 7274 7069 0073 0000 0000 0100 7669 5f61
    015e760 7263 7469 0000 0000 0000 0300 0000 0400
    015e770 0000 e40a 0100 289a 0000 0300 0000 0400
    015e780 0000 f00a 0000 d007 0000 0300 0000 0900
    015e790 0000 2d01 7263 7469 6369 6c61 0000 0000
    015e7a0 0000 0200 0000 0200 0000 0200 0000 0200
    015e7b0 0000 0100 6d70 0075 0000 0300 0000 1300
    015e7c0 0000 1b00 7261 2c6d 6f63 7472 7865 612d
    015e7d0 3531 702d 756d 0000 0000 0300 0000 0400
    015e7e0 0000 2600 0000 0600 0000 0300 0000 1800
    015e7f0 0000 e300 0000 0000 0000 8300 0000 0400
    015e800 0000 0000 0000 8400 0000 0400 0000 0200
    015e810 0000 0100 6966 6578 7264 6765 6c75 7461
    015e820 726f 762d 616d 6e69 0000 0000 0000 0300
    015e830 0000 1000 0000 1b00 6572 7567 616c 6f74
    015e840 2d72 6966 6578 0064 0000 0300 0000 0600
    015e850 0000 1702 4d56 4941 004e 0000 0000 0300
    015e860 0000 0400 0000 2602 4c00 404b 0000 0300
    015e870 0000 0400 0000 3e02 4c00 404b 0000 0300
    015e880 0000 0000 0000 4006 0000 0300 0000 0000
    015e890 0000 5406 0000 0300 0000 0400 0000 1801
    015e8a0 0000 af00 0000 0300 0000 0400 0000 1e01
    015e8b0 0000 af00 0000 0200 0000 0100 6966 6578
    015e8c0 7264 6765 6c75 7461 726f 762d 5f33 6433
    015e8d0 0000 0000 0000 0300 0000 1000 0000 1b00
    015e8e0 6572 7567 616c 6f74 2d72 6966 6578 0064
    015e8f0 0000 0300 0000 0600 0000 1702 3356 335f
    015e900 0044 0000 0000 0300 0000 0400 0000 0f0b
    015e910 0000 ed00 0000 0300 0000 0400 0000 2602
    015e920 3200 a05a 0000 0300 0000 0400 0000 3e02
    015e930 3200 a05a 0000 0300 0000 0000 0000 4006
    015e940 0000 0300 0000 0000 0000 5406 0000 0300
    015e950 0000 0400 0000 1801 0000 b200 0000 0300
    015e960 0000 0400 0000 1e01 0000 b200 0000 0200
    015e970 0000 0100 6966 6578 7264 6765 6c75 7461
    015e980 726f 762d 7474 0000 0000 0300 0000 1000
    015e990 0000 1b00 6572 7567 616c 6f74 2d72 6966
    015e9a0 6578 0064 0000 0300 0000 0a00 0000 1702
    015e9b0 7476 5f74 6966 6578 0064 0000 0000 0300
    015e9c0 0000 0400 0000 0f0b 0000 b200 0000 0300
    015e9d0 0000 0400 0000 2602 3200 a05a 0000 0300
    015e9e0 0000 0400 0000 3e02 3200 a05a 0000 0300
    015e9f0 0000 0000 0000 4006 0000 0300 0000 0000
    015ea00 0000 5406 0000 0200 0000 0100 656d 6f6d
    015ea10 7972 3040 0000 0000 0000 0300 0000 0700
    015ea20 0000 2601 656d 6f6d 7972 0000 0000 0300
    015ea30 0000 1000 0000 1401 0000 0000 0080 0000
    015ea40 0000 0000 0080 0000 0000 0200 0000 0100
    015ea50 7865 6374 6e6f 755f 6273 0032 0000 0300
    015ea60 0000 1600 0000 1b00 696c 756e 2c78 7865
    015ea70 6374 6e6f 752d 6273 672d 6970 006f 0000
    015ea80 0000 0300 0000 0c00 0000 1a0b 0000 ee00
    015ea90 0000 1000 0000 0000 0000 0300 0000 0400
    015eaa0 0000 1801 0000 c900 0000 0300 0000 0400
    015eab0 0000 1e01 0000 c900 0000 0200 0000 0100
    015eac0 7473 7461 7375 6c2d 6465 0073 0000 0300
    015ead0 0000 0a00 0000 1b00 7067 6f69 6c2d 6465
    015eae0 0073 0000 0000 0100 7063 3075 6c2d 6465
    015eaf0 0000 0000 0000 0300 0000 1100 0000 6308
    015eb00 7473 7461 7375 3a30 6572 3a64 7063 3075
    015eb10 0000 0000 0000 0300 0000 0c00 0000 f906
    015eb20 0000 ef00 0000 0000 0000 0000 0000 0300
    015eb30 0000 0400 0000 220b 666f 0066 0000 0300
    015eb40 0000 0500 0000 300b 7063 3075 0000 0000
    015eb50 0000 0200 0000 0100 7375 3072 6c2d 6465
    015eb60 0000 0000 0000 0300 0000 1200 0000 6308
    015eb70 7473 7461 7375 3a30 7267 6565 3a6e 7375
    015eb80 0072 0000 0000 0300 0000 0c00 0000 f906
    015eb90 0000 ee00 0000 0b00 0000 0000 0000 0300
    015eba0 0000 0400 0000 220b 666f 0066 0000 0200
    015ebb0 0000 0100 6568 7261 6274 6165 2d74 656c
    015ebc0 0064 0000 0000 0300 0000 1700 0000 6308
    015ebd0 7473 7461 7375 3a30 6c62 6575 683a 6165
    015ebe0 7472 6562 7461 0000 0000 0300 0000 0c00
    015ebf0 0000 f906 0000 ee00 0000 0c00 0000 0000
    015ec00 0000 0300 0000 0400 0000 220b 666f 0066
    015ec10 0000 0300 0000 0a00 0000 300b 6568 7261
    015ec20 6274 6165 0074 0000 0000 0200 0000 0100
    015ec30 7063 3175 6c2d 6465 0000 0000 0000 0300
    015ec40 0000 1100 0000 6308 7473 7461 7375 3a31
    015ec50 6572 3a64 7063 3175 0000 0000 0000 0300
    015ec60 0000 0c00 0000 f906 0000 ee00 0000 0a00
    015ec70 0000 0000 0000 0300 0000 0400 0000 220b
    015ec80 666f 0066 0000 0300 0000 0500 0000 300b
    015ec90 7063 3175 0000 0000 0000 0200 0000 0100
    015eca0 7375 3172 6c2d 6465 0000 0000 0000 0300
    015ecb0 0000 1200 0000 6308 7473 7461 7375 3a31
    015ecc0 7267 6565 3a6e 7375 0072 0000 0000 0300
    015ecd0 0000 0c00 0000 f906 0000 f000 0000 1700
    015ece0 0000 0000 0000 0300 0000 0400 0000 220b
    015ecf0 666f 0066 0000 0200 0000 0100 6d6d 3063
    015ed00 6c2d 6465 0000 0000 0000 0300 0000 1200
    015ed10 0000 6308 7473 7461 7375 3a31 6c62 6575
    015ed20 6d3a 636d 0030 0000 0000 0300 0000 0c00
    015ed30 0000 f906 0000 f000 0000 1600 0000 0000
    015ed40 0000 0300 0000 0400 0000 220b 666f 0066
    015ed50 0000 0300 0000 0500 0000 300b 6d6d 3063
    015ed60 0000 0000 0000 0200 0000 0200 0000 0200
    015ed70 0000 0900 6123 6464 6572 7373 632d 6c65
    015ed80 736c 2300 6973 657a 632d 6c65 736c 6300
    015ed90 6d6f 6170 6974 6c62 0065 6e69 6574 7272
    015eda0 7075 2d74 6170 6572 746e 6d00 646f 6c65
    015edb0 7300 6474 756f 2d74 6170 6874 6900 6332
    015edc0 0030 3269 3163 6900 6332 0032 3269 3363
    015edd0 6900 6332 0034 6573 6972 6c61 0030 6573
    015ede0 6972 6c61 0031 6573 6972 6c61 0032 6573
    015edf0 6972 6c61 0033 6573 6972 6c61 0034 6573
    015ee00 6972 6c61 0035 6573 6972 6c61 0036 6573
    015ee10 6972 6c61 0037 6573 6972 6c61 0038 6573
    015ee20 6972 6c61 0039 7465 6568 6e72 7465 0030
    015ee30 7465 6568 6e72 7465 0031 5f64 6163 306e
    015ee40 6400 635f 6e61 0031 7073 3069 7200 6374
    015ee50 0030 7472 3163 6900 746e 7265 7572 7470
    015ee60 0073 6e69 6574 7272 7075 2d74 6f63 746e
    015ee70 6f72 6c6c 7265 2300 6e69 6574 7272 7075
    015ee80 2d74 6563 6c6c 0073 6572 0067 696c 756e
    015ee90 2c78 6870 6e61 6c64 0065 6564 6976 6563
    015eea0 745f 7079 0065 706f 7265 7461 6e69 2d67
    015eeb0 6f70 6e69 7374 762d 0032 6c63 636f 736b
    015eec0 6300 6f6c 6b63 6e2d 6d61 7365 6300 6f6c
    015eed0 6b63 6c2d 7461 6e65 7963 6300 6f6f 696c
    015eee0 676e 6d2d 6e69 6c2d 7665 6c65 6300 6f6f
    015eef0 696c 676e 6d2d 7861 6c2d 7665 6c65 2300
    015ef00 6f63 6c6f 6e69 2d67 6563 6c6c 0073 706f
    015ef10 7265 7461 6e69 2d67 6f70 6e69 7374 7300
    015ef20 7379 6f63 006e 706f 2d70 7a68 6f00 7070
    015ef30 6d2d 6369 6f72 6f76 746c 6f00 7070 732d
    015ef40 7075 6f70 7472 6465 682d 0077 706f 2d70
    015ef50 7573 7073 6e65 0064 6974 682c 6d77 646f
    015ef60 0073 6172 676e 7365 6900 746e 7265 7572
    015ef70 7470 2d73 7865 6574 646e 6465 7500 622d
    015ef80 6f6f 2c74 6d64 732d 6c70 7200 6765 6c75
    015ef90 7461 726f 6e2d 6d61 0065 6572 7567 616c
    015efa0 6f74 2d72 696d 2d6e 696d 7263 766f 6c6f
    015efb0 0074 6572 7567 616c 6f74 2d72 616d 2d78
    015efc0 696d 7263 766f 6c6f 0074 6323 6f6c 6b63
    015efd0 632d 6c65 736c 7400 2c69 6962 2d74 6873
    015efe0 6669 0074 6974 6d2c 7861 642d 7669 7400
    015eff0 2c69 616c 6374 2d68 6962 0074 7361 6973
    015f000 6e67 6465 632d 6f6c 6b63 0073 7361 6973
    015f010 6e67 6465 632d 6f6c 6b63 722d 7461 7365
    015f020 6100 7373 6769 656e 2d64 6c63 636f 2d6b
    015f030 6170 6572 746e 0073 7023 6e69 7463 6c72
    015f040 632d 6c65 736c 7000 6e69 7463 6c72 732d
    015f050 6e69 6c67 2c65 6572 6967 7473 7265 772d
    015f060 6469 6874 7000 6e69 7463 6c72 732d 6e69
    015f070 6c67 2c65 7566 636e 6974 6e6f 6d2d 7361
    015f080 006b 6970 636e 7274 2d6c 6973 676e 656c
    015f090 702c 6e69 0073 6423 616d 632d 6c65 736c
    015f0a0 6400 616d 722d 7165 6575 7473 0073 6974
    015f0b0 642c 616d 732d 6661 2d65 616d 0070 6d64
    015f0c0 2d61 616d 7473 7265 0073 6c63 636f 2d6b
    015f0d0 7266 7165 6575 636e 0079 6c63 636f 2d6b
    015f0e0 756d 746c 6300 6f6c 6b63 642d 7669 7400
    015f0f0 2c69 7561 6f74 6469 656c 732d 6968 7466
    015f100 7400 2c69 6e69 6564 2d78 7473 7261 7374
    015f110 612d 2d74 6e6f 0065 6974 692c 766e 7265
    015f120 2d74 7561 6f74 6469 656c 622d 7469 7400
    015f130 2c69 6e69 6564 2d78 6f70 6577 2d72 666f
    015f140 742d 6f77 7400 2c69 6964 6976 6564 7372
    015f150 7400 2c69 6573 2d74 6172 6574 702d 7261
    015f160 6e65 0074 6572 2d67 616e 656d 0073 7562
    015f170 2d73 6172 676e 0065 756e 2d6d 616c 656e
    015f180 0073 696c 756e 2c78 6370 2d69 6f64 616d
    015f190 6e69 7000 7968 0073 6870 2d79 616e 656d
    015f1a0 0073 6e69 6574 7272 7075 2d74 616d 2d70
    015f1b0 616d 6b73 6900 746e 7265 7572 7470 6d2d
    015f1c0 7061 7300 6174 7574 0073 7423 6568 6d72
    015f1d0 6c61 732d 6e65 6f73 2d72 6563 6c6c 0073
    015f1e0 6970 636e 7274 2d6c 6970 2d6e 7261 6172
    015f1f0 0079 6d64 2d61 6863 6e61 656e 736c 6900
    015f200 746e 7265 7572 7470 6e2d 6d61 7365 7400
    015f210 2c69 7074 6374 0073 7067 6f69 632d 6e6f
    015f220 7274 6c6f 656c 0072 6723 6970 2d6f 6563
    015f230 6c6c 0073 6572 2d67 6873 6669 0074 6d64
    015f240 7361 6400 616d 6e2d 6d61 7365 2300 626d
    015f250 786f 632d 6c65 736c 7400 2c69 626d 786f
    015f260 6e2d 6d75 752d 6573 7372 7400 2c69 626d
    015f270 786f 6e2d 6d75 662d 6669 736f 7400 2c69
    015f280 6974 656d 2d72 6c61 6f77 006e 6974 742c
    015f290 6d69 7265 732d 6365 7275 0065 6823 6c77
    015f2a0 636f 2d6b 6563 6c6c 0073 6974 732c 7379
    015f2b0 6574 2d6d 6f70 6577 2d72 6f63 746e 6f72
    015f2c0 6c6c 7265 7300 706d 3173 2d32 6e69 732d
    015f2d0 7075 6c70 0079 6d73 7370 2d33 6e69 732d
    015f2e0 7075 6c70 0079 6d73 7370 3534 692d 2d6e
    015f2f0 7573 7070 796c 7300 706d 3673 692d 2d6e
    015f300 7573 7070 796c 7300 706d 3773 692d 2d6e
    015f310 7573 7070 796c 7300 706d 3873 692d 2d6e
    015f320 7573 7070 796c 7300 706d 3973 692d 2d6e
    015f330 7573 7070 796c 6c00 6f64 2d31 6e69 732d
    015f340 7075 6c70 0079 646c 326f 692d 2d6e 7573
    015f350 7070 796c 6c00 6f64 2d33 6e69 732d 7075
    015f360 6c70 0079 646c 346f 692d 2d6e 7573 7070
    015f370 796c 6c00 6f64 2d39 6e69 732d 7075 6c70
    015f380 0079 646c 6c6f 2d6e 6e69 732d 7075 6c70
    015f390 0079 646c 756f 6273 692d 2d6e 7573 7070
    015f3a0 796c 6c00 6f64 7472 2d63 6e69 732d 7075
    015f3b0 6c70 0079 6572 7567 616c 6f74 2d72 6c61
    015f3c0 6177 7379 6f2d 006e 6572 7567 616c 6f74
    015f3d0 2d72 6f62 746f 6f2d 006e 6177 656b 7075
    015f3e0 732d 756f 6372 0065 6974 702c 6c61 616d
    015f3f0 2d73 6f6c 676e 702d 6572 7373 732d 6365
    015f400 6e6f 7364 7400 2c69 7564 6c61 762d 6c6f
    015f410 0074 6974 6e2c 6565 7364 732d 6570 6963
    015f420 6c61 722d 7365 7465 7000 6962 7361 732d
    015f430 7075 6c70 0079 616d 2d78 7266 7165 6575
    015f440 636e 0079 6d76 636d 732d 7075 6c70 0079
    015f450 6d76 636d 615f 7875 732d 7075 6c70 0079
    015f460 7562 2d73 6977 7464 0068 6463 672d 6970
    015f470 736f 7000 6e69 7463 6c72 6e2d 6d61 7365
    015f480 7000 6e69 7463 6c72 302d 7300 2d64 6875
    015f490 2d73 6473 3272 0035 6473 752d 7368 732d
    015f4a0 7264 3231 6d00 636d 642d 7264 312d 385f
    015f4b0 0076 6974 6e2c 6e6f 722d 6d65 766f 6261
    015f4c0 656c 6e00 2d6f 2d31 2d38 0076 6473 752d
    015f4d0 7368 732d 7264 3035 2300 6f69 6d6d 2d75
    015f4e0 6563 6c6c 0073 6974 732c 7379 6f63 2d6e
    015f4f0 6d6d 6375 6e6f 6966 0067 6974 692c 6d6f
    015f500 756d 622d 7375 652d 7272 622d 6361 006b
    015f510 6974 732c 7465 6c74 6e69 2d67 6974 656d
    015f520 7400 2c69 6c63 636f 2d6b 7963 6c63 7365
    015f530 7400 2c69 7274 6e61 6478 6e6f 2d65 7473
    015f540 7461 7375 6d2d 7361 006b 6974 6c2c 6f64
    015f550 6276 2d62 766f 7265 6972 6564 6d2d 7361
    015f560 006b 6974 6c2c 6f64 6276 2d62 7376 7465
    015f570 6d2d 7361 006b 6974 612c 6262 695f 666e
    015f580 006f 6974 732c 6970 6e2d 6d75 632d 0073
    015f590 7973 6373 6e6f 632d 6968 7370 6c65 6365
    015f5a0 7374 7300 6970 6d2d 7861 662d 6572 7571
    015f5b0 6e65 7963 7300 6970 742d 2d78 7562 2d73
    015f5c0 6977 7464 0068 7073 2d69 7872 622d 7375
    015f5d0 772d 6469 6874 6c00 6261 6c65 7300 7379
    015f5e0 6f63 2d6e 6870 2d79 6f70 6577 0072 7973
    015f5f0 6373 6e6f 702d 6c6c 6572 6573 0074 7023
    015f600 7968 632d 6c65 736c 7300 7379 6f63 2d6e
    015f610 6370 0073 7865 2d74 6c63 2d6b 7273 0063
    015f620 6870 2d79 7573 7070 796c 7500 6d74 2d69
    015f630 6f6d 6564 6d00 7861 6d69 6d75 732d 6570
    015f640 6465 6400 5f72 6f6d 6564 7300 706e 2c73
    015f650 6964 5f73 3375 735f 7375 6870 5f79 7571
    015f660 7269 006b 6e73 7370 642c 7369 755f 5f32
    015f670 7573 7073 7968 715f 6975 6b72 6500 7478
    015f680 6f63 006e 7067 636d 6e2c 6d75 632d 0073
    015f690 7067 636d 6e2c 6d75 772d 6961 7074 6e69
    015f6a0 0073 6974 702c 6f72 6976 6564 2d64 6c63
    015f6b0 636f 736b 7400 2c69 616d 2d78 7269 7371
    015f6c0 7400 2c69 616d 2d78 7263 736f 6273 7261
    015f6d0 732d 756f 6372 7365 7400 2c69 6572 2d67
    015f6e0 6973 657a 7400 2c69 7269 7371 722d 7365
    015f6f0 7265 6576 0064 6974 692c 7172 2d73 6b73
    015f700 7069 7400 2c69 7269 7371 732d 6661 2d65
    015f710 616d 0070 7063 6d64 5f61 6863 6e61 656e
    015f720 736c 6100 656c 655f 746e 6972 7365 6200
    015f730 5f64 6172 5f6d 6973 657a 6e00 5f6f 6462
    015f740 725f 6d61 6d00 6361 635f 6e6f 7274 6c6f
    015f750 7300 616c 6576 0073 6361 6974 6576 735f
    015f760 616c 6576 6300 7470 5f73 6c63 636f 5f6b
    015f770 756d 746c 6300 7470 5f73 6c63 636f 5f6b
    015f780 6873 6669 0074 6974 6e2c 2d6f 6469 656c
    015f790 6400 6175 5f6c 6d65 6361 6200 7375 665f
    015f7a0 6572 0071 616d 2d63 6461 7264 7365 0073
    015f7b0 6870 5f79 6469 7000 7968 6d2d 646f 0065
    015f7c0 7564 6c61 655f 616d 5f63 6572 5f73 6c76
    015f7d0 6e61 7300 7379 6f63 2d6e 6172 696d 696e
    015f7e0 0074 7973 6373 6e6f 702d 6c6c 632d 7274
    015f7f0 006c 7973 6373 6e6f 702d 6c6f 2300 7770
    015f800 2d6d 6563 6c6c 0073 7874 662d 6669 2d6f
    015f810 6572 6973 657a 7000 6c6f 696c 676e 642d
    015f820 6c65 7961 702d 7361 6973 6576 7000 6c6f
    015f830 696c 676e 642d 6c65 7961 7400 6568 6d72
    015f840 6c61 732d 6e65 6f73 7372 6300 656f 6666
    015f850 6369 6569 746e 0073 6574 706d 7265 7461
    015f860 7275 0065 7968 7473 7265 7365 7369 7400
    015f870 6972 0070 6f63 6c6f 6e69 2d67 6564 6976
    015f880 6563 7600 6e69 732d 7075 6c70 0079 6469
    015f890 672d 6970 006f 6564 6166 6c75 2d74 7473
    015f8a0 7461 0065 696c 756e 2c78 6564 6166 6c75
    015f8b0 2d74 7274 6769 6567 0072 0000 0000 0000
    015f8c0 0000 0000 0000 0000 0000 0000 0000 0000
    0400000
  • Hello Kemal,
             I have some doubt about boot-up process.I listedout it below:
            Is there any step missed by us?.
            Any configuration require before follow your steps?
    Thanks.
  • Hello Margarita,
    We visited many blogs/forums,
    Tried many procedure,
    But still we are not able to boot from eMMC.
    Please help us, we are stuck at this point.
    Thank You.
  • Hello kishan and Omkareshwar,
    Here I am posting you a different method to boot AM572x EVM from eMMC.
    Download and install the latest AM57x Processor SDK.
    Copy these files <Processor SDK>/board-support/prebuilt-images/MLO-am57xx-evm, <Processor SDK>/board-support/prebuilt-images/u-boot-am57xx-evm.img and <Processor SDK>/filesystem/tisdk-rootfs-image-am57xx-evm.tar.xz to your SD card.
    Put the SD card to your AM572x EVM and boot the board. Then type these commands:
    am57xx-evm login: root
    root@am57xx-evm:~# echo 0 > /sys/block/mmcblk1boot0/force_ro
    root@am57xx-evm:~# echo 0 > /sys/block/mmcblk1boot1/force_ro
    root@am57xx-evm:~# dd if=/dev/zero of=/dev/mmcblk1boot0 bs=512
    root@am57xx-evm:~# dd if=/dev/zero of=/dev/mmcblk1boot1 bs=512
    root@am57xx-evm:~# umount /dev/mmcblk1p1
    root@am57xx-evm:~# umount /dev/mmcblk1p2
    root@am57xx-evm:~# fdisk /dev/mmcblk1
    Type:
    1. p - print the partition table
    2. o - create a new empty DOS partition table
    3. p - print the partition table
    4. n - add a new partition
    5. p - primary
    6. 1 - default
    7. 2048 - default
    8. 145407 - sectors
    9. t - change a partition type
    10. c - W95 FAT32 (LBA)
    11. p - print the partition table
    12. a - toggle a bootable flag
    13. p - print the partition table
    14. n - add a new partition
    15. Press 4 times Enter and take the default values
    16. p - print the partition table
    17. w - write table to disk and exit
    root@am57xx-evm:~# mkfs.vfat /dev/mmcblk1p1
    root@am57xx-evm:~# mkfs.ext4 /dev/mmcblk1p2
    Press 'y' if it ask you to proceed anyway.
    root@am57xx-evm:~# mkdir boot
    root@am57xx-evm:~# mount -t vfat /dev/mmcblk1p1 boot/
    root@am57xx-evm:~# cp MLO-am57xx-evm boot/MLO
    root@am57xx-evm:~# cp u-boot-am57xx-evm.img boot/u-boot.img
    root@am57xx-evm:~# mkdir rootfs
    root@am57xx-evm:~# mount -t ext4 /dev/mmcblk1p2 rootfs/
    root@am57xx-evm:~# tar xvf tisdk-rootfs-image-am57xx-evm.tar.xz -C rootfs/
    root@am57xx-evm:~# sync
    root@am57xx-evm:~# shutdown now
    Eject the SD card from the board and press the power on button.
    Your board will boot from eMMC hereafter.
    Kemal
  • Hello Kemal,
    The logs I got in first 3 steps are as follow:
    dd: writing '/dev/mmcblk1boot0': No space left on device
    8193+0 records in
    8192+0 records out
    I have some doubt at "dd: writing '/dev/mmcblk1boot0': No space left on device".
    Should I proceed further ?
    Thank You,
    Omkareshwar Tripathi
  • This is expected. Tell me the final result. Does the board successfully boot from eMMC?
  • Hello Kemal,
    Thanks for your early reply,
    Here are some logs for which I am having some doubt. Please go through it and give me the clearance.
    8193+0 records in
    8192+0 records out
    dd: writing '/dev/mmcblk1boot1': No space left on device
    8193+0 records in
    8192+0 records out
    [17292.517164] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
    umount: /dev/mmcblk1p2: mountpoint not found
    Welcome to fdisk (util-linux 2.28.1).
    Changes will remain in memory only, until you decide to write them.
    Be careful before using the write command.
    Command (m for help): p
    Disk /dev/mmcblk1: 3.6 GiB, 3825205248 bytes, 7471104 sectors
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disklabel type: dos
    Disk identifier: 0xf23e8ffc
    Device Boot Start End Sectors Size Id Type
    /dev/mmcblk1p1 2048 7471103 7469056 3.6G 83 Linux
    Command (m for help): o
    Created a new DOS disklabel with disk identifier 0x300904e8.
    Disklabel type: dos
    Disk identifier: 0x300904e8
    Command (m for help): n
    Partition type
    p primary (0 primary, 0 extended, 4 free)
    e extended (container for logical partitions)
    Select (default p): p
    Partition number (1-4, default 1): 1
    First sector (2048-7471103, default 2048): 2048
    Last sector, +sectors or +size{K,M,G,T,P} (2048-7471103, default 7471103): 145407
    Created a new partition 1 of type 'Linux' and of size 70 MiB.
    Command (m for help): t
    Selected partition 1
    Partition type (type L to list all types): c
    Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
    Disklabel type: dos
    /dev/mmcblk1p1 2048 145407 143360 70M c W95 FAT32 (LBA)
    Command (m for help): a
    The bootable flag on partition 1 is enabled now.
    Disklabel type: dos
    /dev/mmcblk1p1 * 2048 145407 143360 70M c W95 FAT32 (LBA)
    Partition type
    p primary (1 primary, 0 extended, 3 free)
    Select (default p):
    Using default response p.
    Partition number (2-4, default 2):
    First sector (145408-7471103, default 145408):
    Last sector, +sectors or +size{K,M,G,T,P} (145408-7471103, default 7471103):
    Created a new partition 2 of type 'Linux' and of size 3.5 GiB.
    Disklabel type: dos
    /dev/mmcblk1p2 145408 7471103 7325696 3.5G 83 Linux
    Command (m for help): w
    The partition table has been altered.
    Calling ioctl() to re-read partition table.
    Re-reading the partition table failed.: Device or resource busy
    The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
    mkfs.fat 4.0 (2016-05-06)
    mkfs.vfat: unable to open /dev/mmcblk1p1: Device or resource busy
    root@am57xx-evm:~# mkfs.ext3 /dev/mmcblk1p2
    mke2fs 1.43 (17-May-2016)
    The file /dev/mmcblk1p2 does not exist and no size was specified.
    Thank You,
  • I could not boot-up EVM by eMMC.
    I want to know steps from beginning.
  • Hello Kemal,
    I followed your step but evm could not boot-up by eMMC.It can boot-up by memory card perfectly.
    Here,i am facing same issue as Omkar.
    Thanks.
  • Reboot the board, repeat the same steps, then post the log.
  • Hello Kemal,
    I tried your mentioned steps and I got this logs:
    U-Boot SPL 2017.01-g340fb36f04 (Dec 23 2017 - 11:25:49)
    DRA752-GP ES2.0
    Trying to boot from MMC1
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    U-Boot 2017.01-g340fb36f04 (Dec 23 2017 - 11:25:49 -0500)
    CPU : DRA752-GP ES2.0
    Model: TI AM572x EVM Rev A3
    Board: AM572x EVM REV A.30
    DRAM: 2 GiB
    MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
    SCSI: SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net: cpsw
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    ** File not found boot.scr **
    ** Unrecognized filesystem type **
    Failed to mount ext2 filesystem...
    Trying to boot Linux from eMMC ...
    Trying to boot Android from eMMC ...
    mmc - MMC sub system
    Usage:
    mmc info - display info of the current MMC device
    mmc read addr blk# cnt
    mmc write addr blk# cnt
    mmc erase blk# cnt
    mmc rescan
    mmc part - lists available partition on current mmc device
    mmc dev [dev] [part] - show or set current mmc device [partition]
    mmc list - lists available devices
    mmc hwpartition [args...] - does hardware partitioning
    arguments (sizes in 512-byte blocks):
    [user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
    [gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
    [check|set|complete] - mode, complete set partitioning completed
    WARNING: Partitioning is a write-once setting once it is set to complete.
    Power cycling is required to initialize partitions after set to complete.
    mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
    - Set the BOOT_BUS_WIDTH field of the specified device
    mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
    - Change sizes of boot and RPMB partitions of specified device
    mmc partconf dev boot_ack boot_partition partition_access
    - Change the bits of the PARTITION_CONFIG field of the specified device
    mmc rst-function dev value
    - Change the RST_n_FUNCTION field of the specified device
    WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
    mmc setdsr <value> - set DSR register value
    Usage:
    mmc erase blk# cnt
    mmc rescan
    Wrong Image Format for bootm command
    ERROR: can't get kernel image!
    Even I am not able to boot from the sd card also.
    Note: I am using prebuilt Image provide with SDK.
    Thank You,
  • Hello Margarita,
    Now ,my EVM board is always boot-up by eMMC automatically.But there is no any files available in eMMC.I dont know why it boot-up bu eMMC instead of sd_card.
    How,can i come back to enable boot-up process by sd_card.
    Whenever,i power-on the board,i can see logs as below:
    DRA752-GP ES2.0
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    DRAM: 2 GiB
    Found 0 device(s).
    Net: cpsw
    Usage:
    mmc erase blk# cnt
    mmc rescan
    Usage:
    mmc erase blk# cnt
    mmc rescan
    Please,if you have any idea related to this issue,tell me.
    Thanks in advance.
    Kishan Patel.
  • Can you post the boot log when the SD card is ejected?
  • Hello Kemal,
    There are no boot log appear on screen (serial console) when we boot the board and sd card is ejected.
    Power led turns off after some time.
    Thank You,
    Omkareshwar
  • Put the SD card and type:
    => env default -f -a
    => saveenv
    => boot
    The board will boot from SD card. Repeat the steps for eMMC programming and post the log.
  • Hello Kemal,
    Now I am able to boot my EVM from the sd card.
    Thank You,
    Omkareshwar
  • Now do the steps from this post and share the log.
  • Hello Kemal,
    I am really thankful to you.
    We tried the method you mentioned in your last comment and now we can boot the EVM board using eMMC.
    Can you please answer my some question I listed below:
    1) How to switch between sd / emmc for booting ?
    2) If I prepare my custom binary then how to flash/replace to eMMC (using sd card) ?
    3) Right now, we didn't use the following command:
    => mmc dev 1 1
    => mmc bootbus 1 2 0 2
    => mmc partconf 1 1 1 0
    => mmc rst-function 1 1
    Are they necessary ?
    Thank You,
    Omkareshwar
  • 1) SYSBOOT, it is used to switch between SD / eMMC. AM572x EVM SYSBOOT depending on the J6 switch order, first tries to boot from SD card then second from eMMC.
    2) Just replace MLO-am57xx-evm, u-boot-am57xx-evm.img and tisdk-rootfs-image-am57xx-evm.tar.xz with yours.
    3) These commands are for advanced users, they are not mandatory for you.
    So what happened with kishan, does his board boot from eMMC too?
  • Hello Kemal,
    Thanks for your early replies.
    Kishan is also able to boot from the eMMC.
    I really appreciate your knowledge.
    Thank you,
    Omkareshwar
  • Hello Kemal,
    Thank you so much for your valuable reply.
    Kishan Patel.
  • Hello Margarita,
    Thanks for your supporting and helping reply.
    Kishan Patel.
