Part Number: SRC4382
Other Parts Discussed in Thread: PCM5100
Hello all,
i 'm struggling with the output delay of two SRC4382 mounted on different equipment and
i think it is the same problem discussed in this thread:
https://e2e.ti.com/support/audio-group/audio/f/audio-forum/944740/src4382-phase-difference-amongst-tx-output-pins?tisearch=e2e-sitesearch&keymatch=src4382#
Previously i got the same problem when changing MCLK clock and PLL registers, but in such case i partially solved the problem turning off and on again the ASRC block after
MCLK change and PLL reprogramming. I said "partially" because it remains an about 500nS uncertainty (when resampled clock is at 38KHz)
Is there a more correct way to have a guaranteed output delay at the SRC output ? Indeed it seems that the output delay is depending somewhat on how the internal PLL
locks to the incoming signal.
Thanks.
