Linux/AM3358: Delay between starting kernel and first log print
Part Number: AM3358
Tool/software: Linux
I am running a custom board with am3358 processor and using processor SDK 03.03.
I am optimising the boot time and something that jumps out to me at the moment is the time delay after booting from nand is printed and first kernel print.
It is more than 2 seconds. That time is longer than time spent loading everything from NAND to RAM.
Could anyone explain what is happening during that time?
Kind regards,
Ugnius
    I am looking at this.
    Steve K.
  • Can you attach the full log?
    Steve K.
  • Hi Steve,
    Here is the full log.
    I checked it booting from SD card and NAND using Falcon mode.
    In all cases it took long time between printing "Starting kernel ..." and the first message from the kernel.
    [Thu Mar 01 14:57:04.878 2018] U-Boot SPL 2016.05-gf4c49fc-dirty (Mar 01 2018 - 14:45:48)
    [Thu Mar 01 14:57:04.955 2018] Trying to boot from NAND
    [Thu Mar 01 14:57:05.091 2018] The Expected Linux image was not found. Please check your NAND configuration.
    [Thu Mar 01 14:57:05.092 2018] Trying to start u-boot now...
    [Thu Mar 01 14:57:05.441 2018]
    [Thu Mar 01 14:57:05.441 2018] U-Boot 2016.05-gf4c49fc-dirty (Mar 01 2018 - 14:45:48 +0000)
    [Thu Mar 01 14:57:05.470 2018]
    [Thu Mar 01 14:57:05.470 2018] CPU  : AM335X-GP rev 2.1
    [Thu Mar 01 14:57:05.471 2018] Model: TI AM335x EVM-SK
    [Thu Mar 01 14:57:05.471 2018]        Watchdog enabled
    [Thu Mar 01 14:57:05.471 2018] DRAM:  256 MiB
    [Thu Mar 01 14:57:05.739 2018] NAND:  1024 MiB
    [Thu Mar 01 14:57:05.740 2018] MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    [Thu Mar 01 14:57:05.771 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:05.793 2018] ** Bad device mmc 0 **
    [Thu Mar 01 14:57:05.793 2018] Using default environment
    [Thu Mar 01 14:57:05.794 2018]
    [Thu Mar 01 14:57:05.825 2018] <ethaddr> not set. Validating first E-fuse MAC
    [Thu Mar 01 14:57:05.864 2018] Net:
    [Thu Mar 01 14:57:05.864 2018] Warning: usb_ether MAC addresses don't match:
    [Thu Mar 01 14:57:05.865 2018] Address in SROM is         de:ad:be:ef:00:01
    [Thu Mar 01 14:57:05.865 2018] Address in environment is  04:a3:16:fb:e7:1c
    [Thu Mar 01 14:57:05.866 2018] eth0: usb_ether
    [Thu Mar 01 14:57:05.866 2018] Press SPACE to abort autoboot in 3 seconds
    [Thu Mar 01 14:57:08.881 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:08.896 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:08.928 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:08.960 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:08.976 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:09.008 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:09.024 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:09.070 2018] Card did not respond to voltage select!
    [Thu Mar 01 14:57:09.071 2018] Booting from nand ...
    [Thu Mar 01 14:57:09.071 2018] NAND read: device 0 offset 0x6c0000, size 0x40000
    [Thu Mar 01 14:57:10.474 2018]  262144 bytes read: OK
    [Thu Mar 01 14:57:10.474 2018] NAND read: device 0 offset 0x2c0000, size 0x400000
    [Thu Mar 01 14:57:11.594 2018]  4194304 bytes read: OK
    [Thu Mar 01 14:57:11.594 2018] Kernel image @ 0x82000000 [ 0x000000 - 0x30b4f0 ]
    [Thu Mar 01 14:57:11.595 2018] ## Flattened Device Tree blob at 88000000
    [Thu Mar 01 14:57:11.596 2018]    Booting using the fdt blob at 0x88000000
    [Thu Mar 01 14:57:11.596 2018]    Loading Device Tree to 8ef19000, end 8ef25b49 ... OK
    [Thu Mar 01 14:57:11.597 2018]
    [Thu Mar 01 14:57:11.597 2018] Starting kernel ...
    [Thu Mar 01 14:57:11.609 2018]
    [Thu Mar 01 14:57:14.009 2018] [    0.000000] Booting Linux on physical CPU 0x0
    [Thu Mar 01 14:57:14.009 2018] [    0.000000] Initializing cgroup subsys cpu
    [Thu Mar 01 14:57:14.010 2018] [    0.000000] Initializing cgroup subsys cpuacct
    [Thu Mar 01 14:57:14.011 2018] [    0.000000] Linux version 4.4.41-rt50-g968d071ce9(gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #130 PREEMPT RT Thu Mar 1 03:10:19 PST 2018
    [Thu Mar 01 14:57:14.012 2018] [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
    [Thu Mar 01 14:57:14.013 2018] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [Thu Mar 01 14:57:14.014 2018] [    0.000000] Machine model: TI AM335x EVM-SK
    [Thu Mar 01 14:57:14.015 2018] [    0.000000] cma: Reserved 48 MiB at 0x8b800000
    [Thu Mar 01 14:57:14.015 2018] [    0.000000] Memory policy: Data cache writeback
    [Thu Mar 01 14:57:14.016 2018] [    0.000000] CPU: All CPU(s) started in SVC mode.
    [Thu Mar 01 14:57:14.016 2018] [    0.000000] AM335X ES2.1 (sgx neon )
    [Thu Mar 01 14:57:14.017 2018] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64960
    [Thu Mar 01 14:57:14.018 2018] [    0.000000] Kernel command line: console=ttyO0,115200n8 consoleblank=0 root=ubi0:rootfs rw ubi.mtd=NAND.file-system rootfstype=ubifs rootwait=1
    [Thu Mar 01 14:57:14.020 2018] [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
    [Thu Mar 01 14:57:14.035 2018] [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [Thu Mar 01 14:57:14.036 2018] [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [Thu Mar 01 14:57:14.037 2018] [    0.000000] Memory: 200556K/262144K available (5835K kernel code, 314K rwdata, 2196K rodata, 932K init, 302K bss, 12436K reserved, 49152K cma-reserved, 0K highmem)
    [Thu Mar 01 14:57:14.039 2018] [    0.000000] Virtual kernel memory layout:
    [Thu Mar 01 14:57:14.039 2018] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [Thu Mar 01 14:57:14.040 2018] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [Thu Mar 01 14:57:14.040 2018] [    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
    [Thu Mar 01 14:57:14.041 2018] [    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    [Thu Mar 01 14:57:14.042 2018] [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [Thu Mar 01 14:57:14.042 2018] [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [Thu Mar 01 14:57:14.043 2018] [    0.000000]       .text : 0xc0008000 - 0xc07e003c   (8033 kB)
    [Thu Mar 01 14:57:14.044 2018] [    0.000000]       .init : 0xc07e1000 - 0xc08ca000   ( 932 kB)
    [Thu Mar 01 14:57:14.044 2018] [    0.000000]       .data : 0xc08ca000 - 0xc09189a0   ( 315 kB)
    [Thu Mar 01 14:57:14.045 2018] [    0.000000]        .bss : 0xc09189a0 - 0xc0964240   ( 303 kB)
    [Thu Mar 01 14:57:14.060 2018] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [Thu Mar 01 14:57:14.061 2018] [    0.000000] Preemptible hierarchical RCU implementation.
    [Thu Mar 01 14:57:14.062 2018] [    0.000000] 	RCU kthread priority: 1.
    [Thu Mar 01 14:57:14.062 2018] [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [Thu Mar 01 14:57:14.062 2018] [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [Thu Mar 01 14:57:14.063 2018] [    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
    [Thu Mar 01 14:57:14.064 2018] [    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [Thu Mar 01 14:57:14.065 2018] [    0.000024] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [Thu Mar 01 14:57:14.066 2018] [    0.000029] OMAP clocksource: timer1 at 24000000 Hz
    [Thu Mar 01 14:57:14.066 2018] [    0.000172] clocksource_probe: no matching clocksources found
    [Thu Mar 01 14:57:14.067 2018] [    0.000337] Console: colour dummy device 80x30
    [Thu Mar 01 14:57:14.068 2018] [    0.000475] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [Thu Mar 01 14:57:14.069 2018] [    0.000477] This ensures that you still see kernel messages. Please
    [Thu Mar 01 14:57:14.069 2018] [    0.000479] update your kernel commandline.
    [Thu Mar 01 14:57:14.070 2018] [    0.089245] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
    [Thu Mar 01 14:57:14.085 2018] [    0.089250] pid_max: default: 32768 minimum: 301
    [Thu Mar 01 14:57:14.085 2018] [    0.089367] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [Thu Mar 01 14:57:14.086 2018] [    0.089372] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [Thu Mar 01 14:57:14.087 2018] [    0.090052] Initializing cgroup subsys io
    [Thu Mar 01 14:57:14.087 2018] [    0.090072] Initializing cgroup subsys memory
    [Thu Mar 01 14:57:14.088 2018] [    0.090106] Initializing cgroup subsys devices
    [Thu Mar 01 14:57:14.088 2018] [    0.090116] Initializing cgroup subsys freezer
    [Thu Mar 01 14:57:14.089 2018] [    0.090127] Initializing cgroup subsys perf_event
    [Thu Mar 01 14:57:14.089 2018] [    0.090133] Initializing cgroup subsys pids
    [Thu Mar 01 14:57:14.090 2018] [    0.090202] CPU: Testing write buffer coherency: ok
    [Thu Mar 01 14:57:14.090 2018] [    0.090568] Setting up static identity map for 0x80008200 - 0x80008260
    [Thu Mar 01 14:57:14.091 2018] [    0.092886] devtmpfs: initialized
    [Thu Mar 01 14:57:14.091 2018] [    0.104014] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [Thu Mar 01 14:57:14.092 2018] [    0.116978] omap_hwmod: debugss: _wait_target_disable failed
    [Thu Mar 01 14:57:14.092 2018] [    0.171545] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Thu Mar 01 14:57:14.278 2018] [    0.175374] pinctrl core: initialized pinctrl subsystem
    [Thu Mar 01 14:57:14.279 2018] [    0.176666] NET: Registered protocol family 16
    [Thu Mar 01 14:57:14.280 2018] [    0.178812] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [Thu Mar 01 14:57:14.280 2018] [    0.184017] OMAP GPIO hardware version 0.1
    [Thu Mar 01 14:57:14.281 2018] [    0.191023] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/nandflash_pins_s0, deferring probe
    [Thu Mar 01 14:57:14.283 2018] [    0.193317] hw-breakpoint: debug architecture 0x4 unsupported.
    [Thu Mar 01 14:57:14.283 2018] [    0.227057] edma 49000000.edma: TI EDMA DMA engine driver
    [Thu Mar 01 14:57:14.284 2018] [    0.231103] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
    [Thu Mar 01 14:57:14.286 2018] [    0.231228] media: Linux media interface: v0.10
    [Thu Mar 01 14:57:14.287 2018] [    0.231286] Linux video capture interface: v2.00
    [Thu Mar 01 14:57:14.287 2018] [    0.231340] pps_core: LinuxPPS API ver. 1 registered
    [Thu Mar 01 14:57:14.288 2018] [    0.231347] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [Thu Mar 01 14:57:14.289 2018] [    0.231373] PTP clock support registered
    [Thu Mar 01 14:57:14.303 2018] [    0.231425] EDAC MC: Ver: 3.0.0
    [Thu Mar 01 14:57:14.304 2018] [    0.232547] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [Thu Mar 01 14:57:14.304 2018] [    0.232801] Advanced Linux Sound Architecture Driver Initialized.
    [Thu Mar 01 14:57:14.304 2018] [    0.233635] clocksource: Switched to clocksource timer1
    [Thu Mar 01 14:57:14.304 2018] [    0.243857] NET: Registered protocol family 2
    [Thu Mar 01 14:57:14.304 2018] [    0.244649] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
    [Thu Mar 01 14:57:14.305 2018] [    0.244692] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
    [Thu Mar 01 14:57:14.305 2018] [    0.244774] TCP: Hash tables configured (established 2048 bind 2048)
    [Thu Mar 01 14:57:14.305 2018] [    0.244857] UDP hash table entries: 256 (order: 2, 16384 bytes)
    [Thu Mar 01 14:57:14.305 2018] [    0.244889] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
    [Thu Mar 01 14:57:14.305 2018] [    0.245066] NET: Registered protocol family 1
    [Thu Mar 01 14:57:14.306 2018] [    0.245953] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
    [Thu Mar 01 14:57:14.306 2018] [    0.247791] futex hash table entries: 256 (order: 1, 8192 bytes)
    [Thu Mar 01 14:57:14.306 2018] [    0.255136] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [Thu Mar 01 14:57:14.306 2018] [    0.255405] ntfs: driver 2.1.32 [Flags: R/O].
    [Thu Mar 01 14:57:14.306 2018] [    0.265525] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    [Thu Mar 01 14:57:14.312 2018] [    0.265556] io scheduler noop registered
    [Thu Mar 01 14:57:14.312 2018] [    0.265567] io scheduler deadline registered
    [Thu Mar 01 14:57:14.312 2018] [    0.265815] io scheduler cfq registered (default)
    [Thu Mar 01 14:57:14.312 2018] [    0.266914] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
    [Thu Mar 01 14:57:14.312 2018] [    0.269793] backlight supply power not found, using dummy regulator
    [Thu Mar 01 14:57:14.312 2018] [    0.271207] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
    [Thu Mar 01 14:57:14.313 2018] [    0.272709] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
    [Thu Mar 01 14:57:14.313 2018] [    0.843857] console [ttyS0] enabled
    [Thu Mar 01 14:57:14.313 2018] [    0.848263] [drm] Initialized drm 1.1.0 20060810
    [Thu Mar 01 14:57:14.313 2018] [    0.853969] panel panel: found backlight
    [Thu Mar 01 14:57:14.313 2018] [    0.859323] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [Thu Mar 01 14:57:14.314 2018] [    0.865980] [drm] No driver support for vblank timestamp query.
    [Thu Mar 01 14:57:14.314 2018] [    0.896693] Console: switching to colour frame buffer device 60x40
    [Thu Mar 01 14:57:14.316 2018] [    0.909640] tilcdc 4830e000.lcdc: fb0:  frame buffer device
    [Thu Mar 01 14:57:14.325 2018] [    0.943961] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
    [Thu Mar 01 14:57:14.693 2018] [    0.956844] loop: module loaded
    [Thu Mar 01 14:57:14.694 2018] [    0.962627] spidev spi1.0: buggy DT: spidev listed directly in DT
    [Thu Mar 01 14:57:14.695 2018] [    0.968773] ------------[ cut here ]------------
    [Thu Mar 01 14:57:14.695 2018] [    0.973427] WARNING: CPU: 0 PID: 1 at drivers/spi/spidev.c:725 spidev_probe+0x1e0/0x1fc()
    [Thu Mar 01 14:57:14.696 2018] [    0.981638] Modules linked in:
    [Thu Mar 01 14:57:14.697 2018] [    0.984722] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.41-rt50-g968d071ce9 #130
    [Thu Mar 01 14:57:14.697 2018] [    0.992146] Hardware name: Generic AM33XX (Flattened Device Tree)
    [Thu Mar 01 14:57:14.698 2018] [    0.998261] Backtrace:
    [Thu Mar 01 14:57:14.699 2018] [    1.000745] [<c00134b4>] (dump_backtrace) from [<c00136b0>] (show_stack+0x18/0x1c)
    [Thu Mar 01 14:57:14.700 2018] [    1.008345]  r7:c03e1e60 r6:000002d5 r5:00000009 r4:00000000
    [Thu Mar 01 14:57:14.700 2018] [    1.014068] [<c0013698>] (show_stack) from [<c025d470>] (dump_stack+0x24/0x28)
    [Thu Mar 01 14:57:14.701 2018] [    1.021330] [<c025d44c>] (dump_stack) from [<c003174c>] (warn_slowpath_common+0x88/0xb4)
    [Thu Mar 01 14:57:14.703 2018] [    1.029459] [<c00316c4>] (warn_slowpath_common) from [<c003181c>] (warn_slowpath_null+0x24/0x2c)
    [Thu Mar 01 14:57:14.704 2018] [    1.038289]  r8:c0905984 r7:00000000 r6:cf251400 r5:00000000 r4:cf251400
    [Thu Mar 01 14:57:14.719 2018] [    1.045051] [<c00317f8>] (warn_slowpath_null) from [<c03e1e60>] (spidev_probe+0x1e0/0x1fc)
    [Thu Mar 01 14:57:14.721 2018] [    1.053366] [<c03e1c80>] (spidev_probe) from [<c03ded6c>] (spi_drv_probe+0x84/0xb0)
    [Thu Mar 01 14:57:14.721 2018] [    1.061053]  r8:c0905984 r7:00000000 r6:c0905974 r5:00000000 r4:cf251400
    [Thu Mar 01 14:57:14.722 2018] [    1.067824] [<c03dece8>] (spi_drv_probe) from [<c03907e4>] (driver_probe_device+0x204/0x300)
    [Thu Mar 01 14:57:14.722 2018] [    1.076296]  r7:00000000 r6:c0952c24 r5:c0952c14 r4:cf251400
    [Thu Mar 01 14:57:14.722 2018] [    1.082005] [<c03905e0>] (driver_probe_device) from [<c0390a04>] (__device_attach_driver+0x8c/0xb4)
    [Thu Mar 01 14:57:14.723 2018] [    1.091112]  r9:00000000 r8:c0952bd0 r7:00000001 r6:cf251400 r5:cf047c48 r4:c0905984
    [Thu Mar 01 14:57:14.723 2018] [    1.098923] [<c0390978>] (__device_attach_driver) from [<c038eb14>] (bus_for_each_drv+0x68/0x9c)
    [Thu Mar 01 14:57:14.723 2018] [    1.107742]  r7:00000001 r6:c0390978 r5:cf047c48 r4:00000000
    [Thu Mar 01 14:57:14.723 2018] [    1.113452] [<c038eaac>] (bus_for_each_drv) from [<c0390538>] (__device_attach+0xb8/0x11c)
    [Thu Mar 01 14:57:14.724 2018] [    1.121748]  r6:cf251434 r5:cf251400 r4:cf251400
    [Thu Mar 01 14:57:14.724 2018] [    1.126405] [<c0390480>] (__device_attach) from [<c0390a78>] (device_initial_probe+0x14/0x18)
    [Thu Mar 01 14:57:14.730 2018] [    1.134962]  r7:00000000 r6:c0905454 r5:cf251400 r4:cf251408
    [Thu Mar 01 14:57:14.731 2018] [    1.140670] [<c0390a64>] (device_initial_probe) from [<c038fa60>] (bus_probe_device+0x8c/0x94)
    [Thu Mar 01 14:57:14.731 2018] [    1.149322] [<c038f9d4>] (bus_probe_device) from [<c038dbe0>] (device_add+0x3ec/0x574)
    [Thu Mar 01 14:57:14.731 2018] [    1.157269]  r7:00000000 r6:cf251400 r5:cf251000 r4:cf251408
    [Thu Mar 01 14:57:14.731 2018] [    1.162979] [<c038d7f4>] (device_add) from [<c03df520>] (spi_add_device+0xa8/0x140)
    [Thu Mar 01 14:57:14.732 2018] [    1.170665]  r10:cf25119a r9:cf138010 r8:cfd971b4 r7:cf138010 r6:cf251000 r5:00000000
    [Thu Mar 01 14:57:14.732 2018] [    1.178557]  r4:cf251400
    [Thu Mar 01 14:57:14.732 2018] [    1.181106] [<c03df478>] (spi_add_device) from [<c03df9b0>] (of_register_spi_device+0x22c/0x2f4)
    [Thu Mar 01 14:57:14.732 2018] [    1.189925]  r7:cf251000 r6:cfd974fc r5:cf251400 r4:00000000
    [Thu Mar 01 14:57:14.732 2018] [    1.195633] [<c03df784>] (of_register_spi_device) from [<c03e0f24>] (spi_register_master+0x2e4/0x4c8)
    [Thu Mar 01 14:57:14.733 2018] [    1.204890]  r7:c077f380 r6:00000000 r5:cfd974fc r4:cf251000
    [Thu Mar 01 14:57:14.733 2018] [    1.210597] [<c03e0c40>] (spi_register_master) from [<c03e1148>] (devm_spi_register_master+0x40/0x78)
    [Thu Mar 01 14:57:14.733 2018] [    1.219852]  r10:cf25119a r9:c077f840 r8:cf251000 r7:cf138010 r6:cf251000 r5:cf23ac10
    [Thu Mar 01 14:57:14.738 2018] [    1.227744]  r4:00000000
    [Thu Mar 01 14:57:14.738 2018] [    1.230297] [<c03e1108>] (devm_spi_register_master) from [<c03e4820>] (omap2_mcspi_probe+0x2d4/0x34c)
    [Thu Mar 01 14:57:14.738 2018] [    1.239553]  r7:cf138010 r6:cf251000 r5:cf251328 r4:00000000
    [Thu Mar 01 14:57:14.738 2018] [    1.245268] [<c03e454c>] (omap2_mcspi_probe) from [<c0391f44>] (platform_drv_probe+0x54/0xb8)
    [Thu Mar 01 14:57:14.739 2018] [    1.253825]  r10:00000000 r9:00000000 r8:c09059d8 r7:fffffdfb r6:c09059d8 r5:cf138010
    [Thu Mar 01 14:57:14.739 2018] [    1.261715]  r4:cf138010
    [Thu Mar 01 14:57:14.739 2018] [    1.264268] [<c0391ef0>] (platform_drv_probe) from [<c03907e4>] (driver_probe_device+0x204/0x300)
    [Thu Mar 01 14:57:14.739 2018] [    1.273174]  r7:00000000 r6:c0952c24 r5:c0952c14 r4:cf138010
    [Thu Mar 01 14:57:14.739 2018] [    1.278885] [<c03905e0>] (driver_probe_device) from [<c0390974>] (__driver_attach+0x94/0x98)
    [Thu Mar 01 14:57:14.740 2018] [    1.287356]  r9:c07e1600 r8:0000007b r7:00000000 r6:cf138044 r5:c09059d8 r4:cf138010
    [Thu Mar 01 14:57:14.740 2018] [    1.295164] [<c03908e0>] (__driver_attach) from [<c038ea54>] (bus_for_each_dev+0x70/0xa4)
    [Thu Mar 01 14:57:14.942 2018] [    1.303373]  r7:00000000 r6:c03908e0 r5:c09059d8 r4:00000000
    [Thu Mar 01 14:57:14.943 2018] [    1.309081] [<c038e9e4>] (bus_for_each_dev) from [<c03900d4>] (driver_attach+0x24/0x28)
    [Thu Mar 01 14:57:14.944 2018] [    1.317116]  r6:c08ff8e0 r5:cf23db00 r4:c09059d8
    [Thu Mar 01 14:57:14.944 2018] [    1.321770] [<c03900b0>] (driver_attach) from [<c038fd1c>] (bus_add_driver+0x1a8/0x220)
    [Thu Mar 01 14:57:14.945 2018] [    1.329811] [<c038fb74>] (bus_add_driver) from [<c0390e94>] (driver_register+0x80/0x100)
    [Thu Mar 01 14:57:14.946 2018] [    1.337934]  r7:cf23a800 r6:c08ceca0 r5:c0803cb4 r4:c09059d8
    [Thu Mar 01 14:57:14.947 2018] [    1.343650] [<c0390e14>] (driver_register) from [<c0391e6c>] (__platform_driver_register+0x48/0x50)
    [Thu Mar 01 14:57:14.948 2018] [    1.352732]  r5:c0803cb4 r4:c08ff8e0
    [Thu Mar 01 14:57:14.949 2018] [    1.356341] [<c0391e24>] (__platform_driver_register) from [<c0803cd0>] (omap2_mcspi_driver_init+0x1c/0x20)
    [Thu Mar 01 14:57:14.950 2018] [    1.366119]  r5:c0803cb4 r4:c08ceca0
    [Thu Mar 01 14:57:14.950 2018] [    1.369725] [<c0803cb4>] (omap2_mcspi_driver_init) from [<c00096d4>] (do_one_initcall+0x98/0x1e4)
    [Thu Mar 01 14:57:14.952 2018] [    1.378653] [<c000963c>] (do_one_initcall) from [<c07e1e88>] (kernel_init_freeable+0x138/0x1cc)
    [Thu Mar 01 14:57:14.953 2018] [    1.387386]  r10:00000007 r9:c07e1600 r8:0000007b r7:c0813830 r6:c08c8098 r5:c09189c0
    [Thu Mar 01 14:57:14.964 2018] [    1.395278]  r4:c09189c0
    [Thu Mar 01 14:57:14.964 2018] [    1.397839] [<c07e1d50>] (kernel_init_freeable) from [<c05b56c8>] (kernel_init+0x18/0xe8)
    [Thu Mar 01 14:57:14.965 2018] [    1.406050]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c05b56b0
    [Thu Mar 01 14:57:14.965 2018] [    1.413938]  r4:c09189c0
    [Thu Mar 01 14:57:14.965 2018] [    1.416491] [<c05b56b0>] (kernel_init) from [<c000fa80>] (ret_from_fork+0x14/0x34)
    [Thu Mar 01 14:57:14.965 2018] [    1.424091]  r5:c05b56b0 r4:00000000
    [Thu Mar 01 14:57:14.965 2018] [    1.427687] ---[ end trace 0000000000000001 ]---
    [Thu Mar 01 14:57:14.965 2018] [    1.433893] libphy: Fixed MDIO Bus: probed
    [Thu Mar 01 14:57:14.966 2018] [    1.439500] i2c /dev entries driver
    [Thu Mar 01 14:57:14.966 2018] [    1.444180] omap_hsmmc 48060000.mmc: Got CD GPIO
    [Thu Mar 01 14:57:14.966 2018] [    1.454405] NET: Registered protocol family 10
    [Thu Mar 01 14:57:14.966 2018] [    1.460166] sit: IPv6 over IPv4 tunneling driver
    [Thu Mar 01 14:57:14.966 2018] [    1.465655] NET: Registered protocol family 17
    [Thu Mar 01 14:57:14.966 2018] [    1.470197] Key type dns_resolver registered
    [Thu Mar 01 14:57:14.967 2018] [    1.474722] omap_voltage_late_init: Voltage driver support not added
    [Thu Mar 01 14:57:14.967 2018] [    1.484160] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [Thu Mar 01 14:57:14.967 2018] [    1.489344] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [Thu Mar 01 14:57:14.967 2018] [    1.497051] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xd3
    [Thu Mar 01 14:57:14.972 2018] [    1.503434] nand: Micron MT29F8G08ABACAWP
    [Thu Mar 01 14:57:14.972 2018] [    1.507466] nand: 1024 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224
    [Thu Mar 01 14:57:14.973 2018] [    1.515271] using OMAP_ECC_BCH16_CODE_HW ECC scheme
    [Thu Mar 01 14:57:14.973 2018] [    1.520227] 1 ofpart partitions found on MTD device 8000000.nand
    [Thu Mar 01 14:57:14.973 2018] [    1.526261] Creating 1 MTD partitions on "8000000.nand":
    [Thu Mar 01 14:57:14.973 2018] [    1.531601] 0x000000700000-0x000019700000 : "NAND.file-system"
    [Thu Mar 01 14:57:14.995 2018] [    1.593998] tps65910 0-002d: No interrupt support, no core IRQ
    [Thu Mar 01 14:57:15.078 2018] [    1.655659] input: pixcir_ts as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0055/input/input0
    [Thu Mar 01 14:57:15.079 2018] [    1.665010] vaux2: supplied by vbat
    [Thu Mar 01 14:57:15.080 2018] [    1.668879] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
    [Thu Mar 01 14:57:15.081 2018] [    1.675199] omap_hsmmc 48060000.mmc: Got CD GPIO
    [Thu Mar 01 14:57:15.081 2018] [    1.680406] vmmc: supplied by vbat
    [Thu Mar 01 14:57:15.140 2018] [    1.729661] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
    [Thu Mar 01 14:57:15.141 2018] [    1.740776] ubi0: attaching mtd0
    [Thu Mar 01 14:57:15.857 2018] [    2.473363] ubi0: scanning is finished
    [Thu Mar 01 14:57:15.983 2018] [    2.485599] ubi0: attached mtd0 (name "NAND.file-system", size 400 MiB)
    [Thu Mar 01 14:57:15.984 2018] [    2.492264] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
    [Thu Mar 01 14:57:15.985 2018] [    2.499170] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024
    [Thu Mar 01 14:57:15.986 2018] [    2.505990] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096
    [Thu Mar 01 14:57:15.987 2018] [    2.512980] ubi0: good PEBs: 1600, bad PEBs: 0, corrupted PEBs: 0
    [Thu Mar 01 14:57:15.987 2018] [    2.519098] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
    [Thu Mar 01 14:57:15.988 2018] [    2.526352] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1012321058
    [Thu Mar 01 14:57:15.989 2018] [    2.535524] ubi0: available PEBs: 0, total reserved PEBs: 1600, PEBs reserved for bad PEB handling: 80
    [Thu Mar 01 14:57:15.991 2018] [    2.544878] ubi0: background thread "ubi_bgt0d" started, PID 80
    [Thu Mar 01 14:57:15.991 2018] [    2.555445] lis3_reg: disabling
    [Thu Mar 01 14:57:15.992 2018] [    2.559255] ALSA device list:
    [Thu Mar 01 14:57:15.992 2018] [    2.562238]   #0: AM335x-EVMSK
    [Thu Mar 01 14:57:15.993 2018] [    2.573770] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 82
    [Thu Mar 01 14:57:16.023 2018] [    2.631505] UBIFS (ubi0:0): recovery needed
    [Thu Mar 01 14:57:16.151 2018] [    2.769853] UBIFS (ubi0:0): recovery completed
    [Thu Mar 01 14:57:16.236 2018] [    2.774480] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
    [Thu Mar 01 14:57:16.237 2018] [    2.781913] UBIFS (ubi0:0): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
    [Thu Mar 01 14:57:16.238 2018] [    2.791873] UBIFS (ubi0:0): FS size: 388620288 bytes (370 MiB, 1506 LEBs), journal size 9420800 bytes (8 MiB, 37 LEBs)
    [Thu Mar 01 14:57:16.240 2018] [    2.802614] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
    [Thu Mar 01 14:57:16.240 2018] [    2.808479] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 4499737A-03BF-479A-9BCB-DFD98CC94C94, small LPT model
    [Thu Mar 01 14:57:16.242 2018] [    2.821754] VFS: Mounted root (ubifs filesystem) on device 0:14.
    [Thu Mar 01 14:57:16.242 2018] [    2.829230] devtmpfs: mounted
    [Thu Mar 01 14:57:16.243 2018] [    2.833386] Freeing unused kernel memory: 932K (c07e1000 - c08ca000)
    [Thu Mar 01 14:57:16.517 2018] [    3.117131] systemd[1]: System time before build time, advancing clock.
    [Thu Mar 01 14:57:16.613 2018] [    3.233384] random: systemd: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:16.649 2018] [    3.268721] random: systemd: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:16.722 2018] [    3.286988] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [Thu Mar 01 14:57:16.724 2018] [    3.306883] systemd[1]: Detected architecture arm.
    [Thu Mar 01 14:57:16.724 2018] Welcome to Arago 2016.12!
    [Thu Mar 01 14:57:16.725 2018]
    [Thu Mar 01 14:57:16.725 2018] [    3.336360] systemd[1]: Set hostname to <am335x-evm>.
    [Thu Mar 01 14:57:16.969 2018] [    3.568079] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:17.016 2018] [    3.614748] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:17.116 2018] [    3.703772] random: systemd: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:17.118 2018] [    3.713275] random: systemd: uninitialized urandom read (16 bytes read, 8 bits of entropy available)
    [Thu Mar 01 14:57:17.195 2018] [    3.811894] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available)
    [Thu Mar 01 14:57:17.224 2018] [    3.821919] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available)
    [Thu Mar 01 14:57:17.285 2018] [    3.904778] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available)
    [Thu Mar 01 14:57:17.322 2018] [    3.941059] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available)
    [Thu Mar 01 14:57:17.511 2018] [    4.109177] systemd[1]: Created slice System Slice.
    [Thu Mar 01 14:57:17.512 2018] [  OK  ] Created slice System Slice.
    [Thu Mar 01 14:57:17.541 2018] [    4.135344] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [Thu Mar 01 14:57:17.542 2018] [  OK  ] Created slice system-serial\x2dgetty.slice.
    [Thu Mar 01 14:57:17.579 2018] [    4.166396] systemd[1]: systemd-journald.socket: Socket service systemd-journald.service not loaded, refusing.
    [Thu Mar 01 14:57:17.580 2018] [    4.176547] systemd[1]: Failed to listen on Journal Socket.
    [Thu Mar 01 14:57:17.581 2018] [FAILED] Failed to listen on Journal Socket.
    [Thu Mar 01 14:57:17.593 2018] See 'systemctl status systemd-journald.socket' for details.
    [Thu Mar 01 14:57:17.610 2018] [    4.227349] systemd[1]: Reached target Timers.
    [Thu Mar 01 14:57:17.625 2018] [  OK  ] Reached target Timers.
    [Thu Mar 01 14:57:17.641 2018] [    4.258823] systemd[1]: Reached target Slices.
    [Thu Mar 01 14:57:17.657 2018] [  OK  ] Reached target Slices.
    [Thu Mar 01 14:57:17.673 2018] [    4.292157] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [Thu Mar 01 14:57:17.701 2018] [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [Thu Mar 01 14:57:17.716 2018] [    4.335369] systemd[1]: Listening on udev Kernel Socket.
    [Thu Mar 01 14:57:17.739 2018] [  OK  ] Listening on udev Kernel Socket.
    [Thu Mar 01 14:57:17.771 2018] [    4.364591] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [Thu Mar 01 14:57:17.772 2018] [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [Thu Mar 01 14:57:17.794 2018] [    4.394145] systemd[1]: Reached target Paths.
    [Thu Mar 01 14:57:17.795 2018] [  OK  ] Reached target Paths.
    [Thu Mar 01 14:57:17.822 2018] [    4.422369] systemd[1]: Starting Apply Kernel Variables...
    [Thu Mar 01 14:57:17.823 2018]          Starting Apply Kernel Variables...
    [Thu Mar 01 14:57:17.838 2018] [    4.459357] systemd[1]: Mounting /media/ram...
    [Thu Mar 01 14:57:17.869 2018]          Mounting /media/ram...
    [Thu Mar 01 14:57:17.896 2018] [    4.496883] systemd[1]: Listening on udev Control Socket.
    [Thu Mar 01 14:57:17.897 2018] [  OK  ] Listening on udev Control Socket.
    [Thu Mar 01 14:57:17.912 2018] [    4.532050] systemd[1]: Starting udev Coldplug all Devices...
    [Thu Mar 01 14:57:17.958 2018]          Starting udev Coldplug all Devices...
    [Thu Mar 01 14:57:17.986 2018] [    4.586862] systemd[1]: Starting udev Kernel Device Manager...
    [Thu Mar 01 14:57:18.033 2018]          Starting udev Kernel Device Manager...
    [Thu Mar 01 14:57:18.049 2018] [    4.665653] systemd[1]: systemd-journald-dev-log.socket: Socket service systemd-journald.service not loaded, refusing.
    [Thu Mar 01 14:57:18.094 2018] [    4.698332] systemd[1]: Failed to listen on Journal Socket (/dev/log).
    [Thu Mar 01 14:57:18.109 2018] [FAILED] Failed to listen on Journal Socket (/dev/log).
    [Thu Mar 01 14:57:18.154 2018] See 'systemctl status systemd-journald-dev-log.socket' for details.
    [Thu Mar 01 14:57:18.185 2018] [    4.799059] systemd[1]: Mounted /media/ram.
    [Thu Mar 01 14:57:18.217 2018] [  OK  ] Mounted /media/ram.
    [Thu Mar 01 14:57:18.233 2018] [    4.846418] systemd[1]: Started Apply Kernel Variables.
    [Thu Mar 01 14:57:18.249 2018] [  OK  ] Started Apply Kernel Variables.
    [Thu Mar 01 14:57:18.584 2018] [    5.204572] systemd[1]: Started udev Kernel Device Manager.
    [Thu Mar 01 14:57:18.610 2018] [  OK  ] Started udev Kernel Device Manager.
    [Thu Mar 01 14:57:19.216 2018] [    5.837921] systemd[1]: Reached target Local File Systems.
    [Thu Mar 01 14:57:19.264 2018] [  OK  ] Reached target Local File Systems.
    [Thu Mar 01 14:57:19.295 2018] [    5.917405] systemd[1]: Started udev Coldplug all Devices.
    [Thu Mar 01 14:57:19.343 2018] [  OK  ] Started udev Coldplug all Devices.
    [Thu Mar 01 14:57:19.535 2018] [    6.146625] systemd[1]: Found device /dev/ttyS0.
    [Thu Mar 01 14:57:19.551 2018] [    6.167937] 47401300.usb-phy supply vcc not found, using dummy regulator
    [Thu Mar 01 14:57:19.583 2018] [  OK  ] Found device /dev/ttyS0.
    [Thu Mar 01 14:57:19.631 2018] [    6.249125] systemd[1]: Created slice system-systemd\x2dbacklight.slice.
    [Thu Mar 01 14:57:19.679 2018] [    6.285094] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [Thu Mar 01 14:57:19.752 2018] [  OK  ] Created slice system-systemd\x2dbacklight.slice.
    [Thu Mar 01 14:57:19.768 2018] [    6.379991] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight...
    [Thu Mar 01 14:57:19.853 2018]          Starting Load/Save Screen Backlight...htness of backlight:backlight...
    [Thu Mar 01 14:57:20.092 2018] [    6.708517] systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:backlight.
    [Thu Mar 01 14:57:20.180 2018] [  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
    [Thu Mar 01 14:57:20.356 2018] [    6.972990] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [Thu Mar 01 14:57:20.435 2018] [    7.052138] systemd[1]: Reached target System Initialization.
    [Thu Mar 01 14:57:20.483 2018] [  OK  ] Reached target System Initialization.
    [Thu Mar 01 14:57:20.524 2018] [    7.124379] systemd[1]: dbus.socket: Socket service dbus.service not loaded, refusing.
    [Thu Mar 01 14:57:20.525 2018] [    7.132434] systemd[1]: Failed to listen on D-Bus System Message Bus Socket.
    [Thu Mar 01 14:57:20.607 2018] [FAILED] Failed to listen on D-Bus System Message Bus Socket.
    [Thu Mar 01 14:57:20.640 2018] See 'systemctl status dbus.socket' for details.
    [Thu Mar 01 14:57:20.655 2018] [    7.267087] systemd[1]: Reached target Sockets.
    [Thu Mar 01 14:57:20.703 2018] [  OK  ] Reached target Sockets.
    [Thu Mar 01 14:57:20.735 2018] [    7.342960] systemd[1]: Reached target Basic System.
    [Thu Mar 01 14:57:20.778 2018] [  OK  ] Reached target Basic System.
    [Thu Mar 01 14:57:20.842 2018] [    7.451582] systemd[1]: Started Serial Getty on ttyS0.
    [Thu Mar 01 14:57:20.874 2018] [  OK  ] Started Serial Getty on ttyS0.
    [Thu Mar 01 14:57:20.890 2018] [    7.504782] systemd[1]: Reached target Login Prompts.
    [Thu Mar 01 14:57:20.969 2018] [  OK  ] Reached target Login Prompts.
    [Thu Mar 01 14:57:21.001 2018] [    7.608488] systemd[1]: Starting rc.pvr.service...
    [Thu Mar 01 14:57:21.081 2018]          Starting rc.pvr.service...
    [Thu Mar 01 14:57:21.254 2018] [    7.855747] systemd-udevd[135]: Process '/usr/sbin/alsactl restore 0' failed with exit code 99.
    [Thu Mar 01 14:57:21.844 2018] [    8.462975] usbcore: registered new interface driver usbfs
    [Thu Mar 01 14:57:21.906 2018] [    8.480656] usbcore: registered new interface driver hub
    [Thu Mar 01 14:57:21.907 2018] [    8.490683] usbcore: registered new device driver usb
    [Thu Mar 01 14:57:21.907 2018] [    8.495272] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [Thu Mar 01 14:57:21.968 2018] [    8.588497] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
    [Thu Mar 01 14:57:21.984 2018] [    8.603944] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
    [Thu Mar 01 14:57:22.021 2018] [    8.631289] hub 1-0:1.0: USB hub found
    [Thu Mar 01 14:57:22.021 2018] [    8.643968] hub 1-0:1.0: 1 port detected
    [Thu Mar 01 14:57:22.127 2018] [    8.724637] systemd[1]: Started rc.pvr.service.
    [Thu Mar 01 14:57:22.128 2018] [  OK  ] Started rc.pvr.service.
    [Thu Mar 01 14:57:22.158 2018] [    8.779230] systemd[1]: Starting init script...
    [Thu Mar 01 14:57:22.175 2018]          Starting init script...
    [Thu Mar 01 14:57:23.898 2018] [   10.513367] Console: switching to colour dummy device 80x30
    [Thu Mar 01 14:57:24.074 2018] [   10.690828] systemd[1]: Started init script.
    [Thu Mar 01 14:57:24.091 2018] [  OK  ] Started init script.
    [Thu Mar 01 14:57:24.132 2018] [   10.735713] systemd[1]: Reached target Multi-User System.
    [Thu Mar 01 14:57:24.133 2018] [  OK  ] Reached target Multi-User System.
    [Thu Mar 01 14:57:24.173 2018] [   10.774523] systemd[1]: Reached target Graphical Interface.
    [Thu Mar 01 14:57:24.174 2018] [  OK  ] Reached target Graphical Interface.
    [Thu Mar 01 14:57:24.189 2018] [   10.805202] systemd[1]: Startup finished in 3.043s (kernel) + 7.757s (userspace) = 10.800s.
    [Thu Mar 01 14:57:25.366 2018]
    [Thu Mar 01 14:57:25.366 2018]  _____                    _____           _         _
    [Thu Mar 01 14:57:25.367 2018] |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    [Thu Mar 01 14:57:25.368 2018] |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    [Thu Mar 01 14:57:25.368 2018] |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
    [Thu Mar 01 14:57:25.369 2018]               |___|                    |___|
    [Thu Mar 01 14:57:25.370 2018] Arago Project http://arago-project.org am335x-evm ttyS0
    [Thu Mar 01 14:57:25.370 2018] Arago 2016.12 am335x-evm ttyS0
    [Thu Mar 01 14:57:25.371 2018]
    [Thu Mar 01 14:57:25.371 2018] am335x-evm login:
  • Do you have any idea of what might cause such a long time between prints?
  • I am looking at it.
    Steve K.
  • From u-boot can you dump CM_CLKSEL_DPLL_MPU (0x44e0042c)? I'd like to know the ARM speed.
    Also, the printf to the serial console will add time.
    Steve K.
  • Hi Steve,
    => md 0x44e0042c
    44e0042c: 0003e817 00000000 00000001 00000000 ................
    It is sitting there for over a second without any prints, so it should not be any delay because of print.
    U-boot already loaded everything into ram and jumped to kernel.
    I would expect first kernel print straight away.
    Is there anything kernel has to do before making first print?
    Kind regards,
    Ugnius
  • ugnius,
    couple of questions.
    1. are you using compressed kernel image (zImage) or uncompressed one (Image).
    2. default boot is configured at lzma (size optimized).
    what happens to that boot stage if you change kernel config to LZ4 (change in ti_config_fragments/baseport.cfg) and build/boot.
  • Hi Praneeth,
    I am using zImage. I will try to do what you suggested and use Image. Will let you know how that goes.
    Also I want to eventually run from NAND using Falcon mode, which uses Uimage.
    I tried generating Uimage from zImage using mkimage.
    Does that mean my Uimage was compressed?
    Is it possible to use falcon mode with a not compressed image?
    kind regards,
    Ugnius
    Looks like Praneeth was correct, the excess time is spent zImage un-compressing itself. I thought there would be print saying when it starts if that was the case, which is why I thought there was something wrong going on.
    I could not confirm this booting from SD card as it fails boot with Image(instead of zImage) saying wrong zImage magic. I am not sure how to change the expected format when booting from MMC.
    Booting from nand in Falcon mode however expects Uimage. So I generated Uimage using Image instead of zImage.
    Comparing the falcon boot timings the uncompressed Uimage takes longer to load to ram, but kernel prints without time delay after SPL jumps to it.
    Compressed Uimage takes quicker to load to ram but there is time delay between jump to kernel and kernel print.
    I think this confirms that the time is spent un-compressing image.
    All in all using uncompressed image is 500 ms quicker when booting in falcon mode.
    Thank you Steve and Praneeth for your help.
    Kind regards,
    Ugnius
  • some of the factors effect the boot time for the area you are trying to optimize
    -- Boot media (NAND/SD/something else) throughput
    -- MPU speed
    Glad to hear that you were able to save some boot time and proceed ahead with your experimentation .
    In anycase, There should be various resources available in http://processors.wiki.ti.com to optimize boot time. feel free to explore and try opitmizing on your custom board.
    Hope it helps.
