Other Parts Discussed in Thread: TAS6424
I am trying to use the ALSA library to play audio on the TAS6424 EVM. I am unable to play sound unless I enable the channels manually on the I2C line. Then I can stream audio via USB. Is there anyway to use the ALSA library to configure this module via USB (clear the warning, configure the channels to play mode, etc). I know this can be done using the TI software, but I need to do it headless over USB.
Thank you,
Tara
