Other Parts Discussed in Thread: TAS6424
- ILIMIT_STATUS
- CLIP_WARNING
- CHANNEL_FAULT
- GLOBAL_FAULT1
- GLOBAL_FAULT2
- WARNINGS
- DC_LOAD_DIAGNOSTICS1_REPORT
- DC_LOAD_DIAGNOSTICS2_REPORT
Hi Yutong,
Please read 0x09 register to check if enable auto DC diag or not. If auto DC diag is enabled, device will auto run DC diag when channels leave Hi-Z. And device will not enter play mode if any load error.
According to your description, I think DC diag failed when connected high impedance load.
Regard,
Derek
Hi Derek,
Thank you for getting back to me. We're having the device shipped to our manufacturer now and they will be able to test it once they receive it. I will keep you updated once we investigate a bit more.
Why might this failure mode not result in anything reported on the registers I mentioned? I would expect at least DC_LOAD_DIAGNOSTICS1_REPORT or DC_LOAD_DIAGNOSTICS2_REPORT to report something. Is it possible that something was shorted which might have damaged the chip?
Yutong
Hi Yutong
You are correct there should be failure reported normally. But according to your description, our customer may have some problem with the I2C communication, maybe our device doesn't been correctly initiated yet, not in the PLAY state. Let's test it first.
