Other Parts Discussed in Thread: TAS5720M
I'm looking to use the TAS5721 as a mono amplifier, but I don't need the additional power that PBTL provides, and would rather not spend the money on the additional output filter components, if possible. Is that supported by the device? Is there any termination required or recommended in that case for the unused channel?
Similarly, the headphone amplifier is not going to be used. Are pull-downs for the inputs and floating outputs ok? The proposed schematic is attached.
Other comments on the schematic are also welcome.
