Part Number: OPA1622
the enable function does'nt work on 8 x OPA1622 after power supply sequencing.
It is possible to turn the op amps correctly on if enable is high. If low, the OPA1622
pulls out a strong distorted 2Vrms signal.
This happens if the +/- 13V opa1622 supply rail is turned off and enable signal is still high.
We have in this state a strong + 2V signal on the pos and + 0.7V on the neg supply line coming out of the Opa1622 supply lines through
the enable input pin if set to high.
I assume enable should be set to logic low before turn off the rails.
TI please check this sequencing behavior and please give a guideline for the redesign.
Best regards
Andy
