Part Number: PCM1821
Other Parts Discussed in Thread: PCM1820
I would like to use the PCM1821 with RCA single-ended inputs, but it is not obvious from the datasheet if it will work with IN1M and IN2M connected to capacitors to AGND. Will the 2Vrms input range be achievable with a single-ended input?
Please do not suggest using a different part unless stock is available or the lead-time is reasonable. I require a 192kHz Stereo ADC with good performance.
Jon
