Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LM4871: Alternative for SSM2211SZ
Part Number: LM4871
Other Parts Discussed in Thread: TPA6211A1, LM4991, TPA2011D1
Hi team,
Our customer is looking for alternative for ADI SSM2211SZ. I've found that LM4871 is TI alternative by using BOM & cross reference tool.
Could you kindly let us know if you have better TI alternative?
  • Hi Shimada-san,
    Are you looking for a direct pin to pin replacement? If not, perhaps TPA6211A1 could be an option? This is a fully-differential amplifier that may be better in terms of performance.
    Otherwise you could stick to LM4871, there are other TPA60x devices that could be same as that, considering LM4871 is a legacy device.
    -Ivan Salazar
    Applications Engineer
  • Hi Ivan,
    Thank you for your reply.
    Customer just wants to know TI alternatives for now so I think it is OK to propose non pin to pin replacement.
    Could you check if my understanding is correct?
    1. If customer wants pin to pin replacement, we propose LM4871MX/NOPB.
    2. If non pin to pin replacement is OK for customer, we can promote TPA6211A1.
  • Shimada-san,
    Correct, additional option is LM4991. If Class-D is OK there are more alternatives like TPA2011D1.
    -Ivan Salazar
