Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
PCM1808: Current capabilities of VREF pin
Part Number: PCM1808
Other Parts Discussed in Thread: MCP6292, PCM4202, OPA1632
It is not clear to me from studying the datasheet and e2e topics related to Vref pin from PCM1808.
I know that Vref pin is not intended to work as an output and it can't be used for virtual ground itself, but can I use that voltage to generate virtual GND using for example MCP6292 to get better noise performance?
Have a good day,
Damian
