Hi
The customer found that when the TPA2011D1YFF has power, the EN pin On/Off will have a pop sound, causing Pop-Noise, The same situation can also be seen on the TPA2011D1YFFT EVM Board, TPA2011D1YFFT gives 5V Power in, OUT+/OUT- connect to SPK, RCA plug is inserted, no need to input signal, press S1 switch on EVM Board, you will also hear pop sound May I ask what is causing this?? How to avoid this Pop-Noise??
