Hello Team,
I'm using a DIT4096 in hardware mode and I have two questions:
1. I've read that 4.7k resistors are recommend to pull each pin up and down -- are 10k fine? I assume they will be, and my breakout board is using 10k resistors and working fine.
2. The BLS, U and MDAT pins are left floating (CSS=0, BLSM=1, MONO=0). Since BLS is an output, I presume we don't want to mess with its output. Further, as MONO is set to "Stereo" mode, I presume the channel selection can be left alone for MDAT. U is the one I'm most concerned about here, since I'm not pushing data into it.
Thanks!
-Ted
