TPA3255: PBTL mode and BTL mode
Part Number: TPA3255
Hi, support team.
For 200W/4Ohm and 100Wx2/8Ohm, The TPA3255 work on PBTL mode and BTL mode, At the same power supply and the same heatsink size,
which solution would working better ? any difference on THD ?
  • Hi Eric,
    How would you define which solution works better? Which one runs more efficiently?
    THD+N will likely be different since you're running the device with different loads which affects the LCR output filter! Also the inductors might be different since the current rating through them would be different.
    Robert Clifton
