Part Number: PCM6260-Q1
Hi team,
The internal boost converter clock is 6MHz, do you have some experience about this EMC design reference?
As you could see, here are some harmonic in 6MHz...
Hi team,
Thanks for reaching out to TI E2E.
Could you clarify if you know that the 6MHz is separate from the all the other harmonics I can see on the frequency sweep?
I do not have design reference or data related to frequency harmonics past 20kHz.
Is the 6MHz causing more issues than all those other spikes?
And what are you inputting in this case?
Carson
Is this negatively impacting performance?
If it is we would need to see circuit and layout to help mitigate.
Carson
