Other Parts Discussed in Thread: PCM4220
I observe a dual tone output from the PCM4202. Amplitudes are nearly equal around -80dB . Frequencies are approximately 1.45KHz and 1.5KHz and drift a bit with temperature.
The Master clock certainly had some jitter but after substantial reduction of the clock jitter I noted zero influence upon the presence of the unwanted Tone.
So, what may be causing the dual tone?
Thank you.
Jaye
