Hi Team,
The current battery voltage is around 3.3V, OCP will active,
I Hope that reduces the gain,when Vbatt 3.3V,
Please help provide the reference adjustment file of TAS2110 for battery, thank you.
Hi Team,
Hi Kevin,
Your capture above suggest to set Limiter at 3.3V, but based on your description you may want to set BOP to this level instead of limiter. If you want BOP to act faster you can set attack step size to 2dB and attack rate 1 sample/step.
-Ivan Salazar
Applications Engineer
Hi Kevin,
Not specifically for TAS2110, but perhaps this app note is useful: https://www.ti.com/lit/an/slaa953/slaa953.pdf
-Ivan Salazar
