PCM4104: Looking for more details on specs after reviewing data sheet
Part Number: PCM4104
Other Parts Discussed in Thread: PCM1795, PCM1796, PCM1792
Hi team,
I got questions from customer.
"I am comparing some DACs you make compared to other companies.
Question 1: Does the PCM4104 support DSD and if so what is the max?
Question 2: Also does any of the Texas instrument models listed below have digital preset filters or is an external chip needed for that?
e.g. For example other companies list things like:
PCM Filter Characteristics (Fast Roll Off, Minimum Phase)
PCM Filter Characteristics (Slow Roll Off, Minimum Phase)
PCM Filter Characteristics (Hybrid, Fast Roll Off, Minimum Phase)
Question 3: Lastly is there any other specs that are important when comparing DACs that is missing from the table below that makes a big difference in sound  quality/performance?"
Brand Model Channels Bits Analog output type THD+N[dB] SNR/DNR(dB)
MuCH | Mono
Digital input max DSD max Digital Preset Filters
AKM AK4490EQ 2 32 Differential -112 120 (123) 768 kHz PCM 11.2 MHz 5
AKM AK4493 2 32 Differential -113 123 (126) 768 kHz PCM 22.4 MHz 6
AKM AK4499EQ 4 32 Differential -124 134 (140) 768 kHz PCM 22.4 MHz 6
Cirrus CS42528 8 24 Differential -100 114 (114) 192 kHz PCM
ESS Technology ES9010K2M 2 32 Differential -106 116 (116) 384 kHz PCM 11.2 MHz 3
ESS Technology ES9026Pro 8 32 Differential -110 124 (124) 768 kHz PCM 45.2 MHz 7
ESS Technology ES9028Pro 8 32 Differential -120 129 (135) 768 kHz PCM 45.2 MHz 7
ESS Technology ES9038Pro 8 32 Differential -122 132 (140) 768 kHz PCM 45.2 MHz 7
Texas Instruments PCM1795 2 32 Differential -106 123 (126) 192 kHz PCM 11.2 MHz
Texas Instruments PCM1796 2 24 Differential -106 123 (126) 192 kHz PCM 11.2 MHz
Texas Instruments PCM4104 4 24 Differential -100 118 (118) 216 kHz PCM ?
Texas Instruments PCM1792 2 24 Differential -108 129 (132) 192 kHz PCM 11.2 MHz
Analog Devices ADAU1966 16 24 Differential -98 1
Thank you very much for your help.
