Other Parts Discussed in Thread: TPA3220
Hi team,
My customer is looking to TPA3244 as an alternate to TPA3220, but the dedicated device soft mute (9.4.4 in 3220) is not specifically listed in 3244. Instead CSTART pin has similar description and timing diagram (11.2 in 3244) and also requires external cap. Noted the value for the cap may be different from looking at the EVAL board datasheet.
I’d like to know if customer can implement the same Mute circuit recommended in TPA3220 datasheet, but connected to C_START pin. They need this mute feature in the product for TPA3244 to be a true alternate without having to redesign their preamp to handle muting. Understood 3244 is not a drop-in replacement, but minor PCB update (for a second PCBA ) can make this a viable option for production.
Connie
