Part Number: AM5728
I want to use openCV with AM5728 EVM board.
I am new for it so if anyone can tell me the steps to use it,that will great for me.
Thanks and Regards,
Kishan Patel.
Part Number: AM5728
Thanks and Regards,
Kishan Patel.
Hello Margarita,
Have you any idea about face detection means how can setup face detection using AM5728 EVM.
I have done it on other system.So,if i want to setup face detection what should be require and how i can setup it?
If you know about it,let me inform.I will setup it.
Thanks in advance,
Kishan Patel.
I am not very sure what you mean. Have you tried wget https://github.com/Itseez/opencv_extra/archive/master.zip
However, you could just cp the opencv_extra-master.zip from you PC to the sd card under /usr/share/OpenCv folder and unzip it there by using unzip command as in the guide.
BR
Margarita
Just cp the zip file to the sd card.
I ran this on the board:
./tapi-example-ufacedetect --cascade="/usr/share/OpenCV/haarcascades/haarcascade_frontalface_alt.xml" --nested-cascade="/usr/share/OpenCV/haarcascades/haarcascade_eye_tree_eyeglasses.xml" --scale=1.3 /usr/share/OpenCV/testdata/cv/face/100040721_1.jpg
you should wait a bit and do not stop weston.
Here is the result:
1.original image:
on the board:
Hope this helps.
BR
Margarita
You do not have enough free space.
There is recommendation in the openCV user guide for the sd card size. If I remember right when you extract it, is > 600MB.
BR
Margarita
Hello
kishan patel14 said:unzip: write error: No space left on device
Your issue is that you do not have enough free space.
BR
Margarita
