Hi team,
I know that it shows PCM4104 can operate during -10℃~70℃(datasheet maybe conservative). But customer's work condition will be up to -45 °C – 85 °C, so whether PCM4104 can afford -45 °C – 85 °C in actual application?
Hi team,
As for previously mentioned part I will need to find more info and come back to you.
Hello Yang,
The datasheet may be conservative but not 30 degrees off conservative, operating at such load temperatures wouldnt be recommended as specs laid out in datasheet would no longer be reliably true.
Best Regards
Carson
