Re: e2e.ti.com/.../tas2563-question-of-tas2563-dvc_pcm-register
Hi Ivan,
Following up on a previous discussion about using the limiter to cap the amplifier output, should we set AMP_LEVEL in Register 0x03 to a lower value?
Will reducing the AMP_LEVEL setting affect the digital processing path? Can it potentially reduce quantization noise?
It's currently set to the 0x10 default value for 16.0 dBV (8.92 Vpk).
Is there a way to do it in PPC3 other than with a manual I2C write?
Thanks, O.R.
