Hello Mike,
the network role is set in the PurePath Configuration Tool, which generates the image file. So it can not be changed during operation. FW 1.2 will support bidirectional audio streaming. At the moment we are waiting for 1.1 to be released ;-). 1.2 was planed for summer (I think late summer).
Oliver
Thanks Oliver, just what I needed to know.
Late summer would still work for us so I'll stay tuned
Mike
Hi Mike,
If you operate in external host operation this could be done by having two different images (i.e. a master image and a slave image) stored in your host controller. It's possible to do flash programming over the SPI interface. This way you could switch between master and slave mode by for example pressing a button, or you could do it remotely by informing the device via the data side channel that it should switch role. This requires that your host is big enough to fit both images.
-Kristoffer
