Other Parts Discussed in Thread: PCM1864
Hi Team,
My customer occurs a abnormal phenomenon when using PCM1863. Customer uses VINL2 and VINR2 as input. The PCM1863 works in master mode and MCLK is 12.288MHz, BCLK is 6.144MHz, LRCLK is 96kHz. When customer configures 0x03 and 0x04 as 0xff, the read value shows 0x03 and 0x04 as 0x00(default mode). It means configuring 0x03 and 0x04 but have no output. What's more, configurating 0x20 as default mode(0x11) but shows 0x20 as 0x17. The more detailed log is as blow.
Gust
