Part Number: TLV320AIC3109-Q1
Hi Team,
Is there any specific initialization/configuration sequence required for the 3109? The following items are the target configuration:
Slave Mode (Do not generate the clock)
BCLK,WCLK,DIN = inputs
I2S Left Justified
16bts
LEFT_LOP/LOM used only (No Right or HP outputs)
I just want to double check if the register writes need to happen at a certain time or in a certain order.
Thank you,
Jared
