I have two questions about AGC. Could you help me?
Kazuto
Hello Kazuto,
Our team is looking into this thread and will respond as soon as possible.
Justin Beigel
Hi Kazuto,
You're correct on the mode descriptions.
Regarding table 2, modifying default values requires very specific business, this may be hard to get at this time.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan, if the following sentence is correct, does it means the datasheet contains an error? If so, will it be corrected?
In Table 1, "(AGC1, AGC2) = (0, 1), AGC Limiter Function enabled" means "AGC is disable, but Limiter is enable", correct?
Secondly, how much is the adjustable range of AGC at factory setting? If it's difficult to put the answer here, please send me an offline message.
Kazuto
Hi Ivan,
The customer is waiting for our answer. please follow my question.
Kazuto
Hi Kazuto,
Regarding data sheet statement, I agree that one is confusing perhaps it's a typo.
The adjustable range is similar to TPA2018D1, however as I mentioned the requirements to request this kind of change in the process in considerable, I may need to loop you in a discussion with marketing team. Please let me know.
-Ivan Salazar
