Other Parts Discussed in Thread: TAS5825M
Hi team,
According to the datasheet, I2S clock is necessary to program DSP register. "DSP register" is defined as DSP memory maps in TAS5825M Process Flows document, e.g. equalizer, correct?
Other registers such as MUTE, Digital Volume can be programmed without I2S clock, because it's just in HiZ mode, is that correct? The customer's MCU stops I2S if there is no audio playing.
Kazuto
